path: root/examples
2022-10-26examples: hello_world: Drop inclusion of common headerPaul Barker
The "common.h" header is not covered by the licensing exception for standalone applications. Let's drop inclusion of this header from the hello_world example to prove that a standalone app can be built without it. Signed-off-by: Paul Barker <paul.barker@sancloud.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2022-10-10examples: standalone: Fix build with LLVM toolchainAlistair Delva
When building the standalone example with llvm, the link step fails: examples/standalone/libstubs.o: In function `dummy': include/_exports.h:10: undefined reference to `jt' include/_exports.h:11: undefined reference to `jt' include/_exports.h:12: undefined reference to `jt' include/_exports.h:13: undefined reference to `jt' include/_exports.h:14: undefined reference to `jt' examples/standalone/libstubs.o:include/_exports.h:15: more undefined references to `jt' follow Indeed, the standalone libstubs.o does use the jt symbol, but it was marked 'static' in stubs.c. It's strange how gcc builds are working. Signed-off-by: Alistair Delva <adelva@google.com> Cc: Rick Chen <rick@andestech.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Cc: Nick Desaulniers <ndesaulniers@google.com>
2022-08-12net: Remove smc91111 ethernet driverTom Rini
This driver has not been converted to DM_ETH. The migration deadline passed 2 years ago. Cc: Linus Walleij <linus.walleij@linaro.org> Cc: David Feng <fenghua@phytium.com.cn> Cc: Liviu Dudau <liviu.dudau@foss.arm.com> Cc: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Ramon Fried <rfried.dev@gmail.com>
2022-04-25nds32: Remove the architectureTom Rini
As removal of nds32 has been ack'd for the Linux kernel, remove support here as well. Cc: Rick Chen <rick@andestech.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Rick Chen <rick@andestech.com>
2021-10-21examples: api: glue: Remove comment that does not apply anymoreMarek BehĂșn
This comment is not true since commit 6215bd4c1fd6 ("api: Use hashtable function for API_env_enum"). Signed-off-by: Marek BehĂșn <marek.behun@nic.cz> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-08-02global: Convert simple_strtoul() with decimal to dectoul()Simon Glass
It is a pain to have to specify the value 10 in each call. Add a new dectoul() function and update the code to use it. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-10-08examples: make examples/ optionalHeinrich Schuchardt
Most users don't need the standalone API examples. Distributions like SUSE do not supply libgcc for cross-compiling and we cannot do without on ARMv8 for building examples/. Make examples selectable via symbol CONFIG_EXAMPLES. It defaults to yes on ARCH_QEMU to ensure that we compile the API as part of our continuous integration. Cc: Matthias Brugger <mbrugger@suse.com> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Matthias Brugger <mbrugger@suse.com>
2020-06-12net: smc911x: Drop the standalone EEPROM exampleMarek Vasut
Drop the example, for two reasons. First, it is tapping directly into the IO accessors of the SMC911x, while it should instead go through the net device API. Second, this makes conversion of the SMC911x driver to DM real hard. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Tom Rini <trini@konsulko.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2020-05-18common: Drop linux/delay.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18Fix some checkpatch warnings in calls to udelay()Simon Glass
Fix up some incorrect code style in calls to functions in the linux/time.h header, mostly udelay(). Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop net.h from common headerSimon Glass
Move this header out of the common header. Network support is used in quite a few places but it still does not warrant blanket inclusion. Note that this net.h header itself has quite a lot in it. It could be split into the driver-mode support, functions, structures, checksumming, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-01net: smc911x: Add DM supportMarek Vasut
Add support for U-Boot DM and DT probing. Furthermore, build the SMC911x standalone EEPROM example only for the non-DM case, as it is not converted yet. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2020-05-01net: smc911x: Drop weak alias from 32bit accessorsMarek Vasut
