CHANGELOG
fs/fat/fat.c
include/configs/MPC8560ADS.h
include/configs/pcs440ep.h
net/eth.c
Fixed some broken instances of "#ifdef CMD_CFG_IDE" too.
Those always evaluated TRUE, and thus were always compiled
even when IDE really wasn't defined/wanted.
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
- Show on the Status LEDs, some States of the board.
- Get the MAC addresses from the EEProm
- use PREBOOT
- use the CF on the board.
- check the U-Boot image in the Flash with a SHA1
checksum.
- use dynamic TLB entries generation for the SDRAM
Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
Some more NAND cleanup and small fixes.
Patch by Patch by Jose Maria (Txema) Lopez, 16 Jan 2006
Patch by Rick Bronson, 15 Jun 2005
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and
BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for
NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is
implemented for these boards.
Insert missing __le32_to_cpu() for filesize in ext2fs_read_file().
Patch by Reinhard Arlt, 30 Dec 2005
Patch by Ladislav Michl, 13 Sep 2005
Patch by Ladislav Michl, 29 Jun 2005
so we can use them to, e.g., check the existence of a file with
"if ls foo; then this; else that; fi" in the hush shell
Patch by Andreas Engel, 16 August 2005
Minor coding style cleanup.
Old, obsolete and duplicated code was cleaned up and replace by the
new partitioning method. There are two possible approaches now:
* define a single, static partition
* use mtdparts command line option and dynamic partitioning
Default is static partitioning.
Patch by Shlomo Kut, 13 Dec 2004
a single #define.
March 13, 2005); new configuration options CONFIG_JFFS2_LZO and
CONFIG_JFFS2_LZARI are added. Both are undefined by default.
(common/cmd_ide.c, common/cmd_reiser.c, common/cmd_scsi.c).
* Enable USB and IDE support for INKA4x0 board
* Patch by Andrew Dyer, 28 February 2005:
fix ext2load passing an incorrect pointer to get_partition_info()
resulting in load failure for devices other than 0
- don't insist on leading '/' for filename in ext2load
- set default partition to useful value (1) in ext2load
* Patch by Andrew Dyer, 08 Jan 2005:
fix wrong return codes in ext2 code
- Added support for both 8 and 16 bit mode access to System ACE CF
through MPU.
- Fixed missing System ACE CF device during get FAT partition info
in fat_register_device function.
- Enabled System ACE CF support on ML300.
* Patch by Sean Chang, 09 Aug 2004:
Synch defines for saveenv and do_saveenv functions so they get
compiled under the same statement.
Using external watchdog for KUP4 boards in mpc8xx/cpu.c;
load_sernum_ethaddr() for KUP4 boards in lib_ppc/board.c;
various changes to KUP4 board specific files
* Fix SL811 USB controller when attached to a USB hub
* Fixes for SL811 USB controller:
- implement workaround for broken memory stick
- improve error handling
* Increase packet send timeout to 10 ms in cpu/mpc8xx/scc.c to better
cope with congested networks.
(JFFS2 speed enhancements) because of using non-public
data (PHYS_FLASH_SECT_SIZE)
* Patch by Travis Sawyer, 23 Apr 2004:
Fix VSC/CIS 8201 phy descrambler interoperability timing due to
errata from Vitesse Semiconductor.
JFFS2 speed enhancements:
- repair header CRC calculation in jffs2_1pass.c
- add eraseblock size to the partition information to skip empty
eraseblocks if we find more then 4k of free space.
- The JFFS2 scanner is now fast enough to remove the spinning wheel
so #ifdef-ed out.
- add watchdog calls in long running loops
* Patch by Philippe Robin, 22 Apr 2004:
Fix ethernet configuration for "versatile" board
* Patch by Kshitij Gupta, 21 Apr 2004:
Remove busy loop and use MPU timer fr usleep() on OMAP1510/1610 boards
* Patch by Steven Scholz, 24 Feb 2004:
Fix a bug in AT91RM9200 ethernet driver:
The MII interface is now initialized before accessing the PHY.
* Cleanup PCI ID's
- add support for microblaze processors
- add support for AtmarkTechno "suzaku" board
* Configure PPChameleon board to use JFFS2 NAND support.
* Added support for JFFS2 filesystem (read-only) on top of NAND flash
- add auto-complete support to the U-Boot CLI
- add support for NETTA and NETPHONE boards; fix NETVIA board
* Patch by Yuli Barcohen, 28 Mar 2004:
- Add support for MPC8272 family including MPC8247/8248/8271/8272
- Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS)
- Change configuration method for MPC8260ADS family
Add Reiserfs support
* Patch by Hinko Kocevar, 20 Mar 2004
- Add auto-release for SMSC LAN91c111 driver
- Add save/restore of PTR and PNR regs as suggested in datasheet
- show PCI clock frequency on MPC8260 systems
- add FCC_PSMR_RMII flag for HiP7 processors
- in do_jffs2_fsload(), take load address from load_addr if not set
explicit, update load_addr otherwise
- replaced printf by putc/puts when no formatting is needed
(smaller code size, faster execution)
- Fix Gigabit Ethernet support for 440GX
- Add Gigabit Ethernet Support to MII PHY utilities
* Patch by Brad Kemp, 12 Mar 2004:
Fixes for drivers/cfi_flash.c:
- Better support for x8/x16 implementations
- Added failure for AMD chips attempting to use CFG_FLASH_USE_BUFFER_WRITE
- Added defines for AMD command and address constants
* Patch by Leon Kukovec, 12 Mar 2004:
Fix get_dentfromdir() to correctly handle deleted dentries
* Patch by George G. Davis, 11 Mar 2004:
Remove hard coded network settings in TI OMAP1610 H2
default board config
add support for ADS GraphicsClient+ board.
