path: root/fs/cramfs
2013-11-17fs: descend into sub directories when it is necessaryMasahiro Yamada
2013-10-31fs: convert makefiles to Kbuild styleMasahiro Yamada
2013-10-15mtd: fix warnings due to 64-bit partition supportScott Wood
commit 39ac34473f3c96e77cbe03a49141771ed1639486 ("cmd_mtdparts: use 64 bits for flash size, partition size & offset") introduced warnings in a couple places due to printf formats or pointer casting. This patch fixes the warnings pointed out here: http://lists.denx.de/pipermail/u-boot/2013-October/164981.html Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: York Sun <yorksun@freescale.com> Cc: Stefan Roese <sr@denx.de> Cc: Paul Burton <paul.burton@imgtec.com> Cc: Tom Rini <trini@ti.com>
2013-07-15cramfs: fix bug for wrong filename comparisonHolger Brunck
"cramfsload uImage_1" succeeds even though the actual file is named "uImage". Fix file name comparison when one name is the prefix of the other. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Wolfgang Denk <wd@denx.de> cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-04-30gunzip: rename z{alloc, free} to gz{alloc, free}Mike Frysinger
This allows us to add a proper zalloc() func (one that does a zeroing alloc), and removes duplicate prototypes. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-05-10cramfs: make cramfs usable without a NOR flashHeiko Schocher
cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2009-04-04rename include/zlib.h to include/u-boot/zlib.hJean-Christophe PLAGNIOL-VILLARD
Some systems have zlib.h installed in /usr/include/. This isn't the desired file for u-boot code - we want the one in include/zlib.h. This rename will avoid the conflict. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-08-31fs: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-03-26Merge branch 'new-image' of git://www.denx.de/git/u-boot-testingBartlomiej Sieka
Conflicts: common/cmd_bootm.c cpu/mpc8xx/cpu.c Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-03-16cramfs: Fix ifdefJean-Christophe PLAGNIOL-VILLARD
2008-02-07[new uImage] Move gunzip() common code to common/gunzip.cMarian Balakowicz
Move gunzip(), zalloc() and zfree() to a separate file. Share zalloc() and zfree() with cramfs uncompress routine. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-01-09Fix building with CRAMFS but not JFFS2 supportHarald Welte
Signed-off-by: Harald Welte <laforge@openmoko.org>
2007-07-09fs/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04fs/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2005-10-11Added support for TQM834x boards.Marian Balakowicz
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
2004-01-04* Fix problems caused by Robert Schwebel's cramfs patchwdenk
* Patch by Scott McNutt, 02 Jan 2004: Add support for the Nios Active Serial Memory Interface (ASMI) on Cyclone devices * Patch by Andrea Marson, 16 Dec 2003: Add support for the PPChameleon ME and HI modules * Patch by Yuli Barcohen, 22 Dec 2003: Add support for Motorola DUET ADS board (MPC87x/88x)
2004-01-03* Patch by Robert Schwebel, 15 Dec 2003:wdenk
add support for cramfs (uses JFFS2 command interface)
