path: root/fs/cbfs
2018-12-31fs: cbfs: Fix out of bound access during CBFS walking throughBin Meng
The call to file_cbfs_fill_cache() is given with the parameter 'start' pointing to the offset by the CBFS base address, but with the parameter 'size' that equals to the whole CBFS size. During CBFS walking through, it checks files one by one and after it pass over the end of the CBFS which is 4GiB boundary it tries to check files from address 0 and so on, until the overall size the codes checked hits to the given 'size'. Fix this by passing 'start' pointing to the CBFS base address. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-31fs: cbfs: remove wrong header validationChristian Gmeiner
cbfs_fileheader.len indicates the content size of the file in the cbfs, and it has nothing to do with cbfs_fileheader.offset which is the starting address of the file in the cbfs. Remove such check in file_cbfs_next_file(). Before this change 'cbfsinit' failed with 'Bad CBFS file'. After this change all cbfs commands are working as expected. Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com> [bmeng: keep the necessary header sanity check] Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-03-31fs: cbfs: fix locating the cbfs headerAndre Heider
The value at the end of the rom is not a pointer, it is an offset relative to the end of rom. Signed-off-by: Andre Heider <a.heider@gmail.com>
2017-04-30fs: Kconfig: Add a separate config for FS_CBFSSimon Glass
Rather than using CMD_CBFS for both the filesystem and its command, we should have a separate option for each. This allows us to enable CBFS support without the command, if desired, which reduces U-Boot's size slightly. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply FS_CBFS on SYS_COREBOOT] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-08-16cbfs: Fix incorrect CBFS file header size being usedYaroslav K
This fixes incorrect filenames in cbfsls output. Signed-off-by: Yaroslav K. <yar444@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> [clean up checkpatch errors and warnings] Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2016-06-19fs: cbfs: Fix build of fs/cbfs/cbfs.c when building u-boot sandbox on x86 32-bitGuillaume GARDET
Fix the following build errors when building sandbox on x86 32-bit: In file included from fs/cbfs/cbfs.c:8:0: include/malloc.h:364:7: error: conflicting types for 'memset' void* memset(void*, int, size_t); ^ In file included from include/compiler.h:123:0, from include/cbfs.h:10, from fs/cbfs/cbfs.c:7: include/linux/string.h:78:15: note: previous declaration of 'memset' was here extern void * memset(void *,int,__kernel_size_t); ^ In file included from fs/cbfs/cbfs.c:8:0: include/malloc.h:365:7: error: conflicting types for 'memcpy' void* memcpy(void*, const void*, size_t); ^ In file included from include/compiler.h:123:0, from include/cbfs.h:10, from fs/cbfs/cbfs.c:7: include/linux/string.h:81:15: note: previous declaration of 'memcpy' was here extern void * memcpy(void *,const void *,__kernel_size_t); ^ scripts/Makefile.build:280: recipe for target 'fs/cbfs/cbfs.o' failed Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-11-17fs: descend into sub directories when it is necessaryMasahiro Yamada
2013-10-31fs: convert makefiles to Kbuild styleMasahiro Yamada
2012-12-06cbfs: Remove mention of CREDITS filesSimon Glass
As requested by Wolfgang, remove references to CREDITS in the CBFS files. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-22fs: Add a Coreboot Filesystem (CBFS) driver and commandsGabe Black
This change adds CBFS support and some commands to use it to u-boot. These commands are: cbfsinit - Initialize CBFS support and pull all metadata into RAM. The end of the ROM is an optional parameter which defaults to the standard 0xffffffff and can be used to support multiple CBFSes in a system. The last one set up with cbfsinit is the one that will be used. cbfsinfo - Print information from the CBFS header. cbfsls - Print out the size, type, and name of all the files in the current CBFS. Recognized types are translated into symbolic names. cbfsload - Load a file from CBFS into memory. Like the similar command for fat filesystems, you can optionally provide a maximum size. Support for CBFS is compiled in when the CONFIG_CMD_CBFS option is specified. The CBFS driver can also be used programmatically from within u-boot. If u-boot needs something out of CBFS very early before the heap is configured, it won't be able to use the normal CBFS support which caches some information in memory it allocates from the heap. The cbfs_file_find_uncached function searches a CBFS instance without touching the heap. Signed-off-by: Gabe Black <gabeblack@google.com> Signed-off-by: Stefan Reinauer <reinauer@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
