path: root/fs
2013-07-22ext4fs: le32_to_cpu() used on a 16-bit fieldRommel Custodio
Fix reading ext4_extent_header struture on BE machines. Some 16 bit fields where converted to 32 bit fields, due to the byte swap on BE machines the containing value was corrupted. Therefore reading ext4 filesystems on BE machines where broken before. Signed-off-by: Rommel Custodio <sessyargc+uboot@gmail.com> [sent via git-send-email; rework commit message] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Tested-by: Lukasz Majewski <l.majewski@samsung.com>
2013-07-15Fix ext2/ext4 filesystem accesses beyond 2TiBFrederic Leroy
With CONFIG_SYS_64BIT_LBA, lbaint_t gets defined as a 64-bit type, which is required to represent block numbers for storage devices that exceed 2TiB (the block size usually is 512B), e.g. recent hard drives We now use lbaint_t for partition offset to reflect the lbaint_t change, and access partitions beyond or crossing the 2.1TiB limit. This required changes to signature of ext4fs_devread(), and type of all variables relatives to block sector. ext2/ext4 fs uses logical block represented by a 32 bit value. Logical block is a multiple of device block sector. To avoid overflow problem when calling ext4fs_devread(), we need to cast the sector parameter. Signed-off-by: Frédéric Leroy <fredo@starox.org>
2013-07-15cramfs: fix bug for wrong filename comparisonHolger Brunck
"cramfsload uImage_1" succeeds even though the actual file is named "uImage". Fix file name comparison when one name is the prefix of the other. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Wolfgang Denk <wd@denx.de> cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-05-31Merge branch 'master' of git://git.denx.de/u-boot-nand-flashTom Rini
2013-05-31mtd: resync with Linux-3.7.1Sergey Lapin
This patch is essentially an update of u-boot MTD subsystem to the state of Linux-3.7.1 with exclusion of some bits: - the update is concentrated on NAND, no onenand or CFI/NOR/SPI flashes interfaces are updated EXCEPT for API changes. - new large NAND chips support is there, though some updates have got in Linux-3.8.-rc1, (which will follow on top of this patch). To produce this update I used tag v3.7.1 of linux-stable repository. The update was made using application of relevant patches, with changes relevant to U-Boot-only stuff sticked together to keep bisectability. Then all changes were grouped together to this patch. Signed-off-by: Sergey Lapin <slapin@ossfans.org> [scottwood@freescale.com: some eccstrength and build fixes] Signed-off-by: Scott Wood <scottwood@freescale.com>
2013-05-24ext4: assign get_fs()->dev_desc before using itStephen Warren
Commit 50ce4c0 "fs/ext4: Support device block sizes != 512 bytes" modified ext4fs_set_blk_dev() to calculate total_sect based on get_fs()->dev_desc->log2blksz rather than SECTOR_SIZE. However, this value wasn't yet assigned. Move the assignment earlier so the code doesn't crash or hang. Cc: Egbert Eich <eich@suse.com> Tested-by: Tom Rini <trini@ti.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-05-10fs/ext4: Support device block sizes != 512 bytesEgbert Eich
The 512 byte block size was hard coded in the ext4 file systems. Large harddisks today support bigger block sizes typically 4096 bytes. This patch removes this limitation. Signed-off-by: Egbert Eich <eich@suse.com>
2013-05-01fs/fat: Don't multiply fatsize with sector sizeEgbert Eich
Bugfix: Here at this place we need the fat size in sectors not bytes. This was found during code review when adding support for storage devices with blocksizes != 512. Signed-off-by: Egbert Eich <eich@suse.com>
2013-05-01sandbox: fs: Add support for saving files to host filesystemSimon Glass
This allows write of files from the host filesystem in sandbox. There is currently no concept of overwriting the file and removing its existing contents - all writing is done on top of what is there. This means that writing 10 bytes to the start of a 1KB file will only update those 10 bytes, not truncate the file to 10 byte slong. If the file does not exist it is created. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-01fs: Add support for saving data to filesystemsSimon Glass
Add a new method for saving that filesystems can implement. This mirrors the existing load method. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-04-11ubi: ubifs: Turn off verbose printsJoe Hershberger
The prints are out of control. SILENCE! Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2013-04-01Consolidate bool typeYork Sun
'bool' is defined in random places. This patch consolidates them into a single header file include/linux/types.h, using stdbool.h introduced in C99. All other #define, typedef and enum are removed. They are all consistent with true = 1, false = 0. Replace FALSE, False with false. Replace TRUE, True with true. Skip *.py, *.php, lib/* files. Signed-off-by: York Sun <yorksun@freescale.com>
2013-03-04ubifs: Allow ubifsmount volume reference by numberJoe Hershberger
