path: root/fs/Makefile
2004-12-16ext2fs support addedstroese
2004-03-25* Patch by Pavel Bartusek, 21 Mar 2004wdenk
Add Reiserfs support * Patch by Hinko Kocevar, 20 Mar 2004 - Add auto-release for SMSC LAN91c111 driver - Add save/restore of PTR and PNR regs as suggested in datasheet
2004-01-03* Patch by Robert Schwebel, 15 Dec 2003:wdenk
add support for cramfs (uses JFFS2 command interface)
2003-06-15* Fix CONFIG_NET_MULTI support in include/net.hLABEL_2003_06_16_0055wdenk
* Patches by Kyle Harris, 13 Mar 2003: - Add FAT partition support - Add command support for FAT - Add command support for MMC ---- - Add Intel PXA support for video - Add Intel PXA support for MMC ---- - Enable MMC and FAT for lubbock board - Other misc changes for lubbock board
2002-11-18* Patch by Daniel Engström, 13 Nov 2002:LABEL_2002_11_18_0115wdenk
Add support for i386 architecture and AMD SC520 board * Patch by Pierre Aubert, 12 Nov 2002: Add support for DOS filesystem and booting from DOS floppy disk
2002-03-08Initial revisionwdenk
