path: root/fs/ubifs
2016-10-31Fix spelling of "multiple".Vagrant Cascadian
Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-04-22ubifs: fix memory corruption in super.cHeiko Schocher
In list "super_blocks" ubifs collects allocated super_block structs. U-Boot frees on unmount the allocated struct, so the pointer stored in this list is free after the umount. On a new ubifs mount, the new allocated super_block struct get inserted into the super_blocks list ... which contains now a freed pointer, and the list_add_tail() corrupts the freed memory ... 2 solutions are possible: - remove the super_block from the super_blocks list on umount - as U-Boot does not use the super_blocks list ... remove it complete for U-Boot. Both solutions should not introduce problems for porting to newer linux version, so this patch removes the unused super_blocks list, as it saves code size and execution time. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-03-14dm: blk: Rename get_device_and_partition()Simon Glass
Rename this function to blk_get_device_part_str(). This is a better name because it makes it clear that the function returns a block device and parses a string. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: Drop the block_dev_desc_t typedefSimon Glass
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long and causes 80-column violations, rename it to struct blk_desc. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-01-25bug.h: move BUILD_BUG_* defines to include/linux/bug.hMasahiro Yamada
BUILD_BUG_* macros have been defined in several headers. It would be nice to collect them in include/linux/bug.h like Linux. This commit is cherry-picking useful macros from include/linux/bug.h of Linux 4.4. I did not import BUILD_BUG_ON_MSG() because it would not work if it is used with include/common.h in U-Boot. I'd like to postpone it until the root cause (the "error()" macro in include/common.h causes the name conflict with "__attribute__((error()))") is fixed. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-19Add more SPDX-License-Identifier tagsTom Rini
In a number of places we had wordings of the GPL (or LGPL in a few cases) license text that were split in such a way that it wasn't caught previously. Convert all of these to the correct SPDX-License-Identifier tag. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-05compat: Remove is_power_of_2() definitionFabio Estevam
Use the is_power_of_2() definition from log2.h to align with the kernel implementation. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-10-26ubi,ubifs: sync with linux v4.2Heiko Schocher
sync with linux v4.2 commit 64291f7db5bd8150a74ad2036f1037e6a0428df2 Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Sun Aug 30 11:34:09 2015 -0700 Linux 4.2 This update is needed, as it turned out, that fastmap was in experimental/broken state in kernel v3.15, which was the last base for U-Boot. Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
2015-10-24ubifs: Add functions for generic fs useHans de Goede
Implement the necessary functions for implementing generic fs support for ubifs. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-10-24ubifs: Modify ubifs u-boot wrapper function prototypes for generic fs useHans de Goede
Modify the ubifs u-boot wrapper function prototypes for generic fs use, and give them their own header file. This is a preparation patch for adding ubifs support to the generic fs code from fs/fs.c. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-09-11Move malloc_cache_aligned() to its own headerSimon Glass
At present malloc.h is included everywhere since it recently was added to common.h in this commit: 4519668 mtd/nand/ubi: assortment of alignment fixes This seems wasteful and unnecessary. We have been trying to trim down common.h and put separate functions into separate header files and that change goes in the opposite direction. Move malloc_cache_aligned() to a new header so that this can be avoided. The header would perhaps be better named as alignmem.h but it needs to be included after common.h and people might be confused by this. With the name memalign.h it fits nicely after malloc() in most cases. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-08-28mtd/nand/ubi: assortment of alignment fixesMarcel Ziswiler
