2003-06-27 | * Code cleanup:LABEL_2003_06_27_2340 | wdenk | |
- remove trailing white space, trailing empty lines, C++ comments, etc. - split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c) * Patches by Kenneth Johansson, 25 Jun 2003: - major rework of command structure (work done mostly by Michal Cendrowski and Joakim Kristiansen) | |||
2003-06-05 | * Patch by Vladimir Gurevich, 04 Jun 2003:LABEL_2003_06_05_2140 | wdenk | |
make ppc405 ethernet driver compatible with CONFIG_NET_MULTI option | |||
2002-08-16 | Initial revision | wdenk | |
