path: root/fs/fdos/vfat.c
2002-11-18* Patch by Daniel Engström, 13 Nov 2002:LABEL_2002_11_18_0115wdenk
Add support for i386 architecture and AMD SC520 board * Patch by Pierre Aubert, 12 Nov 2002: Add support for DOS filesystem and booting from DOS floppy disk
