path: root/fs/fs.c
2015-08-13fs/fs.c: read up to EOF when len would read past EOFMax Krummenacher
http://lists.denx.de/pipermail/u-boot/2012-September/134347.html allows for reading files in chunks from the shell. When this feature is used to read past the end of a file an error was returned instead of returning the bytes read up to the end of file. Thus the following fails in the shell: offset = 0 len = chunksize do read file, offset, len write data until bytes_read < len The patch changes the behaviour to printing an informational message and returning the actual read number of bytes aka read(2) behaviour for convenient use in U-Boot scripts. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-04-18common: Make sure arch-specific map_sysmem() is definedJoe Hershberger
In the case where the arch defines a custom map_sysmem(), make sure that including just mapmem.h is sufficient to have these functions as they are when the arch does not override it. Also split the non-arch specific functions out of common.h Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-01-29fs: Add command to retrieve the filesystem typeSjoerd Simons
New command to determine the filesystem type of a given partition. Optionally stores the filesystem type in a environment variable. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2014-12-01fs/ext4/ext4fs.c, fs/fs.c fs/fat/fat_write.c: Adjust 64bit math methodsTom Rini
The changes to introduce loff_t into filesize means that we need to do 64bit math on 32bit platforms. Make sure we use the right wrappers for these operations. Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Suriyan Ramasami <suriyan.r@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@ti.com> Tested-by: Pierre Aubert <p.aubert@staubli.com>
2014-11-23fs: API changes enabling extra parameter to return size of type loff_tSuriyan Ramasami
The sandbox/ext4/fat/generic fs commands do not gracefully deal with files greater than 2GB. Negative values are returned in such cases. To handle this, the fs functions have been modified to take an additional parameter of type "* loff_t" which is then populated. The return value of the fs functions are used only for error conditions. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> [trini: Update board/gdsys/p1022/controlcenterd-id.c, drivers/fpga/zynqpl.c for changes] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23fs: make it possible to read the filesystem UUIDChristian Gmeiner
Some filesystems have a UUID stored in its superblock. To allow using root=UUID=... for the kernel command line we need a way to read-out the filesystem UUID. changes rfc -> v1: - make the environment variable an option parameter. If not given, the UUID is printed out. If given, it is stored in the env variable. - corrected typos - return error codes changes v1 -> v2: - fix return code of do_fs_uuid(..) - document do_fs_uuid(..) - implement fs_uuid_unsuported(..) be more consistent with the way other optional functionality works changes v2 -> v3: - change ext4fs_uuid(..) to make use of #if .. #else .. #endif construct to get rid of unreachable code Hit any key to stop autoboot: 0 => fsuuid fsuuid - Look up a filesystem UUID Usage: fsuuid <interface> <dev>:<part> - print filesystem UUID fsuuid <interface> <dev>:<part> <varname> - set environment variable to filesystem UUID => fsuuid mmc 0:1 d9f9fc05-45ae-4a36-a616-fccce0e4f887 => fsuuid mmc 0:2 eb3db83c-7b28-499f-95ce-9e0bb21cda81 => fsuuid mmc 0:1 uuid1 => fsuuid mmc 0:2 uuid2 => printenv uuid1 uuid1=d9f9fc05-45ae-4a36-a616-fccce0e4f887 => printenv uuid2 uuid2=eb3db83c-7b28-499f-95ce-9e0bb21cda81 => Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2014-08-09fs: implement size/fatsize/ext4sizeStephen Warren
These commands may be used to determine the size of a file without actually reading the whole file content into memory. This may be used to determine if the file will fit into the memory buffer that will contain it. In particular, the DFU code will use it for this purpose in the next commit. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-07-22catch wrong load address passed to fatload / ext2loadPavel Machek
If filename is passed instead of address to ext2load or fatload, u-boot silently accepts that, and uses 0 for load address and default filename from environment. That is confusing, display help instead. Signed-off-by: Pavel Machek <pavel@denx.de>
2014-02-19fat: implement exists() for FAT fsStephen Warren
This hooks into the generic "file exists" support added in an earlier patch, and provides an implementation for the FAT filesystem. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-19ext4: implement exists() for ext4fsStephen Warren
