path: root/fs/jffs2
2008-12-16jffs2: include <linux/mtd/compat.h> instead of defining own min_tIlya Yanok
Include <linux/mtd/compat.h> header for min_t definition instead of providing our own one. Removes warnings in case of OneNAND support enabled. Although I thinks it's a bit silly to include <linux/mtd/compat.h> just for min_t... Signed-off-by: Ilya Yanok <yanok@emcraft.com> Acked-by: Stefan Roese <sr@denx.de>
2008-12-09jffs2: cache data_crc resultsIlya Yanok
As we moved data_crc() invocation from jffs2_1pass_build_lists() to jffs2_1pass_read_inode() data_crc is going to be calculated on each inode access. This patch adds caching of data_crc() results. There is no significant improvement in speed (because of flash access caching added in previous patch I think, crc in RAM is really fast) but this patch impacts memory usage -- every b_node structure uses 12 bytes instead of 8. Signed-off-by: Alexey Neyman <avn@emcraft.com> Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2008-12-09jffs2: summary supportIlya Yanok
This patch adds support for reading fs information from summary node instead of scanning full eraseblock. Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2008-12-09jffs2: add buffer to cache flash accessesIlya Yanok
With this patch JFFS2 code allocates memory buffer of max_totlen size (size of the largest node, calculated during scan time) and uses it to store entire node. Speeds up loading. If malloc fails we use old ways to do things. Signed-off-by: Alexey Neyman <avn@emcraft.com> Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2008-12-09jffs2: rewrite jffs2 scanning code based on Linux oneIlya Yanok
Rewrites jffs2_1pass_build_lists() function in style of Linux's jffs2_scan_medium() and jffs2_scan_eraseblock(). This includes: - Caching flash acceses - Smart dealing with free space Signed-off-by: Alexey Neyman <avn@emcraft.com> Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2008-12-09jffs2: fix searching for latest version in jffs2_1pass_list_inodes()Ilya Yanok
We need to update i_version inside cycle to find really latest version inside jffs2_1pass_list_inodes(). With that fixed we can use isize inside dump_inode() instead of calling expensive jffs2_1pass_read_inode(). Signed-off-by: Alexey Neyman <avn@emcraft.com> Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2008-10-31JFFS2: Eliminate compiler error when both NAND and OneNAND are enabled.Scott Wood
Reported-by: Alessandro Rubini <rubini-list@gnudd.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-09-06Add JFFS2 command support on OneNANDKyungmin Park
2008-08-31fs: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-08-13drivers/mtd/nand: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-07-14Fix printf() format issues with sizeof_t types by using %zuWolfgang Denk
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-07-13Fix some more printf() format problems.Wolfgang Denk
2008-07-13Fix some more printf() format issues.Jean-Christophe PLAGNIOL-VILLARD
2008-06-29jffs2_1pass.c: add watchdog supportStuart Wood
Signed-off-by: Stuart Wood <stuart.wood@labxtechnologies.com>
2008-05-28Cleanup nand_info[] declaration.Stelian Pop
The nand_info array is declared as extern in several .c files. Those days, nand.h contains a reference to the array, so there is no need to declare it elsewhere. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-04-28jffs2_1pass.c: fix incompatible pointer type warningWolfgang Denk
2008-01-09fix comments with new drivers organizationMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2007-11-15Build: split COBJS value into multiple linesGrant Likely
This change is in preparation for condtitionial compile support in the build system. By spliting them all into seperate lines now, subsequent patches that change 'COBJS-y += ' into 'COBJS-$(CONFIG_<blah>) += ' will be less invasive and easier to review Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-07-10fs/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09fs/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-05Fixing some typos etc. introduced mainly by cfg patches.Wolfgang Denk
2007-07-04fs/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-04-24[PATCH] MTD partition support, JFFS2 supportMichal Simek
2006-04-08Fix JFFS2 support for legacy NAND driver.Marian Balakowicz
Some more NAND cleanup and small fixes.
