As in the case of fs_set_blk_dev(), fs_set_blk_dev_with_part() should
maintain and update fs_dev_part whenever called.
Without this patch, a problem will come up when an efi binary associated
with efi's BOOTxxxx variable is invoked via "bootefi bootmgr".
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
In this patch, unlink support is added to FAT file system.
A directory can be deleted only if it is empty.
In this implementation, only a directory entry for a short file name
will be removed. So entries for a long file name can and should be
reclaimed with fsck.
"unlink" interface is added to file operations.
This is a preparatory change as unlink support for FAT file system
will be added in next patch.
In this patch, mkdir support is added to FAT file system.
A newly created directory contains only "." and ".." entries.
"mkdir" interface is added to file operations.
This is a preparatory change as mkdir support for FAT file system
%s/dumm /dummy /
Add fs_get_type_name so we can get the current filesystem type.
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
The message
"** %s shorter than offset + len **\n"
may be interesting when debugging but it does not indicate an
error.
So we should not write it if we are not in debug mode.
Fixes: 7a3e70cfd88c fs/fs.c: read up to EOF when len would read past EOF
Otherwise fs_opendir will fault.
Signed-off-by: Marek Behun <marek.behun@nic.cz>
create mode 100644 fs/btrfs/Kconfig
create mode 100644 fs/btrfs/Makefile
create mode 100644 fs/btrfs/btrfs.c
create mode 100644 include/btrfs.h
Add a generic implementation of 'ls' using opendir/readdir/closedir, and
replace fat's custom implementation. Other filesystems should move to
the generic implementation after they add opendir/readdir/closedir
support.
Signed-off-by: Rob Clark <robdclark@gmail.com>
Reviewed-by: Łukasz Majewski <lukma@denx.de>
Needed to support efi file protocol. The fallback.efi loader wants
to be able to read the contents of the /EFI directory to find an OS
to boot.
Modelled after POSIX opendir()/readdir()/closedir(). Unlike the other
fs APIs, this is stateful (ie. state is held in the FS_DIR "directory
stream"), to avoid re-traversing of the directory structure at each
step. The directory stream must be released with closedir() when it
is no longer needed.
We are now using an env_ prefix for environment functions. Rename these
two functions for consistency. Also add function comments in common.h.
Quite a few places use getenv() in a condition context, provoking a
warning from checkpatch. These are fixed up in this patch also.
Suggested-by: Wolfgang Denk <wd@denx.de>
commonly used functions, for consistency. Also add function comments in
common.h.
We are now using an env_ prefix for environment functions. Rename setenv()
Rename this function to blk_get_device_part_str(). This is a better name
because it makes it clear that the function returns a block device and
parses a string.
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long
and causes 80-column violations, rename it to struct blk_desc.
In a number of places we had wordings of the GPL (or LGPL in a few
cases) license text that were split in such a way that it wasn't caught
previously. Convert all of these to the correct SPDX-License-Identifier
tag.
Signed-off-by: David Müller <d.mueller@elsoft.ch>
Add generic fs support, so that commands like ls, load and test -e can be
used on ubifs.
http://lists.denx.de/pipermail/u-boot/2012-September/134347.html
allows for reading files in chunks from the shell.
When this feature is used to read past the end of a file an error
was returned instead of returning the bytes read up to the end of
file. Thus the following fails in the shell:
offset = 0
len = chunksize
do
read file, offset, len
write data
until bytes_read < len
The patch changes the behaviour to printing an informational
message and returning the actual read number of bytes aka read(2)
behaviour for convenient use in U-Boot scripts.
In the case where the arch defines a custom map_sysmem(), make sure that
including just mapmem.h is sufficient to have these functions as they
are when the arch does not override it.
Also split the non-arch specific functions out of common.h
New command to determine the filesystem type of a given partition.
Optionally stores the filesystem type in a environment variable.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
The changes to introduce loff_t into filesize means that we need to do
64bit math on 32bit platforms. Make sure we use the right wrappers for
these operations.
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Cc: Suriyan Ramasami <suriyan.r@gmail.com>
Tested-by: Pierre Aubert <p.aubert@staubli.com>
The sandbox/ext4/fat/generic fs commands do not gracefully deal with files
greater than 2GB. Negative values are returned in such cases.