These accessors are not overridden by any board, and even if they were, this is something which should be handled via DM now, so remove the weak alias option. Moreover, drop the inline keyword, as the compiler can decide better. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2020-05-01net: smc911x: Inline all functions from header fileMarek Vasut
Inline all the functions from the header file, as they are not used outside of the driver or the standalone EEPROM example. Note that this does introduce considerable amount of duplication in the standalone EEPROM example, however that one has to be rewritten anyway, roughly such that the SMC911x driver would expose DM EEPROM interface and the standalone example would use that. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2020-04-10kconfig / kbuild: Re-sync with Linux 4.19Tom Rini
Align Kconfig and Kbuild logic to Linux 4.19 release with minimal impact on files outside of this scope. Our previous Kconfig sync was done by commit 5972ff077e0f ("kconfig / kbuild: re-sync with Linux 4.18"). In this particular re-sync in order to keep clang support working a number of related changes needed to be pulled in that had been missed previously. Not all of these changes we easily traceable and so have been omitted from the list below. The imported Linux commits are: [From prior to v4.18] 9f3f1fd29976 kbuild: Add __cc-option macro d7f14c66c273 kbuild: Enable Large File Support for hostprogs 6d79a7b424a5 kbuild: suppress warnings from 'getconf LFS_*' 24403874316a Shared library support 86a9df597cdd kbuild: fix linker feature test macros when cross compiling with Clang 0294e6f4a000 kbuild: simplify ld-option implementation [From v4.18 to v4.19] 96f14fe738b6 kbuild: Rename HOSTCFLAGS to KBUILD_HOSTCFLAGS 10844aebf448 kbuild: Rename HOSTCXXFLAGS to KBUILD_HOSTCXXFLAGS b90a368000ab kbuild: Rename HOSTLDFLAGS to KBUILD_HOSTLDFLAGS 8377bd2b9ee1 kbuild: Rename HOST_LOADLIBES to KBUILD_HOSTLDLIBS f92d19e0ef9b kbuild: Use HOST*FLAGS options from the command line 4ab3b80159d4 kconfig: check for pkg-config on make {menu,n,g,x}config 693359f7ac90 kconfig: rename SYMBOL_AUTO to SYMBOL_NO_WRITE f60b992e30ff kbuild: replace $(LDFLAGS) $(ldflags-y) with $(ld_flags) 2fb9279f2c3e kbuild: change ld_flags to contain LDFLAGS_$(@F) c931d34ea085 arm64: build with baremetal linker target instead of Linux when available 5accd7f3360e kconfig: handle format string before calling conf_message_callback() a2ff4040151a kconfig: rename file_write_dep and move it to confdata.c 0608182ad542 kconfig: split out useful helpers in confdata.c adc18acf42a1 kconfig: remove unneeded directory generation from local*config 79123b1389cc kconfig: create directories needed for syncconfig by itself 16952b77d8b5 kconfig: make syncconfig update .config regardless of sym_change_count d6c6ab93e17f kbuild: remove deprecated host-progs variable 56869d45e364 kconfig: fix the rule of mainmenu_stmt symbol c151272d1687 kconfig: remove unused sym_get_env_prop() function 1880861226c1 kconfig: remove P_ENV property type e3fd9b5384f3 scripts/dtc: consolidate include path options in Makefile 4bf6a9af0e91 kconfig: add build-only configurator targets f1575595d156 kconfig: error out when seeing recursive dependency 5e8c5299d315 kconfig: report recursive dependency involving 'imply' f498926c47aa kconfig: improve the recursive dependency report 98a4afbfafd2 kconfig: fix "Can't open ..." in parallel build 9a9ddcf47831 kconfig: suppress "configuration written to .config" for syncconfig 87a32e624037 kbuild: pass LDFLAGS to recordmcount.pl d503ac531a52 kbuild: rename LDFLAGS to KBUILD_LDFLAGS 217c3e019675 disable stringop truncation warnings for now bc8d2e20a3eb kconfig: remove a spurious self-assignment fd65465b7016 kconfig: do not require pkg-config on make {menu,n}config 5a4630aadb9a ftrace: Build with CPPFLAGS to get -Qunused-arguments Note that this adds new cleanup work to do in that we should adapt the shared library support we have to what is now upstream. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Masahiro Yamada <masahiroy@kernel.org>
2020-01-17common: Move hang() to the same header as panic()Simon Glass
At present panic() is in the vsprintf.h header file. That does not seem like an obvious choice for hang(), even though it relates to panic(). So let's put hang() in its own header. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Migrate a few more files] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-02crc32: Use the crc.h header for crc functionsSimon Glass
Drop inclusion of crc.h in common.h and use the correct header directly instead. With this we can drop the conflicting definition in fw_env.h and rely on the crc.h header, which is already included. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Move env_set() to env.hSimon Glass