This hooks into the generic "file exists" support added in an earlier patch, and provides an implementation for the ext4 filesystem. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-19sandbox: implement exists() functionStephen Warren
This hooks into the generic "file exists" support added in an earlier patch, and provides an implementation for the sandbox test environment. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-19fs: don't pass NULL dev_desc to most filesystemsStephen Warren
FAT and ext4 expect that the passed in block device descriptor not be NULL. This causes problems on sandbox, where get_device_and_partition() succeeds for the "host" device, yet passes back a NULL device descriptor. Add special handling for this situation, so that the generic filesystem commands operate as expected on sandbox. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-02-19fs: implement infrastructure for an 'exists' functionStephen Warren
This could be used in scripts such as: if test -e mmc 0:1 /boot/boot.scr; then load mmc 0:1 ${scriptaddr} /boot/boot.scr source ${scriptaddr} fi rather than: if load mmc 0:1 ${scriptaddr} /boot/boot.scr; then source ${scriptaddr} fi This prevents errors being printed by attempts to load non-existent files, which can be important when checking for a large set of files, such as /boot/boot.scr.uimg, /boot/boot.scr, /boot/extlinux.conf, /boot.scr.uimg, /boot.scr, /extlinux.conf. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-19fs: fix generic save command implementationStephen Warren
Fix a few issues with the generic "save" shell command, and fs_write() function. 1) fstypes[].write wasn't filled in for some file-systems, and isn't checked when used, which could cause crashes/... if executing save on e.g. fat/ext filesystems. 2) fs_write() requires the length argument to be non-zero, since it needs to know exactly how many bytes to write. Adjust the comments and code according to this. 3) fs_write() wasn't prototyped in <fs.h> like other generic functions; other code should be able to call this directly rather than invoking the "save" shell command. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-10-07Fix number base handling of "load" commandWolfgang Denk
As documented, almost all U-Boot commands expect numbers to be entered in hexadecimal input format. (Exception: for historical reasons, the "sleep" command takes its argument in decimal input format.) This rule was broken for the "load" command; for details please see especially commits 045fa1e "fs: add filesystem switch libary, implement ls and fsload commands" and 3f83c87 "fs: fix number base behaviour change in fatload/ext*load". In the result, the load command would always require an explicit "0x" prefix for regular (i. e. base 16 formatted) input. Change this to use the standard notation of base 16 input format. While strictly speaking this is a change of the user interface, we hope that it will not cause trouble. Stephen Warren comments (see [1]): I suppose you can change the behaviour if you want; anyone writing "0x..." for their values presumably won't be affected, and if people really do assume all values in U-Boot are in hex, presumably nobody currently relies upon using non-prefixed values with the generic load command, since it doesn't work like that right now. [1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/171172 Acked-by: Tom Rini <trini@ti.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2013-05-01sandbox: fs: Add support for saving files to host filesystemSimon Glass
This allows write of files from the host filesystem in sandbox. There is currently no concept of overwriting the file and removing its existing contents - all writing is done on top of what is there. This means that writing 10 bytes to the start of a 1KB file will only update those 10 bytes, not truncate the file to 10 byte slong. If the file does not exist it is created. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-01fs: Add support for saving data to filesystemsSimon Glass
Add a new method for saving that filesystems can implement. This mirrors the existing load method. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-04sandbox: Add host filesystemSimon Glass
This allows reading of files from the host filesystem in sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-04fs: Move ls and read methods into ext4, fatSimon Glass
It doesn't make a lot of sense to have these methods in fs.c. They are filesystem-specific, not generic code. Add each to the relevant filesystem and remove the associated #ifdefs in fs.c. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-04fs: Use map_sysmem() on readSimon Glass