To handle this, the fs functions have been modified to take an additional
parameter of type "* loff_t" which is then populated. The return value
of the fs functions are used only for error conditions.
Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com>
[trini: Update board/gdsys/p1022/controlcenterd-id.c,
drivers/fpga/zynqpl.c for changes]
Some filesystems have a UUID stored in its superblock. To
allow using root=UUID=... for the kernel command line we
need a way to read-out the filesystem UUID.
changes rfc -> v1:
- make the environment variable an option parameter. If not
given, the UUID is printed out. If given, it is stored in the env
variable.
- corrected typos
- return error codes
changes v1 -> v2:
- fix return code of do_fs_uuid(..)
- document do_fs_uuid(..)
- implement fs_uuid_unsuported(..) be more consistent with the
way other optional functionality works
changes v2 -> v3:
- change ext4fs_uuid(..) to make use of #if .. #else .. #endif
construct to get rid of unreachable code
Hit any key to stop autoboot: 0
=> fsuuid
fsuuid - Look up a filesystem UUID
Usage:
fsuuid <interface> <dev>:<part>
- print filesystem UUID
fsuuid <interface> <dev>:<part> <varname>
- set environment variable to filesystem UUID
=> fsuuid mmc 0:1
d9f9fc05-45ae-4a36-a616-fccce0e4f887
=> fsuuid mmc 0:2
eb3db83c-7b28-499f-95ce-9e0bb21cda81
=> fsuuid mmc 0:1 uuid1
=> fsuuid mmc 0:2 uuid2
=> printenv uuid1
uuid1=d9f9fc05-45ae-4a36-a616-fccce0e4f887
=> printenv uuid2
uuid2=eb3db83c-7b28-499f-95ce-9e0bb21cda81
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
These commands may be used to determine the size of a file without
actually reading the whole file content into memory. This may be used
to determine if the file will fit into the memory buffer that will
contain it. In particular, the DFU code will use it for this purpose
in the next commit.
If filename is passed instead of address to ext2load or fatload,
u-boot silently accepts that, and uses 0 for load address and default
filename from environment. That is confusing, display help instead.
Signed-off-by: Pavel Machek <pavel@denx.de>
This hooks into the generic "file exists" support added in an earlier
patch, and provides an implementation for the FAT filesystem.
patch, and provides an implementation for the ext4 filesystem.
patch, and provides an implementation for the sandbox test environment.
FAT and ext4 expect that the passed in block device descriptor not be
NULL. This causes problems on sandbox, where get_device_and_partition()
succeeds for the "host" device, yet passes back a NULL device descriptor.
Add special handling for this situation, so that the generic filesystem
commands operate as expected on sandbox.
This could be used in scripts such as:
if test -e mmc 0:1 /boot/boot.scr; then
load mmc 0:1 ${scriptaddr} /boot/boot.scr
source ${scriptaddr}
fi
rather than:
if load mmc 0:1 ${scriptaddr} /boot/boot.scr; then
fi
This prevents errors being printed by attempts to load non-existent
files, which can be important when checking for a large set of files,
such as /boot/boot.scr.uimg, /boot/boot.scr, /boot/extlinux.conf,
/boot.scr.uimg, /boot.scr, /extlinux.conf.
Fix a few issues with the generic "save" shell command, and fs_write()
function.
1) fstypes[].write wasn't filled in for some file-systems, and isn't
checked when used, which could cause crashes/... if executing save
on e.g. fat/ext filesystems.
2) fs_write() requires the length argument to be non-zero, since it needs
to know exactly how many bytes to write. Adjust the comments and code
according to this.
3) fs_write() wasn't prototyped in <fs.h> like other generic functions;
other code should be able to call this directly rather than invoking
the "save" shell command.
As documented, almost all U-Boot commands expect numbers to be entered
in hexadecimal input format. (Exception: for historical reasons, the
"sleep" command takes its argument in decimal input format.)
