Various U-Boot adoptions/extensions to MTD/NAND/UBI did not take buffer
alignment into account which led to failures of the following form:
ERROR: v7_dcache_inval_range - start address is not aligned - 0x1f7f0108
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x1f7f1108
http://lists.denx.de/pipermail/u-boot/2012-September/134347.html
allows for reading files in chunks from the shell.
When this feature is used to read past the end of a file an error
was returned instead of returning the bytes read up to the end of
file. Thus the following fails in the shell:
offset = 0
len = chunksize
do
read file, offset, len
write data
until bytes_read < len
The patch changes the behaviour to printing an informational
message and returning the actual read number of bytes.
(cherry picked from commit 4641b92713300089c5980259ba31e668657aa75d)
fs/fs.c
After rework of the file system API, the size of ext4
write was missed. This causes printing unreliable write
size at the end of the file system write operation.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Cc: Lukasz Majewski <l.majewski@samsung.com>
New command to determine the filesystem type of a given partition.
Optionally stores the filesystem type in a environment variable.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Enable ubifs_replay_journal during mount_ubifs, which was
disabled before.
This commit fix an issue with unrecoverable ubifs volumes
after power cut.
Therefor the gc.c is imported now from 1860e37 Linux 3.15
hs: added SPDX-License-Identifier for fs/ubifs/gc.c
Signed-off-by: Anton Habegger <anton.habegger@gmail.com>
This commit is a preperation for a subsequent UBIFS commit
which needs atomic_long operations.
Therefor "include/asm-generic/atomic-long.h" is imported
The present fat implementation ignores FAT16 long name
directory entries which aren't placed in a single sector.
This was becouse of the buffer was always filled by the
two sectors, and the loop was made also for two sectors.
If some file long name entries are stored in two sectors,
the we have two cases:
Case 1:
Both of sectors are in the buffer - all required data
for long file name is in the buffer.
- Read OK!
Case 2:
The current directory entry is placed at the end of the
second buffered sector. And the next entries are placed
in a sector which is not buffered yet. Then two next
sectors are buffered and the mentioned entry is ignored.
- Read fail!
This commit fixes this issue by:
- read two sectors after loop on each single is done
- keep the last used sector as a first in the buffer
before the read of two next
The commit doesn't affects the fat32 imlementation,
which works good as previous.
Cc: Mikhail Zolotaryov <lebon@lebon.org.ua>
Cc: Tom Rini <trini@ti.com>
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Suriyan Ramasami <suriyan.r@gmail.com>
Tested-by: Simon Glass <sjg@chomium.org>
The changes to introduce loff_t into filesize means that we need to do
64bit math on 32bit platforms. Make sure we use the right wrappers for
these operations.
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Tested-by: Pierre Aubert <p.aubert@staubli.com>
The sandbox/ext4/fat/generic fs commands do not gracefully deal with files
greater than 2GB. Negative values are returned in such cases.
To handle this, the fs functions have been modified to take an additional
parameter of type "* loff_t" which is then populated. The return value
of the fs functions are used only for error conditions.
Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com>
[trini: Update board/gdsys/p1022/controlcenterd-id.c,
drivers/fpga/zynqpl.c for changes]
Change the internal sandbox functions to use loff_t for file offsets.
Change the internal EXT4 functions to use loff_t for offsets.
[trini: Update common/spl/spl_ext.c]
Change the internal FAT functions to use loff_t for offsets.
[trini: Fix fs/fat/fat.c for min3 updates]
Some filesystems have a UUID stored in its superblock. To
allow using root=UUID=... for the kernel command line we
need a way to read-out the filesystem UUID.
changes rfc -> v1:
- make the environment variable an option parameter. If not
given, the UUID is printed out. If given, it is stored in the env
variable.
- corrected typos
- return error codes
changes v1 -> v2:
- fix return code of do_fs_uuid(..)
- document do_fs_uuid(..)
- implement fs_uuid_unsuported(..) be more consistent with the
way other optional functionality works
changes v2 -> v3:
- change ext4fs_uuid(..) to make use of #if .. #else .. #endif
construct to get rid of unreachable code
Hit any key to stop autoboot: 0
=> fsuuid
fsuuid - Look up a filesystem UUID
Usage:
fsuuid <interface> <dev>:<part>
- print filesystem UUID
fsuuid <interface> <dev>:<part> <varname>
- set environment variable to filesystem UUID
=> fsuuid mmc 0:1
d9f9fc05-45ae-4a36-a616-fccce0e4f887
=> fsuuid mmc 0:2
eb3db83c-7b28-499f-95ce-9e0bb21cda81
=> fsuuid mmc 0:1 uuid1
=> fsuuid mmc 0:2 uuid2
=> printenv uuid1
uuid1=d9f9fc05-45ae-4a36-a616-fccce0e4f887
=> printenv uuid2
uuid2=eb3db83c-7b28-499f-95ce-9e0bb21cda81
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
U-Boot has never cared about the type when we get max/min of two
values, but Linux Kernel does. This commit gets min, max, min3, max3
macros synced with the kernel introducing type checks.
