path: root/fs/jffs2
2007-07-10fs/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09fs/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-05Fixing some typos etc. introduced mainly by cfg patches.Wolfgang Denk
2007-07-04fs/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-04-24[PATCH] MTD partition support, JFFS2 supportMichal Simek
2006-04-08Fix JFFS2 support for legacy NAND driver.Marian Balakowicz
Some more NAND cleanup and small fixes.
2006-03-17Add support for Lite5200B board.Wolfgang Denk
Patch by Patch by Jose Maria (Txema) Lopez, 16 Jan 2006
2006-03-12Add crc of data to jffs2 (in jffs2_1pass_build_lists()).Wolfgang Denk
Patch by Rick Bronson, 15 Jun 2005
2006-03-05Re-factoring the legacy NAND code (legacy NAND now only in board-specificBartlomiej Sieka
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards.
2006-02-24Merge with /home/wd/git/u-boot/testing-NAND/ to add new NAND handling.Bartlomiej Sieka
2005-10-15Merge with /home/m8/git/u-bootWolfgang Denk
2005-10-11Added support for TQM834x boards.Marian Balakowicz
2005-09-14Update of new NAND codeWolfgang Denk
Patch by Ladislav Michl, 13 Sep 2005
2005-08-17Merge with testing-NAND (Rewrite of NAND code)Wolfgang Denk
2005-08-17Rewrite of NAND code based on what is in 2.6.12 Linux kernelWolfgang Denk
Patch by Ladislav Michl, 29 Jun 2005
2005-08-16Fix return values of the jffs2 commands ls/fsload/fsinfo,Wolfgang Denk
so we can use them to, e.g., check the existence of a file with "if ls foo; then this; else that; fi" in the hush shell Patch by Andreas Engel, 16 August 2005
2005-08-10Add configuration for IFM AEV FIFO board.Wolfgang Denk
Minor coding style cleanup.
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
2005-05-05It's better to handle LZO and LZARI compression mdoes for JFFS2 withLABEL_2005_05_05_1920wdenk
a single #define.
2005-05-05Major upate of JFFS2 code; now in sync with snapshot of MTD CVS ofwdenk
March 13, 2005); new configuration options CONFIG_JFFS2_LZO and CONFIG_JFFS2_LZARI are added. Both are undefined by default.
2005-05-04Fix problem with symbolic links in JFFS2 code.wdenk
2004-05-12Patch by Klaus Heydeck, 12 May 2004:wdenk
Using external watchdog for KUP4 boards in mpc8xx/cpu.c; load_sernum_ethaddr() for KUP4 boards in lib_ppc/board.c; various changes to KUP4 board specific files
2004-05-05* Fix memory leak in the NAND-specific JFFS2 codewdenk
* Fix SL811 USB controller when attached to a USB hub
2004-05-03* Fix minor NAND JFFS2 related issuewdenk
* Fixes for SL811 USB controller: - implement workaround for broken memory stick - improve error handling * Increase packet send timeout to 10 ms in cpu/mpc8xx/scc.c to better cope with congested networks.
2004-04-25* Back out Patch by Christian Hohnstaedt, 23 Apr 2004:wdenk
(JFFS2 speed enhancements) because of using non-public data (PHYS_FLASH_SECT_SIZE) * Patch by Travis Sawyer, 23 Apr 2004: Fix VSC/CIS 8201 phy descrambler interoperability timing due to errata from Vitesse Semiconductor.
2004-04-25* Patch by Christian Hohnstaedt, 23 Apr 2004:wdenk
JFFS2 speed enhancements: - repair header CRC calculation in jffs2_1pass.c - add eraseblock size to the partition information to skip empty eraseblocks if we find more then 4k of free space. - The JFFS2 scanner is now fast enough to remove the spinning wheel so #ifdef-ed out. - add watchdog calls in long running loops * Patch by Philippe Robin, 22 Apr 2004: Fix ethernet configuration for "versatile" board * Patch by Kshitij Gupta, 21 Apr 2004: Remove busy loop and use MPU timer fr usleep() on OMAP1510/1610 boards * Patch by Steven Scholz, 24 Feb 2004: Fix a bug in AT91RM9200 ethernet driver: The MII interface is now initialized before accessing the PHY. * Cleanup PCI ID's
2004-04-18* Patch by Yasushi Shoji, 07 Apr 2004:wdenk
- add support for microblaze processors - add support for AtmarkTechno "suzaku" board
2004-04-18* Configure PPChameleon board to use redundand environment in flashLABEL_2004_04_18_2135wdenk
* Configure PPChameleon board to use JFFS2 NAND support. * Added support for JFFS2 filesystem (read-only) on top of NAND flash
2004-03-23* Patches by Thomas Viehweger, 16 Mar 2004:wdenk
- show PCI clock frequency on MPC8260 systems - add FCC_PSMR_RMII flag for HiP7 processors - in do_jffs2_fsload(), take load address from load_addr if not set explicit, update load_addr otherwise - replaced printf by putc/puts when no formatting is needed (smaller code size, faster execution)
2004-01-04* Fix problems caused by Robert Schwebel's cramfs patchwdenk
* Patch by Scott McNutt, 02 Jan 2004: Add support for the Nios Active Serial Memory Interface (ASMI) on Cyclone devices * Patch by Andrea Marson, 16 Dec 2003: Add support for the PPChameleon ME and HI modules * Patch by Yuli Barcohen, 22 Dec 2003: Add support for Motorola DUET ADS board (MPC87x/88x)
2004-01-03* Patch by Robert Schwebel, 15 Dec 2003:wdenk
add support for cramfs (uses JFFS2 command interface)
2003-09-10* Patches by Denis Peter, 9 Sep 2003:U-Boot-0_4_8wdenk
add FAT support for IDE, SCSI and USB * Patches by Gleb Natapov, 2 Sep 2003: - cleanup of POST code for unsupported architectures - MPC824x locks way0 of data cache for use as initial RAM; this patch unlocks it after relocation to RAM and invalidates the locked entries. * Patch by Gleb Natapov, 30 Aug 2003: new I2C driver for mpc107 bridge. Now works from flash. * Patch by Dave Ellis, 11 Aug 2003: - JFFS2: fix typo in common/cmd_jffs2.c - JFFS2: fix CFG_JFFS2_SORT_FRAGMENTS option - JFFS2: remove node version 0 warning - JFFS2: accept JFFS2 PADDING nodes - SXNI855T: add AM29LV800 support - SXNI855T: move environment from EEPROM to flash - SXNI855T: boot from JFFS2 in NOR or NAND flash * Patch by Bill Hargen, 11 Aug 2003: fixes for I2C on MPC8240 - fix i2c_write routine - fix iprobe command - eliminates use of global variables, plus dead code, cleanup.
2003-03-14* Avoid flicker on the TRAB's VFD by synchronizing the enable withwdenk
the HSYNC/VSYNC. Requires new CPLD code (Version 101 for Rev. 100 boards, version 153 for Rev. 200 boards). * Patch by Vladimir Gurevich, 12 Mar 2003: Fix relocation problem of statically initialized string pointers in common/cmd_pci.c * Patch by Kai-Uwe Blöm, 12 Mar 2003: Cleanup & bug fixes for JFFS2 code: - the memory mangement was broken. It caused havoc on malloc by writing beyond the block boundaries. - the length calculation for files was wrong, sometimes resulting in short file reads. - data copying now optionally takes fragment version numbers into account, to avoid copying from older data. See doc/README.JFFS2 for details.
2002-03-08Initial revisionwdenk
2002-02-17Initial revisionwdenk