UBI can mount volumes by name or number The current code forces you to name the volume by prepending every name with "ubi:". >From fs/ubifs/super.c * There are several ways to specify UBI volumes when mounting UBIFS: * o ubiX_Y - UBI device number X, volume Y; * o ubiY - UBI device number 0, volume Y; * o ubiX:NAME - mount UBI device X, volume with name NAME; * o ubi:NAME - mount UBI device 0, volume with name NAME. Now any name passed in any of the above forms are allowed. Also update the configs that referenced ubifsmount. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2013-03-04sandbox: Add host filesystemSimon Glass
This allows reading of files from the host filesystem in sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-04fs: Move ls and read methods into ext4, fatSimon Glass
It doesn't make a lot of sense to have these methods in fs.c. They are filesystem-specific, not generic code. Add each to the relevant filesystem and remove the associated #ifdefs in fs.c. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-04fs: Use map_sysmem() on readSimon Glass
This allows us to use filesystems on sandbox. It has no effect on other architectures. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-04fs: Tell probe functions where to put their resultsSimon Glass
Rather than rely on global variables for the probe functions, pass in the information that we need filled in. This allows us to potentially keep the variables private to fs.c in the future, and the meaning of the probe function is clearer. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-04fs: Use filesystem methods instead of switch()Simon Glass
We can use the available methods and avoid using switch(). When the filesystem is not supported, we fall through to the 'unsupported' methods: fs_probe_unsupported() prints an error, so the others do not need to. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-04fs: Fully populate the filesystem method structSimon Glass
There is a structure in fs.c with just a probe method. By adding methods for other operations, we can avoid lots of #ifdefs and switch()s. As a first step, create the structure ready for use. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-04ext4: Split write support into its own fileSimon Glass
This code seems to be entirely othogonal, so remove the #ifdef and put the condition in the Makefile instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-28fs: Use new numeric setenv functionsSimon Glass
Use setenv_ulong(), setenv_hex() and setenv_addr() in fs/ Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04FAT: remove ifdefs to make the code more readableRichard Genoud
ifdefs in the code are making it harder to read. The use of simple if(vfat_enabled) makes no more code and is cleaner. (the code is discarded by the compiler instead of the preprocessor.) NB: if -O0 is used, the code won't be discarded and bonus, now the code compiles even if CONFIG_SUPPORT_VFAT is not defined. Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
2013-02-04FAT: use toupper/tolower instead of recoding themRichard Genoud
toupper/tolower function are already declared, so use them. Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2013-01-31vfat: Fix mkcksum argument sizesMarek Vasut
In case a function argument is known/fixed size array in C, the argument is still decoyed as pointer instead ( T f(U n[k]) ~= T fn(U *n) ) and therefore calling sizeof on the function argument will result in the size of the pointer, not the size of the array. The VFAT code contains such a bug, this patch fixes it. Reported-by: Aaron Williams <Aaron.Williams@cavium.com> Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <tom.rini@gmail.com> Cc: Aaron Williams <Aaron.Williams@cavium.com> Tested-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-07fs:ext4:write: Initialize cache aligned filename bufferŁukasz Majewski
The filename buffer is allocated dynamically. It must be cache aligned. Moreover, it is necessary to erase its content before we use it for file name operations. This prevents from corruption of written file names. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-12-07fs:ext4:fix: Code refactoring to suppress compiler warningsŁukasz Majewski
Several fixes to suppress compiler's (eldk-5.[12].x gcc 4.6) warning [-Wunused-but-set-variable] Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-12-07fs:ext4:write: Store block device descriptor in file system structureŁukasz Majewski
The device block descriptor (block_dev_desc_t) )shall be stored at ext4 early code (at ext4fs_set_blk_dev in this case) to be available for latter use (like put_ext4()). Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-12-07fs:ext4:write: Add lldiv and do_div to perform 64-32 bits divisionŁukasz Majewski
The ext4write code has been using direct calls to 64-32 division (/ and %). Officially supported u-boot toolchains (eldk-5.[12].x) generate calls to __aeabi_uldivmod(), which is niether defined in the toolchain libs nor u-boot source tree. Due to that, when the ext4write command has been executed, "undefined instruction" execption was generated (since the __aeabi_uldivmod() is not provided). To fix this error, lldiv() for division and do_div() for modulo have been used. Those two functions are recommended for performing 64-32 bit number division in u-boot. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-12-06cbfs: Remove mention of CREDITS filesSimon Glass
