path: root/fs/fat
2018-01-19fs/fat: remove distractive message in file_fat_read_at()Heinrich Schuchardt
The message "reading %s\n" may be interesting when debugging but otherwise it is superfluous. Only output the message when debugging. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-10fat write: Fixed a problem with the case of file names when writing filesJean-Jacques Hiblot
commit 21a24c3bf35b ("fs/fat: fix case for FAT shortnames") made it possible that get_name() returns file names with some upper cases. find_directory_entry() must be updated to take this account, and use case-insensitive functions to compare file names. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2017-11-29fat: Use cache aligned buffers for fat_opendirNeil Armstrong
Before this patch one could receive following errors when executing "fatls" command on machine with cache enabled (ex i.MX6Q) : => fatls mmc 0:1 CACHE: Misaligned operation at range [4f59dfc8, 4f59e7c8] CACHE: Misaligned operation at range [4f59dfc8, 4f59e7c8] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x4f59dfc8 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x4f59e7c8 CACHE: Misaligned operation at range [4f59dfc8, 4f59e7c8] CACHE: Misaligned operation at range [4f59dfc8, 4f59e7c8] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x4f59dfc8 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x4f59e7c8 To alleviate this problem - the calloc()s have been replaced with malloc_cache_aligned() and memset(). After those changes the buffers are properly aligned (with both start address and size) to SoC cache line. Fixes: 09fa964bba80 ("fs/fat: Fix 'CACHE: Misaligned operation at range' warnings") Suggested-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-10-08fs/fat: Check malloc return values and fix memory leaksTuomas Tynkkynen
Check malloc() return values and properly unwind on errors so memory allocated for fat_itr structures get freed properly. Also fixes a leak of fsdata.fatbuf in fat_size(). Fixes: 2460098cffacd1 ("fs/fat: Reduce stack usage") Reported-by: Coverity (CID: 167225, 167233, 167234) Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-10-08fs/fat: Fix 'CACHE: Misaligned operation at range' warningsTuomas Tynkkynen
The 'block' field of fat_itr needs to be properly aligned for DMA and while it does have '__aligned(ARCH_DMA_MINALIGN)', the fat_itr structure itself needs to be properly aligned as well. While at it use malloc_cache_aligned() for the other aligned allocations in the file as well. Fixes: 2460098cffacd1 ("fs/fat: Reduce stack usage") Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-10-06fs/fat: Fix pathnames using '..' that lead to the root directoryTuomas Tynkkynen
If we end up back in the root directory via a '..' directory entry, set itr->is_root accordingly. Failing to do that gives spews like "Invalid FAT entry" and being unable to access directory entries located past the first cluster of the root directory. Fixes: 8eafae209c35 ("fat/fs: convert to directory iterators") Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-09-22fs/fat: Reduce stack usageTom Rini
We have limited stack in SPL builds. Drop itrblock and move to malloc/free of itr to move this off of the stack. As part of this fix a double-free issue in fat_size(). Signed-off-by: Tom Rini <trini@konsulko.com> --- Rework to use malloc/free as moving this to a global overflows some SH targets.
