In SquashFS, the contents of a directory is stored by
squashfs_directory_entry structures which contain the file's name, inode
and position within the filesystem.
The inode number is not stored directly; instead each directory has one
or more headers which set a base inode number, and files store the
offset from that to the file's inode number.
In mksquashfs, each inode is allocated a number in the same order as
they are written to the directory table; thus the offset from the
header's base inode number to the file's inode number is usually
positive.
Hardlinks are simply stored with two directory entries referencing the
same file. This means the second entry will thus have an inode number
much lower than the surrounding files. Since the header's base inode
number comes from the first entry that uses the header, this delta will
usually be negative.
Previously, U-Boot's squashfs_directory_entry.inode_offset field was
declared as an unsigned value. Thus when a negative value was found, it
would either resolve to an invalid inode number or to that of an
unrelated file.
A squashfs image to test this can be created like so:
echo hi > sqfs_test_files/001-root-file
mkdir sqfs_test_files/002-subdir
touch sqfs_test_files/002-subdir/003-file
ln sqfs_test_files/{001-root-file,002-subdir/004-link}
mksquashfs sqfs_test_files/ test.sqfs -noappend
Note that squashfs sorts the files ASCIIbetacally, so we can use the
names to control the order they appear in. The ordering is important -
the first reference to the file must have a lower inode number than the
directory in which the second reference resides, and the second
reference cannot be the first file in the directory.
Listing this sample image in U-Boot results in:
=> sqfsls virtio 2 002-subdir
0 003-file
Inode not found.
0 004-link
Signed-off-by: Campbell Suter <campbell@snapit.group>
Reviewed-by: Miquel Raynal <miquel.raynal@bootlin.com>
It is a pain to have to specify the value 16 in each call. Add a new
hextoul() function and update the code to use it.
Add a proper comment to simple_strtoul() while we are here.
Since the ACPI-generation code makes use of UUIDs we typically need to
enabled UUID support for it to build. Add a new Kconfig condition.
Use it for BTRFS also.
Add a check that the offset is within the allowed range.
Reported-by: Coverity (CID: 331155)
When reading a directory in the UEFI file system we have to return file
attributes and timestamps. Copy this data to the directory entry structure.
The fragmented files were not correctly read because of two issues:
- The squashfs_file_info struct has a field named 'comp', which tells if
the file's fragment is compressed or not. This field was always set to
'true' in sqfs_get_regfile_info and sqfs_get_lregfile_info. It should
actually take sqfs_frag_lookup's return value. This patch addresses
these two assignments.
- In sqfs_read, the fragments (compressed or not) were copied to the
output buffer through a for loop which was reading data at the wrong
offset. Replace these loops by equivalent calls to memcpy, with the
right parameters.
I tested this patch by comparing the MD5 checksum of a few fragmented
files with the respective md5sum output in sandbox, considering both
compressed and uncompressed fragments.
Signed-off-by: Joao Marcos Costa <jmcosta944@gmail.com>
Tested-by: Richard Genoud <richard.genoud@posteo.net>
The superblock buffer must be cache aligned, since it might be used
in DMA context, allocate it using ALLOC_CACHE_ALIGN_BUFFER() just
like it was done in btrfs_read_superblock() and read_tree_node().
This fixes this output on boot and non-working btrfs on iMX53:
CACHE: Misaligned operation at range [ced299d0, ced2a9d0]
Cc: Marek Behún <marek.behun@nic.cz>
Cc: Qu Wenruo <wqu@suse.com>
Reviewed-by: Marek Behún <marek.behun@nic.cz>
When reading directories the UEFI sub-system must supply file attributes
and timestamps. These fields will have to be added to struct fs_dirent.
SquashFS should not fill these fields with random data. Ensure that they
are zeroed out.
There are some cases where decompressed sectors can have padding zeros.
In kernel code, we have lines to address such situation:
* btrfs_getblock is doing a zero on the tail of the page too,
* but this will cover anything missing from the decompressed
* data.
if (bytes < destlen)
memset(kaddr+bytes, 0, destlen-bytes);
kunmap_local(kaddr);
But not in U-boot code, thus we have some reports of U-boot failed to
read compressed files in btrfs.
Fix it by doing the same thing of the kernel, for both inline and
regular compressed extents.
Reported-by: Matwey Kornilov <matwey.kornilov@gmail.com>
Link: https://bugzilla.suse.com/show_bug.cgi?id=1183717
Fixes: a26a6bedafcf ("fs: btrfs: Introduce btrfs_read_extent_inline() and btrfs_read_extent_reg()")
Signed-off-by: Qu Wenruo <wqu@suse.com>
This allows using dev#partlabel syntax.
Signed-off-by: Sean Anderson <sean.anderson@seco.com>
Up to now file_fat_detectfs() did not detect some interface types like
EFI, HOST, VIRTIO.
Avoid duplicate code by calling blk_get_if_type_name().
The interface type now will be shown in lower case to match all other use
cases.