As requested by Wolfgang, remove references to CREDITS in the CBFS files. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-14fs/fs.c: do_fsload: measure throughputAndreas Bießmann
This patch adds time measurement and throughput calculation for all supported load commands. The output of ext2load changes from ---8<--- 1830666 bytes read --->8--- to ---8<--- 1830666 bytes read in 237 ms (7.4 MiB/s) --->8--- Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> [agust: rebased and revised commit log] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-11-14fs: zfs: fix illegal use of fpAlejandro Mery
the upcoming sunxi (allwinner a10/a13) platform enables zfs by default, and using linaro's hf -msoft-float makes the build fail because this u64 division. Signed-off-by: Alejandro Mery <amery@geeks.cl> Acked-by: Stefan Roese <sr@denx.de>
2012-11-04include/linux/byteorder: import latest endian definitions from linuxKim Phillips
u-boot's byteorder headers did not contain endianness attributions for use with sparse, causing a lot of false positives. Import the kernel's latest definitions, and enable them by including compiler.h and types.h. They come with 'const' added for some swab functions, so fix those up, too: include/linux/byteorder/big_endian.h:46:2: warning: passing argument 1 of '__swab64p' discards 'const' qualifier from pointer target type [enabled by default] Also, note: u-boot's historic __BYTE_ORDER definition has been preserved (for the time being at least). We also remove ad-hoc barrier() definitions, since we're including compiler.h in files that hadn't in the past: macb.c:54:0: warning: "barrier" redefined [enabled by default] In addition, including compiler.h in byteorder changes the 'noinline' definition to expand to __attribute__((noinline)). This fixes arch/powerpc/lib/bootm.c: bootm.c:329:16: error: attribute '__attribute__': unknown attribute bootm.c:329:16: error: expected ')' before '__attribute__' bootm.c:329:25: error: expected identifier or '(' before ')' token powerpc sparse builds yield: include/common.h:356:22: error: marked inline, but without a definition the unknown-reason inlining without a definition is considered obsolete given it was part of the 2002 initial commit, and no arm version was 'fixed.' also fixed: ydirectenv.h:60:0: warning: "inline" redefined [enabled by default] and: Configuring for devconcenter - Board: intip, Options: DEVCONCENTER make[1]: *** [4xx_ibm_ddr2_autocalib.o] Error 1 make: *** [arch/powerpc/cpu/ppc4xx/libppc4xx.o] Error 2 powerpc-fsl-linux-size: './u-boot': No such file 4xx_ibm_ddr2_autocalib.c: In function 'DQS_autocalibration': include/asm/ppc4xx-sdram.h:1407:13: sorry, unimplemented: inlining failed in call to 'ppc4xx_ibm_ddr2_register_dump': function body not available 4xx_ibm_ddr2_autocalib.c:1243:32: sorry, unimplemented: called from here and: In file included from crc32.c:50:0: crc32table.h:4:1: warning: implicit declaration of function '___constant_swab32' [-Wimplicit-function-declaration] crc32table.h:4:1: error: initializer element is not constant crc32table.h:4:1: error: (near initialization for 'crc32table_le[0]') Signed-off-by: Kim Phillips <kim.phillips@freescale.com> [trini: Remove '#endif' in include/common.h around setenv portion] Signed-off-by: Tom Rini <trini@ti.com>
2012-11-04fs: rename fsload command to loadStephen Warren
When the generic filesystem load command "fsload" was written, I felt that "load" was too generic of a name for it, since many other similar commands already existed. However, it turns out that there is already an "fsload" command, so that name cannot be used. Rename the new "fsload" to plain "load" to avoid the conflict. At least anyone who's used a Basic interpreter should feel familiar with the name! Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-11-04fs: fix number base behaviour change in fatload/ext*loadStephen Warren
Commit 045fa1e "fs: add filesystem switch libary, implement ls and fsload commands" unified the implementation of fatload and ext*load with the new command fsload. However, this altered the interpretation of command-line numbers from always being base-16, to requiring a "0x" prefix for base-16 numbers. Enhance do_fsload() to allow commands to specify which base to use. Use base 0, thus requiring a "0x" prefix for the new fsload command. This feels much cleaner than assuming base 16. Use base 16 for the pre-existing fatload and ext*load to prevent a change in behaviour. Use base 16 exclusively for the loadaddr environment variable, since that variable is interpreted in multiple places, so we don't want the behaviour to change. Update command help text to make it clear where numbers are assumed to be hex, and where an explicit "0x" prefix is required. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2012-11-04fs: fix do_fsload() handling of optional argumentsStephen Warren