Move env_set() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move envmatch() to env.hSimon Glass
Move envmatch() over to the new header file. Also rename it to env_match() to better line up with other functions. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-01-15Merge git://git.denx.de/u-boot-riscvTom Rini
1. Improve cache implementation. 2. Fix and improve standalone applications
2019-01-15kbuild: add .SECONDARY special target to scripts/Kbuild.includeMasahiro Yamada
Based on the following Linux commits: - 54a702f70589 ("kbuild: mark $(targets) as .SECONDARY and remove .PRECIOUS markers") - 8e9b61b293d9 ("kbuild: move .SECONDARY special target to Kbuild.include") GNU Make automatically deletes intermediate files that are updated in a chain of pattern rules. Example 1) %.dtb.o <- %.dtb.S <- %.dtb <- %.dts Example 2) %.o <- %.c <- %.c_shipped A couple of makefiles mark such targets as .PRECIOUS to prevent Make from deleting them, but the correct way is to use .SECONDARY. .SECONDARY Prerequisites of this special target are treated as intermediate files but are never automatically deleted. .PRECIOUS When make is interrupted during execution, it may delete the target file it is updating if the file was modified since make started. If you mark the file as precious, make will never delete the file if interrupted. Both can avoid deletion of intermediate files, but the difference is the behavior when Make is interrupted; .SECONDARY deletes the target, but .PRECIOUS does not. The use of .PRECIOUS is relatively rare since we do not want to keep partially constructed (possibly corrupted) targets. .SECONDARY with no prerequisites causes all targets to be treated as secondary. This agrees the policy of Kbuild. scripts/Kbuild.include seems a suitable place to add it because it is included from almost all sub-makes. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-01-15riscv: support standalone applications on RV64I systemsLukas Auer
Add an implementation of EXPORT_FUNC() for RV64I systems to support them in standalone applications. Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2019-01-15riscv: replace use of callee-saved register in standaloneLukas Auer
Register x19 (s3) is a callee-saved register. It must not be used to load and jump to exported functions without saving it beforehand. Replace it with t0, a temporary and caller-saved register. Change the code comment to reflect this and fix it to correctly list gp as the register with the pointer to global data. Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2019-01-15riscv: remove RISC-V standalone linker scriptLukas Auer
Standalone applications do not require a separate linker script and can use the default linker script of the compiler instead. Remove the RISC-V standalone linker script. Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2018-11-27spi: Remove used spi_initJagan Teki
spi_init used in some areas in tree, but the respective drivers will remove in future patches. So remove the same instances. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2018-11-18MIPS: fix linking of standalone programsDaniel Schwierzeck
Use the global MIPS specific u-boot.lds for linking standalone programs instead of the outdated ones in examples/standalone/. Also pass --gc-sections in LDFLAGS_STANDALONE to optimize the size of standalone programs. Finally remove the deprecated config.mk files in arch/mips/cpu/mips[32,64]/. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-11-18Kbuild: standalone: do not ignore platform-specific OBJCOPYFLAGSDaniel Schwierzeck
Currently the OBJCOPYFLAGS are cleared when assigning "-O srec" or "-O binary" for standalone programs. All flags set by arch-specific Makefiles are lost. This is bad if an arch demands arch-specific flags for the objcopy step. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-11-18Kbuild: add LDFLAGS_STANDALONEDaniel Schwierzeck
Introduce a new Makefile variable for passing LDFLAGS to standalone programs. Currently the variable CONFIG_STANDALONE_LOAD_ADDR is misued on some archs to pass a specific linker script. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Rick Chen <rick@andestech.com>
2018-06-13lib: Add hexdumpAlexey Brodkin
