path: root/fs/reiserfs/Makefile
2008-08-31fs: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2004-03-25* Patch by Pavel Bartusek, 21 Mar 2004wdenk
Add Reiserfs support * Patch by Hinko Kocevar, 20 Mar 2004 - Add auto-release for SMSC LAN91c111 driver - Add save/restore of PTR and PNR regs as suggested in datasheet
