This patch adds support for multiple I2C busses on the PPC4xx
platforms. Define CONFIG_I2C_MULTI_BUS in the board config file
to make use of this feature.
It also merges the 405 and 440 i2c header files into one common
file 4xx_i2c.h.
Also the 4xx i2c reset procedure is reworked since I experienced
some problems with the first access on the 440SPe Katmai board.
- Add support for PPC440EPx & PPC440GRx
- Add support for PPC440EP(x)/GR(x) NAND controller
in cpu/ppc4xx directory
- Add NAND boot functionality for Sequoia board,
please see doc/README.nand-boot-ppc440 for details
- This Sequoia NAND image doesn't support environment
in NAND for now. This will be added in a short while.
Patch by Stefan Roese, 07 Sep 2006
Patch by Stefan Roese, 08 Aug 2005
Patch by Steven Blakeslee, 27 Jul 2005
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
