path: root/fs/ubifs
2014-11-20include: move various macros to include/linux/kernel.hMasahiro Yamada
U-Boot has imported various utility macros from Linux scattering them to various places without consistency. In include/common.h are min, max, min3, max3, ARRAY_SIZE, ALIGN, container_of, DIV_ROUND_UP, etc. In include/linux/compat.h are min_t, max_t, round_up, round_down, etc. We also have duplicated defines of min_t in some *.c files. Moreover, we are suffering from too cluttered include/common.h. This commit moves various macros that originate in include/linux/kernel.h of Linux to their original position. Note: This commit simply moves the macros; the macros roundup, min, max, min2, max3, ARRAY_SIZE are different from those of Linux at this point. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-24kconfig: add blank Kconfig filesMasahiro Yamada
This would be useful to start moving various config options. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-09-16kbuild: force to define __UBOOT__ in all the C sourcesMasahiro Yamada
U-Boot has imported various source files from other projects, mostly Linux. Something like #ifdef __UBOOT__ [ modification for U-Boot ] #else [ original code ] #endif is an often used strategy for clarification of adjusted parts, that is, easier re-sync in future. Instead of defining __UBOOT__ in each source file, passing it from the top Makefile would be easier. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2014-08-25mtd,ubi,ubifs: sync with linux v3.15Heiko Schocher
snyc with linux v3.15: commit 1860e379875dfe7271c649058aeddffe5afd9d0d Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Sun Jun 8 11:19:54 2014 -0700 Linux 3.15 Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Tom Rini <trini@ti.com>
2014-08-25mtd, ubi, ubifs: update for the sync with linux v3.14Heiko Schocher
while playing with the new mtd/ubi/ubifs sync, found some small updates for it: - add del_mtd_partition() to include/linux/mtd/mtd - mtd: add a debug_printf - remove some not used functions Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Tom Rini <trini@ti.com>
2014-08-25mtd, ubi, ubifs: resync with Linux-3.14Heiko Schocher
resync ubi subsystem with linux: commit 455c6fdbd219161bd09b1165f11699d6d73de11c Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Sun Mar 30 20:40:15 2014 -0700 Linux 3.14 A nice side effect of this, is we introduce UBI Fastmap support to U-Boot. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Scott Wood <scottwood@freescale.com> Cc: Joerg Krause <jkrause@posteo.de>
2014-05-12fs: ubifs: drop __DATE__ and __TIME__Masahiro Yamada
__DATE__ and __TIME__ makes the build non-deterministic. Drop the debug message using them. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-26Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Conflicts: arch/arm/cpu/armv7/config.mk board/ti/am43xx/mux.c include/configs/am43xx_evm.h Signed-off-by: Tom Rini <trini@ti.com>
2014-02-26arm: Switch to -mno-unaligned-access when supported by the compilerTom Rini
When we tell the compiler to optimize for ARMv7 (and ARMv6 for that matter) it assumes a default of SCTRL.A being cleared and unaligned accesses being allowed and fast at the hardware level. We set this bit and must pass along -mno-unaligned-access so that the compiler will still breakdown accesses and not trigger a data abort. To better help understand the requirements of the project with respect to unaligned memory access, the Documentation/unaligned-memory-access.txt file has been added as doc/README.unaligned-memory-access.txt and is taken from the v3.14-rc1 tag of the kernel. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Mans Rullgard <mans@mansr.com> Signed-off-by: Tom Rini <trini@ti.com>
2014-02-21ubifs: fix checkpatch warningKaricheri, Muralidharan
Fix the following checkpatch warning:- WARNING: externs should be avoided in .c files Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2013-11-17fs: descend into sub directories when it is necessaryMasahiro Yamada
2013-10-31fs: convert makefiles to Kbuild styleMasahiro Yamada
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-04-11ubi: ubifs: Turn off verbose printsJoe Hershberger
The prints are out of control. SILENCE! Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2013-03-04ubifs: Allow ubifsmount volume reference by numberJoe Hershberger
UBI can mount volumes by name or number The current code forces you to name the volume by prepending every name with "ubi:". >From fs/ubifs/super.c * There are several ways to specify UBI volumes when mounting UBIFS: * o ubiX_Y - UBI device number X, volume Y; * o ubiY - UBI device number 0, volume Y; * o ubiX:NAME - mount UBI device X, volume with name NAME; * o ubi:NAME - mount UBI device 0, volume with name NAME. Now any name passed in any of the above forms are allowed. Also update the configs that referenced ubifsmount. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2013-02-28fs: Use new numeric setenv functionsSimon Glass
Use setenv_ulong(), setenv_hex() and setenv_addr() in fs/ Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-15ARM: prevent misaligned array initsAlbert ARIBAUD