The function jffs2_1pass_read_inode() was discarding the summary
inodes and dirent because the value in datacrc flag wasn't
initialized in function jffs2_sum_process_sum_data().
This fix initializes the status of all summary records to indicate
that the CRC needs to be verified when they are loaded.
Before this fix, the behaviors produced by the undefined value of
datacrc was:
- Summary's registries were discarded when 'b->datacrc' is equal
as 'CRC_BAD'.
- Summary's registries were not checked when b->datacrc differs of
'CRC_BAD' and 'CRC_UNKNOWN'
So, almost all of the time the crc just isn't checked, and in some
cases the registries are discarded.
Signed-off-by: Wagner Popov dos Santos <wpopov@gmail.com>
Fixes address violation in functions read_nand_cached() and
read_onenand_cached(). This happens because these functions
try to read a fixed amount
of data even when the offset+length
is above the nand's limit.
The results of malloc() are a void * and so this cast is unnecessary. Drop
it.
CBFS now supports compressed filed. Add support for reading this
information so that the correct decompression can be applied. The
decompression itself is not implemented in CBFS.
In file_cbfs_next_file() there is a lot of complicated code to move to
the next file. Use the ALIGN() macros to simplify this.
The file_cbfs_next_file() function is already fairly long. Before
expanding it further, move the core part into a separate function.
The file traversal functions currently use a single global CBFS. In some
cases we need to access multiple CBFSs to obtain different files. Add new
functions to support this.
In some cases CBFS does not start with a header but is just a collection
of files. It is possible to support this so long as the size of the CBFS
is provided.
Update the cbfs_init_mem() function to support this.
Rename this variable since there is no need to distinguish it from an old
node.
CBFS now supports attributes for things that cannot fit in the header as
originally conceived. Add the structures for these.
Also rename attributes_offset to something shorter, to ease code
readability.
Commit 401d1c4f5d2d29c4bc4beaec95402ca23eb63295 ("common: Drop
asm/global_data.h from common header") broke compilation of squashfs
filesystem when CONFIG_CMD_SQUASHFS=y is enabled.
Compilation is failing on error:
aarch64-linux-gnu-ld.bfd: u-boot/fs/squashfs/sqfs_inode.c:121: undefined reference to `le32_to_cpu'
Fixes: 401d1c4f5d2d29c4bc4beaec95402ca23eb63295 ("common: Drop asm/global_data.h from common header")
Suggested-by: Tom Rini <trini@konsulko.com>
Signed-off-by: Pali Rohár <pali@kernel.org>
When the btrfs_read_fs_root() function is searching a ROOT_ITEM with
location key offset other than -1, it currently fails via BUG_ON.
The offset can have other value than -1, though. This can happen for
example if a subvolume is renamed:
$ btrfs subvolume create X && sync
Create subvolume './X'
$ btrfs inspect-internal dump-tree /dev/root | grep -B 2 'name: X$
location key (270 ROOT_ITEM 18446744073709551615) type DIR
transid 283 data_len 0 name_len 1
$ mv X Y && sync
$ btrfs inspect-internal dump-tree /dev/root | grep -B 2 'name: Y$
location key (270 ROOT_ITEM 0) type DIR
transid 285 data_len 0 name_len 1
As can be seen the offset changed from -1ULL to 0.
Do not fail in this case.
Signed-off-by: Marek Behún <marek.behun@nic.cz>
Cc: David Sterba <dsterba@suse.com>
Since commit 325dd1f642dd ("fs: btrfs: Use btrfs_iter_dir() to ...")
when btrfs is listing a directory, the output is not aligned:
<SYMLINK> 15 Wed Sep 09 13:20:03 2020 boot.scr -> @/boot/boot.scr
<DIR> 0 Tue Feb 02 12:42:09 2021 @
<FILE> 108 Tue Feb 02 12:54:04 2021 1.info
Return back to how it was displayed previously, i.e.:
<SYM> 15 Wed Sep 09 13:20:03 2020 boot.scr -> @/boot/boot.scr
< > 108 Tue Feb 02 12:54:04 2021 1.info
Instead of '<FILE>', print '< >', as ext4 driver.
If an unknown directory item type is encountered, we will print the type
number left padded with spaces, enclosed by '?', instead of '<' and '>',
i.e.:
? 30? ............................. name
Fixes: 325dd1f642dd ("fs: btrfs: Use btrfs_iter_dir() to replace ...")
Reviewed-by: Qu Wenruo <wqu@suse.com>
Skip xattrs in directory listing. U-Boot filesystem drivers do not list
xattrs.
sqfs_opendir() called in sqfs_size(), sqfs_read(), sqfs_exists() may fail
leading to sqfs_closedir(NULL) being called. Do not dereference NULL.
- Merge the patch to take <asm/global_data.h> out of <common.h>
The FAT32 File System Specification [1] requires leading and trailing
spaces as well as trailing periods of long names to be ignored.
[1]
Microsoft Extensible Firmware Initiative
Version 1.03, December 6, 2000
Microsoft Corporation
https://www.win.tue.nl/~aeb/linux/fs/fat/fatgen103.pdf
Directories or files called '.' or '..' cannot be created or written to
in any directory. Move the test to normalize_longname() to check this
early.
