path: root/examples
2009-12-02smc91111_eeprom: drop CONFIG stub protectionMike Frysinger
Since the Makefile now controls the compilation of this, there is no need for CONFIG checking nor the stub function. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-02Fix build failure in examples/standaloneSanjeev Premi
Some versions of 'make' do not handle trailing white-spaces properly. Trailing spaces in ELF causes a 'fake' source to be added to the variable COBJS; leading to build failure (listed below). The problem was found with GNU Make 3.80. Using text-function 'strip' as a workaround for the problem. make[1]: Entering directory `/home/sanjeev/u-boot/examples/standalone' arm-none-linux-gnueabi-gcc -g -Os -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0x80e80000 -I/home/sanjeev/u-boot/include -fno-builtin -ffreestanding -nostdinc -isystem /opt/codesourcery/2009q1- 203/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.3/include -pipe -DCONFIG_ ARM -D__ARM__ -marm -mabi=aapcs-linux -mno-thumb-interwork -march=armv5 -Wall -Wstrict-prototypes -fno-stack-protector -g -Os -fno-common -ff ixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0x80e80000 -I/home/sanje ev/u-boot/include -fno-builtin -ffreestanding -nostdinc -isystem /opt/co desourcery/2009q1-203/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.3/includ e -pipe -DCONFIG_ARM -D__ARM__ -marm -mabi=aapcs-linux -mno-thumb-inte rwork -march=armv5 -I.. -Bstatic -T u-boot.lds -Ttext 0x80e80000 -o .c arm-none-linux-gnueabi-gcc: no input files make[1]: *** [.c] Error 1 make[1]: Leaving directory `/home/sanjeev/u-boot/examples/standalone' make: *** [examples/standalone] Error 2 premi # Signed-off-by: Sanjeev Premi <premi@ti.com> Fixed typo (s/ElF/ELF/). Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-11-23Nios2/Nios: Remove unnecessary (residual) linker Nios command scripts fromScott McNutt
the standalone examples. Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2009-11-12smc911x_eeprom: fix building after smc911x overhaulMike Frysinger
When the smc911x driver was converted to NET_MULTI, the smc911x eeprom was missed. The config option needed updating as well as overhauling of the rergister read/write functions. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Mike Rapoport <mike.rapoport@gmail.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-27Fix bug in jumptable call stubs for SPARC.Sergey Mironov
Signed-off-by: Sergey Mironov <ierton@gmail.com> Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-15standalone: convert to kbuild styleMike Frysinger
Clean up the arch/cpu/board/config checks as well as redundant setting of srec/bin variables by using the kbuild VAR-$(...) style. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-04push LOAD_ADDR out to arch mk filesMike Frysinger
Rather than maintain/extend the current ifeq($(ARCH)) mess that exists in the standalone Makefile, push the setting up of LOAD_ADDR out to the arch config.mk (and rename to STANDALONE_LOAD_ADDR in the process). This keeps the common code clean and lets the arch do whatever crazy crap it wants in its own area. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-04atmel_df_pow2: standalone to convert dataflashes to pow2Mike Frysinger
Atmel DataFlashes by default operate with pages that are slightly bigger than normal binary sizes (i.e. many are 1056 byte pages rather than 1024 bytes). However, they also have a "power of 2" mode where the pages show up with the normal binary size. The latter mode is required in order to boot with a Blackfin processor, so many people wish to convert their DataFlashes on their development systems to this mode. This standalone application does just that. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-02Blackfin: change global data register from P5 to P3Robin Getz
Since the Blackfin ABI favors higher scratch registers by default, use the last scratch register (P3) for global data rather than the first (P5). This allows the compiler's register allocator to use higher number scratch P registers, which in turn better matches the Blackfin instruction set, which reduces the size of U-Boot by more than 1024 bytes... Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-08Fix examples for OMAP3 boards...Michael Evans
The attached patch corrects an error in the examples/Makefile which causes the applications in the examples directory to hang on OMAP3 based boards. The current Makefile sets -Ttext during linking to 0x0c100000 which is outside of addressable SDRAM memory. The script corrects the existing ifeq...else...endif logic to look at the VENDOR tag rather than the CPU tag. The patch affects the following configs: omap3_beagle_config, omap3_overo_config, omap3_evm_config, omap3_pandora_config, omap3_zoom1_config and omap3_zoom2_config. Signed-off-by: Michael Evans <horse_dung@hotmail.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-27ABI: fix build problems due to now needed div64 routine.Wolfgang Denk
2009-07-21Move api_examples to examples/apiPeter Tyser
Also add a rule to remove demo.bin which was previously leftover after a "make clean" Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-07-21Move examples/ to examples/standalonePeter Tyser