2017-09-15fs/fat: fix fatbuf leakRob Clark
A new fatbuf was allocated by get_fs_info() (called by fat_itr_root()), but not freed, resulting in eventually running out of memory. Spotted by running 'ls -r' in a large FAT filesystem from Shell.efi. fatbuf is mainly used to cache FAT entry lookups (get_fatent()).. possibly once fat_write.c it can move into the iterator to simplify this. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Łukasz Majewski <lukma@denx.de>
2017-09-15fs/fat: Clean up open-coded sector <-> cluster conversionsRob Clark
Use the clust_to_sect() helper that was introduced earlier, and add an inverse sect_to_clust(), plus update the various spots that open-coded this conversion previously. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-15fs/fat: fix case for FAT shortnamesRob Clark
Noticed when comparing our output to linux. There are some lcase bits which control whether filename and/or extension should be downcase'd. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-15fat/fs: move ls to generic implementationRob Clark
Add a generic implementation of 'ls' using opendir/readdir/closedir, and replace fat's custom implementation. Other filesystems should move to the generic implementation after they add opendir/readdir/closedir support. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-15fat/fs: remove a bunch of dead codeRob Clark
Spotted by chance, when trying to remove file_fat_ls(), I noticed there were some dead users of the API. Signed-off-by: Rob Clark <robdclark@gmail.com> Acked-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-15fs/fat: implement opendir/readdir/closedirRob Clark
Implement the readdir interface using the directory iterators. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-15fat/fs: convert to directory iteratorsRob Clark
And drop a whole lot of ugly code! Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-15fs/fat: introduce new director iteratorsRob Clark
Untangle directory traversal into a simple iterator, to replace the existing multi-purpose do_fat_read_at() + get_dentfromdir(). Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Łukasz Majewski <lukma@denx.de>
2017-09-15fs/fat: split out helper to init fsdataRob Clark
Want to re-use this in fat dirent iterator in next patch. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-26fs: fat: fix fatwrite overflow calculationReno Farnesi
The overflow calculation was incorrect. Adding the start block of the partition is not needed because the sectors are already relative to the beginning of the partition. If you attempted to write a file smaller than cur_part_info.start blocks on a full partition the old calculation fails to catch the overflow. This would cause an infinite loop in the determine_fatent function. Old, incorrect calculation: ending sector of new file = start sector + file size (in sectors) last sector = partition start + total sectors on the partition Adding the partition start block number is not needed because sectors are already relative to the start of the partition. New calculation: ending sector of new file = start sector + file size (in sectors) last sector = total sectors on the partition Signed-off-by: Reno Farnesi <nfarnesi4@gmail.com>
2017-08-20fs/fat: Correct blk_dread() return value checkTom Rini
The function blk_dread will return -ENOSYS on failure or on success the number of blocks read, which must be the number asked to read (otherwise it failed somewhere). Correct this check. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-11Kconfig: Add CONFIG_SATA to enable SATASimon Glass
At present CONFIG_CMD_SATA enables the 'sata' command which also brings in SATA support. Some boards may wish to enable SATA without the command. Add a separate CONFIG to permit this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-06-03fs: fat: add kbuild configuration supportSekhar Nori
Add Kconfig symbols for various configurations supported by FAT filesystem support code. CONFIG_SUPPORT_VFAT has been left out since its force enabled in include/fat.h and probably should get removed at some point. Signed-off-by: Sekhar Nori <nsekhar@ti.com> [trini: add select FS_FAT for CMD_FAT and SPL_FAT_SUPPORT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Kconfig: Add a CONFIG_IDE optionSimon Glass
At present IDE support is controlled by CONFIG_CMD_IDE. Add a separate CONFIG_IDE option so that IDE support can be enabled without requiring the 'ide' command. Update existing users and move the ide driver into drivers/block since it should not be in common/. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-28fs/fat: Fix unaligned __u16 reads for FAT12 accessStefan Brüns
Doing unaligned reads is not supported on all architectures, use byte sized reads of the little endian buffer. Rename off16 to off8, as it reflects the buffer offset in byte granularity (offset is in entry, i.e. 12 bit, granularity). Fix a regression introduced in 8d48c92b45aea91e2a2be90f2ed93677e85526f1 Reported-by: Oleksandr Tymoshenko <gonzo@bluezbox.com> Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Tested-by: Oleksandr Tymoshenko <gonzo@bluezbox.com>
