path: root/fs/yaffs2/yaffs_summary.c
2012-10-08yaffs2: Fix GCC 4.6 compile warningsAnatolij Gustschin
Fix: yaffs_guts.c: In function 'yaffs_check_chunk_erased': yaffs_guts.c:324:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_verify_chunk_written': yaffs_guts.c:352:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_grab_chunk_cache': yaffs_guts.c:1488:6: warning: variable 'pushout' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_check_obj_details_loaded': yaffs_guts.c:3180:6: warning: variable 'alloc_failed' set but not used [-Wunused-but-set-variable] yaffs_guts.c:3179:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_update_oh': yaffs_guts.c:3288:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_get_obj_name': yaffs_guts.c:4447:7: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_summary.c: In function 'yaffs_summary_read': yaffs_summary.c:194:6: warning: variable 'sum_tags_bytes' set but not used [-Wunused-but-set-variable] yaffs_verify.c: In function 'yaffs_verify_file': yaffs_verify.c:227:6: warning: variable 'actual_depth' set but not used [-Wunused-but-set-variable] yaffs_yaffs1.c: In function 'yaffs1_scan': yaffs_yaffs1.c:26:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_yaffs2.c: In function 'yaffs2_scan_chunk': yaffs_yaffs2.c:949:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_yaffs2.c: In function 'yaffs2_scan_backwards': yaffs_yaffs2.c:1352:6: warning: variable 'deleted' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Charles Manning <cdhmanning@gmail.com> Tested-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-08-09u-boot: Update yaffs2 file systemCharles Manning
This patch updates the yaffs2 in u-boot to correspond to git://www.aleph1.co.uk/yaffs2 commit id 9ee5d0643e559568dbe62215f76e0a7bd5a63d93 Signed-off-by: Charles Manning <cdhmanning@gmail.com>
