path: root/fs
2015-09-11fs: ext4: fix symlink read functionGary Bisson
Since last API changes for files >2GB, the read of symlink is broken as ext4fs_read_file now returns 0 instead of the length of the actual read. Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com>
2015-09-11ext4: fix leak in check_filename()Stephen Warren
root_first_block_buffer should be free()d in all cases, not just when an error occurs. Fix the success exit path of the function to do this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com>
2015-09-11ext4: free allocations by parse_path()Stephen Warren
parse_path() malloc()s the entries in the array it's passed. Those allocations must be free()d by the caller, ext4fs_get_parent_inode_num(). Add code to do this. For this to work, all the array entries must be dynamically allocated, rather than a mix of dynamic and static allocations. Fix parse_path() not to over-write arr[0] with a pointer to statically allocated data. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com>
2015-09-11ext4: avoid calling ext4fs_mount() twice, which leaksStephen Warren
ext4_write_file() is only called from the "fs" layer, which calls both ext4fs_mount() and ext4fs_close() before/after calling ext4_write_file(). Fix ext4_write_file() not to call ext4fs_mount() again, since the mount operation malloc()s some RAM which is leaked when a second mount call over-writes the pointer to that data, if no intervening close call is made. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com>
2015-09-11FIX: fat: Provide correct return code from disk_{read|write} to upper layersŁukasz Majewski
It is very common that FAT code is using following pattern: if (disk_{read|write}() < 0) return -1; Up till now the above code was dead, since disk_{read|write) could only return value >= 0. As a result some errors from medium layer (i.e. eMMC/SD) were not caught. The above behavior was caused by block_{read|write|erase} declared at struct block_dev_desc (@part.h). It returns unsigned long, where 0 indicates error and > 0 indicates that medium operation was correct. This patch as error regards 0 returned from block_{read|write|erase} when nr_blocks is grater than zero. Read/Write operation with nr_blocks=0 should return 0 and hence is not considered as an error. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Test HW: Odroid XU3 - Exynos 5433
2015-09-11Move ALLOC_CACHE_ALIGN_BUFFER() to the new memalign.h headerSimon Glass
Now that we have a new header file for cache-aligned allocation, we should move the stack-based allocation macro there also. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-11Move malloc_cache_aligned() to its own headerSimon Glass
At present malloc.h is included everywhere since it recently was added to common.h in this commit: 4519668 mtd/nand/ubi: assortment of alignment fixes This seems wasteful and unnecessary. We have been trying to trim down common.h and put separate functions into separate header files and that change goes in the opposite direction. Move malloc_cache_aligned() to a new header so that this can be avoided. The header would perhaps be better named as alignmem.h but it needs to be included after common.h and people might be confused by this. With the name memalign.h it fits nicely after malloc() in most cases. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-09-11fat: handle paths that include ../Stephen Warren
The FAT code contains a special case to parse the root directory. This is needed since the root directory location/layout on disk is special cased for FAT12/16. In particular, the location and size of the FAT12/16 root directory is hard-coded and contiguous, whereas all FAT12/16 non-root directories, and all FAT32 directories, are stored in a non-contiguous fashion, with the layout represented by a linked-list of clusters in the FAT. If a file path contains ../ (for example /extlinux/../bcm2835-rpi-cm.dtb), it is possible to need to parse the root directory for the first element in the path (requiring application of the special case), then a sub- directory (in the general way), then re-parse the root directory (again requiring the special case). However, the current code in U-Boot only applies the special case for the very first path element, and never for any later path element. When reparsing the root directory without