This allows us to use filesystems on sandbox. It has no effect on other architectures. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-04fs: Tell probe functions where to put their resultsSimon Glass
Rather than rely on global variables for the probe functions, pass in the information that we need filled in. This allows us to potentially keep the variables private to fs.c in the future, and the meaning of the probe function is clearer. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-04fs: Use filesystem methods instead of switch()Simon Glass
We can use the available methods and avoid using switch(). When the filesystem is not supported, we fall through to the 'unsupported' methods: fs_probe_unsupported() prints an error, so the others do not need to. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-04fs: Fully populate the filesystem method structSimon Glass
There is a structure in fs.c with just a probe method. By adding methods for other operations, we can avoid lots of #ifdefs and switch()s. As a first step, create the structure ready for use. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-02-28fs: Use new numeric setenv functionsSimon Glass
Use setenv_ulong(), setenv_hex() and setenv_addr() in fs/ Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-14fs/fs.c: do_fsload: measure throughputAndreas Bießmann
This patch adds time measurement and throughput calculation for all supported load commands. The output of ext2load changes from ---8<--- 1830666 bytes read --->8--- to ---8<--- 1830666 bytes read in 237 ms (7.4 MiB/s) --->8--- Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> [agust: rebased and revised commit log] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-11-04fs: rename fsload command to loadStephen Warren
When the generic filesystem load command "fsload" was written, I felt that "load" was too generic of a name for it, since many other similar commands already existed. However, it turns out that there is already an "fsload" command, so that name cannot be used. Rename the new "fsload" to plain "load" to avoid the conflict. At least anyone who's used a Basic interpreter should feel familiar with the name! Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-11-04fs: fix number base behaviour change in fatload/ext*loadStephen Warren
Commit 045fa1e "fs: add filesystem switch libary, implement ls and fsload commands" unified the implementation of fatload and ext*load with the new command fsload. However, this altered the interpretation of command-line numbers from always being base-16, to requiring a "0x" prefix for base-16 numbers. Enhance do_fsload() to allow commands to specify which base to use. Use base 0, thus requiring a "0x" prefix for the new fsload command. This feels much cleaner than assuming base 16. Use base 16 for the pre-existing fatload and ext*load to prevent a change in behaviour. Use base 16 exclusively for the loadaddr environment variable, since that variable is interpreted in multiple places, so we don't want the behaviour to change. Update command help text to make it clear where numbers are assumed to be hex, and where an explicit "0x" prefix is required. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2012-11-04fs: fix do_fsload() handling of optional argumentsStephen Warren
Most arguments to the shell command do_fsload() implements are optional. Fix the minimum argc check to respect that. Cater for the situation where argv[2] is not provided. Enhance both do_fsload() and do_ls() to check the maximum number of arguments too. While this check would typically be implemented via U_BOOT_CMD()'s max_args parameter, if these functions are called directly, then that check won't exist. Finally, alter do_ls() to check (argc >= 4) rather than (argc == 4) so that if the function is enhanced to allow extra arguments in the future, this test won't need to be changed at that time. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2012-11-02fs: handle CONFIG_NEEDS_MANUAL_RELOCStephen Warren
Without this, fstypes[].probe points at the wrong place, so calling the function results in undefined behaviour. Signed-off-by: Stephen Warren <swarren@nvidia.com> Tested-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-10-29fs: add filesystem switch libary, implement ls and fsload commandsStephen Warren
Implement "ls" and "fsload" commands that act like {fat,ext2}{ls,load}, and transparently handle either file-system. This scheme could easily be extended to other filesystem types; I only didn't do it for zfs because I don't have any filesystems of that type to test with. Replace the implementation of {fat,ext[24]}{ls,load} with this new code too. Signed-off-by: Stephen Warren <swarren@nvidia.com>
