path: root/examples
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19Makefile: move some flags to examples makefilesMasahiro Yamada
This commit moves some flags which are used under examples/ directory only. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makfile: move suffix rules to Makefile.buildMasahiro Yamada
This commit moves suffix rules from config.mk to scripts/Makefile.build, which will allow us to switch smoothly to real Kbuild. Note1: post/lib_powerpc/fpu/Makefile has its own rule to compile C sources. We need to tweak it to keep the same behavior. Note2: There are two file2 with the same name: arch/arm/lib/crt0.S and eamples/api/crt0.S. To keep the same build behavior, examples/api/Makefile also has to be treaked. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19examples: Use scripts/Makefile.buildMasahiro Yamada
2014-02-07arc: add support for standalone programsAlexey Brodkin
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Francois Bedard <fbedard@synopsys.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de>
2014-01-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Bringing in the MMC tree means that CONFIG_BOUNCE_BUFFER needed to be added to include/configs/exynos5-dt.h now. Conflicts: include/configs/exynos5250-dt.h Signed-off-by: Tom Rini <trini@ti.com>
2014-01-09arm64: core supportDavid Feng
Relocation code based on a patch by Scott Wood, which is: Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: David Feng <fenghua@phytium.com.cn>
2013-12-16Makefile, .gitignore: Cleanup non-existing binariesMasahiro Yamada
2013-12-16examples: x86: delete 82559_eepromMasahiro Yamada
Commit fea25720 renamed arch/i386 to arch/x86. But it missed to modify examples/standalone/Makefile. Since then, examples/standalone/82559_eeprom has never compiled and nobody has noticed that. After some discussion on ML, we agreed to delete this example. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-16Makefile: Select objects by CONFIG_ rather than $(ARCH) or $(CPU)Masahiro Yamada
Convert like follows: CPU mpc83xx -> CONFIG_MPC83xx CPU mpc85xx -> CONFIG_MPC85xx CPU mpc86xx -> CONFIG_MPC86xx CPU mpc5xxx -> CONFIG_MPC5xxx CPU mpc8xx -> CONFIG_8xx CPU mpc8260 -> CONFIG_8260 CPU ppc4xx -> CONFIG_4xx CPU x86 -> CONFIG_X86 ARCH x86 -> CONFIG_X86 ARCH powerpc -> CONFIG_PPC Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-12ARM: fix the standalone programsJeroen Hofstee
The standalone programs do not use the api calls, but rely directly on u-boot variable gd->jt for the jump table. Commit fe1378a - "ARM: use r9 for gd" changed the register holding the address of gd, but the assembly code in the standalone examples was not updated accordingly. This broke the programs on ARM relying on the jumptable in the v2013.10 release. This patch unbricks them by using the correct register. Cc: Michal Simek <monstr@monstr.eu> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-11-25Makefile: descend into subdirectories only when CONFIG_API is definedMasahiro Yamada
All objects under api/ and examples/api/ directories are selected by CONFIG_API. So we can move CONFIG_API switch to the top Makefile. In order to use CONFIG_API, the definition of SUBDIR_EXAMPLES-y must be moved after "sinlude $(obj)include/autoconf.mk". Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-25examples: delete unnecessary CPPFLAGSMasahiro Yamada
2013-11-15examples: remove the remainders of dead boardMasahiro Yamada
Commit 309a292e deleted OXC board, but missed to remove the standalone example specific to OXC board. eepro100_eeprom.c has been an orphan file for a long term. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-08cosmetic: remove empty lines at the top of fileMasahiro Yamada
2013-11-04examples: enable gc-sections optionRob Herring
This fixes building time.c when unreferenced functions are added. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-09-20Cosmetic: Fix a number of typos, no functional changes.Robert P. J. Day
Fix various misspellings of things like "environment", "kernel", "default" and "volatile", and throw in a couple grammar fixes. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2013-09-12Revert "standalone-examples: support custom GCC lib"Tom Rini
After further testing, this patch has two problems. First, examples/standalone/Makefile was already inherting PLATFORM_LIBS from the top-level Makefile so this lead to duplicating the private libgcc. Second, currently the private libgcc has a reference to 'hang' that is not being fulfilled. This reverts commit 4412db46468d5965da736d06f84d13e68a6e0b51. Signed-off-by: Tom Rini <trini@ti.com>
2013-09-06standalone-examples: support custom GCC libJack Mitchell
Add support for defining the gcc lib in standalone examples as is done in the main u-boot Makefile Signed-off-by: Jack Mitchell <jack.mitchell@dbbroadcast.co.uk>
