path: root/fs
2019-12-06linux_compat: move kmemdup() from ubifs.c to linux_compat.cAKASHI Takahiro
linux_compat.c is the best place for kmemdup(), which is currenly used only in ubifs.c, but will also be used when other kernel files (in my case, lib/crypto/x509_cert_parser.c and pkcs7_parser.c) will be imported. So just move it. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-12-05fs: fat: handle deleted directory entries correctlyAKASHI Takahiro
Unlink test for FAT file system seems to fail at test_unlink2. (When I added this test, I haven't seen any errors though.) for example, ===8<=== fs_obj_unlink = ['fat', '/home/akashi/tmp/uboot_sandbox_test/128MB.fat32.img'] def test_unlink2(self, u_boot_console, fs_obj_unlink): """ Test Case 2 - delete many files """ fs_type,fs_img = fs_obj_unlink with u_boot_console.log.section('Test Case 2 - unlink (many)'): output = u_boot_console.run_command('host bind 0 %s' % fs_img) for i in range(0, 20): output = u_boot_console.run_command_list([ '%srm host 0:0 dir2/0123456789abcdef%02x' % (fs_type, i), '%sls host 0:0 dir2/0123456789abcdef%02x' % (fs_type, i)]) assert('' == ''.join(output)) output = u_boot_console.run_command( '%sls host 0:0 dir2' % fs_type) > assert('0 file(s), 2 dir(s)' in output) E AssertionError: assert '0 file(s), 2 dir(s)' in ' ./\r\r\n ../\r\r\n 0 0123456789abcdef11\r\r\n\r\r\n1 file(s), 2 dir(s)' test/py/tests/test_fs/test_unlink.py:52: AssertionError ===>8=== This can happen when fat_itr_next() wrongly detects an already- deleted directory entry. File deletion, which was added in the commit f8240ce95d64 ("fs: fat: support unlink"), is implemented by marking its entry for a short name with DELETED_FLAG, but related entry slots for a long file name are kept unmodified. (So entries will never be actually deleted from media.) To handle this case correctly, an additional check for a directory slot will be needed in fat_itr_next(). In addition, I added extra comments about long file name and short file name format in FAT file system. Although they are not directly related to the issue, I hope it will be helpful for better understandings in general. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2019-12-02common: Move sorting functions to their own header fileSimon Glass
These don't need to be in common.h so move them out into a new header. Also add some missing comments. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02crc32: Use the crc.h header for crc functionsSimon Glass
Drop inclusion of crc.h in common.h and use the correct header directly instead. With this we can drop the conflicting definition in fw_env.h and rely on the crc.h header, which is already included. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-10-17fs: add fs_get_type() for current filesystem typeAKASHI Takahiro
This function is a variant of fs_get_type_name() and returns a filesystem type with which the current device is associated. We don't want to export fs_type variable directly because we have to take care of it consistently within fs.c. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-10-17fs: clean up around fs_typeAKASHI Takahiro
fs_ls(), fs_mkdir() and fs_unlink() sets fs_type to FS_TYPE_ANY explicitly, but it is redundant as they call fs_close(). So just remove those lines. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-10-17fs: export fs_close()AKASHI Takahiro
fs_close() closes the connection to a file system which opened with either fs_set_blk_dev() or fs_set_dev_with_part(). Many file system functions implicitly call fs_close(), e.g. fs_closedir(), fs_exist(), fs_ln(), fs_ls(), fs_mkdir(), fs_read(), fs_size(), fs_write() and fs_unlink(). So just export it. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-10-11fs: fat: get_contents() always returns -1 for errorsHeinrich Schuchardt
If out of memory, return -1 and not -ENOMEM from get_contents(). Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-10-11fs: fat: treat invalid FAT clusters as errorsHeinrich Schuchardt
When hitting an invalid FAT cluster while reading a file always print an error message and return an error code. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-08-26fat: FAT filesystem premature release of info struct.Martin Vystrčil
File was found on specified location. Info about file was read, but then immediately destroyed using 'free' call. As a result file size was set to 0, hence fat process didn't read any data. Premature 'free' call removed. Resources are freed right before function return. File is read correctly. Signed-off-by: Martin Vystrcil <martin.vystrcil@m-linux.cz>
2019-08-20jffs2: remove unused code filesUwe Kleine-König
I failed to find where these two files are used and a few test compile runs with JFFS2 enabled succeeded also without these.