Various U-Boot adoptions/extensions to MTD/NAND/UBI did not take buffer alignment into account which led to failures of the following form: ERROR: v7_dcache_inval_range - start address is not aligned - 0x1f7f0108 ERROR: v7_dcache_inval_range - stop address is not aligned - 0x1f7f1108 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Scott Wood <scottwood@freescale.com> [trini: Add __UBOOT__ hunk to lib/zlib/zutil.c due to malloc.h in common.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-01-29ubifs: Enable journal replay during mountAnton Habegger
Enable ubifs_replay_journal during mount_ubifs, which was disabled before. This commit fix an issue with unrecoverable ubifs volumes after power cut. Therefor the gc.c is imported now from 1860e37 Linux 3.15 hs: added SPDX-License-Identifier for fs/ubifs/gc.c Signed-off-by: Anton Habegger <anton.habegger@gmail.com>
2015-01-28ubifs: Import atomic_long operations from LinuxAnton Habegger
This commit is a preperation for a subsequent UBIFS commit which needs atomic_long operations. Therefor "include/asm-generic/atomic-long.h" is imported from 1860e37 Linux 3.15 Signed-off-by: Anton Habegger <anton.habegger@gmail.com>
2014-11-20include: move various macros to include/linux/kernel.hMasahiro Yamada
U-Boot has imported various utility macros from Linux scattering them to various places without consistency. In include/common.h are min, max, min3, max3, ARRAY_SIZE, ALIGN, container_of, DIV_ROUND_UP, etc. In include/linux/compat.h are min_t, max_t, round_up, round_down, etc. We also have duplicated defines of min_t in some *.c files. Moreover, we are suffering from too cluttered include/common.h. This commit moves various macros that originate in include/linux/kernel.h of Linux to their original position. Note: This commit simply moves the macros; the macros roundup, min, max, min2, max3, ARRAY_SIZE are different from those of Linux at this point. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-24kconfig: add blank Kconfig filesMasahiro Yamada
This would be useful to start moving various config options. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-09-16kbuild: force to define __UBOOT__ in all the C sourcesMasahiro Yamada
U-Boot has imported various source files from other projects, mostly Linux. Something like #ifdef __UBOOT__ [ modification for U-Boot ] #else [ original code ] #endif is an often used strategy for clarification of adjusted parts, that is, easier re-sync in future. Instead of defining __UBOOT__ in each source file, passing it from the top Makefile would be easier. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2014-08-25mtd,ubi,ubifs: sync with linux v3.15Heiko Schocher
snyc with linux v3.15: commit 1860e379875dfe7271c649058aeddffe5afd9d0d Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Sun Jun 8 11:19:54 2014 -0700 Linux 3.15 Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Tom Rini <trini@ti.com>
2014-08-25mtd, ubi, ubifs: update for the sync with linux v3.14Heiko Schocher
while playing with the new mtd/ubi/ubifs sync, found some small updates for it: - add del_mtd_partition() to include/linux/mtd/mtd - mtd: add a debug_printf - remove some not used functions Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Tom Rini <trini@ti.com>
2014-08-25mtd, ubi, ubifs: resync with Linux-3.14Heiko Schocher
resync ubi subsystem with linux: commit 455c6fdbd219161bd09b1165f11699d6d73de11c Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Sun Mar 30 20:40:15 2014 -0700 Linux 3.14 A nice side effect of this, is we introduce UBI Fastmap support to U-Boot. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Scott Wood <scottwood@freescale.com> Cc: Joerg Krause <jkrause@posteo.de>
2014-05-12fs: ubifs: drop __DATE__ and __TIME__Masahiro Yamada
__DATE__ and __TIME__ makes the build non-deterministic. Drop the debug message using them. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-26Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Conflicts: arch/arm/cpu/armv7/config.mk board/ti/am43xx/mux.c include/configs/am43xx_evm.h Signed-off-by: Tom Rini <trini@ti.com>
2014-02-26arm: Switch to -mno-unaligned-access when supported by the compilerTom Rini
