Added some comments, and moved function return values to the same line as the
function name.
TEST=Compiled for x86-alex.
BUG=chrome-os-partner:5702
Change-Id: I101ab927f72653a912ec82df5e665a0baf223c92
Signed-off-by: Gabe Black <gabeblack@google.com>
Reviewed-on: http://gerrit.chromium.org/gerrit/6726
Reviewed-by: Stefan Reinauer <reinauer@google.com>
If u-boot needs something out of CBFS very early before the heap is
configured, it won't be able to use the normal CBFS support which caches some
information in memory it allocates from the heap. This change adds a new
cbfs_file_find_uncached function which searchs a CBFS instance without touching
the heap. It also refactors the implementation of u-boot's CBFS support to
avoid code duplication, and allows some functions to be used without CBFS being
initialized which sets up the cache on the heap.
BUG=chrome-os-partner:5432
TEST=Built x86-alex, verified that the CBFS commands still work, and with
later changes verified that the device tree could be loaded from CBFS before
the heap is initialized.
Change-Id: Ia57a5c553a0cd524073c05ca964501ccf6c5e025
Reviewed-on: http://gerrit.chromium.org/gerrit/5858
Tested-by: Gabe Black <gabeblack@chromium.org>
This change refactors the implementation of the CBFS driver so that it can be
used effectively both from the command line and programmatically from within
u-boot.
BUG=chrome-os-partner:4993
TEST=Built and booted on Alex. Verified that the CBFS commands still behaved
correctly.
Change-Id: I97720828e282261f69479979d7d0c2c7d193c53f
Reviewed-on: http://gerrit.chromium.org/gerrit/4916
Reviewed-by: Gabe Black <gabeblack@chromium.org>
This change adds CBFS support and some commands to use it to u-boot. These
commands are:
cbfsinit - Initialize CBFS support and pull all metadata into RAM. The end of
the ROM is an optional parameter which defaults to the standard 0xffffffff and
can be used to support multiple CBFSes in a system. The last one set up with
cbfsinit is the one that will be used.
cbfsinfo - Print information from the CBFS header.
cbfsls - Print out the size, type, and name of all the files in the current
CBFS. Recognized types are translated into symbolic names.
cbfsload - Load a file from CBFS into memory. Like the similar command for fat
filesystems, you can optionally provide a maximum size.
Support for CBFS is compiled in when the CONFIG_CMD_CBFS option is specified.
BUG=chrome-os-partner:3910
TEST=Built and booted on an Alex. Initialized with and without specifying the
end of the ROM, and with a bad end of ROM. Ran the commands before CBFS was
initialized. Ran cbfsinfo and saw reasonable output. Ran cbfsls and saw output
that matched what was printed when the CBFS was put together by the coreboot
ebuild. Used cbfsload to load a test text file into memory and verified that it
was the correct size and had the correct contents. Ran with a max size and saw
the file was truncated in memory.
Change-Id: I64d06d49633cef3cffac1d571519eae38c7d267f
Reviewed-on: http://gerrit.chromium.org/gerrit/4167
This allocates a cache line size aligned sector sized bounce buffer the
first time that ext2fs_devread is called. This is required to avoid
bounce buffers on ARM.
BUG=chromium-os:16317
TEST=run "ext2ls mmc 0:3" on Seaboard
Change-Id: Ia01d17d655eb503bf7835a8e663c3b71806872a8
Reviewed-on: http://gerrit.chromium.org/gerrit/2328
Reviewed-by: Anton Staaf <robotboy@chromium.org>
Tested-by: Anton Staaf <robotboy@chromium.org>
Previously reading or writing zero full sectors (reading the end of
one sector and the beginning of the next for example) was special
cased and involved stack allocating a second sector buffer. This
change uses the same code path for this case as well as when there
are a non-zero number of full sectors to access. The result is
easier to read and reduces the maximum stack used.
