path: root/fs/yaffs2
2014-03-04yaffs: Remove private list implementationSimon Glass
U-Boot already has a list implementation, and files which include both that and the yaffs implementation will get errors: In file included from ydirectenv.h:80:0, from yportenv.h:81, from yaffs_guts.h:19, from yaffs_allocator.h:19, from yaffs_allocator.c:14: yaffs_list.h:32:8: error: redefinition of ‘struct list_head’ struct list_head { ^ Remove the yaffs implementation. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-01-20yaffs2: Remove block number check from summary verificationCharles Manning
The summary already has other verification. This one is not needed. The check caused summaries to be ignored if they were not on the numbered block. This caused problems when a summary was embedded in an image and the image is written to a flash with bad blocks. Signed-off-by: Charles Manning <cdhmanning@gmail.com>
2013-12-13yaffs2: Use lldiv for 64bit divisionTom Rini
2013-11-17fs: descend into sub directories when it is necessaryMasahiro Yamada
2013-10-31fs: convert makefiles to Kbuild styleMasahiro Yamada
2013-08-19SPDX-License-Identifier: convert BSD-3-Clause filesWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini Don't remove some copyrights by accident] Signed-off-by: Tom Rini <trini@ti.com>
2013-05-31mtd: resync with Linux-3.7.1Sergey Lapin
This patch is essentially an update of u-boot MTD subsystem to the state of Linux-3.7.1 with exclusion of some bits: - the update is concentrated on NAND, no onenand or CFI/NOR/SPI flashes interfaces are updated EXCEPT for API changes. - new large NAND chips support is there, though some updates have got in Linux-3.8.-rc1, (which will follow on top of this patch). To produce this update I used tag v3.7.1 of linux-stable repository. The update was made using application of relevant patches, with changes relevant to U-Boot-only stuff sticked together to keep bisectability. Then all changes were grouped together to this patch. Signed-off-by: Sergey Lapin <slapin@ossfans.org> [scottwood@freescale.com: some eccstrength and build fixes] Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-11-04include/linux/byteorder: import latest endian definitions from linuxKim Phillips
u-boot's byteorder headers did not contain endianness attributions for use with sparse, causing a lot of false positives. Import the kernel's latest definitions, and enable them by including compiler.h and types.h. They come with 'const' added for some swab functions, so fix those up, too: include/linux/byteorder/big_endian.h:46:2: warning: passing argument 1 of '__swab64p' discards 'const' qualifier from pointer target type [enabled by default] Also, note: u-boot's historic __BYTE_ORDER definition has been preserved (for the time being at least). We also remove ad-hoc barrier() definitions, since we're including compiler.h in files that hadn't in the past: macb.c:54:0: warning: "barrier" redefined [enabled by default] In addition, including compiler.h in byteorder changes the 'noinline' definition to expand to __attribute__((noinline)). This fixes arch/powerpc/lib/bootm.c: bootm.c:329:16: error: attribute '__attribute__': unknown attribute bootm.c:329:16: error: expected ')' before '__attribute__' bootm.c:329:25: error: expected identifier or '(' before ')' token powerpc sparse builds yield: include/common.h:356:22: error: marked inline, but without a definition the unknown-reason inlining without a definition is considered obsolete given it was part of the 2002 initial commit, and no arm version was 'fixed.' also fixed: ydirectenv.h:60:0: warning: "inline" redefined [enabled by default] and: Configuring for devconcenter - Board: intip, Options: DEVCONCENTER make[1]: *** [4xx_ibm_ddr2_autocalib.o] Error 1 make: *** [arch/powerpc/cpu/ppc4xx/libppc4xx.o] Error 2 powerpc-fsl-linux-size: './u-boot': No such file 4xx_ibm_ddr2_autocalib.c: In function 'DQS_autocalibration': include/asm/ppc4xx-sdram.h:1407:13: sorry, unimplemented: inlining failed in call to 'ppc4xx_ibm_ddr2_register_dump': function body not available 4xx_ibm_ddr2_autocalib.c:1243:32: sorry, unimplemented: called from here and: In file included from crc32.c:50:0: crc32table.h:4:1: warning: implicit declaration of function '___constant_swab32' [-Wimplicit-function-declaration] crc32table.h:4:1: error: initializer element is not constant crc32table.h:4:1: error: (near initialization for 'crc32table_le[0]') Signed-off-by: Kim Phillips <kim.phillips@freescale.com> [trini: Remove '#endif' in include/common.h around setenv portion] Signed-off-by: Tom Rini <trini@ti.com>
2012-10-08yaffs2: Fix GCC 4.6 compile warningsAnatolij Gustschin
Fix: yaffs_guts.c: In function 'yaffs_check_chunk_erased': yaffs_guts.c:324:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_verify_chunk_written': yaffs_guts.c:352:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_grab_chunk_cache': yaffs_guts.c:1488:6: warning: variable 'pushout' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_check_obj_details_loaded': yaffs_guts.c:3180:6: warning: variable 'alloc_failed' set but not used [-Wunused-but-set-variable] yaffs_guts.c:3179:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_update_oh': yaffs_guts.c:3288:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_get_obj_name': yaffs_guts.c:4447:7: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_summary.c: In function 'yaffs_summary_read': yaffs_summary.c:194:6: warning: variable 'sum_tags_bytes' set but not used [-Wunused-but-set-variable] yaffs_verify.c: In function 'yaffs_verify_file': yaffs_verify.c:227:6: warning: variable 'actual_depth' set but not used [-Wunused-but-set-variable] yaffs_yaffs1.c: In function 'yaffs1_scan': yaffs_yaffs1.c:26:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_yaffs2.c: In function 'yaffs2_scan_chunk': yaffs_yaffs2.c:949:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_yaffs2.c: In function 'yaffs2_scan_backwards': yaffs_yaffs2.c:1352:6: warning: variable 'deleted' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Charles Manning <cdhmanning@gmail.com> Tested-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-09-02u-boot yaffs2: Fix compilation warningsCharles Manning
Also remove yaffs_hweight and use the hweight in u-boot. Signed-off-by: Charles Manning <cdhmanning@gmail.com>
2012-08-09u-boot: Update yaffs2 file systemCharles Manning
This patch updates the yaffs2 in u-boot to correspond to git://www.aleph1.co.uk/yaffs2 commit id 9ee5d0643e559568dbe62215f76e0a7bd5a63d93 Signed-off-by: Charles Manning <cdhmanning@gmail.com>
2011-12-10fs/yaffs2/yaffs_guts.c: Fix GCC 4.6 compile warning (and bug)Wolfgang Denk
Fix: yaffs_guts.c: In function 'yaffs_GarbageCollectBlock': yaffs_guts.c:2761:6: warning: variable 'retVal' set but not used [-Wunused-but-set-variable] Here GCC actually detected a bug. The code was always returning OK instead of the previously set retrun code. Fix that. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: William Juul <wiljuul@cisco.com> Cc: Scott Wood <scottwood@freescale.com> Acked-by: William Juul <wiljuul@cisco.com>
2011-11-16Fix warnings in yaffsSimon Glass