When we tell the compiler to optimize for ARMv7 (and ARMv6 for that matter) it assumes a default of SCTRL.A being cleared and unaligned accesses being allowed and fast at the hardware level. We set this bit and must pass along -mno-unaligned-access so that the compiler will still breakdown accesses and not trigger a data abort. To better help understand the requirements of the project with respect to unaligned memory access, the Documentation/unaligned-memory-access.txt file has been added as doc/README.unaligned-memory-access.txt and is taken from the v3.14-rc1 tag of the kernel. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Mans Rullgard <mans@mansr.com> Signed-off-by: Tom Rini <trini@ti.com>
2014-02-21ubifs: fix checkpatch warningKaricheri, Muralidharan
Fix the following checkpatch warning:- WARNING: externs should be avoided in .c files Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2013-11-17fs: descend into sub directories when it is necessaryMasahiro Yamada
2013-10-31fs: convert makefiles to Kbuild styleMasahiro Yamada
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-04-11ubi: ubifs: Turn off verbose printsJoe Hershberger
The prints are out of control. SILENCE! Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2013-03-04ubifs: Allow ubifsmount volume reference by numberJoe Hershberger
UBI can mount volumes by name or number The current code forces you to name the volume by prepending every name with "ubi:". >From fs/ubifs/super.c * There are several ways to specify UBI volumes when mounting UBIFS: * o ubiX_Y - UBI device number X, volume Y; * o ubiY - UBI device number 0, volume Y; * o ubiX:NAME - mount UBI device X, volume with name NAME; * o ubi:NAME - mount UBI device 0, volume with name NAME. Now any name passed in any of the above forms are allowed. Also update the configs that referenced ubifsmount. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2013-02-28fs: Use new numeric setenv functionsSimon Glass
Use setenv_ulong(), setenv_hex() and setenv_addr() in fs/ Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-15ARM: prevent misaligned array initsAlbert ARIBAUD
Under option -munaligned-access, gcc can perform local char or 16-bit array initializations using misaligned native accesses which will throw a data abort exception. Fix files where these array initializations were unneeded, and for files known to contain such initializations, enforce gcc option -mno-unaligned-access. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> [trini: Switch to usign call cc-option for -mno-unaligned-access as Albert had done previously as that's really correct] Signed-off-by: Tom Rini <trini@ti.com>
2012-09-10ubifs: Fix ubifsload when using ZLIBVeli-Pekka Peltola
Using ZLIB compression with UBIFS fails if last data node is not a size of UBIFS_BLOCK_SIZE (4096 bytes). Easiest way to test this is trying to read a file smaller than 4k: => ubifsload 41000000 /etc/fstab Loading file '/etc/fstab' to addr 0x41000000 with size 704 (0x000002c0)... UBIFS error (pid 0): read_block: bad data node (block 0, inode 2506) UBIFS error (pid 0): do_readpage: cannot read page 0 of inode 2506, error -22 Error reading file '/etc/fstab' /etc/fstab not found! exit not allowed from main input shell. => With this patch: => ubifsload 41000000 /etc/fstab Loading file '/etc/fstab' to addr 0x41000000 with size 704 (0x000002c0)... Done => Signed-off-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com> Cc: kmpark@infradead.org Tested-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2012-09-03ubifs: Fix memory leak in ubifs_finddirStefan Roese
This patch fixes a memory leak in ubifs_finddir(). Signed-off-by: Stefan Roese <sr@denx.de> Cc: dev.ma.dma@gmail.com
2012-08-09UBIFS: Improve error message when reading superblock failedBernhard Walle
In addition to the error message also display the error code. I had the problem that my malloc memory was not enough (ENOMEM), and if u-boot had displayed the error code immediately that would have saved me some debugging. Signed-off-by: Bernhard Walle <walle@corscience.de> Use ubifs_err instead of printf. Add "errno=%d" in output as suggested by Albert Aribaud. Signed-off-by: Thomas Weber <weber@corscience.de>