Many of references of those macros must be fixed to suppress warnings.
We have two options:
- Use min, max, min3, max3 only when the arguments have the same type
(or add casts to the arguments)
- Use min_t/max_t instead with the appropriate type for the first
argument
Acked-by: Pavel Machek <pavel@denx.de>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
Tested-by: Lukasz Majewski <l.majewski@samsung.com>
[trini: Fixup arch/blackfin/lib/string.c]
U-Boot has imported various utility macros from Linux
scattering them to various places without consistency.
In include/common.h are min, max, min3, max3, ARRAY_SIZE, ALIGN,
container_of, DIV_ROUND_UP, etc.
In include/linux/compat.h are min_t, max_t, round_up, round_down,
etc.
We also have duplicated defines of min_t in some *.c files.
Moreover, we are suffering from too cluttered include/common.h.
This commit moves various macros that originate in
include/linux/kernel.h of Linux to their original position.
Note:
This commit simply moves the macros; the macros roundup,
min, max, min2, max3, ARRAY_SIZE are different
from those of Linux at this point.
In a message from Wolfgang Denk highlighting warnings from cppcheck,
the patch will address those that are correctly diagnosed. Some are
false-positives:
> [fs/zfs/zfs.c:937]: (error) Memory leak: l
dmu_read() allocates "l" if successful, so error-case should not free
it.
> [fs/zfs/zfs.c:1141]: (error) Memory leak: dnbuf
dmu_read() allocates "dnbuf" if successful, so error-case should not
free it.
> [fs/zfs/zfs.c:1372]: (error) Memory leak: osp
zio_read() allocates "osp" if successful, so error-case should
not free it.
> [fs/zfs/zfs.c:1726]: (error) Memory leak: nvlist
int_zfs_fetch_nvlist() allocates "nvlist" if successful, so error-case
should not free it.
Signed-off-by: Jorgen Lundman <lundman@lundman.net>
Add EXT filesystem support to SPL.
Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr>
[trini: Fix a warning and checkpatch problems]
On 64-bit platforms (like sandbox) 64-bit integers may be 'long' rather
than 'long long'. Use the inttypes header to avoid compiler warnings.
The macro MIN, MAX is defined as the aliase of min, max,
respectively.
This would be useful to start moving various config options.
U-Boot has imported various source files from other projects,
mostly Linux.
Something like
#ifdef __UBOOT__
[ modification for U-Boot ]
#else
[ original code ]
#endif
is an often used strategy for clarification of adjusted parts,
that is, easier re-sync in future.
Instead of defining __UBOOT__ in each source file,
passing it from the top Makefile would be easier.
Acked-by: Heiko Schocher <hs@denx.de>
snyc with linux v3.15:
commit 1860e379875dfe7271c649058aeddffe5afd9d0d
Author: Linus Torvalds <torvalds@linux-foundation.org>
Date: Sun Jun 8 11:19:54 2014 -0700
Linux 3.15
Cc: Scott Wood <scottwood@freescale.com>
while playing with the new mtd/ubi/ubifs sync, found some
small updates for it:
- add del_mtd_partition() to include/linux/mtd/mtd
- mtd: add a debug_printf
- remove some not used functions
resync ubi subsystem with linux:
commit 455c6fdbd219161bd09b1165f11699d6d73de11c
Date: Sun Mar 30 20:40:15 2014 -0700
Linux 3.14
A nice side effect of this, is we introduce UBI Fastmap support
to U-Boot.
Cc: Sergey Lapin <slapin@ossfans.org>
Cc: Joerg Krause <jkrause@posteo.de>
- move linux specific defines from usb and video code
into linux/compat.h
- move common linux specific defines from include/ubi_uboot.h
to linux/compat.h
- add for new mtd/ubi/ubifs sync new needed linux specific
defines to linux/compat.h
[trini: Add spin_lock_irqsave/spin_unlock_irqrestore dummies from
usb/lin_gadet_compat.h]
These commands may be used to determine the size of a file without
actually reading the whole file content into memory. This may be used
to determine if the file will fit into the memory buffer that will
contain it. In particular, the DFU code will use it for this purpose
in the next commit.
