path: root/fs
2008-03-03Fix checking fat32 cluster size.michael
This fixes the cluster size tests in the FAT32 file system. The current implementation of VFAT support doesn't work if the referred cluster has an offset > 16bit representation, causing "fatload" and "fatls" commands etc. to fail. Signed-off-by: michael trimarchi <trimarchi@gandalf.sssup.it>
2008-03-02fs: Fix ext2 read issueDave Liu
The ext2 aligned process will corrupt the key data struct, the patch fix this. Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-02-14Fix CONFIG_MMC usage in fat codeAndy Fleming
A #if statement in fat.c depended on CONFIG_MMC, instead of defined(CONFIG_MMC). This meant CONFIG_MMC needed to be defined as "1" rather than just defined. Now it's better. Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-01-09Fix my own merge stupidityAndy Fleming
Way back in August I merged Heiko's patch: 566a494f592: [PCS440EP] upgrade the PCS440EP board with Jon's CONFIG_COMMANDS patches. This was done in commit: 6bf6f114dcdd97ec3f80c2761ed40e31229d6b78 However, in the process, I left out some of Heiko's good changes. Now Heiko's and Jon's patches are properly merged in fat_register_device() Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-01-09fix comments with new drivers organizationMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2008-01-09Fix building with CRAMFS but not JFFS2 supportHarald Welte
Signed-off-by: Harald Welte <laforge@openmoko.org>
2008-01-09Fix memset bug in ext2fs_read_file()Wolfgang Denk
ext2fs_read_file() had the function arguments swapped. Pointed out by Mike Montour, 19 Dec 2007 22:34:25 -0800 Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-11-15Build: split COBJS value into multiple linesGrant Likely
This change is in preparation for condtitionial compile support in the build system. By spliting them all into seperate lines now, subsequent patches that change 'COBJS-y += ' into 'COBJS-$(CONFIG_<blah>) += ' will be less invasive and easier to review Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-09-16[FIX] remove files form repositoryMichal Simek
2007-09-15Synchronize with U-BOOT mainlineMichal Simek
2007-08-15[FIX] Correction command definitionMichal Simek
2007-08-07Merge git://www.denx.de/git/u-bootMichal Simek
2007-08-07Fix missing brace error in fs/fat/fat.cWolfgang Denk
[pointed out by Roderik Wildenburg] Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-08-06[FIX] Fix romfs codeMichal Simek
2007-08-03Merge branch 'testing' into workingAndy Fleming
Conflicts: CHANGELOG fs/fat/fat.c include/configs/MPC8560ADS.h include/configs/pcs440ep.h net/eth.c
2007-07-14[FS] Added support for ROMFSMichal Simek
2007-07-10fs/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09fs/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-05Fixing some typos etc. introduced mainly by cfg patches.Wolfgang Denk
2007-07-04fs/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-06-22[PCS440EP] upgrade the PCS440EP board:Heiko Schocher
- Show on the Status LEDs, some States of the board. - Get the MAC addresses from the EEProm - use PREBOOT - use the CF on the board. - check the U-Boot image in the Flash with a SHA1 checksum. - use dynamic TLB entries generation for the SDRAM Signed-off-by: Heiko Schocher <hs@denx.de>
2007-05-18Reduce line lengths to 80 characters max.Peter Pearse
2007-05-18Merge with git://www.denx.de/git/u-boot.gitPeter Pearse
2007-05-09New board SMN42 branchPeter Pearse
2007-04-24[PATCH] MTD partition support, JFFS2 supportMichal Simek
2006-04-08Fix JFFS2 support for legacy NAND driver.Marian Balakowicz
Some more NAND cleanup and small fixes.
2006-03-17Add support for Lite5200B board.Wolfgang Denk
Patch by Patch by Jose Maria (Txema) Lopez, 16 Jan 2006
2006-03-12Add crc of data to jffs2 (in jffs2_1pass_build_lists()).Wolfgang Denk
Patch by Rick Bronson, 15 Jun 2005
2006-03-05Re-factoring the legacy NAND code (legacy NAND now only in board-specificBartlomiej Sieka
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards.
2006-02-24Merge with /home/wd/git/u-boot/testing-NAND/ to add new NAND handling.Bartlomiej Sieka
2006-01-18Add VGA support (CT69000) to CPCI750 board.Stefan Roese
Insert missing __le32_to_cpu() for filesize in ext2fs_read_file(). Patch by Reinhard Arlt, 30 Dec 2005
2005-10-15Merge with /home/m8/git/u-bootWolfgang Denk
2005-10-11Added support for TQM834x boards.Marian Balakowicz
2005-09-14Update of new NAND codeWolfgang Denk
Patch by Ladislav Michl, 13 Sep 2005
2005-08-17Merge with testing-NAND (Rewrite of NAND code)Wolfgang Denk
2005-08-17Rewrite of NAND code based on what is in 2.6.12 Linux kernelWolfgang Denk
Patch by Ladislav Michl, 29 Jun 2005
2005-08-16Fix return values of the jffs2 commands ls/fsload/fsinfo,Wolfgang Denk
so we can use them to, e.g., check the existence of a file with "if ls foo; then this; else that; fi" in the hush shell Patch by Andreas Engel, 16 August 2005
2005-08-10Add configuration for IFM AEV FIFO board.Wolfgang Denk
Minor coding style cleanup.
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
2005-08-06Add support for Altera NIOS DK1C20 boardWolfgang Denk
Patch by Shlomo Kut, 13 Dec 2004
2005-05-05It's better to handle LZO and LZARI compression mdoes for JFFS2 withLABEL_2005_05_05_1920wdenk
a single #define.
2005-05-05Major upate of JFFS2 code; now in sync with snapshot of MTD CVS ofwdenk
March 13, 2005); new configuration options CONFIG_JFFS2_LZO and CONFIG_JFFS2_LZARI are added. Both are undefined by default.
2005-05-04Fix problem with symbolic links in JFFS2 code.wdenk
2005-03-04* Fix get_partition_info() parameter error in all other callswdenk
(common/cmd_ide.c, common/cmd_reiser.c, common/cmd_scsi.c). * Enable USB and IDE support for INKA4x0 board * Patch by Andrew Dyer, 28 February 2005: fix ext2load passing an incorrect pointer to get_partition_info() resulting in load failure for devices other than 0
2005-02-04* Patch by Cajus Hahn, 04 Feb 2005:wdenk
- don't insist on leading '/' for filename in ext2load - set default partition to useful value (1) in ext2load * Patch by Andrew Dyer, 08 Jan 2005: fix wrong return codes in ext2 code
2004-12-19Cleanup: avoid trigraph warning in fs/ext2/ext2fs.c; rename UC100 -> uc100wdenk
2004-12-16Code cleanup.wdenk