2016-12-27fs/fat: simplify get_fatent for FAT12Stefan Brüns
Instead of shuffling bits from two adjacent 16 bit words, use one 16 bit word with the appropriate byte offset in the buffer. Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
2016-12-27fs/fat: merge readwrite get_fatent_value() with readonly get_fatent()Stefan Brüns
get_fatent_value(...) flushes changed FAT entries to disk when fetching the next FAT blocks, in every other aspect it is identical to get_fatent(...). Provide a stub implementation for flush_dirty_fat_buffer if CONFIG_FAT_WRITE is not set. Calling flush_dirty_fat_buffer during read only operation is fine as it checks if any buffers needs flushing. Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau.dev@gmail.com>
2016-12-27fs/fat: Avoid corruption of sectors following the FATStefan Brüns
The FAT is read/flushed in segments of 6 (FATBUFBLOCKS) disk sectors. The last segment may be less than 6 sectors, cap the length. Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau.dev@gmail.com>
2016-12-27fat: fatwrite: fix the command for FAT12Philipp Skadorov
The u-boot command fatwrite empties FAT clusters from the beginning till the end of the file. Specifically for FAT12 it fails to detect the end of the file and goes beyond the file bounds thus corrupting the file system. Additionally, FAT entry chaining-up into a file is not implemented for FAT12. The users normally workaround this by re-formatting the partition as FAT16/FAT32, like here: https://github.com/FEDEVEL/openrex-uboot-v2015.10/issues/1 The patch fixes the bounds of a file and FAT12 entries chaining into a file, including EOF markup. Signed-off-by: Philipp Skadorov <philipp.skadorov@savoirfairelinux.com>
2016-11-28fs/fat/fatwrite: Local variable as buffer to store dir_slot entriesTien Fong Chee
fill_dir_slot use get_contents_vfatname_block as a temporary buffer for constructing a list of dir_slot entries. To save the memory and providing correct type of memory for above usage, a local buffer with accurate size declaration is introduced. The local array size 640 is used because for long file name entry, each entry use 32 bytes, one entry can store up to 13 characters. The maximum number of entry possible is 20. So, total size is 32*20=640bytes. Signed-off-by: Genevieve Chan <ccheauya@altera.com> Signed-off-by: Tien Fong Chee <tfchee@altera.com>
2016-09-23fs/fat: Correct description of determine_fatent functionStefan Brüns
Current description does not match the function behaviour. Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-09-23fs/fat: Do not write unmodified fat entries to diskStefan Brüns
The code caches 6 sectors of the FAT. On FAT traversal, the old contents needs to be flushed to disk, but only if any FAT entries had been modified. Explicitly flag the buffer on modification. Currently, creating a new file traverses the whole FAT up to the first free cluster and rewrites the on-disk blocks. Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2016-09-23fs/fat: Remove two statements without effectStefan Brüns
fatlength is a local variable which is no more used after the assignment. s_name is not used in the function, save the strncpy. Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Acked-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau.dev@gmail.com>
2016-05-17dm: scsi: Rename CONFIG_CMD_SCSI to CONFIG_SCSISimon Glass
This option currently enables both the command and the SCSI functionality. Rename the existing option to CONFIG_SCSI since most of the code relates to the feature. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-22Fix spelling of "supported/unsupported".Vagrant Cascadian
Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Peter Griffin <peter.griffin@linaro.org>
2016-03-14dm: block: Adjust device calls to go through helpers functionSimon Glass
To ease conversion to driver model, add helper functions which deal with calling each block device method. With driver model we can reimplement these functions with the same arguments. Use inline functions to avoid increasing code size on some boards. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: block: Rename device number member dev to devnumSimon Glass
This is a device number, and we want to use 'dev' to mean a driver model device. Rename the member. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: part: Rename some partition functionsSimon Glass
Rename three partition functions so that they start with part_. This makes it clear what they relate to. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: Drop the block_dev_desc_t typedefSimon Glass