applying the special case, any file in a sector (or cluster?) other than the first sector/cluster of the root directory will not be found. This change modifies the non-root-dir-parsing loop of do_fat_read_at() to detect if it's walked back to the root directory, and if so, jumps back to the special case code that handles parsing of the root directory. This change was tested using sandbox by executing: ./u-boot -c "host bind 0 ../sd-p1.bin; ls host 0:0" ./u-boot -c "host bind 0 ../sd-p1.bin; ls host 0:0 /" ./u-boot -c "host bind 0 ../sd-p1.bin; ls host 0:0 /extlinux" ./u-boot -c "host bind 0 ../sd-p1.bin; ls host 0:0 /extlinux/" ./u-boot -c "host bind 0 ../sd-p1.bin; ls host 0:0 /extlinux/.." ./u-boot -c "host bind 0 ../sd-p1.bin; ls host 0:0 /extlinux/../" ./u-boot -c "host bind 0 ../sd-p1.bin; ls host 0:0 /extlinux/../backup" ./u-boot -c "host bind 0 ../sd-p1.bin; ls host 0:0 /extlinux/../backup/" ./u-boot -c "host bind 0 ../sd-p1.bin; ls host 0:0 /extlinux/../backup/.." ./u-boot -c "host bind 0 ../sd-p1.bin; ls host 0:0 /extlinux/../backup/../" ./u-boot -c "host bind 0 ../sd-p1.bin; load host 0:0 0 /bcm2835-rpi-cm.dtb" ./u-boot -c "host bind 0 ../sd-p1.bin; load host 0:0 0 /extlinux/../bcm2835-rpi-cm.dtb" ./u-boot -c "host bind 0 ../sd-p1.bin; load host 0:0 0 /backup/../bcm2835-rpi-cm.dtb" ./u-boot -c "host bind 0 ../sd-p1.bin; load host 0:0 0 /extlinux/..backup/../bcm2835-rpi-cm.dtb" ./u-boot -c "host bind 0 ../sd-p1.bin; load host 0:0 0 /extlinux/../backup/../bcm2835-rpi-cm.dtb" (/extlinux and /backup are in different sectors so trigger some different cases, and bcm2835-rpi-cm.dtb is in a sector of the root directory other than the first). In all honesty, this change is a bit of a hack, using goto and all. However, as demonstrated above it appears to work well in practice, is quite minimal, likely doesn't introduce any risk of regressions, and hopefully doesn't introduce any maintenance issues. The correct fix would be to collapse the root and non-root loops in do_fat_read_at() and get_dentfromdir() into a single loop that has a small special-case when moving from one sector to the next, to handle the layout difference of root/non-root directories. AFAIK all other aspects of directory parsing are identical. However, that's a much larger change which needs significantly more thought before it's implemented. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2015-08-28mtd/nand/ubi: assortment of alignment fixesMarcel Ziswiler
Various U-Boot adoptions/extensions to MTD/NAND/UBI did not take buffer alignment into account which led to failures of the following form: ERROR: v7_dcache_inval_range - start address is not aligned - 0x1f7f0108 ERROR: v7_dcache_inval_range - stop address is not aligned - 0x1f7f1108 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Scott Wood <scottwood@freescale.com> [trini: Add __UBOOT__ hunk to lib/zlib/zutil.c due to malloc.h in common.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-13fs/fs.c: read up to EOF when len would read past EOFMax Krummenacher
http://lists.denx.de/pipermail/u-boot/2012-September/134347.html allows for reading files in chunks from the shell. When this feature is used to read past the end of a file an error was returned instead of returning the bytes read up to the end of file. Thus the following fails in the shell: offset = 0 len = chunksize do read file, offset, len write data until bytes_read < len The patch changes the behaviour to printing an informational message and returning the actual read number of bytes aka read(2) behaviour for convenient use in U-Boot scripts. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-08-12JFFS2: Use merge sort when parsing filesystemMark Tomlinson
When building the file system the existing code does an insertion into a linked list. It attempts to speed this up by keeping a pointer to where the last entry was inserted but it's still slow. Now the nodes are just inserted into the list without searching through for the correct place. This unsorted list is then sorted once using mergesort after all the entries have been added to the list. This speeds up the scanning of the flash file system considerably. Signed-off-by: Mark Tomlinson <mark.tomlinson@alliedtelesis.co.nz>
2015-08-12JFFS2: Use CLEANMARKER to reduce scanning timeMark Tomlinson