BUG=None
Change-Id: Iac92172bf40724302292a2a9695cb61029b02ae7
Reviewed-on: http://gerrit.chromium.org/gerrit/2327
TEST=Build and run "ext2ls mmc 0:3" on Seaboard
Change-Id: Ie927ee8a2b5d15d0ff33b2531814a3bff7ec9cea
Reviewed-on: http://gerrit.chromium.org/gerrit/2386
cc: Wolfgang Denk <wd@denx.de>
cc: Detlev Zundel <dzu@denx.de>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Holger Brunck <holger.brunck@keymile.com>
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Signed-off-by: Loïc Minier <loic.minier@linaro.org>
Fat directory handling didn't check reaching the end of the root directory. It
relied on a stop condition based on a directory entry with a name starting with
a '\0' character. This check in itself is wrong ('\0' indicates free entry, not
end_of_directory) but outside the scope of this fix. For FAT32, the end of the
rootdir is reached when the end of the cluster chain is reached. The code didn't
check this condition and started to read an incorrect cluster. This caused a
subsequent read request of a sector outside the range of the usb stick in
use. On its turn, the usb stick protested with a stall handshake.
Both FAT32 and non-FAT32 (FAT16/FAT12) end or rootdir checks have been put in.
Signed-off-by: Erik Hansen <erik@makarta.com>
Fix compiler warning
In file included from ubifs.h:2137:0,
from ubifs.c:26:
misc.h: In function 'ubifs_idx_key':
misc.h:263:26: warning: dereferencing type-punned pointer will break strict-aliasing rules
seen with gcc version 4.5.1 (Sourcery G++ Lite 2010.09-50).
No functional change.
CC: Stefan Roese <sr@denx.de>
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
The link_name variable is declared inside the if block and it is used
outside it through the name pointer.
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
Until now ubifsload pads the destination with 0 up to a multiple of
UBIFS_BLOCK_SIZE (4KiB) while reading a file to memory. This patch
changes this behaviour to only read to the requested length. This
is either the file length or the length/size provided as parameter
to the ubifsload command.
This new ubifsumount command allows the user to unmount a previously
mounted UBIFS volume.
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
By now, the majority of architectures have working relocation
support, so the few remaining architectures have become exceptions.
To make this more obvious, we make working relocation now the default
case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC.
Tested-by: Heiko Schocher <hs@denx.de>
Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
Last commit 3831530dcb7b71329c272ccd6181f8038b6a6dd0a was intended
"explicitly specify FAT12/16 root directory parsing buffer size, instead
of relying on cluster size". Howver, the underlying function requires
the size of the buffer in blocks, not in bytes, and instead of passing
a double sector size a request for 1024 blocks is sent. This generates
a buffer overflow with overwriting of other structure (in the case seen,
USB structures were overwritten).
CC: Mikhail Zolotaryov <lebon@lebon.org.ua>
The U-Boot code has the following bugs related to the processing of Long File
Name (LFN) entries scattered across several clusters/sectors :
1) get_vfatname() function is designed to gather scattered LFN entries by
cluster chain processing - that doesn't work for FAT12/16 root directory.
In other words, the function expects the following input data:
1.1) FAT32 directory (which is cluster chain based);
OR
1.2) FAT12/16 non-root directory (which is also cluster chain based);
OR
1.3) FAT12/16 root directory (allocated as contiguous sectors area), but
all necessary information MUST be within the input buffer of filesystem cluster
size (thus cluster-chain jump is never initiated).
In order to accomplish the last condition, root directory parsing code in
do_fat_read() uses the following trick: read-out cluster-size block, process
only first sector (512 bytes), then shift 512 forward, read-out cluster-size
block and so on. This works great unless cluster size is equal to 512 bytes
(in a case you have a small partition), or long file name entries are scattered
across three sectors, see 4) for details.
2) Despite of the fact that get_vfatname() supports FAT32 root directory
browsing, do_fat_read() function doesn't send current cluster number correctly,
so root directory look-up doesn't work correctly.
3) get_vfatname() doesn't gather scattered entries correctly also is the case
when all LFN entries are located at the end of the source cluster, but real
directory entry (which must be returned) is at the only beginning of the
next one. No error detected, the resulting directory entry returned contains
a semi-random information (wrong size, wrong start cluster number and so on)
i.e. the entry is not accessible.
4) LFN (VFAT) allows up to 20 entries (slots) each containing 26 bytes (13
UTF-16 code units) to represent a single long file name i.e. up to 520 bytes.