Sorry if this is already fixed somewhere - I could not find it. This fixes the warnings show below. yaffs_tagscompat.c: In function 'yaffs_TagsCompatabilityReadChunkWithTagsFromNAND': yaffs_tagscompat.c:151: warning: dereferencing pointer 'tu' does break strict-aliasing rules yaffs_tagscompat.c:150: warning: dereferencing pointer 'tu' does break strict-aliasing rules yaffs_tagscompat.c:149: warning: dereferencing pointer 'tu' does break strict-aliasing rules yaffs_tagscompat.c:148: warning: dereferencing pointer 'tu' does break strict-aliasing rules yaffs_tagscompat.c:147: warning: dereferencing pointer 'tu' does break strict-aliasing rules yaffs_tagscompat.c:146: warning: dereferencing pointer 'tu' does break strict-aliasing rules yaffs_tagscompat.c:145: warning: dereferencing pointer 'tu' does break strict-aliasing rules yaffs_tagscompat.c:144: warning: dereferencing pointer 'tu' does break strict-aliasing rules yaffs_tagscompat.c:141: note: initialized from here Signed-off-by: Simon Glass <sjg@chromium.org>
2011-11-16fs/yaffs2/yaffs_guts.c: Fix some GCC 4.6 warningsAnatolij Gustschin
Fix: yaffs_guts.c: In function 'yaffs_CheckChunkErased': yaffs_guts.c:854:6: warning: variable 'result' set but not used yaffs_guts.c: In function 'yaffs_UpdateObjectHeader': yaffs_guts.c:3463:6: warning: variable 'result' set but not used yaffs_guts.c: In function 'yaffs_GrabChunkCache': yaffs_guts.c:3774:6: warning: variable 'pushout' set but not used yaffs_guts.c: In function 'yaffs_Scan': yaffs_guts.c:5237:6: warning: variable 'result' set but not used yaffs_guts.c: In function 'yaffs_CheckObjectDetailsLoaded': yaffs_guts.c:5748:6: warning: variable 'alloc_failed' set but not used yaffs_guts.c:5747:6: warning: variable 'result' set but not used yaffs_guts.c: In function 'yaffs_ScanBackwards': yaffs_guts.c:5808:6: warning: variable 'deleted' set but not used yaffs_guts.c:5806:6: warning: variable 'result' set but not used yaffs_guts.c: In function 'yaffs_GetObjectName': yaffs_guts.c:6657:7: warning: variable 'result' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-10-27GCC4.6: Squash warnings in yaffs_guts.cMarek Vasut
yaffs_guts.c: In function 'yaffs_ReadDataFromFile': yaffs_guts.c:4461:8: warning: 'chunk' may be used uninitialized in this function yaffs_guts.c:4462:8: warning: 'start' may be used uninitialized in this function yaffs_guts.c: In function 'yaffs_WriteDataToFile': yaffs_guts.c:4581:8: warning: 'chunk' may be used uninitialized in this function yaffs_guts.c:4582:8: warning: 'start' may be used uninitialized in this function yaffs_guts.c: In function 'yaffs_ResizeFile': yaffs_guts.c:4816:8: warning: 'newSizeOfPartialChunk' may be used uninitialized in this function yaffs_guts.c:4817:8: warning: 'newFullChunks' may be used uninitialized in this function Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org> Cc: William Juul <william.juul@tandberg.com>
2011-10-27GCC4.6: Drop dead code from yaffs_guts.cMarek Vasut
Drop yaffs_DeleteWorker(): yaffs_guts.c:1556:12: warning: 'yaffs_DeleteWorker' defined but not used Drop yaffs_VerifyTnodeWorker(): yaffs_guts.c:600:12: warning: 'yaffs_VerifyTnodeWorker' defined but not used Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org>
2011-09-10YAFFS2: fs/yaffs2/yaffs_guts.c - fix build warningsWolfgang Denk
Fix these: yaffs_guts.c: In function 'yaffs_ReadDataFromFile': yaffs_guts.c:4622: warning: pointer targets in passing argument 3 of 'yaffs_AddrToChunk' differ in signedness yaffs_guts.c:4622: warning: pointer targets in passing argument 4 of 'yaffs_AddrToChunk' differ in signedness yaffs_guts.c: In function 'yaffs_WriteDataToFile': yaffs_guts.c:4745: warning: pointer targets in passing argument 3 of 'yaffs_AddrToChunk' differ in signedness yaffs_guts.c:4745: warning: pointer targets in passing argument 4 of 'yaffs_AddrToChunk' differ in signedness yaffs_guts.c: In function 'yaffs_ResizeFile': yaffs_guts.c:4968: warning: pointer targets in passing argument 3 of 'yaffs_AddrToChunk' differ in signedness yaffs_guts.c:4968: warning: pointer targets in passing argument 4 of 'yaffs_AddrToChunk' differ in signedness yaffs_guts.c: In function 'yaffs_GutsInitialise': yaffs_guts.c:7235: warning: assignment from incompatible pointer type yaffs_guts.c: In function 'yaffs_CreateNewObject': yaffs_guts.c:2143: warning: 'tn' may be used uninitialized in this function yaffs_guts.c: In function 'yaffs_MknodObject': yaffs_guts.c:2258: warning: 'str' may be used uninitialized in this function Signed-off-by: Wolfgang Denk <wd@denx.de>