Most arguments to the shell command do_fsload() implements are optional. Fix the minimum argc check to respect that. Cater for the situation where argv[2] is not provided. Enhance both do_fsload() and do_ls() to check the maximum number of arguments too. While this check would typically be implemented via U_BOOT_CMD()'s max_args parameter, if these functions are called directly, then that check won't exist. Finally, alter do_ls() to check (argc >= 4) rather than (argc == 4) so that if the function is enhanced to allow extra arguments in the future, this test won't need to be changed at that time. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2012-11-02ZFS: Fix compile warning in fs/zfs/zfs.c (GCC 4.6.4 from ELDK 5.2.1)Stefan Roese
This patch fixes the following compile warning: zfs.c:2006:1: warning: 'zfs_label' defined but not used [-Wunused-function] zfs.c:2029:1: warning: 'zfs_uuid' defined but not used [-Wunused-function] Signed-off-by: Stefan Roese <sr@denx.de> Cc: Jorgen Lundman <lundman@lundman.net>
2012-11-02fs: handle CONFIG_NEEDS_MANUAL_RELOCStephen Warren
Without this, fstypes[].probe points at the wrong place, so calling the function results in undefined behaviour. Signed-off-by: Stephen Warren <swarren@nvidia.com> Tested-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-10-29fs: add filesystem switch libary, implement ls and fsload commandsStephen Warren
Implement "ls" and "fsload" commands that act like {fat,ext2}{ls,load}, and transparently handle either file-system. This scheme could easily be extended to other filesystem types; I only didn't do it for zfs because I don't have any filesystems of that type to test with. Replace the implementation of {fat,ext[24]}{ls,load} with this new code too. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-10-29fs: separate CONFIG_FS_{FAT, EXT4} from CONFIG_CMD_{FAT, EXT*}Stephen Warren
This makes the FAT and ext4 filesystem implementations build if CONFIG_FS_{FAT,EXT4} are defined, rather than basing the build on whether CONFIG_CMD_{FAT,EXT*} are defined. This will allow the filesystems to be built separately from the filesystem-specific commands that use them. This paves the way for the creation of filesystem-generic commands that used the filesystems, without requiring the filesystem- specific commands. Minor documentation changes are made for this change. The new config options are automatically selected by the old config options to retain backwards-compatibility. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2012-10-29fs: delete unused MakefileStephen Warren
fs/Makefile is unused. The top-level Makefile sets LIBS-y += fs/xxx and hence causes make to directly descend two directory levels into each individual filesystem, and it never descends into fs/ itself. So, delete this useless file. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-10-25FAT: implement fat_set_blk_dev(), convert cmd_fat.cStephen Warren
This makes the FAT filesystem API more consistent with other block-based filesystems. If in the future standard multi-filesystem commands such as "ls" or "load" are implemented, having FAT work the same way as other filesystems will be necessary. Convert cmd_fat.c to the new API, so the code looks more like other files implementing the same commands for other filesystems. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2012-10-25FAT: initialize all fields in cur_part_info, simplify initStephen Warren
cur_part_info.{name,type} are strings. So, we don't need to memset() the entire thing, just put the NULL-termination in the first byte. Add missing initialization of the bootable and uuid fields. None of these fields are actually used by fat.c. However, since it stores the entire disk_partition_t, we should make sure that all fields are valid. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2012-10-25FAT: remove cur_part_nrStephen Warren
A future patch will implement the more standard filesystem API fat_set_blk_dev(). This API has no way to know which partition number the partition represents. Equally, future DM rework will make the concept of partition number harder to pass around. So, simply remove cur_part_nr from fat.c; its only use is in a diagnostic printf, and the context where it's printed should make it obvious which partition is referred to anyway (since the partition ID would come from the user command-line that caused it). Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2012-10-22fs: Add a Coreboot Filesystem (CBFS) driver and commandsGabe Black
This change adds CBFS support and some commands to use it to u-boot. These commands are: cbfsinit - Initialize CBFS support and pull all metadata into RAM. The end of the ROM is an optional parameter which defaults to the standard 0xffffffff and can be used to support multiple CBFSes in a system. The last one set up with cbfsinit is the one that will be used. cbfsinfo - Print information from the CBFS header. cbfsls - Print out the size, type, and name of all the files in the current CBFS. Recognized types are translated into symbolic names. cbfsload - Load a file from CBFS into memory. Like the similar command for fat filesystems, you can optionally provide a maximum size. Support for CBFS is compiled in when the CONFIG_CMD_CBFS option is specified. The CBFS driver can also be used programmatically from within u-boot. If u-boot needs something out of CBFS very early before the heap is configured, it won't be able to use the normal CBFS support which caches some information in memory it allocates from the heap. The cbfs_file_find_uncached function searches a CBFS instance without touching the heap. Signed-off-by: Gabe Black <gabeblack@google.com> Signed-off-by: Stefan Reinauer <reinauer@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-17fs: fat: Fix mkcksum() function parametersMarek Vasut