The current files in examples are all standalone application examples, so put them in their own subdirectory for organizational purposes Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-04smc91111_eeprom: move board-specific init into SMC91111_EEPROM_INIT()Mike Frysinger
Rather than sticking Blackfin-specific stuff into the eeprom example, use an indirect macro so that any board can override it with their own magic sauce in their board config file. Also fix some spurious semi-colons in defines while I'm at it ... Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-19smc911x_eeprom: update register APIMike Frysinger
The smc911x driver changed the naming convention for its register funcs, so update the eeprom code accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-02-22smc911x_eeprom: new example app for managing newer SMC partsMike Frysinger
A forward port of the last version to work with the newer smc911x driver. I only have a board with a LAN9218 part on it, so that is the only one I've tested. But there isn't anything in this that would make it terribly chip specific afaik. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Sascha Hauer <s.hauer@pengutronix.de> CC: Guennadi Liakhovetski <lg@denx.de> CC: Magnus Lilja <lilja.magnus@gmail.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-01-24OMAP3: Add common board, interrupt and system infoDirk Behme
Add common board, interrupt and system info code. Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2008-12-10Fixed build error due to #define of _LINUX_STRING_H_ in 82559_eeprom.cGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2008-10-14sh: Fix cannot execute a stand-alone applicationNobuhiro Iwamatsu
Address calculated in EXPORT_FUNC in SuperH was wrong, I revised it. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-09-09Update i386 code (sc520_cdp)Graeme Russ
Attempt to bring i386 / sc520 inline with master Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2008-08-31sh: Add support SH2/SH2A which is CPU of Renesas TechnologyNobuhiro Iwamatsu
Add support SH2/SH2A basic function. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-07-11Fix some more print() format errors.Wolfgang Denk
2008-07-10Fix some more print() format errors.Wolfgang Denk
2008-05-19example/gitignore: update with all generated examplesJean-Christophe PLAGNIOL-VILLARD
2008-04-08SPARC: Added generic support for SPARC architecture.Daniel Hellstrom
2008-03-12Merge branch 'master' of git://www.denx.de/git/u-boot into new-imageMarian Balakowicz
2008-03-04examples/Makefile: build "hello_world" on 8xx, too.Wolfgang Denk
2008-03-02Fix alignment error on ARM for modulesWoodruff, Richard
Fix alignment fault on ARM when running modules. With out an explicit linker file gcc4.2.1 will half word align __bss_start's value. The word dereference will crash hello_world. signed-off-by Richard Woodruff <r-woodruff2@ti.com>
2008-02-21Merge branch 'master' of /home/git/u-bootMarian Balakowicz
2008-02-17Remove files added by mistake, update CHANGELOG.Wolfgang Denk
2008-02-15Merge branch 'master' of git://www.denx.de/git/u-boot-blackfinWolfgang Denk
Conflicts: Makefile doc/README.standalone Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-02-14PPC: Use r2 instead of r29 as global data pointerWolfgang Denk
R29 was an unlucky choice as with recent toolchains (gcc-4.2.x) gcc will refuse to use load/store multiple insns; instead, it issues a list of simple load/store instructions upon function entry and exit, resulting in bigger code size, which in turn makes the build for a few boards fail. Use r2 instead. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-02-07[new uImage] Define a API for image handling operationsMarian Balakowicz
- Add inline helper macros for basic header processing - Move common non inline code common/image.c - Replace direct header access with the API routines - Rename IH_CPU_* to IH_ARCH_* Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-04use C code rather than inline assemblyMike Frysinger
2008-02-04add support for Blackfin symbol prefixes to examplesMike Frysinger
2008-02-04make smc91111_eeprom managment simpler by depending on the board ↵Mike Frysinger
configuration file rather than a hardcoded list of boards Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-02-04add gitignores for Blackfin piecesMike Frysinger
2007-12-27Fix coding style issues; update CHANGELOG.Wolfgang Denk
2007-12-07Merge git://www.denx.de/git/u-bootNobuhiro Iwamatsu
Conflicts: drivers/Makefile
2007-11-29Merge git://www.denx.de/git/u-bootNobuhiro Iwamatsu
2007-11-25drivers/net : move net drivers to drivers/netJean-Christophe PLAGNIOL-VILLARD
2007-11-15Add .gitignore filesGrant Likely
Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2007-10-21[MIPS] u-boot.lds: Define _gp in a standard mannerShinya Kuribayashi
Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2007-10-21[MIPS] u-boot.lds: Fix __got_start and __got_endShinya Kuribayashi
Ensure that __got_start points to top of the `.got', and __got_end points to bottom as well, so that we never fail to count num_got_entries. Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