Under option -munaligned-access, gcc can perform local char or 16-bit array initializations using misaligned native accesses which will throw a data abort exception. Fix files where these array initializations were unneeded, and for files known to contain such initializations, enforce gcc option -mno-unaligned-access. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> [trini: Switch to usign call cc-option for -mno-unaligned-access as Albert had done previously as that's really correct] Signed-off-by: Tom Rini <trini@ti.com>
2012-09-10ubifs: Fix ubifsload when using ZLIBVeli-Pekka Peltola
Using ZLIB compression with UBIFS fails if last data node is not a size of UBIFS_BLOCK_SIZE (4096 bytes). Easiest way to test this is trying to read a file smaller than 4k: => ubifsload 41000000 /etc/fstab Loading file '/etc/fstab' to addr 0x41000000 with size 704 (0x000002c0)... UBIFS error (pid 0): read_block: bad data node (block 0, inode 2506) UBIFS error (pid 0): do_readpage: cannot read page 0 of inode 2506, error -22 Error reading file '/etc/fstab' /etc/fstab not found! exit not allowed from main input shell. => With this patch: => ubifsload 41000000 /etc/fstab Loading file '/etc/fstab' to addr 0x41000000 with size 704 (0x000002c0)... Done => Signed-off-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com> Cc: kmpark@infradead.org Tested-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2012-09-03ubifs: Fix memory leak in ubifs_finddirStefan Roese
This patch fixes a memory leak in ubifs_finddir(). Signed-off-by: Stefan Roese <sr@denx.de> Cc: dev.ma.dma@gmail.com
2012-08-09UBIFS: Improve error message when reading superblock failedBernhard Walle
In addition to the error message also display the error code. I had the problem that my malloc memory was not enough (ENOMEM), and if u-boot had displayed the error code immediately that would have saved me some debugging. Signed-off-by: Bernhard Walle <walle@corscience.de> Use ubifs_err instead of printf. Add "errno=%d" in output as suggested by Albert Aribaud. Signed-off-by: Thomas Weber <weber@corscience.de>
2011-10-12ubifs bad superblock bugLars Poeschel
This patch fixes an issue when ubifs reads a bad superblock. Later it tries to free memory, that was not allocated, which freezes u-boot. This is fixed by looking for a non null pointer before free. The message I got before u-boot freezes: UBI: max/mean erase counter: 53/32 UBIFS: mounted UBI device 0, volume 1, name "rootfs" UBIFS: mounted read-only UBIFS: file system size: 49140 bytes (50319360 KiB, 0 MiB, 49140 LEBs) UBIFS: journal size: 49 bytes (6838272 KiB, 0 MiB, 6678 LEBs) UBIFS: media format: w4/r0 (latest is w4/r0) UBIFS: default compressor: LZO UBIFS: reserved for root: 0 bytes (0 KiB) UBIFS error (pid 0): ubifs_read_node: bad node type (255 but expected 9) UBIFS error (pid 0): ubifs_read_node: bad node at LEB 330:13104 UBIFS error (pid 0): ubifs_iget: failed to read inode 1, error -22 Error reading superblock on volume 'ubi:rootfs'! Signed-off-by: Lars Poeschel <larsi@wh2.tu-dresden.de> Cc: Kyungmin Park <kmpark@infradead.org> Signed-off-by: Stefan Roese <sr@denx.de>
2011-09-10UBIFS: fix warning: format '%lX' expects type 'long unsigned int'Wolfgang Denk
Commit 46d7274 "UBIFS: Change ubifsload to set the filesize variable" introduced the follwing compiler warning: ubifs.c: In function 'ubifs_load': ubifs.c:742: warning: format '%lX' expects type 'long unsigned int', but argument 3 has type 'u32' Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Bastian Ruppert <Bastian.Ruppert@Sewerin.de>
2011-09-10UBIFS: Change ubifsload to set the filesize variableBastian Ruppert
This is the same behaviour like tftp or fatload command. Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> CC: kmpark@infradead.org Acked-by: Detlev Zundel <dzu@denx.de>
2011-08-19ubifs: Fix bad free() sequence in ubifs_finddir()Wolfgang Denk
Free private_data member element before freeing file structure. This was causing malloc to crash. Also remove unnecessary variable assigments as file structure gets free'd as well. Signed-off-by: Rod Boyce <uboot@teamboyce.co.uk> Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2011-01-11UBIFS: Fix dereferencing type-punned pointer compiler warningDirk Behme
Fix compiler warning In file included from ubifs.h:2137:0, from ubifs.c:26: misc.h: In function 'ubifs_idx_key': misc.h:263:26: warning: dereferencing type-punned pointer will break strict-aliasing rules seen with gcc version 4.5.1 (Sourcery G++ Lite 2010.09-50). No functional change. CC: Stefan Roese <sr@denx.de> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2010-12-03ubifs.c: BUG: Error following linksRicardo Ribalda Delgado
The link_name variable is declared inside the if block and it is used outside it through the name pointer. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2010-12-03UBIFS: Change ubifsload to not read beyond the requested sizeStefan Roese
Until now ubifsload pads the destination with 0 up to a multiple of UBIFS_BLOCK_SIZE (4KiB) while reading a file to memory. This patch changes this behaviour to only read to the requested length. This is either the file length or the length/size provided as parameter to the ubifsload command. Signed-off-by: Stefan Roese <sr@denx.de>
2010-12-03UBIFS: Add ubifsumount command to unmount an active volumeStefan Roese
This new ubifsumount command allows the user to unmount a previously mounted UBIFS volume. Signed-off-by: Stefan Roese <sr@denx.de>