2019-08-18cbfs: Rename camel-case variablesSimon Glass
Rename some camel-case variables to match U-Boot style. Camel case is not generally allowed in U-Boot. Rename this variable to fit in with the style. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2019-08-18cbfs: Add functions to support multiple CBFSsSimon Glass
Sometimes an image has multiple CBFS. The current CBFS API is limited to handling only one at time. Also it keeps track of the CBFS internally in BSS, which does not work before relocation, for example. Add a few new functions to overcome these limitations. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2019-08-18cbfs: Move result variable into the structSimon Glass
Move the result variable into the struct also, so that it can be used when BSS is not available. Add a function to read it. Note that all functions sill use the BSS version of the data. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2019-08-18cbfs: Move static variables into a structSimon Glass
At present there are a number of static variables in BSS. This cannot work with SPL, at least until BSS is available in board_init_r(). Move the variables into a struct, so it is possible to malloc() it and use it before BSS is available. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2019-08-18cbfs: Move declarations above functionsSimon Glass
At present this file has a function at the top, above declarations. This is normally avoided, so fix it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2019-08-18cbfs: Allow CBFS to be used in SPLSimon Glass
Add a new Kconfig option to enable CBFS in SPL. This can be useful when the memory-init code is in CBFS. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2019-08-11env: Move env_set_hex() to env.hSimon Glass
Move env_set_hex() over to the new header file along with env_set_addr() which uses it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-08-11common: Move gzip functions into a new gzip headerSimon Glass
As part of the effort to remove things from common.h, create a new header for the gzip functions. Move the function declarations to it and add missing documentation. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2019-07-23cbfs: Rename checksum to attributes_offsetSimon Glass
It seems that this field has been renamed in later version of coreboot. Update it. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-07-18CVE-2019-13106: ext4: fix out-of-bounds memsetPaul Emge
In ext4fs_read_file in ext4fs.c, a memset can overwrite the bounds of the destination memory region. This patch adds a check to disallow this. Signed-off-by: Paul Emge <paulemge@forallsecure.com>
2019-07-18ext4: gracefully fail on divide-by-0Paul Emge
This patch checks for 0 in several ext4 headers and gracefully fails instead of raising a divide-by-0 exception. Signed-off-by: Paul Emge <paulemge@forallsecure.com>
2019-07-18CVE-2019-13104: ext4: check for underflow in ext4fs_read_filePaul Emge
in ext4fs_read_file, it is possible for a broken/malicious file system to cause a memcpy of a negative number of bytes, which overflows all memory. This patch fixes the issue by checking for a negative length. Signed-off-by: Paul Emge <paulemge@forallsecure.com>
2019-07-18CVE-2019-13105: ext4: fix double-free in ext4_cache_readPaul Emge
ext_cache_read doesn't null cache->buf, after freeing, which results in a later function double-freeing it. This patch fixes ext_cache_read to call ext_cache_fini instead of free. Signed-off-by: Paul Emge <paulemge@forallsecure.com>
2019-07-18ext4: add support for filesystems without JOURNALMarek Szyprowski
JOURNAL is optional for EXT4 (and EXT3) filesystems, so add support for skipping it. This fixes corrupting EXT4 volumes without JOURNAL after using uboot's 'ext4write' command. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2019-07-18ext4: fix calculating inode blkcount for non-512 blocksize filesystemsMarek Szyprowski
The block count entry in the EXT4 filesystem disk structures uses standard 512-bytes units for most of the typical files. The only exception are HUGE files, which use the filesystem block size, but those are not supported by uboot's EXT4 implementation anyway. This patch fixes the EXT4 code to use proper unit count for inode block count. This fixes errors reported by fsck.ext4 on disks with non-standard (i.e. 4KiB, in case of new flash drives) PHYSICAL block size after using 'ext4write' uboot's command. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2019-06-20fs: do_load: pass device path for efi payloadMian Yousaf Kaukab
fatload command can be used to load the EFI payload since EFI system partition is always a FAT partition. Call into EFI code from do_load() to set the device path from which the last binary was loaded. An EFI application like grub2 can’t find its configuration file without the device path set. Since device path is now set in do_load() there is no need to set it in do_load_wrapper() for the load command. Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-05-28fs: fat: allocate a new cluster for root directory of fat32AKASHI Takahiro
Contrary to fat12/16, fat32 can have root directory at any location and its size can be expanded. Without this patch, root directory won't grow properly and so we will eventually fail to add files under root directory. Please note that this can happen even if you delete many files as deleted directory entries are not reclaimed but just marked as "deleted" under the current implementation. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-05-28fs: fat: flush a directory cluster properlyAKASHI Takahiro
When a long name directory entry is created, multiple directory entries may be occupied across a directory cluster boundary. Since only one directory cluster is cached in a directory iterator, a first cluster must be written back to device before switching over a second cluster. Without this patch, some added files may be lost even if you don't see any failures on write operation. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-05-28fs: fat: write to non-cluster-aligned root directoryAKASHI Takahiro