The mkcksum() function now takes one parameter, the pointer to 11-byte wide character array, which it then operates on. Currently, the function is wrongly passed (dir_entry)->name, which is only 8-byte wide character array. Though by further inspecting the dir_entry structure, it can be noticed that the name[8] entry is immediatelly followed by ext[3] entry. Thus, name[8] and ext[3] in the dir_entry structure actually work as this 11-byte wide array since they're placed right next to each other by current compiler behavior. Depending on this is obviously wrong, thus fix this by correctly passing both (dir_entry)->name and (dir_entry)->ext to the mkcksum() function and adjust the function appropriately. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com>
2012-10-15ARM: prevent misaligned array initsAlbert ARIBAUD
Under option -munaligned-access, gcc can perform local char or 16-bit array initializations using misaligned native accesses which will throw a data abort exception. Fix files where these array initializations were unneeded, and for files known to contain such initializations, enforce gcc option -mno-unaligned-access. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> [trini: Switch to usign call cc-option for -mno-unaligned-access as Albert had done previously as that's really correct] Signed-off-by: Tom Rini <trini@ti.com>
2012-10-08yaffs2: Fix GCC 4.6 compile warningsAnatolij Gustschin
Fix: yaffs_guts.c: In function 'yaffs_check_chunk_erased': yaffs_guts.c:324:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_verify_chunk_written': yaffs_guts.c:352:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_grab_chunk_cache': yaffs_guts.c:1488:6: warning: variable 'pushout' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_check_obj_details_loaded': yaffs_guts.c:3180:6: warning: variable 'alloc_failed' set but not used [-Wunused-but-set-variable] yaffs_guts.c:3179:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_update_oh': yaffs_guts.c:3288:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_get_obj_name': yaffs_guts.c:4447:7: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_summary.c: In function 'yaffs_summary_read': yaffs_summary.c:194:6: warning: variable 'sum_tags_bytes' set but not used [-Wunused-but-set-variable] yaffs_verify.c: In function 'yaffs_verify_file': yaffs_verify.c:227:6: warning: variable 'actual_depth' set but not used [-Wunused-but-set-variable] yaffs_yaffs1.c: In function 'yaffs1_scan': yaffs_yaffs1.c:26:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_yaffs2.c: In function 'yaffs2_scan_chunk': yaffs_yaffs2.c:949:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_yaffs2.c: In function 'yaffs2_scan_backwards': yaffs_yaffs2.c:1352:6: warning: variable 'deleted' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Charles Manning <cdhmanning@gmail.com> Tested-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-08FAT: check for partition 0 not 1 for whole-disk fsStephen Warren
The recent switch to use get_device_and_partition() from do_fat_ls() broke the ability to access a FAT filesystem directly on a whole device; FAT only works within a partition on a device. This change makes e.g. "fatls mmc 0:0" work; explicitly requesting partition ID 0 is something that get_device_and_partition() fully supports. However, fat_register_device() expects partition ID 1 to be used in the full-disk case; partition ID 1 was previously implicitly specified when the user didn't actually specify a partition ID. Update fat_register_device() to expect the correct ID. This change does imply that if a user explicitly executes "fatls mmc 0:1" then this will fail, and may be a change in behaviour. Note that this still prevents "fatls mmc 0:auto" from working. The next patch will fix that. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-10-03ext4: Rename block group descriptor table from gd to bgdSimon Glass
On x86 machines gd is unfortunately a #define, so we should avoid using gd for anything. This patch changes uses of gd to bgd so that ext4fs can be used on x86. A better fix would be to remove the #define in x86, but I'm not sure how to do that. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-09-26FAT: Make it possible to read from any file positionBenoît Thébaudeau
When storage devices contain files larger than the embedded RAM, it is useful to be able to read these files by chunks, e.g. for a software update to the embedded NAND Flash from an external storage device (USB stick, SD card, etc.). Hence, this patch makes it possible by adding a new FAT API to read files from a given position. This patch also adds this feature to the fatload command. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