2011-10-12ubifs bad superblock bugLars Poeschel
This patch fixes an issue when ubifs reads a bad superblock. Later it tries to free memory, that was not allocated, which freezes u-boot. This is fixed by looking for a non null pointer before free. The message I got before u-boot freezes: UBI: max/mean erase counter: 53/32 UBIFS: mounted UBI device 0, volume 1, name "rootfs" UBIFS: mounted read-only UBIFS: file system size: 49140 bytes (50319360 KiB, 0 MiB, 49140 LEBs) UBIFS: journal size: 49 bytes (6838272 KiB, 0 MiB, 6678 LEBs) UBIFS: media format: w4/r0 (latest is w4/r0) UBIFS: default compressor: LZO UBIFS: reserved for root: 0 bytes (0 KiB) UBIFS error (pid 0): ubifs_read_node: bad node type (255 but expected 9) UBIFS error (pid 0): ubifs_read_node: bad node at LEB 330:13104 UBIFS error (pid 0): ubifs_iget: failed to read inode 1, error -22 Error reading superblock on volume 'ubi:rootfs'! Signed-off-by: Lars Poeschel <larsi@wh2.tu-dresden.de> Cc: Kyungmin Park <kmpark@infradead.org> Signed-off-by: Stefan Roese <sr@denx.de>
2011-09-10UBIFS: fix warning: format '%lX' expects type 'long unsigned int'Wolfgang Denk
Commit 46d7274 "UBIFS: Change ubifsload to set the filesize variable" introduced the follwing compiler warning: ubifs.c: In function 'ubifs_load': ubifs.c:742: warning: format '%lX' expects type 'long unsigned int', but argument 3 has type 'u32' Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Bastian Ruppert <Bastian.Ruppert@Sewerin.de>
2011-09-10UBIFS: Change ubifsload to set the filesize variableBastian Ruppert
This is the same behaviour like tftp or fatload command. Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> CC: kmpark@infradead.org Acked-by: Detlev Zundel <dzu@denx.de>
2011-08-19ubifs: Fix bad free() sequence in ubifs_finddir()Wolfgang Denk
Free private_data member element before freeing file structure. This was causing malloc to crash. Also remove unnecessary variable assigments as file structure gets free'd as well. Signed-off-by: Rod Boyce <uboot@teamboyce.co.uk> Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2011-01-11UBIFS: Fix dereferencing type-punned pointer compiler warningDirk Behme
Fix compiler warning In file included from ubifs.h:2137:0, from ubifs.c:26: misc.h: In function 'ubifs_idx_key': misc.h:263:26: warning: dereferencing type-punned pointer will break strict-aliasing rules seen with gcc version 4.5.1 (Sourcery G++ Lite 2010.09-50). No functional change. CC: Stefan Roese <sr@denx.de> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2010-12-03ubifs.c: BUG: Error following linksRicardo Ribalda Delgado
The link_name variable is declared inside the if block and it is used outside it through the name pointer. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2010-12-03UBIFS: Change ubifsload to not read beyond the requested sizeStefan Roese
Until now ubifsload pads the destination with 0 up to a multiple of UBIFS_BLOCK_SIZE (4KiB) while reading a file to memory. This patch changes this behaviour to only read to the requested length. This is either the file length or the length/size provided as parameter to the ubifsload command. Signed-off-by: Stefan Roese <sr@denx.de>
2010-12-03UBIFS: Add ubifsumount command to unmount an active volumeStefan Roese
This new ubifsumount command allows the user to unmount a previously mounted UBIFS volume. Signed-off-by: Stefan Roese <sr@denx.de>
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-04-28ubifsmount fails due to not initialized listStefano Babic
ubifsmount is not working and causes an access with a pointer set to zero because the ubifs_fs_type is not initialized correctly. Signed-off-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-12-21move prototypes for gunzip() and zunzip() to common.hWolfgang Wegner
Prototype for gunzip/zunzip was only in lib_generic/gunzip.c and thus repeated in every file using it. This patch moves the prototypes to common.h and removes all prototypes distributed anywhere else. Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