If a sector has a CLEANMARKER at the beginning, it indicates that the entire sector has been erased. Therefore, if this is found, we can skip the entire block. This was not being done before this patch. The code now does the same as the kernel does when encountering a CLEANMARKER. It still checks that the next few words are FFFFFFFF, and if so, the block is assumed to be empty, and so is skipped. Signed-off-by: Mark Tomlinson <mark.tomlinson@alliedtelesis.co.nz>
2015-08-12JFFS2: Change scansize to match linux kernelMark Tomlinson
The scan code is similar to the linux kernel, but the kernel defines a much smaller size to scan through before deciding a sector is blank. Assuming that what is in the kernel is OK, make these two match. On its own, this change makes no difference to scanning of any sectors which have a clean marker at the beginning, since the entire sector is not blank. Signed-off-by: Mark Tomlinson <mark.tomlinson@alliedtelesis.co.nz>
2015-08-12JFFS2: Optimize building lists during scanMark Tomlinson
If the flash is slow, reading less from the flash into buffers makes the process faster. Signed-off-by: Mark Tomlinson <mark.tomlinson@alliedtelesis.co.nz>
2015-08-12JFFS2: Improve speed reading flash filesMark Tomlinson
jffs2_1pass_read_inode() would read the entire data for each node in the filesystem, regardless of whether it was part of the file to be loaded or not. By only reading the header data for an inode, and then reading the data only when it is found to be part of the file to be loaded, much copying of data is saved. jffs2_1pass_list_inodes() read each inode for every file in the directory into a buffer. By using NULL as a buffer pointer, NOR flash simply returns a pointer, and therefore avoids a memory copy. Signed-off-by: Mark Tomlinson <mark.tomlinson@alliedtelesis.co.nz>
2015-08-12JFFS2: Only list each directory entry onceMark Tomlinson
If multiple versions of a file exist, only the most recent version should be used. The scheme to write 0 for the inode in older versions did not work, since this would have required writing to flash. The only time this caused an issue was listing a directory, where older versions of the file would still be seen. Since the directory entries are sorted, just look at the next entry in the list, and if it's the same move to that entry instead. Signed-off-by: Mark Tomlinson <mark.tomlinson@alliedtelesis.co.nz>
2015-08-12JFFS2: Speed up and fix comparison functionsMark Tomlinson
Copying complete nodes from flash can be slow if the flash is slow to read. By only reading the data needed, the sorting operation can be made much faster. The directory entry comparison function also had a two bugs. First, it did not ensure the name was copied, so the name comparison may have been faulty (although it would have worked with NOR flash). Second, setting the ino to zero to ignore the entry did not work, since this was either writing to a temporary buffer, or (for NOR flash) directly to flash. Either way, the change was not remembered. Signed-off-by: Mark Tomlinson <mark.tomlinson@alliedtelesis.co.nz>
2015-08-12JFFS2: Return early when file read not necessaryMark Tomlinson
If a destination is not provided, jffs2_1pass_read_inode() only returns the length of the file. In this case, avoid reading all the data nodes, and return as soon as the length of the file is known. Signed-off-by: Mark Tomlinson <mark.tomlinson@alliedtelesis.co.nz>
2015-04-19sandbox: only do sandboxfs for hostfs interfaceSjoerd Simons
Only do sandbox filesystem access when using the hostfs device interface, rather then falling back to it in all cases. This prevents confusion situations due to the fallback being taken rather then an unsupported error being raised. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18common: Make sure arch-specific map_sysmem() is definedJoe Hershberger
In the case where the arch defines a custom map_sysmem(), make sure that including just mapmem.h is sufficient to have these functions as they are when the arch does not override it. Also split the non-arch specific functions out of common.h Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-03-05fs: ext4 write: return file len on successPrzemyslaw Marczak
After rework of the file system API, the size of ext4 write was missed. This causes printing unreliable write size at the end of the file system write operation. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2015-02-04Merge branch 'master' of git://git.denx.de/u-boot-ubiTom Rini