With the commit below, fat now correctly handles a file read under a non-cluster-aligned root directory of fat12/16. Write operation should be fixed in the same manner. Fixes: commit 9b18358dc05d ("fs: fat: fix reading non-cluster-aligned root directory") Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Cc: Anssi Hannula <anssi.hannula@bitwise.fi> Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-05-28fs: fat: Fix possible double free of fatbufAndrew F. Davis
fat_itr_root() allocates fatbuf so we free it on the exit path, if the function fails we should not free it, check the return value and skip freeing if the function fails. Signed-off-by: Andrew F. Davis <afd@ti.com>
2019-05-28fs: fat: correct file name normalizationHeinrich Schuchardt
File names may not contain control characters (< 0x20). Simplify the coding. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-05-05fs: btrfs: add zstd decompression supportMarek Behún
This adds decompression support for Zstandard, which has been included in Linux btrfs driver for some time. Signed-off-by: Marek Behún <marek.behun@nic.cz>
2019-05-03fs: btrfs: fix btrfs methods return values on failureMarek Behún
The btrfs implementation methods .ls(), .size() and .read() returns 1 on failure, but the command handlers expect values <0 on failure. For example if given a nonexistent path, the load command currently returns success, and hush scripting does not work. Fix this by setting return values of these methods to -1 instead of 1 on failure. Signed-off-by: Marek Behún <marek.behun@nic.cz>
2019-05-03fs: btrfs: Do not print mount fail message when not btrfs filesystemMarek Behún
Other filesystem drivers don't do this. Signed-off-by: Marek Behún <marek.behun@nic.cz>
2019-04-27Revert "fs: btrfs: fix false negatives in ROOT_ITEM search"Tom Rini
Per Pierre this change shouldn't have been applied as it was superseded by "fs: btrfs: fix btrfs_search_tree invalid results" which is also applied now as 1627e5e5985d. This reverts commit 633967f9818cb6a0e87ffa8cba33148a5bcc6edb. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-04-26fs: btrfs: fix btrfs_search_tree invalid resultsPierre Bourdon
btrfs_search_tree should return the first item in the tree that is greater or equal to the searched item. The search algorithm did not properly handle the edge case where the searched item is higher than the last item of the node but lower than the first item of the next node. Instead of properly returning the first item of the next node, it was returning an invalid path pointer (pointing to a non-existent item after the last item of the node + 1). This fixes two issues in the btrfs driver: - Looking for a ROOT_ITEM could fail if it was the first item of its leaf node. - Iterating through DIR_INDEX entries (for readdir) could fail if the first DIR_INDEX entry was the first item of a leaf node. Signed-off-by: Pierre Bourdon <delroth@gmail.com> Cc: Marek Behun <marek.behun@nic.cz>
2019-04-26fs: fat: Build only if CONFIG_FS_FAT=yIsmael Luceno Cortes
Signed-off-by: Ismael Luceno <ismael.luceno@silicon-gears.com>
2019-04-26fs: btrfs: fix false negatives in ROOT_ITEM searchPierre Bourdon
ROOT_ITEMs in btrfs are referenced without knowing their actual "offset" value. To perform these searches using only two items from the key, the btrfs driver uses a special "btrfs_search_tree_key_type" function. The algorithm used by that function to transform a 3-tuple search into a 2-tuple search was subtly broken, leading to items not being found if they were the first in their tree node. This commit fixes btrfs_search_tree_key_type to properly behave in these situations. Signed-off-by: Pierre Bourdon <delroth@gmail.com> Cc: Marek Behun <marek.behun@nic.cz>
2019-04-09Fix ext4 block group descriptor sizingBenjamin Lim
Ext4 allows for arbitrarily sized block group descriptors when 64-bit addressing is enabled, which was previously not properly supported. This patch dynamically allocates a chunk of memory of the correct size. Signed-off-by: Benjamin Lim <jarsp.ctf@gmail.com>
2019-04-09fs: fat: fix reading non-cluster-aligned root directoryAnssi Hannula
A FAT12/FAT16 root directory location is specified by a sector offset and it might not start at a cluster boundary. It also resides before the data area (before cluster 2). However, the current code assumes that the root directory is located at a beginning of a cluster, causing no files to be found if that is not the case. Since the FAT12/FAT16 root directory is located before the data area and is not aligned to clusters, using unsigned cluster numbers to refer to the root directory does not work well (the "cluster number" may be negative, and even allowing it be signed would not make it properly aligned). Modify the code to not use the normal cluster numbering when referring to the root directory of FAT12/FAT16 and instead use a cluster-sized offsets counted from the root directory start sector. This is a relatively common case as at least the filesystem formatter on Win7 seems to create such filesystems by default on 2GB USB sticks when "FAT" is selected (cluster size 64 sectors, rootdir size 32 sectors, rootdir starts at half a cluster before cluster 2). dosfstools mkfs.vfat does not seem to create affected filesystems. Signed-off-by: Anssi Hannula <anssi.hannula@bitwise.fi> Reviewed-by: Bernhard Messerklinger <bernhard.messerklinger@br-automation.com> Tested-by: Bernhard Messerklinger <bernhard.messerklinger@br-automation.com>
2019-04-09fs: ext4: Problem with ext4load and sparse filesGero Schumacher
Hi, when I try to load a sparse file via ext4load, I am getting the error message 'invalid extent' After a deeper look in the code, it seems to be an issue in the function ext4fs_get_extent_block in fs/ext4/ext4_common.c: The file starts with 1k of zeros. The blocksize is 1024. So the first extend block contains the following information: eh_entries: 1 eh_depth: 1 ei_block 1 When the upper layer (ext4fs_read_file) asks for fileblock 0, we are running in the 'invalid extent' error message. For me it seems, that the code is not prepared for handling a sparse block at the beginning of the file. The following change, solved my problem: I am really not an expert in ext4 filesystems. Can somebody please have a look at this issue and give me a feedback, if I am totally wrong or not?
