This adds a filesystem which is backed by the host's filesystem. It is
modeled off of sandboxfs, which has very similar aims. Semihosting
doesn't support listing directories (except with SYS_SYSTEM), so neither
do we. it's possible to optimize a bit for the common case of reading a
whole file by omitting a call to smh_seek, but this is left as a future
optimization.
Signed-off-by: Sean Anderson <sean.anderson@seco.com>
This patch mainly deals with uncompressed files.
Signed-off-by: Huang Jianan <jnhuang95@gmail.com>
Add support for SquashFS filesystem. Right now, it does not support
compression but support for zlib will be added in a follow-up commit.
Signed-off-by: Joao Marcos Costa <joaomarcos.costa@bootlin.com>
Add a new Kconfig option to enable CBFS in SPL. This can be useful when
the memory-init code is in CBFS.
Tested-by: Bin Meng <bmeng.cn@gmail.com>
Signed-off-by: Ismael Luceno <ismael.luceno@silicon-gears.com>
Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPLY_FS_EXT4 so both
obj-$(CONFIG_$(SPL_)FS_EXT4) and CONFIG_IS_ENABLED(FS_EXT4) can be
used to control the build in both SPL and U-Boot.
Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FAT so
obj-$(CONFIG_$(SPL_)FS_FAT) can be used to control the build in both
SPL and U-Boot.
Add fs.c under SPL as well as it is needed for fs_loader
Signed-off-by: Keerthy <j-keerthy@ti.com>
[trini: Add as obj-$(CONFIG_FS_LOADER) for non-SPL_FRAMEWORK builds]
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Signed-off-by: Marek Behun <marek.behun@nic.cz>
create mode 100644 fs/btrfs/Kconfig
create mode 100644 fs/btrfs/Makefile
create mode 100644 fs/btrfs/btrfs.c
create mode 100644 include/btrfs.h
The ext4, reiserfs and zfs filesystems all have their own implementation
of the same function, *_devread. Generalize this function into fs_devread
and put the code into fs/fs_internal.c.
[trini: Move fs/fs_internal.o hunk to the end of fs/Makefile as all
cases need it]
Rather than using CMD_JFFS2 for both the filesystem and its command, we
should have a separate option for each. This allows us to enable JFFS2
support without the command, if desired, which reduces U-Boot's size
slightly.
Rather than using CMD_CBFS for both the filesystem and its command, we
should have a separate option for each. This allows us to enable CBFS
slightly.
[trini: imply FS_CBFS on SYS_COREBOOT]
Add EXT filesystem support to SPL.
Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr>
[trini: Fix a warning and checkpatch problems]
We have an unused FAT implementation in fs/fdos, remove.
This commit moves some subdirectories of fs
from the toplevel Makefile to fs/Makefile
using Kbuild descending feature.
[trini: Fixup common/cmd_io.c]
Implement "ls" and "fsload" commands that act like {fat,ext2}{ls,load},
and transparently handle either file-system. This scheme could easily be
extended to other filesystem types; I only didn't do it for zfs because
I don't have any filesystems of that type to test with.
Replace the implementation of {fat,ext[24]}{ls,load} with this new code
too.
fs/Makefile is unused. The top-level Makefile sets LIBS-y += fs/xxx and
hence causes make to directly descend two directory levels into each
individual filesystem, and it never descends into fs/ itself.
So, delete this useless file.
Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
This change adds CBFS support and some commands to use it to u-boot. These
commands are:
cbfsinit - Initialize CBFS support and pull all metadata into RAM. The end of
the ROM is an optional parameter which defaults to the standard 0xffffffff and
can be used to support multiple CBFSes in a system. The last one set up with
cbfsinit is the one that will be used.
cbfsinfo - Print information from the CBFS header.
cbfsls - Print out the size, type, and name of all the files in the current
CBFS. Recognized types are translated into symbolic names.
cbfsload - Load a file from CBFS into memory. Like the similar command for fat
filesystems, you can optionally provide a maximum size.
Support for CBFS is compiled in when the CONFIG_CMD_CBFS option is specified.
The CBFS driver can also be used programmatically from within u-boot.
If u-boot needs something out of CBFS very early before the heap is
configured, it won't be able to use the normal CBFS support which caches some
information in memory it allocates from the heap. The
cbfs_file_find_uncached function searches a CBFS instance without touching
the heap.
Signed-off-by: Gabe Black <gabeblack@google.com>
Signed-off-by: Stefan Reinauer <reinauer@chromium.org>
Signed-off-by: Uma Shankar <uma.shankar@samsung.com>
Signed-off-by: Manjunatha C Achar <a.manjunatha@samsung.com>
Signed-off-by: Iqbal Shareef <iqbal.ams@samsung.com>
Signed-off-by: Hakgoo Lee <goodguy.lee@samsung.com>
U-Boot port is based on sources forked from GRUB-0.97 by Sun in 2004,
which can be found here:
http://src.opensolaris.org/source/xref/onnv/onnv-gate/usr/src/grub/grub-0.97/stage2/zfs-include/zfs.h
Released by Sun for GRUB under the license:
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
GRUB official releases include ZFS in version:
ftp://alpha.gnu.org/gnu/grub/grub-1.99~rc1.tar.gz
And patched against GRUB Bazaar repository for ashift fixes (4KB HDDs)
more conveniently found at github:
https://github.com/pendor/grub-zfs/commit/e7b6ef3ac3b9685ac4c394c897b1d4221b7381f1
Signed-off-by: Jorgen Lundman <lundman@lundman.net>
The U-Boot UBIFS implementation is largely a direct copy from the current
Linux version (2.6.29-rc6). As already done in the UBI version we have an
"abstraction layer" to redefine or remove some OS calls (e.g. mutex_lock()
...). This makes it possible to use the original Linux code with very
little changes. And by this we can better update to later Linux versions.
I removed some of the Linux features that are not used in the U-Boot
version (e.g. garbage-collection, write support).
CC: Artem Bityutskiy <dedekind@infradead.org>
CC: Adrian Hunter <ext-Adrian.Hunter@nokia.com>
Signed-off-by: William Juul <william.juul@tandberg.com>
To use YAFFS2 define CONFIG_YAFFS2
Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
Add Reiserfs support
* Patch by Hinko Kocevar, 20 Mar 2004
- Add auto-release for SMSC LAN91c111 driver
- Add save/restore of PTR and PNR regs as suggested in datasheet
add support for cramfs (uses JFFS2 command interface)
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
* Patches by Kyle Harris, 13 Mar 2003:
- Add FAT partition support
- Add command support for FAT
- Add command support for MMC
- Add Intel PXA support for video
- Add Intel PXA support for MMC
- Enable MMC and FAT for lubbock board
- Other misc changes for lubbock board
Add support for i386 architecture and AMD SC520 board
* Patch by Pierre Aubert, 12 Nov 2002:
Add support for DOS filesystem and booting from DOS floppy disk