U-Boot allocates 256 bytes buffer instead, i.e. 10 or more LFN slots record
may cause buffer overflow / memory corruption.
Also, it's worth to mention that 20+1 slots occupy 672 bytes space which may
take more than one cluster of 512 bytes (medium-size FAT32 or small FAT16
partition) - get_vfatname() function doesn't support such case as well.
The patch attached fixes these problems in the following way:
- keep using 256 bytes buffer for a long file name, but safely prevent a
possible buffer overflow (skip LFN processing, if it contains 10 or more
slots).
- explicitly specify FAT12/16 root directory parsing buffer size, instead
of relying on cluster size. The value used is a double sector size (to store
current sector and the next one). This fixes the first problem and increases
performance on big FAT12/16 partitions;
- send current cluster number (FAT32) to get_vfatname() during root
directory processing;
- use LFN counter to seek the real directory entry in get_vfatname() - fixes the
third problem;
- skip deleted entries in the root directory (to prevent bogus buffer
overflow detection and LFN counter steps).
Note: it's not advised to split up the patch, because a separate part may
operate incorrectly.
Signed-off-by: Mikhail Zolotaryov <lebon@lebon.org.ua>
Doubly-indirect block numbers are compared against the first-level
indirect block when checking for a cached copy. This is causing the
doubly-indirect block to be re-read each time it is accessed.
Repairing this reduces load time for a 70M file from 72 seconds
to 38 seconds.
Signed-off-by: Aaron Pace <Aaron.Pace@alcatel-lucent.com>
- reformat
- throw out macros like FAT_DPRINT and FAT_DPRINT
- remove dead code
On FAT32, instead of fetching the cluster numbers from the FAT, the
code assumed (incorrectly) that the clusters for the root directory
were allocated contiguously. In the result, only the first cluster
could be accessed. At the typical cluster size of 8 sectors this
caused all accesses to files after the first 128 entries to fail -
"fatls" would terminate after 128 files (usually displaying a bogus
file name, occasionally even crashing the system), and "fatload"
would fail to find any files that were not in the first directory
cluster.
"Superfloppy" format (in U-Boot called PBR) did not work for FAT32 as
the file system type string is at a different location. Add support
for FAT32.
The nios-32 arch is obsolete and broken. So it is removed.
ubifsmount is not working and causes an access with
a pointer set to zero because the ubifs_fs_type
is not initialized correctly.
$ ./MAKEALL suen3
jffs2_1pass.c: In function 'get_fl_mem':
jffs2_1pass.c:399: warning: unused variable 'id'
jffs2_1pass.c: In function 'get_node_mem':
jffs2_1pass.c:423: warning: unused variable 'id'
Tested-by: Tom <Tom.Rix@windriver.com>
Support for LZARI compression mode was added based on a MTD CVS
snapshot of March 13, 2005. However, fs/jffs2/compr_lzari.c contains
contradictory licensing terms: the original copyright clause says "All
rights reserved. Permission granted for non-commercial use.", but
later reference to the file 'LICENCE' in the jffs2 directory was added
which says GPL v2 or later.
As no boards ever used LZARI compression, and this file is also not
present in recent MTD code, we resolve this conflict by removing the
conflicting file and references to it.
Also copy the referenced but missing file 'LICENCE' from the current
MTD source tree.
Prototype for gunzip/zunzip was only in lib_generic/gunzip.c and thus
repeated in every file using it. This patch moves the prototypes to
common.h and removes all prototypes distributed anywhere else.
Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
There is more and more usage of printing 64bit values,
so enable this feature generally, and delete the
CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL
defines.
extfs.c assumes that there is always a valid inode_size field in the
superblock. But this is not true for ext2fs rev 0. Such ext2fs images
are for instance generated by genext2fs. Symptoms on ARM machines are
messages like: "raise: Signal # 8 caught"; on PowerPC "ext2ls" will
print nothing.
This fix checks for rev 0 and uses then 128 bytes as inode size.
Signed-off-by: Michael Brandt <Michael.Brandt@emsyso.de>
Tested on: TQM5200S
Tested-by: Wolfgang Denk <wd@denx.de>
Add #ifdefs where necessary to not perform relocation fixups. This
allows boards/architectures which support relocation to trim a decent
chunk of code.