Fix these: yaffs_guts.c: At top level: yaffs_guts.c:400: warning: 'yaffs_SkipFullVerification' defined but not used Testing shows no changes of the image sizes. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-09-10YAFFS2: fs/yaffs2/yaffs_nand.[hc] - fix build warningsWolfgang Denk
Fix these: yaffs_guts.c: In function 'yaffs_Scan': yaffs_guts.c:5436: warning: pointer targets in passing argument 4 of 'yaffs_QueryInitialBlockState' differ in signedness yaffs_guts.c: In function 'yaffs_ScanBackwards': yaffs_guts.c:6017: warning: pointer targets in passing argument 4 of 'yaffs_QueryInitialBlockState' differ in signedness yaffs_nand.c: In function 'yaffs_QueryInitialBlockState': yaffs_nand.c:109: warning: pointer targets in passing argument 4 of 'dev->queryNANDBlock' differ in signedness yaffs_nand.c:113: warning: pointer targets in passing argument 4 of 'yaffs_TagsCompatabilityQueryNANDBlock' differ in signedness Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-09-10YAFFS2: fs/yaffs2/Makefile - fix build warningsWolfgang Denk
Drop the "-DNO_Y_INLINE" setting to fix these: yaffs_guts.h:806: warning: 'yaffs_GetBlockInfo' defined but not used Impact on image size is negligible - for the VCMA9 board the text segment size grew from 496353 to 496357 bytes (i. e. 0.0008%); total image size even remained constant. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-09-10YAFFS2: fs/yaffs2/yaffscfg.c - fix build warningsWolfgang Denk
Fix these: yaffscfg.c: In function 'cmd_yaffs_mread_file': yaffscfg.c:316: warning: format '%08x' expects type 'unsigned int', but argument 3 has type 'char *' yaffscfg.c: In function 'cmd_yaffs_ls': yaffscfg.c:371: warning: format '%7d' expects type 'int', but argument 3 has type 'off_t' Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-08-21Make the YAFFS filesystem workRemy Bohmer
Recently the YAFFS filesystem support has been added to U-boot. However, just enabling CONFIG_YAFFS2 is not enough to get it working. ymount will generate an exception (when dereferencing mtd->readoob()), because the genericDevice is a null pointer. Further, a lot of logging is produced while using YAFFS fs, so logging should also be disabled. Both issues are solved by this patch. With this patch and CONFIG_YAFFS2 enabled, I get a readable filesystem in U-boot, as well as in Linux. Tested on a Atmel AT91SAM9261EK board. Signed-off-by: Remy Bohmer <linux@bohmer.net> Acked-by: William Juul <william.juul@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-14Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-08-12moving files from yaffs2/direct/ to yaffs2/ and deleting all symlinksWilliam Juul
Signed-off-by: William Juul <william.juul@tandberg.com>
2008-08-12Clean out unneeded filesWilliam Juul
2008-08-12Create symlinks from yaffs2/direct to yaffs2William Juul
2008-08-12Incorporate yaffs2 into U-bootWilliam Juul
To use YAFFS2 define CONFIG_YAFFS2 Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12YAFFS2 importWilliam Juul
Direct import of yaffs as a tarball as of 20071113 from their public CVS-web at http://www.aleph1.co.uk/cgi-bin/viewcvs.cgi/yaffs2/ The code can also be imported on the command line with: export CVSROOT=:pserver:anonymous@cvs.aleph1.co.uk:/home/aleph1/cvs cvs logon (Hit return when asked for a password) cvs checkout yaffs2 Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Stig Olsen <stig.olsen@tandberg.com>