2019-04-09fs: Add a new command to create symbolic linksJean-Jacques Hiblot
The command line is: ln <interface> <dev[:part]> target linkname Currently symbolic links are supported only in ext4 and only if the option CMD_EXT4_WRITE is enabled. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-04-09fs: ext4: Add support for the creation of symbolic linksJean-Jacques Hiblot
Re-use the functions used to write/create a file, to support creation of a symbolic link. The difference with a regular file are small: - The inode mode is flagged with S_IFLNK instead of S_IFREG - The ext2_dirent's filetype is FILETYPE_SYMLINK instead of FILETYPE_REG - Instead of storing the content of a file in allocated blocks, the path to the target is stored. And if the target's path is short enough, no block is allocated and the target's path is stored in ext2_inode.b.symlink As with regulars files, if a file/symlink with the same name exits, it is unlinked first and then re-created. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Fix ext4 env code] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-04-09fs: ext4: constify the buffer passed to write functionsJean-Jacques Hiblot
There is no need to modify the buffer passed to ext4fs_write_file(). The memset() call is not required here and was likely copied from the equivalent part of the ext4fs_read_file() function where we do need it. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-04-09fs: ext4: cache extent dataStephen Warren
When a file contains extents, U-Boot currently reads extent-related data for each block in the file, even if that data is located in the same block each time. This significantly slows down loading of files that use extents. Implement a very dumb cache to prevent repeatedly reading the same block. Files with extents now load as fast as files without. Note: There are many cases where read_allocated_block() is called. This patch only addresses one of those places; all others still read redundant data in any case they did before. This is a minimal patch to fix the load command; other cases aren't fixed. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2019-04-09mtd: ubi, ubifs debug: Use pr_debug instead of pr_critEran Matityahu
Before printk.h was introduced and MTDDEBUG was removed, pr_crit() was calling MTDDEBUG(), which was since then replaced by the current pr_debug(). pr_debug is more appropriate here. Signed-off-by: Eran Matityahu <eran.m@variscite.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2019-03-22fs: ext4: do not write on filesystem with metadata_csum featureSébastien Szymanski
U-Boot doesn't support metadata_csum feature. Writing to filesystem with metadata_csum feature makes the filesystem corrupted and unbootable by Linux: [ 2.527495] EXT4-fs (mmcblk0p2): ext4_check_descriptors: Checksum for group 0 failed (52188!=0) [ 2.537421] EXT4-fs (mmcblk0p2): ext4_check_descriptors: Checksum for group 1 failed (5262!=0) ... [ 2.653308] EXT4-fs (mmcblk0p2): ext4_check_descriptors: Checksum for group 14 failed (42611!=0) [ 2.662179] EXT4-fs (mmcblk0p2): ext4_check_descriptors: Checksum for group 15 failed (21527!=0) [ 2.687920] JBD2: journal checksum error [ 2.691982] EXT4-fs (mmcblk0p2): error loading journal [ 2.698292] VFS: Cannot open root device "mmcblk0p2" or unknown-block(179,2): error -74 Don't write to filesystem with meatadata_csum feature to not corrupt the filesystem. Signed-off-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2019-02-28fs: fat: fix link error when building with DEBUG=1Heinrich Schuchardt
When compiling with DEBUG=1 an error fs/fat/fat_write.c:831: undefined reference to `__aeabi_ldivmod' occurred. We should use do_div() instead of the modulus operator. filesize and cur_pos cannot be negative. So let's use u64 to avoid warnings. Fixes: cb8af8af5ba0 ("fs: fat: support write with non-zero offset") Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-19fs: fat: Reduce default max clustersize 64KiB from malloc poolTien Fong Chee
Release cluster block immediately when no longer use would help to reduce 64KiB memory allocated to the memory pool. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