2015-01-29fs: Add command to retrieve the filesystem typeSjoerd Simons
New command to determine the filesystem type of a given partition. Optionally stores the filesystem type in a environment variable. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2015-01-29ubifs: Enable journal replay during mountAnton Habegger
Enable ubifs_replay_journal during mount_ubifs, which was disabled before. This commit fix an issue with unrecoverable ubifs volumes after power cut. Therefor the gc.c is imported now from 1860e37 Linux 3.15 hs: added SPDX-License-Identifier for fs/ubifs/gc.c Signed-off-by: Anton Habegger <anton.habegger@gmail.com>
2015-01-28ubifs: Import atomic_long operations from LinuxAnton Habegger
This commit is a preperation for a subsequent UBIFS commit which needs atomic_long operations. Therefor "include/asm-generic/atomic-long.h" is imported from 1860e37 Linux 3.15 Signed-off-by: Anton Habegger <anton.habegger@gmail.com>
2015-01-05fs: fat: read: fix fat16 ls/read issuePrzemyslaw Marczak
The present fat implementation ignores FAT16 long name directory entries which aren't placed in a single sector. This was becouse of the buffer was always filled by the two sectors, and the loop was made also for two sectors. If some file long name entries are stored in two sectors, the we have two cases: Case 1: Both of sectors are in the buffer - all required data for long file name is in the buffer. - Read OK! Case 2: The current directory entry is placed at the end of the second buffered sector. And the next entries are placed in a sector which is not buffered yet. Then two next sectors are buffered and the mentioned entry is ignored. - Read fail! This commit fixes this issue by: - read two sectors after loop on each single is done - keep the last used sector as a first in the buffer before the read of two next The commit doesn't affects the fat32 imlementation, which works good as previous. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Mikhail Zolotaryov <lebon@lebon.org.ua> Cc: Tom Rini <trini@ti.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Simon Glass <sjg@chromium.org> Cc: Suriyan Ramasami <suriyan.r@gmail.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Wolfgang Denk <wd@denx.de> Tested-by: Simon Glass <sjg@chomium.org>
2014-12-01fs/ext4/ext4fs.c, fs/fs.c fs/fat/fat_write.c: Adjust 64bit math methodsTom Rini
The changes to introduce loff_t into filesize means that we need to do 64bit math on 32bit platforms. Make sure we use the right wrappers for these operations. Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Suriyan Ramasami <suriyan.r@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@ti.com> Tested-by: Pierre Aubert <p.aubert@staubli.com>
2014-11-23fs: API changes enabling extra parameter to return size of type loff_tSuriyan Ramasami
The sandbox/ext4/fat/generic fs commands do not gracefully deal with files greater than 2GB. Negative values are returned in such cases. To handle this, the fs functions have been modified to take an additional parameter of type "* loff_t" which is then populated. The return value of the fs functions are used only for error conditions. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> [trini: Update board/gdsys/p1022/controlcenterd-id.c, drivers/fpga/zynqpl.c for changes] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23sandbox: Prepare API change for files greater than 2GBSuriyan Ramasami
Change the internal sandbox functions to use loff_t for file offsets. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-23ext4: Prepare API change for files greater than 2GBSuriyan Ramasami
Change the internal EXT4 functions to use loff_t for offsets. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> [trini: Update common/spl/spl_ext.c] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23fat: Prepare API change for files greater than 2GBSuriyan Ramasami
Change the internal FAT functions to use loff_t for offsets. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> [trini: Fix fs/fat/fat.c for min3 updates] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23fs: make it possible to read the filesystem UUIDChristian Gmeiner