2006-03-17Add support for Lite5200B board.Wolfgang Denk
Patch by Patch by Jose Maria (Txema) Lopez, 16 Jan 2006
2006-03-12Add crc of data to jffs2 (in jffs2_1pass_build_lists()).Wolfgang Denk
Patch by Rick Bronson, 15 Jun 2005
2006-03-05Re-factoring the legacy NAND code (legacy NAND now only in board-specificBartlomiej Sieka
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards.
2006-02-24Merge with /home/wd/git/u-boot/testing-NAND/ to add new NAND handling.Bartlomiej Sieka
2005-10-15Merge with /home/m8/git/u-bootWolfgang Denk
2005-10-11Added support for TQM834x boards.Marian Balakowicz
2005-09-14Update of new NAND codeWolfgang Denk
Patch by Ladislav Michl, 13 Sep 2005
2005-08-17Merge with testing-NAND (Rewrite of NAND code)Wolfgang Denk
2005-08-17Rewrite of NAND code based on what is in 2.6.12 Linux kernelWolfgang Denk
Patch by Ladislav Michl, 29 Jun 2005
2005-08-16Fix return values of the jffs2 commands ls/fsload/fsinfo,Wolfgang Denk
so we can use them to, e.g., check the existence of a file with "if ls foo; then this; else that; fi" in the hush shell Patch by Andreas Engel, 16 August 2005
2005-08-10Add configuration for IFM AEV FIFO board.Wolfgang Denk
Minor coding style cleanup.
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
2005-05-05It's better to handle LZO and LZARI compression mdoes for JFFS2 withLABEL_2005_05_05_1920wdenk
a single #define.
2005-05-05Major upate of JFFS2 code; now in sync with snapshot of MTD CVS ofwdenk
March 13, 2005); new configuration options CONFIG_JFFS2_LZO and CONFIG_JFFS2_LZARI are added. Both are undefined by default.
2005-05-04Fix problem with symbolic links in JFFS2 code.wdenk
2004-05-12Patch by Klaus Heydeck, 12 May 2004:wdenk
Using external watchdog for KUP4 boards in mpc8xx/cpu.c; load_sernum_ethaddr() for KUP4 boards in lib_ppc/board.c; various changes to KUP4 board specific files
2004-05-05* Fix memory leak in the NAND-specific JFFS2 codewdenk
* Fix SL811 USB controller when attached to a USB hub
2004-05-03* Fix minor NAND JFFS2 related issuewdenk
* Fixes for SL811 USB controller: - implement workaround for broken memory stick - improve error handling * Increase packet send timeout to 10 ms in cpu/mpc8xx/scc.c to better cope with congested networks.
2004-04-25* Back out Patch by Christian Hohnstaedt, 23 Apr 2004:wdenk
(JFFS2 speed enhancements) because of using non-public data (PHYS_FLASH_SECT_SIZE) * Patch by Travis Sawyer, 23 Apr 2004: Fix VSC/CIS 8201 phy descrambler interoperability timing due to errata from Vitesse Semiconductor.
2004-04-25* Patch by Christian Hohnstaedt, 23 Apr 2004:wdenk
JFFS2 speed enhancements: - repair header CRC calculation in jffs2_1pass.c - add eraseblock size to the partition information to skip empty eraseblocks if we find more then 4k of free space. - The JFFS2 scanner is now fast enough to remove the spinning wheel so #ifdef-ed out. - add watchdog calls in long running loops * Patch by Philippe Robin, 22 Apr 2004: Fix ethernet configuration for "versatile" board * Patch by Kshitij Gupta, 21 Apr 2004: Remove busy loop and use MPU timer fr usleep() on OMAP1510/1610 boards * Patch by Steven Scholz, 24 Feb 2004: Fix a bug in AT91RM9200 ethernet driver: The MII interface is now initialized before accessing the PHY. * Cleanup PCI ID's
2004-04-18* Patch by Yasushi Shoji, 07 Apr 2004:wdenk
- add support for microblaze processors - add support for AtmarkTechno "suzaku" board