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-04-28ubifsmount fails due to not initialized listStefano Babic
ubifsmount is not working and causes an access with a pointer set to zero because the ubifs_fs_type is not initialized correctly. Signed-off-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-12-21move prototypes for gunzip() and zunzip() to common.hWolfgang Wegner
Prototype for gunzip/zunzip was only in lib_generic/gunzip.c and thus repeated in every file using it. This patch moves the prototypes to common.h and removes all prototypes distributed anywhere else. Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-10-03Conditionally perform common relocation fixupsPeter Tyser
Add #ifdefs where necessary to not perform relocation fixups. This allows boards/architectures which support relocation to trim a decent chunk of code. Note that this patch doesn't add #ifdefs to architecture-specific code which does not support relocation. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-28ubifs: Correct dereferencing of files-after-symlinksSimon Kagstrom
Files in directories which are symlinked to were not dereferenced correctly in last commit. E.g., with a symlink /boot/lnk -> /boot/real_dir loading /boot/lnk/uImage will fail. This patch fixes that by simply seeing to it that the target base directory has a slash after it. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-23ubifs: Add support for looking up directory and relative symlinksSimon Kagstrom
This patch adds support for resolving symlinks to directories as well as relative symlinks. Symlinks are now always resolved during file lookup, so the load stage no longer needs to special-case them. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-15Move __set/clear_bit from ubifs.h to bitops.hSimon Kagstrom
__set_bit and __clear_bit are defined in ubifs.h as well as in asm/include/bitops.h for some architectures. This patch moves the generic implementation to include/linux/bitops.h and uses that unless it's defined by the architecture. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
2009-06-09ubifs: fix small error path mismatchDaniel Mack
In do_readpage(), don't free 'dn' if its allocation failed. Signed-off-by: Daniel Mack <daniel@caiaq.de>
2009-04-30ubifs: BUG: Blocks commpressed with zlibRicardo Ribalda Delgado
Blocks compressed with zlib dont have the full gzip header. Without this patch, block compressed with zlib cannot be readed! Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es>
2009-04-28ubifs: BUG realpath string must be ended with NULLRicardo Ribalda Delgado
If the memory used to copy the link_make is "dirty" the string wont be ended with NULL, throwing out multiple memory bugs. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es> Acked-by: Stefan Roese <sr@denx.de>
2009-04-28UBIFS: Remove tnc_commit.c which is not used in the read-only versionStefan Roese
I missed removing this file while implementing the UBIFS support. It's not referenced at all, so let's remove it. Thanks to Artem Bityutskiy for spotting. Signed-off-by: Stefan Roese <sr@denx.de>
2009-04-28UBIFS: fix recovery bugAdrian Hunter
UBIFS did not recovery in a situation in which it could have. The relevant function assumed there could not be more nodes in an eraseblock after a corrupted node, but in fact the last (NAND) page written might contain anything. The correct approach is to check for empty space (0xFF bytes) from then on. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-04-05Update CHANGELOG, coding style cleanup.Wolfgang Denk
2009-04-04UBIFS: add R/O compatibilityArtem Bityutskiy
Now UBIFS is supported by u-boot. If we ever decide to change the media format, then people will have to upgrade their u-boots to mount new format images. However, very often it is possible to preserve R/O forward-compatibility, even though the write forward-compatibility is not preserved. This patch introduces a new super-block field which stores the R/O compatibility version. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Acked-by: Adrian Hunter <Adrian.Hunter@nokia.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-20UBIFS: Missing offset relocation for compressor 'none'Michael Lawnick
On systems where U-Boot is linked to another address than it really lays (e.g. backup image), calls via function pointers must be fixed with a '+= gd->reloc_off'. This was not done for none_compr in ubifs_compressors_init() what leads to system crash on ubifsmount command. Signed-off-by: Michael Lawnick <ml.lawnick@gmx.de> Acked-by: Stefan Roese <sr@denx.de>
2009-03-20UBIFS: Implement read-only UBIFS support in U-BootStefan Roese
The U-Boot UBIFS implementation is largely a direct copy from the current Linux version (2.6.29-rc6). As already done in the UBI version we have an "abstraction layer" to redefine or remove some OS calls (e.g. mutex_lock() ...). This makes it possible to use the original Linux code with very little changes. And by this we can better update to later Linux versions. I removed some of the Linux features that are not used in the U-Boot version (e.g. garbage-collection, write support). Signed-off-by: Stefan Roese <sr@denx.de> CC: Artem Bityutskiy <dedekind@infradead.org> CC: Adrian Hunter <ext-Adrian.Hunter@nokia.com>