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long and causes 80-column violations, rename it to struct blk_desc. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-01-13block: pass block dev not num to read/write/erase()Stephen Warren
This will allow the implementation to make use of data in the block_dev structure beyond the base device number. This will be useful so that eMMC block devices can encompass the HW partition ID rather than treating this out-of-band. Equally, the existence of the priv field is crying out for this patch to exist. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-11fs/fat/fat_write: Fix management of empty filesBenoît Thébaudeau
Overwriting an empty file not created by U-Boot did not work, and it could even corrupt the FAT. Moreover, creating empty files or emptying existing files allocated a cluster, which is not standard. Fix this by always keeping empty files clusterless as specified by Microsoft (the start cluster must be set to 0 in the directory entry in that case), and by supporting overwriting such files. Signed-off-by: Benoît Thébaudeau <benoit@wsystem.com>
2015-10-11fs/fat/fat_write: Factor out duplicate codeBenoît Thébaudeau
2015-10-11fs/fat/fat_write: Fix curclust/newclust mix-upBenoît Thébaudeau
curclust was used instead of newclust in the debug() calls and in one CHECK_CLUST() call, which could skip a failure case. Signed-off-by: Benoît Thébaudeau <benoit@wsystem.com>
2015-10-11fs/fat/fat_write: Merge calls to set_cluster()Benoît Thébaudeau
set_contents() had uselessly split calls to set_cluster(). Merge these calls, which removes some cases of set_cluster() being called with a size of zero. Signed-off-by: Benoît Thébaudeau <benoit@wsystem.com>
2015-10-11fs/fat/fat_write: Fix buffer alignmentsBenoît Thébaudeau
set_cluster() was using a temporary buffer without enforcing its alignment for DMA and cache. Moreover, it did not check the alignment of the passed buffer, which can come directly from applicative code or from the user. This could cause random data corruption, which has been observed on i.MX25 writing to an SD card. Fix this by only passing ARCH_DMA_MINALIGN-aligned buffers to disk_write(), which requires the introduction of a buffer bouncing mechanism for the misaligned buffers passed to set_cluster(). By the way, improve the handling of the corresponding return values from disk_write(): - print them with debug() in case of error, - consider that there is an error is disk_write() returns a smaller block count than the requested one, not only if its return value is negative. After this change, set_cluster() and get_cluster() are almost symmetrical. Signed-off-by: Benoît Thébaudeau <benoit@wsystem.com>
2015-09-11FIX: fat: Provide correct return code from disk_{read|write} to upper layersŁukasz Majewski
It is very common that FAT code is using following pattern: if (disk_{read|write}() < 0) return -1; Up till now the above code was dead, since disk_{read|write) could only return value >= 0. As a result some errors from medium layer (i.e. eMMC/SD) were not caught. The above behavior was caused by block_{read|write|erase} declared at struct block_dev_desc (@part.h). It returns unsigned long, where 0 indicates error and > 0 indicates that medium operation was correct. This patch as error regards 0 returned from block_{read|write|erase} when nr_blocks is grater than zero. Read/Write operation with nr_blocks=0 should return 0 and hence is not considered as an error. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Test HW: Odroid XU3 - Exynos 5433
2015-09-11Move ALLOC_CACHE_ALIGN_BUFFER() to the new memalign.h headerSimon Glass
Now that we have a new header file for cache-aligned allocation, we should move the stack-based allocation macro there also. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-11fat: handle paths that include ../Stephen Warren
The FAT code contains a special case to parse the root directory. This is needed since the root directory location/layout on disk is special cased for FAT12/16. In particular, the location and size of the FAT12/16 root directory is hard-coded and contiguous, whereas all FAT12/16 non-root directories, and all FAT32 directories, are stored in a non-contiguous fashion, with the layout represented by a linked-list of clusters in the FAT. If a file path contains ../ (for example /extlinux/../bcm2835-rpi-cm.dtb), it is possible to need to parse the root directory for the first element in the path (requiring application of the special case), then a sub- directory (in the general way), then re-parse the root directory (again requiring the special case). However, the current code in U-Boot only applies the special case for the very first path element, and never for any later path element. When reparsing the root directory without applying the special case, any file in a sector (or cluster?) other than the first sector/cluster of the root directory will not be found. This change modifies the