Some filesystems have a UUID stored in its superblock. To allow using root=UUID=... for the kernel command line we need a way to read-out the filesystem UUID. changes rfc -> v1: - make the environment variable an option parameter. If not given, the UUID is printed out. If given, it is stored in the env variable. - corrected typos - return error codes changes v1 -> v2: - fix return code of do_fs_uuid(..) - document do_fs_uuid(..) - implement fs_uuid_unsuported(..) be more consistent with the way other optional functionality works changes v2 -> v3: - change ext4fs_uuid(..) to make use of #if .. #else .. #endif construct to get rid of unreachable code Hit any key to stop autoboot: 0 => fsuuid fsuuid - Look up a filesystem UUID Usage: fsuuid <interface> <dev>:<part> - print filesystem UUID fsuuid <interface> <dev>:<part> <varname> - set environment variable to filesystem UUID => fsuuid mmc 0:1 d9f9fc05-45ae-4a36-a616-fccce0e4f887 => fsuuid mmc 0:2 eb3db83c-7b28-499f-95ce-9e0bb21cda81 => fsuuid mmc 0:1 uuid1 => fsuuid mmc 0:2 uuid2 => printenv uuid1 uuid1=d9f9fc05-45ae-4a36-a616-fccce0e4f887 => printenv uuid2 uuid2=eb3db83c-7b28-499f-95ce-9e0bb21cda81 => Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2014-11-23linux/kernel.h: sync min, max, min3, max3 macros with LinuxMasahiro Yamada
U-Boot has never cared about the type when we get max/min of two values, but Linux Kernel does. This commit gets min, max, min3, max3 macros synced with the kernel introducing type checks. Many of references of those macros must be fixed to suppress warnings. We have two options: - Use min, max, min3, max3 only when the arguments have the same type (or add casts to the arguments) - Use min_t/max_t instead with the appropriate type for the first argument Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Pavel Machek <pavel@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [trini: Fixup arch/blackfin/lib/string.c] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-20include: move various macros to include/linux/kernel.hMasahiro Yamada
U-Boot has imported various utility macros from Linux scattering them to various places without consistency. In include/common.h are min, max, min3, max3, ARRAY_SIZE, ALIGN, container_of, DIV_ROUND_UP, etc. In include/linux/compat.h are min_t, max_t, round_up, round_down, etc. We also have duplicated defines of min_t in some *.c files. Moreover, we are suffering from too cluttered include/common.h. This commit moves various macros that originate in include/linux/kernel.h of Linux to their original position. Note: This commit simply moves the macros; the macros roundup, min, max, min2, max3, ARRAY_SIZE are different from those of Linux at this point. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-10ZFS: Clean up cppcheck warnings where relevant, leaked memory etcJorgen Lundman
In a message from Wolfgang Denk highlighting warnings from cppcheck, the patch will address those that are correctly diagnosed. Some are false-positives: > [fs/zfs/zfs.c:937]: (error) Memory leak: l dmu_read() allocates "l" if successful, so error-case should not free it. > [fs/zfs/zfs.c:1141]: (error) Memory leak: dnbuf dmu_read() allocates "dnbuf" if successful, so error-case should not free it. > [fs/zfs/zfs.c:1372]: (error) Memory leak: osp zio_read() allocates "osp" if successful, so error-case should not free it. > [fs/zfs/zfs.c:1726]: (error) Memory leak: nvlist int_zfs_fetch_nvlist() allocates "nvlist" if successful, so error-case should not free it. Signed-off-by: Jorgen Lundman <lundman@lundman.net>
2014-10-27spl: Add EXT support to SPLGuillaume GARDET
Add EXT filesystem support to SPL. Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> [trini: Fix a warning and checkpatch problems] Signed-off-by: Tom Rini <trini@ti.com>
2014-10-27ext4: Use inttypes for printf() stringSimon Glass
On 64-bit platforms (like sandbox) 64-bit integers may be 'long' rather than 'long long'. Use the inttypes header to avoid compiler warnings. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-24cosmetic: replace MIN, MAX with min, maxMasahiro Yamada
The macro MIN, MAX is defined as the aliase of min, max, respectively. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-24kconfig: add blank Kconfig filesMasahiro Yamada
This would be useful to start moving various config options. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-09-16kbuild: force to define __UBOOT__ in all the C sourcesMasahiro Yamada
