path: root/include/altera.h
2013-05-06fpga: Remove all CONFIG_SYS_* fpga related optionsMichal Simek
All these macros are completely unused by any code. CONFIG_FPGA is not a bitfield anymore. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2011-08-01fpga: constify to fix build warningWolfgang Denk
Fix compiler warning: cmd_fpga.c:318: warning: passing argument 3 of 'fit_image_get_data' from incompatible pointer type Adding the needed 'const' here entails a whole bunch of additonal changes all over the FPGA code. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andre Schwarz <andre.schwarz@matrix-vision.de> Cc: Murray Jensen <Murray.Jensen@csiro.au> Acked-by: Andre Schwarz<andre.schwarz@matrix-vision.de>
2011-07-28cosmetic: spell fixes etc.Michael Jones
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Detlev Zundel <dzu@denx.de>
2009-10-03fpga: Remove relocation fixupsPeter Tyser
PPC boards are the only users of the current FPGA code which is littered with manual relocation fixups. Now that proper relocation is supported for PPC boards, remove FPGA manual relocation. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-04-13Altera Stratix II supporteran liberty
Adds Support for Altera's Stratix II. Within your board specific init file you will have to call 1. fpga_init (/* relocated code offset. usually => */ gd->reloc_off); 2. fpga_add (fpga_altera, (Altera_desc*)&altera_desc); Altera_desc* contines (for example): { Altera_StratixII, /* part type */ passive_serial, /* interface type */ 1, /* bytes of data part can accept */ (void *)(&funcs), /* interface function table */ 0L, /* base interface address */ 0 /* implementation specific cookie */ } funcs is the interface. It is of type altera_board_specific_func. It looks like this: altera_board_specific_func func = { pre_fn, config_fn, status_fn, done_fn, clk_fn, data_fn, abort_fn, post_fn, }; you will have to implement these functions, which is usually bit banging some gpio. Signed-off-by: Eran Liberty <liberty@extricom.com>
2006-08-15Add FPGA Altera Cyclone 2 supportStefan Roese
Patch by Heiko Schocher, 15 Aug 2006
2003-10-09* Patch by Steven Scholz, 10 Oct 2003LABEL_2003_10_09_2320wdenk
- Add support for Altera FPGA ACEX1K * Patches by Thomas Lange, 09 Oct 2003: - Endian swap ATA identity for all big endian CPUs, not just PPC - MIPS only: New option CONFIG_MEMSIZE_IN_BYTES for passing memsize args to linux - add support for dbau1x00 board (MIPS32)