Note that this patch doesn't add #ifdefs to architecture-specific code
which does not support relocation.
Files in directories which are symlinked to were not dereferenced
correctly in last commit. E.g., with a symlink
/boot/lnk -> /boot/real_dir
loading
/boot/lnk/uImage
will fail. This patch fixes that by simply seeing to it that the target
base directory has a slash after it.
Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
This patch adds support for resolving symlinks to directories as well as
relative symlinks. Symlinks are now always resolved during file lookup,
so the load stage no longer needs to special-case them.
__set_bit and __clear_bit are defined in ubifs.h as well as in
asm/include/bitops.h for some architectures. This patch moves
the generic implementation to include/linux/bitops.h and uses
that unless it's defined by the architecture.
This patch fixes some issues with JFFS2 summary support in U-Boot.
1/ Summary support made compilation configurable (as summary support
considered expiremental even in Linux).
2/ Summary code can do unaligned 16-bit and 32-bit memory accesses.
We need to get data byte by byte to exclude data aborts.
3/ Make summary scan in two passes so we can safely fall back to full
scan if we found unsupported entry in the summary.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
We should call jffs2_clean_cache() if we return from jffs2_build_lists()
with an error to prevent usage of incomplete lists. Also we should
free() a local buffer to prevent memory leaks.
Signed-off-by: unsik Kim <donari75@gmail.com>
Signed-off-by: Bernhard Weirich <bernhard.weirich@riedel.net>
Legacy NAND had been scheduled for removal. Any boards that use this
were already not building in the previous release due to an #error.
The disk on chip code in common/cmd_doc.c relies on legacy NAND,
and it has also been removed. There is newer disk on chip code
in drivers/mtd/nand; someone with access to hardware and sufficient
time and motivation can try to get that working, but for now disk
on chip is not supported.
The static function compare_sign is only used to compare the fs_type string
and does not do anything more than what strncmp does.
The addition of the trailing '\0' to fs_type, while legal, is not needed
because the it is never printed out and strncmp does not depend on NULL
terminated strings.
Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
In do_readpage(), don't free 'dn' if its allocation failed.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Blocks compressed with zlib dont have the full gzip header.
Without this patch, block compressed with zlib cannot be readed!
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es>
If the memory used to copy the link_make is "dirty" the string wont
be ended with NULL, throwing out multiple memory bugs.
I missed removing this file while implementing the UBIFS support. It's
not referenced at all, so let's remove it. Thanks to Artem Bityutskiy
for spotting.
UBIFS did not recovery in a situation in which it could
have. The relevant function assumed there could not be
more nodes in an eraseblock after a corrupted node, but
in fact the last (NAND) page written might contain anything.
The correct approach is to check for empty space (0xFF bytes)
from then on.
Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com>
Now UBIFS is supported by u-boot. If we ever decide to change the
media format, then people will have to upgrade their u-boots to
mount new format images. However, very often it is possible to
preserve R/O forward-compatibility, even though the write
forward-compatibility is not preserved.
This patch introduces a new super-block field which stores the
R/O compatibility version.
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Acked-by: Adrian Hunter <Adrian.Hunter@nokia.com>
Some systems have zlib.h installed in /usr/include/. This isn't the
desired file for u-boot code - we want the one in include/zlib.h.
This rename will avoid the conflict.
Mflash is fusion memory device mainly targeted consumer eletronic and
mobile phone.
Internally, it have nand flash and other hardware logics and supports
some different operation (ATA, IO, XIP) modes.
IO mode is custom mode for the host that doesn't have IDE interface.
(Many mobile targeted SoC doesn't have IDE bus)
This driver support mflash IO mode.
Followings are brief descriptions about IO mode.
1. IO mode based on ATA protocol and uses some custom command. (read
confirm, write confirm)
2. IO mode uses SRAM bus interface.
On systems where U-Boot is linked to another address than it really lays
(e.g. backup image), calls via function pointers must be fixed with a
'+= gd->reloc_off'.
This was not done for none_compr in ubifs_compressors_init() what leads
to system crash on ubifsmount command.
Signed-off-by: Michael Lawnick <ml.lawnick@gmx.de>
