path: root/include/_exports.h
2016-10-11x86: Don't export interrupt handlers with x86_64Simon Glass
We don't have a way of adjusting these at present so it is best to refuse to export these functions. This can be implemented later if the API is required. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-09-14Export memset for standalone AQ FW load appsShaohui Xie
The 'commit 95279315076c ("board/ls2085rdb: Export functions for standalone AQ FW load apps")' mentioned memset was exported but it was not, this patch exports the memset. Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2015-10-20malloc_simple: Add Kconfig option for using only malloc_simple in the SPLHans de Goede
common/dlmalloc.c is quite big, both in .text and .data usage, therefor on some boards the SPL is build to use only malloc_simple.c and not the dlmalloc.c code. This is done in various include/configs/foo.h with the following construct: #ifdef CONFIG_SPL_BUILD #define CONFIG_SYS_MALLOC_SIMPLE #endif This commit introduces a SPL_MALLOC_SIMPLE Kconfig bool which allows selecting this functionality through Kconfig instead. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-20board/ls2085rdb: Export functions for standalone AQ FW load appsPrabhakar Kushwaha
Export functions required by Aquntia PHY firmware load application. functions are memset, strcpy, mdelay, mdio_get_current_dev, phy_find_by_mask, mdio_phydev_for_ethname and miiphy_set_current_dev Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-03-04Make export interface support CONFIG_SYS_MALLOC_SIMPLESimon Glass
When CONFIG_SYS_MALLOC_SIMPLE is defined, free() is a static inline. Make sure that the export interface still builds in this case. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29Export redesignMartin Dorwig
this is an atempt to make the export of functions typesafe. I replaced the jumptable void ** by a struct (jt_funcs) with function pointers. The EXPORT_FUNC macro now has 3 fixed parameters and one variadic parameter The first is the name of the exported function, the rest of the parameters are used to format a functionpointer in the jumptable, the EXPORT_FUNC macros are expanded three times, 1. to declare the members of the struct 2. to initialize the structmember pointers 3. to call the functions in stubs.c Signed-off-by: Martin Dorwig <dorwig@tetronik.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (resending to the list since my tweaks are not quite trivial)
2011-05-12lib, vsprintf: introduce strict_strtoulHeiko Schocher
as checkpatch proposes to use strict_strtoul instead of simple_strtoul, introduce it. Ported this function from Linux 2.6.38 commit ID: 521cb40b0c44418a4fd36dc633f575813d59a43d Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2010-09-19Remove support for CONFIG_HAS_UID and "forceenv" commandWolfgang Denk
This (undocumented) concept was only in use for the MVSMR and davinci_schmoogie Sergey Kubushyn <ksi@koi8.net> boards. Drop it for now. If really needed, it should be reimplemented later in the context of the new environment command set. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andre Schwarz <andre.schwarz@matrix-vision.de> Cc: Sergey Kubushyn <ksi@koi8.net> Acked-by: Sergey Kubushyn <ksi@koi8.net>
2009-08-09export SPI functions to standalone appsMike Frysinger
While we're here, fix the broken #ifdef handling in _exports.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2007-08-10[ARM] TI DaVinci support, hopefully finalSergey Kubushyn
Add support for the following DaVinci boards: - DV_EVM - SCHMOOGIE - SONATA Changes: - Split into separate board directories - Removed changes to MTD_DEBUG (or whatever it's called) - New CONFIG_CMD party line followed - Some cosmetic fixes, cleanup etc. - Patches against the latest U-Boot tree as of now. - Fixed CONFIG_CMD_NET in net files. - Fixed CONFIG_CMD_EEPROM for schmoogie. - Made sure it compiles and works (forceenv() link problem) on SCHMOOGIE and DV_EVM. Can't check if it works on SONATA, don't have a board any more, but it at least compiles. Here is an excerpt from session log on SCHMOOGIE... U-Boot 1.2.0-g6c33c785-dirty (Aug 7 2007 - 13:07:17) DRAM: 128 MB NAND: 128 MiB In: serial Out: serial Err: serial ARM Clock : 297MHz DDR Clock : 162MHz ETH PHY : DP83848 @ 0x01 U-Boot > iprobe Valid chip addresses: 1B 38 3A 3D 3F 50 5D 6F U-Boot > ping 192.168.253.10 host 192.168.253.10 is alive U-Boot > Signed-off-by: Sergey Kubushyn <ksi@koi8.net> Acked-by: Dirk Behme <dirk.behme@gmail.com> Acked-by: Zach Sadecki <Zach.Sadecki@ripcode.com> Acked-by: Stefan Roese <sr@denx.de>
2007-08-06Add functions to list of exported functionsMartin Krause
Additionally export the following fuctions (to make trab_config build again): - simple_strtol() - strcmp() Also bump the ABI version to reflect this change Signed-off-by: Martin Krause <martin.krause@tqs.de>
2007-07-10cpu/ rtc/ include/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09include/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
Mostly removed from comments here. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-04include/ non-config: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-09-01Added simple_strtoul(), getenv() and setenv() to the exported functions.Detlev Zundel
Also bumped up ABI version to reflect this change.
2003-09-12Move TRAB burn-in tests to TRAB board directoryLABEL_2003_09_12_1745wdenk
2003-09-11* Patch by Martin Krause, 11 Sep 2003:LABEL_2003_09_12_0110wdenk
add burn-in tests for TRAB board * Enable instruction cache on MPC5200 board
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