U-Boot has imported various source files from other projects, mostly Linux. Something like #ifdef __UBOOT__ [ modification for U-Boot ] #else [ original code ] #endif is an often used strategy for clarification of adjusted parts, that is, easier re-sync in future. Instead of defining __UBOOT__ in each source file, passing it from the top Makefile would be easier. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2014-08-25mtd,ubi,ubifs: sync with linux v3.15Heiko Schocher
snyc with linux v3.15: commit 1860e379875dfe7271c649058aeddffe5afd9d0d Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Sun Jun 8 11:19:54 2014 -0700 Linux 3.15 Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Tom Rini <trini@ti.com>
2014-08-25mtd, ubi, ubifs: update for the sync with linux v3.14Heiko Schocher
while playing with the new mtd/ubi/ubifs sync, found some small updates for it: - add del_mtd_partition() to include/linux/mtd/mtd - mtd: add a debug_printf - remove some not used functions Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Tom Rini <trini@ti.com>
2014-08-25mtd, ubi, ubifs: resync with Linux-3.14Heiko Schocher
resync ubi subsystem with linux: commit 455c6fdbd219161bd09b1165f11699d6d73de11c Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Sun Mar 30 20:40:15 2014 -0700 Linux 3.14 A nice side effect of this, is we introduce UBI Fastmap support to U-Boot. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Scott Wood <scottwood@freescale.com> Cc: Joerg Krause <jkrause@posteo.de>
2014-08-25lib, linux: move linux specific defines to linux/compat.hHeiko Schocher
- move linux specific defines from usb and video code into linux/compat.h - move common linux specific defines from include/ubi_uboot.h to linux/compat.h - add for new mtd/ubi/ubifs sync new needed linux specific defines to linux/compat.h Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Anatolij Gustschin <agust@denx.de> [trini: Add spin_lock_irqsave/spin_unlock_irqrestore dummies from usb/lin_gadet_compat.h] Signed-off-by: Tom Rini <trini@ti.com>
2014-08-09fs: implement size/fatsize/ext4sizeStephen Warren
These commands may be used to determine the size of a file without actually reading the whole file content into memory. This may be used to determine if the file will fit into the memory buffer that will contain it. In particular, the DFU code will use it for this purpose in the next commit. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-07-22catch wrong load address passed to fatload / ext2loadPavel Machek
If filename is passed instead of address to ext2load or fatload, u-boot silently accepts that, and uses 0 for load address and default filename from environment. That is confusing, display help instead. Signed-off-by: Pavel Machek <pavel@denx.de>
2014-07-18yaffs2: preprocessor cleanupJeroen Hofstee
Current code uses the preprocessor to change an else case to a statement without any if condition at all. Although this works, change the optional code to return early, so all optional code is contained within a single #ifdef. Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-07-18yaffs2: cosmetic: remove self assignmentsJeroen Hofstee
Remove self assignments which is just dead code to prevent compiler warnings about non used arguments. For u-boot this does not prevent any warning though, on the contrary it actual introduces warnings when compiling with clang. Remove them. Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-06-19fs: ext4: fix writing zero-length filesStephen Warren
ext4fs_allocate_blocks() always allocates at least one block for a file. If the file size is zero, this causes total_remaining_blocks to underflow, which then causes an apparent hang while 2^32 blocks are allocated. To solve this, check that total_remaining_blocks is non-zero as part of the loop condition (i.e. before each loop) rather than at the end of the loop. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-06-11jffs2:jffs2_1pass.c: remove double bracesJeroen Hofstee
Clang interpretes an if condition like  "if ((a = b) == NULL) as it tries to assign a value in a statement. Hence if you do "if ((something)) it warns you that you might be confused. Hence drop the double braces for plane if statements. Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