Often during debugging session it's very interesting to see what data we were dealing with. For example what we write or read to/from memory or peripherals. This change introduces functions that allow to dump binary data with one simple function invocation like: ------------------->8---------------- print_hex_dump_bytes("", DUMP_PREFIX_OFFSET, buf, len); ------------------->8---------------- which gives us the following: ------------------->8---------------- 00000000: f2 b7 c9 88 62 61 75 64 72 61 74 65 3d 31 31 35 ....baudrate=115 00000010: 32 30 30 00 62 6f 6f 74 61 72 67 73 3d 63 6f 6e 200.bootargs=con 00000020: 73 6f 6c 65 3d 74 74 79 53 33 2c 31 31 35 32 30 sole=ttyS3,11520 00000030: 30 6e 38 00 62 6f 6f 74 64 65 6c 61 79 3d 33 00 0n8.bootdelay=3. 00000040: 62 6f 6f 74 66 69 6c 65 3d 75 49 6d 61 67 65 00 bootfile=uImage. 00000050: 66 64 74 63 6f 6e 74 72 6f 6c 61 64 64 72 3d 39 fdtcontroladdr=9 00000060: 66 66 62 31 62 61 30 00 6c 6f 61 64 61 64 64 72 ffb1ba0.loadaddr 00000070: 3d 30 78 38 32 30 30 30 30 30 30 00 73 74 64 65 =0x82000000.stde 00000080: 72 72 3d 73 65 72 69 61 6c 30 40 65 30 30 32 32 rr=serial0@e0022 00000090: 30 30 30 00 73 74 64 69 6e 3d 73 65 72 69 61 6c 000.stdin=serial 000000a0: 30 40 65 30 30 32 32 30 30 30 00 73 74 64 6f 75 0@e0022000.stdou 000000b0: 74 3d 73 65 72 69 61 6c 30 40 65 30 30 32 32 30 t=serial0@e00220 000000c0: 30 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00.............. ... ------------------->8---------------- Source of hexdump.c was copied from Linux kernel v4.7-rc2. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Mario Six <mario.six@gdsys.cc> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Cc: Stefan Roese <sr@denx.de>
2018-01-22vsprintf.c: add EFI device path printingHeinrich Schuchardt
For debugging efi_loader we need the capability to print EFI device paths. With this patch we can write: debug("device path: %pD", dp); A possible output would be device path: /MemoryMapped(0x0,0x3ff93a82,0x3ff93a82) This enhancement is not available when building without EFI support and neither in the SPL nor in the API example. A test is provided. It can be executed in the sandbox with command ut_print. The development for EFI support in the sandbox is currently in branch u-boot-dm/efi-working. The branch currently lacks commit 6ea8b580f06b ("efi_loader: correct DeviceNodeToText for media types"). Ater rebasing the aforementioned branch on U-Boot v2018.01 the test is executed successfully. Without EFI support in the sandbox the test is simply skipped. Suggested-by: Rob Clark <robdclark@gmail.com> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-12riscv: Support standaloneRick Chen
Run hello_world successfully. U-Boot 2018.01-rc2-00033-gb265b91-dirty (Dec 22 2017 - 13:54:21 +0800) DRAM: 1 GiB MMC: mmc@f0e00000: 0 SF: Detected mx25u1635e with page size 256 Bytes, erase size 4 KiB, total 2 MiB In: serial@f0300000 Out: serial@f0300000 Err: serial@f0300000 Net: Warning: mac@e0100000 (eth0) using random MAC address - 0a:47:9b:f8:b4:f2 eth0: mac@e0100000 RISC-V # mmc rescan RISC-V # fatls mmc 0:1 318907 u-boot-ae250-64.bin 1252 hello_world_ae250_32.bin 328787 u-boot-ae250-32.bin 3 file(s), 0 dir(s) RISC-V # fatload mmc 0:1 0x600000 hello_world_ae250_32.bin reading hello_world_ae250_32.bin 1252 bytes read in 23 ms (52.7 KiB/s) RISC-V # go 0x600000 Example expects ABI version 9 Actual U-Boot ABI version 9 Hello World argc = 1 argv[0] = "0x600000" argv[1] = "$B@" Hit any key to exit ... RISC-V # Signed-off-by: Rick Chen <rick@andestech.com> Signed-off-by: Rick Chen <rickchen36@gmail.com> Signed-off-by: Greentime Hu <green.hu@gmail.com>
2017-09-12examples: add fallback memcpyRob Clark
Solves build issue: Building current source for 134 boards (12 threads, 1 job per thread) arm: + lsxhl +examples/api/vsprintf.o: In function `string16': +lib/vsprintf.c:278: undefined reference to `memcpy' +examples/api/uuid.o: In function `uuid_bin_to_str': +lib/uuid.c:197: undefined reference to `memcpy' +lib/uuid.c:199: undefined reference to `memcpy' +make[3]: *** [examples/api/demo] Error 1 +make[2]: *** [examples/api] Error 2 +make[1]: *** [examples] Error 2 +make: *** [sub-make] Error 2 133 0 1 /134 sheevaplug Signed-off-by: Rob Clark <robdclark@gmail.com>
2017-09-12vsprintf.c: add GUID printingRob Clark
This works (roughly) the same way as linux's, but we currently always print lower-case (ie. we just keep %pUB and %pUL for compat with linux), mostly just because that is what uuid_bin_to_str() supports. %pUb: 01020304-0506-0708-090a-0b0c0d0e0f10 %pUl: 04030201-0605-0807-090a-0b0c0d0e0f10 It will be used by a later efi_loader paths for efi variables and for device-path-to-text protocol, and also quite useful for debug prints of protocol GUIDs. Signed-off-by: Rob Clark <robdclark@gmail.com> Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-12vsprintf.c: add UTF-16 string (%ls) supportRob Clark