This rule was broken for the "load" command; for details please see
especially commits 045fa1e "fs: add filesystem switch libary,
implement ls and fsload commands" and 3f83c87 "fs: fix number base
behaviour change in fatload/ext*load". In the result, the load
command would always require an explicit "0x" prefix for regular
(i. e. base 16 formatted) input.
Change this to use the standard notation of base 16 input format.
While strictly speaking this is a change of the user interface, we
hope that it will not cause trouble. Stephen Warren comments (see
[1]):
I suppose you can change the behaviour if you want; anyone
writing "0x..." for their values presumably won't be
affected, and if people really do assume all values in U-Boot
are in hex, presumably nobody currently relies upon using
non-prefixed values with the generic load command, since it
doesn't work like that right now.
[1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/171172
Acked-by: Tom Rini <trini@ti.com>
This allows write of files from the host filesystem in sandbox. There is
currently no concept of overwriting the file and removing its existing
contents - all writing is done on top of what is there. This means that
writing 10 bytes to the start of a 1KB file will only update those 10
bytes, not truncate the file to 10 byte slong.
If the file does not exist it is created.
Add a new method for saving that filesystems can implement. This mirrors the
existing load method.
This allows reading of files from the host filesystem in sandbox.
Reviewed-by: Tom Rini <trini@ti.com>
It doesn't make a lot of sense to have these methods in fs.c. They are
filesystem-specific, not generic code. Add each to the relevant
filesystem and remove the associated #ifdefs in fs.c.
This allows us to use filesystems on sandbox. It has no effect on other
architectures.
Rather than rely on global variables for the probe functions, pass in
the information that we need filled in. This allows us to potentially
keep the variables private to fs.c in the future, and the meaning of
the probe function is clearer.
We can use the available methods and avoid using switch(). When the
filesystem is not supported, we fall through to the 'unsupported'
methods: fs_probe_unsupported() prints an error, so the others do
not need to.
There is a structure in fs.c with just a probe method. By adding methods
for other operations, we can avoid lots of #ifdefs and switch()s. As a
first step, create the structure ready for use.
Use setenv_ulong(), setenv_hex() and setenv_addr() in fs/
This patch adds time measurement and throughput calculation for
all supported load commands.
The output of ext2load changes from
---8<---
1830666 bytes read
--->8---
to
---8<---
1830666 bytes read in 237 ms (7.4 MiB/s)
--->8---
[agust: rebased and revised commit log]
When the generic filesystem load command "fsload" was written, I felt
that "load" was too generic of a name for it, since many other similar
commands already existed. However, it turns out that there is already
an "fsload" command, so that name cannot be used. Rename the new
"fsload" to plain "load" to avoid the conflict. At least anyone who's
used a Basic interpreter should feel familiar with the name!
Commit 045fa1e "fs: add filesystem switch libary, implement ls and
fsload commands" unified the implementation of fatload and ext*load
with the new command fsload. However, this altered the interpretation
of command-line numbers from always being base-16, to requiring a "0x"
prefix for base-16 numbers. Enhance do_fsload() to allow commands to
specify which base to use.
Use base 0, thus requiring a "0x" prefix for the new fsload command.
This feels much cleaner than assuming base 16.
Use base 16 for the pre-existing fatload and ext*load to prevent a
change in behaviour.
Use base 16 exclusively for the loadaddr environment variable, since
that variable is interpreted in multiple places, so we don't want the
behaviour to change.
Update command help text to make it clear where numbers are assumed to
be hex, and where an explicit "0x" prefix is required.
Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Most arguments to the shell command do_fsload() implements are optional.
Fix the minimum argc check to respect that. Cater for the situation
where argv[2] is not provided.
Enhance both do_fsload() and do_ls() to check the maximum number of
arguments too. While this check would typically be implemented via
U_BOOT_CMD()'s max_args parameter, if these functions are called
directly, then that check won't exist.
Finally, alter do_ls() to check (argc >= 4) rather than (argc == 4) so
that if the function is enhanced to allow extra arguments in the future,
this test won't need to be changed at that time.
Without this, fstypes[].probe points at the wrong place, so calling the
function results in undefined behaviour.
Tested-by: Andreas Bießmann <andreas.devel@googlemail.com>
