path: root/fs
2008-08-14Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-08-13drivers/mtd/nand: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-08-12moving files from yaffs2/direct/ to yaffs2/ and deleting all symlinksWilliam Juul
Signed-off-by: William Juul <william.juul@tandberg.com>
2008-08-12Clean out unneeded filesWilliam Juul
2008-08-12Create symlinks from yaffs2/direct to yaffs2William Juul
2008-08-12Incorporate yaffs2 into U-bootWilliam Juul
To use YAFFS2 define CONFIG_YAFFS2 Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12YAFFS2 importWilliam Juul
Direct import of yaffs as a tarball as of 20071113 from their public CVS-web at http://www.aleph1.co.uk/cgi-bin/viewcvs.cgi/yaffs2/ The code can also be imported on the command line with: export CVSROOT=:pserver:anonymous@cvs.aleph1.co.uk:/home/aleph1/cvs cvs logon (Hit return when asked for a password) cvs checkout yaffs2 Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Stig Olsen <stig.olsen@tandberg.com>
2008-07-14Fix printf() format issues with sizeof_t types by using %zuWolfgang Denk
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-07-13Fix some more printf() format problems.Wolfgang Denk
2008-07-13Fix some more printf() format issues.Jean-Christophe PLAGNIOL-VILLARD
2008-06-29jffs2_1pass.c: add watchdog supportStuart Wood
Signed-off-by: Stuart Wood <stuart.wood@labxtechnologies.com>
2008-05-28Cleanup nand_info[] declaration.Stelian Pop
The nand_info array is declared as extern in several .c files. Those days, nand.h contains a reference to the array, so there is no need to declare it elsewhere. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-04-28jffs2_1pass.c: fix incompatible pointer type warningWolfgang Denk
2008-03-26Merge branch 'new-image' of git://www.denx.de/git/u-boot-testingBartlomiej Sieka
Conflicts: common/cmd_bootm.c cpu/mpc8xx/cpu.c Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-03-16cramfs: Fix ifdefJean-Christophe PLAGNIOL-VILLARD
2008-03-12Merge branch 'master' of git://www.denx.de/git/u-boot into new-imageMarian Balakowicz
2008-03-03Fix checking fat32 cluster size.michael
This fixes the cluster size tests in the FAT32 file system. The current implementation of VFAT support doesn't work if the referred cluster has an offset > 16bit representation, causing "fatload" and "fatls" commands etc. to fail. Signed-off-by: michael trimarchi <trimarchi@gandalf.sssup.it>
2008-03-02fs: Fix ext2 read issueDave Liu
The ext2 aligned process will corrupt the key data struct, the patch fix this. Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-02-21Merge branch 'master' of /home/git/u-bootMarian Balakowicz
2008-02-14Fix CONFIG_MMC usage in fat codeAndy Fleming
A #if statement in fat.c depended on CONFIG_MMC, instead of defined(CONFIG_MMC). This meant CONFIG_MMC needed to be defined as "1" rather than just defined. Now it's better. Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-02-07[new uImage] Move gunzip() common code to common/gunzip.cMarian Balakowicz
Move gunzip(), zalloc() and zfree() to a separate file. Share zalloc() and zfree() with cramfs uncompress routine. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-01-09Fix my own merge stupidityAndy Fleming
Way back in August I merged Heiko's patch: 566a494f592: [PCS440EP] upgrade the PCS440EP board with Jon's CONFIG_COMMANDS patches. This was done in commit: 6bf6f114dcdd97ec3f80c2761ed40e31229d6b78 However, in the process, I left out some of Heiko's good changes. Now Heiko's and Jon's patches are properly merged in fat_register_device() Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-01-09fix comments with new drivers organizationMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2008-01-09Fix building with CRAMFS but not JFFS2 supportHarald Welte
Signed-off-by: Harald Welte <laforge@openmoko.org>
2008-01-09Fix memset bug in ext2fs_read_file()Wolfgang Denk
ext2fs_read_file() had the function arguments swapped. Pointed out by Mike Montour, 19 Dec 2007 22:34:25 -0800 Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-11-15Build: split COBJS value into multiple linesGrant Likely
This change is in preparation for condtitionial compile support in the build system. By spliting them all into seperate lines now, subsequent patches that change 'COBJS-y += ' into 'COBJS-$(CONFIG_<blah>) += ' will be less invasive and easier to review Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-09-16[FIX] remove files form repositoryMichal Simek
2007-09-15Synchronize with U-BOOT mainlineMichal Simek
2007-08-15[FIX] Correction command definitionMichal Simek
2007-08-07Merge git://www.denx.de/git/u-bootMichal Simek
2007-08-07Fix missing brace error in fs/fat/fat.cWolfgang Denk
[pointed out by Roderik Wildenburg] Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-08-06[FIX] Fix romfs codeMichal Simek
2007-08-03Merge branch 'testing' into workingAndy Fleming
Conflicts: CHANGELOG fs/fat/fat.c include/configs/MPC8560ADS.h include/configs/pcs440ep.h net/eth.c
2007-07-14[FS] Added support for ROMFSMichal Simek
2007-07-10fs/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09fs/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-05Fixing some typos etc. introduced mainly by cfg patches.Wolfgang Denk
2007-07-04fs/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-06-22[PCS440EP] upgrade the PCS440EP board:Heiko Schocher
- Show on the Status LEDs, some States of the board. - Get the MAC addresses from the EEProm - use PREBOOT - use the CF on the board. - check the U-Boot image in the Flash with a SHA1 checksum. - use dynamic TLB entries generation for the SDRAM Signed-off-by: Heiko Schocher <hs@denx.de>
2007-05-18Reduce line lengths to 80 characters max.Peter Pearse
2007-05-18Merge with git://www.denx.de/git/u-boot.gitPeter Pearse
2007-05-09New board SMN42 branchPeter Pearse
2007-04-24[PATCH] MTD partition support, JFFS2 supportMichal Simek
2006-04-08Fix JFFS2 support for legacy NAND driver.Marian Balakowicz
Some more NAND cleanup and small fixes.
2006-03-17Add support for Lite5200B board.Wolfgang Denk
Patch by Patch by Jose Maria (Txema) Lopez, 16 Jan 2006
2006-03-12Add crc of data to jffs2 (in jffs2_1pass_build_lists()).Wolfgang Denk
Patch by Rick Bronson, 15 Jun 2005
2006-03-05Re-factoring the legacy NAND code (legacy NAND now only in board-specificBartlomiej Sieka
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards.