If filename is passed instead of address to ext2load or fatload,
u-boot silently accepts that, and uses 0 for load address and default
filename from environment. That is confusing, display help instead.
Signed-off-by: Pavel Machek <pavel@denx.de>
Current code uses the preprocessor to change an else case
to a statement without any if condition at all. Although
this works, change the optional code to return early, so
all optional code is contained within a single #ifdef.
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
Remove self assignments which is just dead code to prevent
compiler warnings about non used arguments. For u-boot this
does not prevent any warning though, on the contrary it actual
introduces warnings when compiling with clang. Remove them.
ext4fs_allocate_blocks() always allocates at least one block for a file.
If the file size is zero, this causes total_remaining_blocks to
underflow, which then causes an apparent hang while 2^32 blocks are
allocated.
To solve this, check that total_remaining_blocks is non-zero as part of
the loop condition (i.e. before each loop) rather than at the end of
the loop.
Clang interpretes an if condition like "if ((a = b) == NULL)
as it tries to assign a value in a statement. Hence if you do
"if ((something)) it warns you that you might be confused.
Hence drop the double braces for plane if statements.
Since ALLOC_CACHE_ALIGN_BUFFER declares a char* for filename
sizeof(filename) is not the size of the buffer. Use the already
known length instead.
cc: Uma Shankar <uma.shankar@samsung.com>
cc: Manjunatha C Achar <a.manjunatha@samsung.com>
cc: Marek Vasut <marek.vasut@gmail.com>
- update the comments regarding lbaint_t usage
- cleanup casting of values related to the lbaint_t type
- cleanup of a type that requires a u64
Tested on little endian ARMv7 and ARMv8 configurations
Signed-off-by: Steve Rae <srae@broadcom.com>
When write a file into FAT file system, it will search a match file in
root dir. So the find_directory_entry() will get the first cluster of
root dir content and search the directory item one by one. If the file
is not found, we will call get_fatent_value() to get next cluster of root
dir via lookup the FAT table and continue the search.
The issue is in FAT16/12 system, we cannot get root dir's next clust
from FAT table. The FAT table only be use to find the clust of data
aera in FAT16/12.
In FAT16/12 if the clust is in root dir, the clust number is a negative
number or 0, 1. Since root dir is located in front of the data area.
Data area start clust #2. So the root dir clust number should < 2.
This patch will check above situation before call get_fatenv_value().
If curclust is < 2, include minus number, we just increase one on the
curclust since root dir is in continous cluster.
The patch also add a sanity check for entry in get_fatenv_value().
Signed-off-by: Josh Wu <josh.wu@atmel.com>
In fat_write.c, the last clust condition check is incorrect:
if ((curclust >= 0xffffff8) || (curclust >= 0xfff8)) {
For example, in FAT32 if curclust is 0x11000. It is a valid clust.
But on above condition check, it will be think as a last clust.
So the correct last clust check should be:
in fat32, curclust >= 0xffffff8
in fat16, curclust >= 0xfff8
in fat12, curclust >= 0xff8
This patch correct the last clust check.
This bug shows up when file stored on the ext4 file system is updated.
The ext4fs_delete_file() is responsible for deleting file's (e.g. uImage)
data.
However some global data (especially ext4fs_indir2_block), which is used
during file deletion are left unchanged.
The ext4fs_indir2_block pointer stores reference to old ext4 double
indirect allocated blocks. When it is unchanged, after file deletion,
ext4fs_write_file() uses the same pointer (since it is already initialized
- i.e. not NULL) to return number of blocks to write. This trunks larger
file when previous one was smaller.
Lets consider following scenario:
1. Flash target with ext4 formatted boot.img (which has uImage [*] on itself)
2. Developer wants to upload their custom uImage [**]
- When new uImage [**] is smaller than the [*] - everything works
correctly - we are able to store the whole smaller file with corrupted
- When new uImage [**] is larger than the [*] - theCRC is corrupted,
since truncation on data stored at eMMC was done.
3. When uImage CRC error appears, then reboot and LTHOR/DFU reflashing causes
proper setting of ext4fs_indir2_block() and after that uImage[**]
is successfully stored (correct uImage [*] metadata is stored at an
eMMC on the first flashing).
Due to above the bug was very difficult to reproduce.
This patch sets default values for all ext4fs_indir* pointers/variables.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Code responsible for handling situation when ext4 has block size of 1024B
can be ordered to take less space.
This patch does that for ext4 common and write files.
__DATE__ and __TIME__ makes the build non-deterministic.
Drop the debug message using them.
Use of malloc of do_fat_write() causes cache error on ARM v7 platforms.
