nand_info[] is now an array of pointers, with the actual mtd_info
instance embedded in struct nand_chip.
This is in preparation for syncing the NAND code with Linux 4.6,
which makes the same change to struct nand_chip. It's in a separate
commit due to the large amount of changes required to accommodate the
change to nand_info[].
Signed-off-by: Scott Wood <oss@buserror.net>
We only use 'ofs' in jffs2_sum_scan_sumnode when debugging as it's part
of a dbg_summary call. Mark this as __maybe_unused.
When building the file system the existing code does an insertion into
a linked list. It attempts to speed this up by keeping a pointer to
where the last entry was inserted but it's still slow.
Now the nodes are just inserted into the list without searching
through for the correct place. This unsorted list is then sorted once
using mergesort after all the entries have been added to the list.
This speeds up the scanning of the flash file system considerably.
Signed-off-by: Mark Tomlinson <mark.tomlinson@alliedtelesis.co.nz>
If a sector has a CLEANMARKER at the beginning, it indicates that the
entire sector has been erased. Therefore, if this is found, we can skip the
entire block. This was not being done before this patch.
The code now does the same as the kernel does when encountering a
CLEANMARKER. It still checks that the next few words are FFFFFFFF, and if
so, the block is assumed to be empty, and so is skipped.
The scan code is similar to the linux kernel, but the kernel defines a much
smaller size to scan through before deciding a sector is blank. Assuming
that what is in the kernel is OK, make these two match.
On its own, this change makes no difference to scanning of any sectors
which have a clean marker at the beginning, since the entire sector is not
blank.
If the flash is slow, reading less from the flash into buffers makes
the process faster.
jffs2_1pass_read_inode() would read the entire data for each node
in the filesystem, regardless of whether it was part of the file
to be loaded or not. By only reading the header data for an inode,
and then reading the data only when it is found to be part of the
file to be loaded, much copying of data is saved.
jffs2_1pass_list_inodes() read each inode for every file in the
directory into a buffer. By using NULL as a buffer pointer, NOR
flash simply returns a pointer, and therefore avoids a memory copy.
If multiple versions of a file exist, only the most recent version
should be used. The scheme to write 0 for the inode in older versions
did not work, since this would have required writing to flash.
The only time this caused an issue was listing a directory, where older
versions of the file would still be seen. Since the directory entries
are sorted, just look at the next entry in the list, and if it's the same
move to that entry instead.
Copying complete nodes from flash can be slow if the flash is slow
to read. By only reading the data needed, the sorting operation can
be made much faster.
The directory entry comparison function also had a two bugs. First, it
did not ensure the name was copied, so the name comparison may have
been faulty (although it would have worked with NOR flash). Second,
setting the ino to zero to ignore the entry did not work, since this
was either writing to a temporary buffer, or (for NOR flash) directly
to flash. Either way, the change was not remembered.
If a destination is not provided, jffs2_1pass_read_inode() only
returns the length of the file. In this case, avoid reading all
the data nodes, and return as soon as the length of the file is
known.
Clang interpretes an if condition like "if ((a = b) == NULL)
as it tries to assign a value in a statement. Hence if you do
"if ((something)) it warns you that you might be confused.
Hence drop the double braces for plane if statements.
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
Since part_info size became 64bit we need to use lldiv here.
This lets us use it in more places than just mtd code.
Fix:
jffs2_1pass.c: In function 'jffs2_1pass_read_inode':
jffs2_1pass.c:699:7: warning: variable 'ret' set but not used [-Wunused-but-set-variable]
jffs2_1pass.c: In function 'jffs2_1pass_build_lists':
jffs2_1pass.c:1578:14: warning: variable 'empty_start' set but not used [-Wunused-but-set-variable]
Signed-off-by: Loïc Minier <loic.minier@linaro.org>
$ ./MAKEALL suen3
jffs2_1pass.c: In function 'get_fl_mem':
jffs2_1pass.c:399: warning: unused variable 'id'
jffs2_1pass.c: In function 'get_node_mem':
jffs2_1pass.c:423: warning: unused variable 'id'
Tested-by: Tom <Tom.Rix@windriver.com>
Support for LZARI compression mode was added based on a MTD CVS
snapshot of March 13, 2005. However, fs/jffs2/compr_lzari.c contains
contradictory licensing terms: the original copyright clause says "All
rights reserved. Permission granted for non-commercial use.", but
later reference to the file 'LICENCE' in the jffs2 directory was added
which says GPL v2 or later.
As no boards ever used LZARI compression, and this file is also not
present in recent MTD code, we resolve this conflict by removing the
conflicting file and references to it.
Also copy the referenced but missing file 'LICENCE' from the current
MTD source tree.
This patch fixes some issues with JFFS2 summary support in U-Boot.
1/ Summary support made compilation configurable (as summary support
considered expiremental even in Linux).
2/ Summary code can do unaligned 16-bit and 32-bit memory accesses.
We need to get data byte by byte to exclude data aborts.
3/ Make summary scan in two passes so we can safely fall back to full
scan if we found unsupported entry in the summary.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
We should call jffs2_clean_cache() if we return from jffs2_build_lists()
with an error to prevent usage of incomplete lists. Also we should
free() a local buffer to prevent memory leaks.
Legacy NAND had been scheduled for removal. Any boards that use this
were already not building in the previous release due to an #error.
The disk on chip code in common/cmd_doc.c relies on legacy NAND,
and it has also been removed. There is newer disk on chip code
in drivers/mtd/nand; someone with access to hardware and sufficient
time and motivation can try to get that working, but for now disk
on chip is not supported.
Include <linux/mtd/compat.h> header for min_t definition instead of
providing our own one. Removes warnings in case of OneNAND support
enabled.
Although I thinks it's a bit silly to include <linux/mtd/compat.h>
just for min_t...
As we moved data_crc() invocation from jffs2_1pass_build_lists() to
jffs2_1pass_read_inode() data_crc is going to be calculated on each
inode access. This patch adds caching of data_crc() results. There
is no significant improvement in speed (because of flash access
caching added in previous patch I think, crc in RAM is really fast)
but this patch impacts memory usage -- every b_node structure uses
12 bytes instead of 8.
Signed-off-by: Alexey Neyman <avn@emcraft.com>
This patch adds support for reading fs information from summary
node instead of scanning full eraseblock.
With this patch JFFS2 code allocates memory buffer of max_totlen size
(size of the largest node, calculated during scan time) and uses it to
store entire node. Speeds up loading. If malloc fails we use old ways
to do things.
Rewrites jffs2_1pass_build_lists() function in style of Linux's
jffs2_scan_medium() and jffs2_scan_eraseblock().
This includes:
- Caching flash acceses
- Smart dealing with free space
We need to update i_version inside cycle to find really latest version
inside jffs2_1pass_list_inodes(). With that fixed we can use isize inside
dump_inode() instead of calling expensive jffs2_1pass_read_inode().
Reported-by: Alessandro Rubini <rubini-list@gnudd.com>
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY
Signed-off-by: Stuart Wood <stuart.wood@labxtechnologies.com>
The nand_info array is declared as extern in several .c files.
Those days, nand.h contains a reference to the array, so there is
no need to declare it elsewhere.
Signed-off-by: Stelian Pop <stelian@popies.net>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
Fixed some broken instances of "#ifdef CMD_CFG_IDE" too.
Those always evaluated TRUE, and thus were always compiled
even when IDE really wasn't defined/wanted.
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
Some more NAND cleanup and small fixes.
Patch by Rick Bronson, 15 Jun 2005
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and
BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for
NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is
implemented for these boards.