This patch involves no functional change. It is just about code
readability.
Both in file_fat_write_at() and fat_mkdir() the incoming file or directory
path are split into two parts: the parent directory and the base name.
In file_fat_write_at() the value of the variable basename is assigned to
the filename parameter and afterwards the variable filename is used instead
of basename. It is more readable to use the variable basename and leave
filename unchanged.
In fat_mkdir() the base name variable is called directory. This is
confusing. Call it basename like in file_fat_write_at(). This allows to
rename parameter new_directory to directory in the implementation of
fat_mkdir() to match the function declaration.
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
The load command should not silently return to the console prompt if an
invalid block device is specified and no file is loaded.
Since commit 565a4147d17a ("fs: btrfs: Add more checksum algorithms")
btrfs uses the sha256 checksum algorithm. But Kconfig lacks to select
it. This leads to compilation errors:
fs/built-in.o: In function `hash_sha256':
fs/btrfs/crypto/hash.c:25: undefined reference to `sha256_starts'
fs/btrfs/crypto/hash.c:26: undefined reference to `sha256_update'
fs/btrfs/crypto/hash.c:27: undefined reference to `sha256_finish'
Signed-off-by: Matthias Brugger <mbrugger@suse.com>
Do not assign a value to a variable if it is not used.
When copying short name plus extension refer to the encapsulating structure
and not to the short name element.
The short name and extension of FAT files are stored in adjacent fields of
the directory entry. For some operations like calculating a checksum or
copying both fields it is preferable to treat both as one structure.
Change the definition of the directory entry structure to include a
structure comprising the name and the extension field.
This resolves Coverity CID 316357, CID 316350, CID 316348.
Provide function description for flush_dir().
Move all error messages for flush_dir() from the callers to the function.
Move mapping of errors to -EIO to the function.
Always check return value of flush_dir() (Coverity CID 316362).
In fat_unlink() return -EIO if flush_dirty_fat_buffer() fails.
Before 'if (err)' we have to initialize the variable otherwise we use a
random value from the stack.
At the beginning of close_ctree_fs_info() the value 0 is assigned to err
and never changed before testing it.
Let's get rid of the superfluous variable.
Fixes: f06bfcf54d0e ("fs: btrfs: Crossport open_ctree_fs_info() from btrfs-progs")
SquashFS supports sprase blocks in files - that is, if a given block is
composed only of zeros, it's not written to the output file to save
space and it's on-disk length field is set to zero to indicate that.
Previously the squashfs driver did not recognise that, and would attempt
to read and decompress a zero-sized block, which obviously failed.
The following command may be used to create a file for testing:
cat <(dd if=/dev/urandom of=/dev/stdout bs=1M count=1) \
<(dd if=/dev/zero of=/dev/stdout bs=1M count=1) \
<(dd if=/dev/urandom of=/dev/stdout bs=1k count=200) >test_file
In __btrfs_map_block() we do a int * int and assign it to u64.
This is not safe as the result (int * int) is still evaluated as (int)
thus it can overflow.
Convert one of the multiplier to u64 to prevent such problem.
In real world, this should not cause problem as we have device number
limit thus it won't go beyond 4G for a single stripe.
But it's harder to teach coverity about all these hidden limits, so just
fix the possible overflow.
Reported-by: Coverity CID 312957
Reported-by: Coverity CID 312948
Up to now the bootefi command used the last file loaded to determine the
boot partition. This has led to errors when the fdt had been loaded from
another partition after the EFI binary.
Before setting the boot device from a loaded file check if it is a PE-COFF
image or a FIT image.
For a PE-COFF image remember address and size, boot device and path.
For a FIT image remember boot device and path.
If the PE-COFF image is overwritten by loading another file, forget it.
Do not allow to start an image via bootefi which is not the last loaded
PE-COFF image.
Prepare v2021.01-rc5
The FAT file system does not have a UUID but a 4 byte volume ID.
Let the fsuuid command show it in XXXX-XXXX format.
The FAT filesystem implementation uses several marcros referring to a magic
variable name mydata which renders the code less readable. Eliminate one of
them which is only used for a debug() statement.
Use log_debug() instead of debug().
Long file names are stored in multiple directory entries. When deleting a
file we must delete all of them.
A long name is split over multiple directory entries. When deleting a file
with a long name we need the first directory entry to be able to delete the
whole chain.
Add the necessary fields to the FAT iterator:
* cluster of first directory entry
* address of first directory entry
* remaining entries in cluster
When deleting a directory entry 0xe5 is written to name[0].
We have a constant for this value and should use it consistently.
Searching for a file is not a write operation. So it should not lead to the
allocation of a new cluster to the directory.
If we reuse deleted entries, we might not even use the new cluster and due
to not flushing it the directory could be corrupted.
When creating new directory entries try to reuse entries marked as deleted.
In fill_dir_slot() do not allocate new clusters as this has already been
done in fat_find_empty_dentries().
