path: root/fs/ext2
2009-12-05EXT2FS: fix inode size for ext2fs rev#0Michael Brandt
extfs.c assumes that there is always a valid inode_size field in the superblock. But this is not true for ext2fs rev 0. Such ext2fs images are for instance generated by genext2fs. Symptoms on ARM machines are messages like: "raise: Signal # 8 caught"; on PowerPC "ext2ls" will print nothing. This fix checks for rev 0 and uses then 128 bytes as inode size. Signed-off-by: Michael Brandt <Michael.Brandt@emsyso.de> Tested on: TQM5200S Tested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-28ext2: fix inode size and calculationsWeirich, Bernhard
Signed-off-by: unsik Kim <donari75@gmail.com> Signed-off-by: Bernhard Weirich <bernhard.weirich@riedel.net> Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Wolfgang Denk <wd@denx.de>
2008-08-31fs: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-03-02fs: Fix ext2 read issueDave Liu
The ext2 aligned process will corrupt the key data struct, the patch fix this. Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-01-09Fix memset bug in ext2fs_read_file()Wolfgang Denk
ext2fs_read_file() had the function arguments swapped. Pointed out by Mike Montour, 19 Dec 2007 22:34:25 -0800 Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-07-10fs/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09fs/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04fs/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-01-18Add VGA support (CT69000) to CPCI750 board.Stefan Roese
Insert missing __le32_to_cpu() for filesize in ext2fs_read_file(). Patch by Reinhard Arlt, 30 Dec 2005
2005-03-04* Fix get_partition_info() parameter error in all other callswdenk
(common/cmd_ide.c, common/cmd_reiser.c, common/cmd_scsi.c). * Enable USB and IDE support for INKA4x0 board * Patch by Andrew Dyer, 28 February 2005: fix ext2load passing an incorrect pointer to get_partition_info() resulting in load failure for devices other than 0
2005-02-04* Patch by Cajus Hahn, 04 Feb 2005:wdenk
- don't insist on leading '/' for filename in ext2load - set default partition to useful value (1) in ext2load * Patch by Andrew Dyer, 08 Jan 2005: fix wrong return codes in ext2 code
2004-12-19Cleanup: avoid trigraph warning in fs/ext2/ext2fs.c; rename UC100 -> uc100wdenk
2004-12-16Code cleanup.wdenk
2004-12-16ext2fs support addedstroese
