path: root/fs/btrfs
2017-10-16fs: btrfs: Remove a foreign language noteMarek Behún
I accidentaly left a foreign language note in the code from development. Signed-off-by: Marek Behun <marek.behun@nic.cz>
2017-10-16fs: btrfs: Fix usage of uninitialized variablesMarek Behún
The variable res should be initialized to 0 in these functions, because if the searched key is not found, the variable is used uninitialized. Reported-by: Coverity (CID: 167335) Reported-by: Coverity (CID: 167336) Reported-by: Coverity (CID: 167337) Signed-off-by: Marek Behun <marek.behun@nic.cz>
2017-10-03fs/btrfs: Fix warning in btrfs_check_super()Tom Rini
We specifically say that the last arg is u32, so use %lu. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-02fs: btrfs: Add U-Boot fs handlers.Marek Behún
Signed-off-by: Marek Behun <marek.behun@nic.cz> create mode 100644 fs/btrfs/Kconfig create mode 100644 fs/btrfs/Makefile create mode 100644 fs/btrfs/btrfs.c create mode 100644 include/btrfs.h
2017-10-02fs: btrfs: Add single-device read-only BTRFS implementationMarek Behún
This adds the proper implementation for the BTRFS filesystem. The implementation currently supports only read-only mode and the filesystem can be only on a single device. Checksums of data chunks is unimplemented. Compression is implemented (ZLIB + LZO). Signed-off-by: Marek Behun <marek.behun@nic.cz> create mode 100644 fs/btrfs/btrfs.h create mode 100644 fs/btrfs/chunk-map.c create mode 100644 fs/btrfs/compression.c create mode 100644 fs/btrfs/ctree.c create mode 100644 fs/btrfs/dev.c create mode 100644 fs/btrfs/dir-item.c create mode 100644 fs/btrfs/extent-io.c create mode 100644 fs/btrfs/hash.c create mode 100644 fs/btrfs/inode.c create mode 100644 fs/btrfs/root.c create mode 100644 fs/btrfs/subvolume.c create mode 100644 fs/btrfs/super.c
2017-10-02fs: btrfs: Add disk-to-cpu and cpu-to-disk conversion functionsMarek Behún
BTRFS on disk structures are stored in Little Endian. Add functions to convert this structures to cpu and to disk format. On Little Endian hosts, these functions do nothing. On Big Endian the CALL_MACRO_FROM_EACH from variadic-macro.h is used to define all the members for each structure on which cpu_to_le* or le*_to_cpu is to be called. Signed-off-by: Marek Behun <marek.behun@nic.cz> create mode 100644 fs/btrfs/conv-funcs.h
2017-10-02fs: btrfs: Add btrfs_tree.h and ctree.h from Linux (and modified)Marek Behún
Add btrfs_tree.h and ctree.h from Linux which contains constants and structures for the BTRFS filesystem. Signed-off-by: Marek Behun <marek.behun@nic.cz> create mode 100644 fs/btrfs/btrfs_tree.h create mode 100644 fs/btrfs/ctree.h