This is convenient for efi_loader which deals a lot with UTF-16. Only enabled with CC_SHORT_WCHAR, leaving room to add a UTF-32 version when CC_SHORT_WCHAR is not enabled. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-06avr32: Retire AVR32 for goodAndy Shevchenko
AVR32 is gone. It's already more than two years for no support in Buildroot, even longer there is no support in GCC (last version is heavily patched 4.2.4). Linux kernel v4.12 got rid of it (and v4.11 didn't build successfully). There is no good point to keep this support in U-Boot either. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-06-16powerpc, 5xxx, 512x: remove support for mpc5xxx and mpc512xHeiko Schocher
There was for long time no activity in the mpx5xxx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in mpc5xxx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 8260: remove support for mpc8260Heiko Schocher
There was for long time no activity in the 8260 area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8260, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 8xx: remove support for 8xxHeiko Schocher
There was for long time no activity in the 8xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8xx, so remove it (with a heavy heart, knowing that I remove here the root of U-Boot). Signed-off-by: Heiko Schocher <hs@denx.de>
2017-04-05OpenRISC: RemoveTom Rini
The OpenRISC architecture is currently unmaintained, remove. Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-05SPARC: RemoveTom Rini
The SPARC architecture is currently unmaintained, remove. Cc: Francois Retief <fgretief@spaceteq.co.za> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05Blackfin: RemoveTom Rini
The architecture is currently unmaintained, remove. Cc: Benjamin Matthews <mben12@gmail.com> Cc: Chong Huang <chuang@ucrobotics.com> Cc: Dimitar Penev <dpn@switchfin.org> Cc: Haitao Zhang <hzhang@ucrobotics.com> Cc: I-SYST Micromodule <support@i-syst.com> Cc: M.Hasewinkel (MHA) <info@ssv-embedded.de> Cc: Marek Vasut <marex@denx.de> Cc: Martin Strubel <strubel@section5.ch> Cc: Peter Meerwald <devel@bct-electronic.com> Cc: Sonic Zhang <sonic.adi@gmail.com> Cc: Valentin Yakovenkov <yakovenkov@niistt.ru> Cc: Wojtek Skulski <info@skutek.com> Cc: Wojtek Skulski <skulski@pas.rochester.edu> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-20ARM: Default to using optimized memset and memcpy routinesTom Rini
We have long had available optimized versions of the memset and memcpy functions that are borrowed from the Linux kernel. We should use these in normal conditions as the speed wins in many workflows outweigh the relatively minor size increase. However, we have a number of places where we're simply too close to size limits in SPL and must be able to make the size vs performance trade-off in those cases. Cc: Philippe Reynes <tremyfr@yahoo.fr> Cc: Eric Jarrige <eric.jarrige@armadeus.org> Cc: Heiko Schocher <hs@denx.de> Cc: Magnus Lilja <lilja.magnus@gmail.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Chander Kashyap <k.chander@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-26Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
trini: Drop local memset() from examples/standalone/mem_to_mem_idma2intr.c Signed-off-by: Tom Rini <trini@konsulko.com>
2016-08-15xtensa: add support for the xtensa processor architecture [1/2]Chris Zankel
The Xtensa processor architecture is a configurable, extensible, and synthesizable 32-bit RISC processor core provided by Cadence. This is the first part of the basic architecture port with changes to common files. The 'arch/xtensa' directory, and boards and additional drivers will be in separate commits. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-05-21Add support for 64-bit MIPS to examples/standaloneStanislav Galabov
Signed-off-by: Stanislav Galabov <sgalabov@gmail.com>
2016-05-21Fix FreeBSD loader API so that it works on both 32-bit and 64-bit targets.Stanislav Galabov
Specifically tested on MIPS under QEMU (works with all combination of bit-ness and endian-ness) Signed-off-by: Stanislav Galabov <sgalabov@gmail.com>
2016-02-08api: Add FreeBSD API support for MIPS platformsStanislav Galabov
This patch adds U-Boot API support (used by FreeBSD loader) for MIPS platforms. Signed-off-by: Stanislav Galabov <sgalabov@gmail.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