non-root-dir-parsing loop of do_fat_read_at() to detect if it's walked back to the root directory, and if so, jumps back to the special case code that handles parsing of the root directory. This change was tested using sandbox by executing: ./u-boot -c "host bind 0 ../sd-p1.bin; ls host 0:0" ./u-boot -c "host bind 0 ../sd-p1.bin; ls host 0:0 /" ./u-boot -c "host bind 0 ../sd-p1.bin; ls host 0:0 /extlinux" ./u-boot -c "host bind 0 ../sd-p1.bin; ls host 0:0 /extlinux/" ./u-boot -c "host bind 0 ../sd-p1.bin; ls host 0:0 /extlinux/.." ./u-boot -c "host bind 0 ../sd-p1.bin; ls host 0:0 /extlinux/../" ./u-boot -c "host bind 0 ../sd-p1.bin; ls host 0:0 /extlinux/../backup" ./u-boot -c "host bind 0 ../sd-p1.bin; ls host 0:0 /extlinux/../backup/" ./u-boot -c "host bind 0 ../sd-p1.bin; ls host 0:0 /extlinux/../backup/.." ./u-boot -c "host bind 0 ../sd-p1.bin; ls host 0:0 /extlinux/../backup/../" ./u-boot -c "host bind 0 ../sd-p1.bin; load host 0:0 0 /bcm2835-rpi-cm.dtb" ./u-boot -c "host bind 0 ../sd-p1.bin; load host 0:0 0 /extlinux/../bcm2835-rpi-cm.dtb" ./u-boot -c "host bind 0 ../sd-p1.bin; load host 0:0 0 /backup/../bcm2835-rpi-cm.dtb" ./u-boot -c "host bind 0 ../sd-p1.bin; load host 0:0 0 /extlinux/..backup/../bcm2835-rpi-cm.dtb" ./u-boot -c "host bind 0 ../sd-p1.bin; load host 0:0 0 /extlinux/../backup/../bcm2835-rpi-cm.dtb" (/extlinux and /backup are in different sectors so trigger some different cases, and bcm2835-rpi-cm.dtb is in a sector of the root directory other than the first). In all honesty, this change is a bit of a hack, using goto and all. However, as demonstrated above it appears to work well in practice, is quite minimal, likely doesn't introduce any risk of regressions, and hopefully doesn't introduce any maintenance issues. The correct fix would be to collapse the root and non-root loops in do_fat_read_at() and get_dentfromdir() into a single loop that has a small special-case when moving from one sector to the next, to handle the layout difference of root/non-root directories. AFAIK all other aspects of directory parsing are identical. However, that's a much larger change which needs significantly more thought before it's implemented. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2015-01-05fs: fat: read: fix fat16 ls/read issuePrzemyslaw Marczak
The present fat implementation ignores FAT16 long name directory entries which aren't placed in a single sector. This was becouse of the buffer was always filled by the two sectors, and the loop was made also for two sectors. If some file long name entries are stored in two sectors, the we have two cases: Case 1: Both of sectors are in the buffer - all required data for long file name is in the buffer. - Read OK! Case 2: The current directory entry is placed at the end of the second buffered sector. And the next entries are placed in a sector which is not buffered yet. Then two next sectors are buffered and the mentioned entry is ignored. - Read fail! This commit fixes this issue by: - read two sectors after loop on each single is done - keep the last used sector as a first in the buffer before the read of two next The commit doesn't affects the fat32 imlementation, which works good as previous. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Mikhail Zolotaryov <lebon@lebon.org.ua> Cc: Tom Rini <trini@ti.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Simon Glass <sjg@chromium.org> Cc: Suriyan Ramasami <suriyan.r@gmail.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Wolfgang Denk <wd@denx.de> Tested-by: Simon Glass <sjg@chomium.org>
2014-12-01fs/ext4/ext4fs.c, fs/fs.c fs/fat/fat_write.c: Adjust 64bit math methodsTom Rini
The changes to introduce loff_t into filesize means that we need to do 64bit math on 32bit platforms. Make sure we use the right wrappers for these operations. Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Suriyan Ramasami <suriyan.r@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@ti.com> Tested-by: Pierre Aubert <p.aubert@staubli.com>
2014-11-23fs: API changes enabling extra parameter to return size of type loff_tSuriyan Ramasami
The sandbox/ext4/fat/generic fs commands do not gracefully deal with files greater than 2GB. Negative values are returned in such cases. To handle this, the fs functions have been modified to take an additional parameter of type "* loff_t" which is then populated. The return value of the fs functions are used only for error conditions. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> [trini: Update board/gdsys/p1022/controlcenterd-id.c, drivers/fpga/zynqpl.c for changes] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23fat: Prepare API change for files greater than 2GBSuriyan Ramasami
Change the internal FAT functions to use loff_t for offsets. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> [trini: Fix fs/fat/fat.c for min3 updates] Signed-off-by: Tom Rini <trini@ti.com>