Perhaps, the same problem will occur at any other CPUs.
This replaces malloc with memalign to fix cache buffer alignment.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Signed-off-by: Yoshiyuki Ito <yoshiyuki.ito.ub@renesas.com>
Tested-by: Hector Palacios <hector.palacios@digi.com>
U-Boot already has a list implementation, and files which include both
that and the yaffs implementation will get errors:
In file included from ydirectenv.h:80:0,
from yportenv.h:81,
from yaffs_guts.h:19,
from yaffs_allocator.h:19,
from yaffs_allocator.c:14:
yaffs_list.h:32:8: error: redefinition of ‘struct list_head’
struct list_head {
Remove the yaffs implementation.
arch/arm/cpu/armv7/config.mk
board/ti/am43xx/mux.c
include/configs/am43xx_evm.h
When we tell the compiler to optimize for ARMv7 (and ARMv6 for that
matter) it assumes a default of SCTRL.A being cleared and unaligned
accesses being allowed and fast at the hardware level. We set this bit
and must pass along -mno-unaligned-access so that the compiler will
still breakdown accesses and not trigger a data abort.
To better help understand the requirements of the project with respect
to unaligned memory access, the
Documentation/unaligned-memory-access.txt file has been added as
doc/README.unaligned-memory-access.txt and is taken from the v3.14-rc1
tag of the kernel.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Mans Rullgard <mans@mansr.com>
This reverts commit fc0fc50f38a4d7d0554558076a79dfe8b0d78cd5.
The author has asked on the mailing list that we revert this for now as
it breaks write support.
Reported-by: Łukasz Majewski <l.majewski@samsung.com>
Fix the following checkpatch warning:-
WARNING: externs should be avoided in .c files
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
In an ext4 filesystem, the inode corresponding to a file has a 60-byte
area which contains an extent header structure and up to 4 extent
structures (5 x 12 bytes).
For files that need more than 4 extents to be represented (either files
larger than 4 x 128MB = 512MB or smaller files but very fragmented),
ext4 creates extent index structures. Each extent index points to a 4KB
physical block where one extent header and additional 340 extents could
be stored.
The current u-boot ext4 code is very inefficient when it tries to load a
file which has extent indexes. For each logical file block the code will
read over and over again the same blocks of 4096 bytes from the disk.
Since the extent tree in a file is always the same, we can cache the
extent structures in memory before actually starting to read the file.
This patch creates a simple linked list of structures holding information
about all the extents used to represent a file. The list is sorted by
the logical block number (ee_block) so that we can easily find the
proper extent information for any file block.
Without this patch, a 69MB file which had just one extent index pointing
to a block with another 6 extents was read in approximately 3 minutes.
With this patch applied the same file can be read in almost 20 seconds.
Signed-off-by: Ionut Nicu <ioan.nicu.ext@nsn.com>
We have an unused FAT implementation in fs/fdos, remove.
Now we are ready to switch over to real Kbuild.
This commit disables temporary scripts:
scripts/{Makefile.build.tmp, Makefile.host.tmp}
and enables real Kbuild scripts:
scripts/{Makefile.build,Makefile.host,Makefile.lib}.
This switch is triggered by the line in scripts/Kbuild.include
-build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj
+build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj
We need to adjust some build scripts for U-Boot.
But smaller amount of modification is preferable.
Additionally, we need to fix compiler flags which are
locally added or removed.
In Kbuild, it is not allowed to change CFLAGS locally.
Instead, ccflags-y, asflags-y, cppflags-y,
CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o
are prepared for that purpose.
Tested-by: Gerhard Sittig <gsi@denx.de>
This commit changes the working directory
where the build process occurs.
Before this commit, build process occurred under the source
tree for both in-tree and out-of-tree build.
That's why we needed to add $(obj) prefix to all generated
files in makefiles like follows:
$(obj)u-boot.bin: $(obj)u-boot
Here, $(obj) is empty for in-tree build, whereas it points
to the output directory for out-of-tree build.
And our old build system changes the current working directory
with "make -C <sub-dir>" syntax when descending into the
sub-directories.
On the other hand, Kbuild uses a different idea
to handle out-of-tree build and directory descending.
The build process of Kbuild always occurs under the output tree.
When "O=dir/to/store/output/files" is given, the build system
changes the current working directory to that directory and
restarts the make.
Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>"
syntax for descending into sub-directories.
(We can write it like "make $(obj)=<sub-dir>" with a shorthand.)
This means the current working directory is always the top
of the output directory.
This hooks into the generic "file exists" support added in an earlier
patch, and provides an implementation for the FAT filesystem.