2013-07-24Add LGPL-2.1+ SPDX-License-Identifier to source filesWolfgang Denk
2013-06-11powerpc: fix 8xx and 82xx type-punning warnings with GCC 4.7Scott Wood
C99's strict aliasing rules are insane to use in low-level code such as a bootloader, but as Wolfgang has rejected -fno-strict-aliasing in the past, add a union so that 16-bit accesses can be performed. Compile-tested only. Signed-off-by: Scott Wood <scottwood@freescale.com> Acked-by: Wolfgang Denk <wd@denx.de>
2013-03-15Change stub example to use asm-generic/sections.hSimon Glass
We can use the declarations of __bss_start and _end from this header instead of declaring them locally. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04ppc: Move dp_alloc_base, dp_alloc_top to arch_global_dataSimon Glass
Move these fields into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-16MIPS: add board qemu-mips64 supportZhi-zhou Zhang
Both big-endian and little-endian are tested with below commands: Rom version: (Default, Now we config it as rom version) qemu-system-mips64el -M mips -bios u-boot.bin -cpu MIPS64R2-generic -nographic qemu-system-mips64 -M mips -bios u-boot.bin -cpu MIPS64R2-generic -nographic Ram version: qemu-system-mips64el -M mips -cpu MIPS64R2-generic -kernel u-boot -nographic qemu-system-mips64 -M mips -cpu MIPS64R2-generic -kernel u-boot -nographic Signed-off-by: Zhizhou Zhang <etou.zh@gmail.com> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2012-03-26Examples: Properly append LDFLAGS to LD commandMarek Vasut
The LD command in examples/standalone/Makefile ignored platform specific LDFLAGS setup. Pass these LDFLAGS to the command. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Bryan Hundven <bryanhundven@gmail.com> Cc: Michael Schwingen <rincewind@discworld.dascon.de>
2012-01-13openrisc: Add support for standalone programsStefan Kristiansson
Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
2011-12-06Standalone Apps: Standalone apps should need only exports.h.Mike Partington
Modify exports.h to remove its dependencies on other files, thus enabling standalone apps to require only exports.h from the U-Boot source tree. This appears to be the intent based on the following note: http://lists.denx.de/pipermail/u-boot/2010-January/067174.html Signed-off-by: Mike Partington <mparting@lexmark.com>
2011-11-15api: export LCD device to external appsChe-Liang Chiou
This patch exports LCD info-query and bitmap-rendering functions to external apps. This patch is tested on a Seaboard. Because the LCD driver is not yet upstreamed, the test was done in a local downstream repo. Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
2011-11-03Reduce build timesWolfgang Denk
U-Boot Makefiles contain a number of tests for compiler features etc. which so far are executed again and again. On some architectures (especially ARM) this results in a large number of calls to gcc. This patch makes sure to run such tests only once, thus largely reducing the number of "execve" system calls. Example: number of "execve" system calls for building the "P2020DS" (Power Architecture) and "qong" (ARM) boards, measured as: -> strace -f -e trace=execve -o /tmp/foo ./MAKEALL <board> -> grep execve /tmp/foo | wc -l Before: After: Reduction: ================================== P2020DS 20555 15205 -26% qong 31692 14490 -54% As a result, built times are significantly reduced, typically by 30...50%. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andy Fleming <afleming@gmail.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Albert Aribaud <albert.aribaud@free.fr> cc: Graeme Russ <graeme.russ@gmail.com> cc: Mike Frysinger <vapier@gentoo.org> Tested-by: Graeme Russ <graeme.russ@gmail.com> Tested-by: Matthias Weisser <weisserm@arcor.de> Tested-by: Sanjeev Premi <premi@ti.com> Tested-by: Simon Glass <sjg@chromium.org> Tested-by: Macpaul Lin <macpaul@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22nds32: standalone supportMacpaul Lin
Add standalone program related support for nds32 architecture. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-10-22examples: api: allow build with private libgccChe-liang Chiou
The examples/api is not configured with USE_PRIVATE_LIBGCC. This makes building examples/api break on certain boards that do not/cannot use the public libgcc. Nevertheless, this patch has to also touch the top-level Makefile to fix this problem because the current top-level Makefile does not specify libgcc as a prerequisite of examples/api, and explicitly builds examples/api _before_ libgcc. For testing this patch, I added the following to configs/seaboard.h and ran demo.bin on a Seaboard. +#define CONFIG_API +#define CONFIG_SYS_MMC_MAX_DEVICE 2 +#define CONFIG_CMD_NET +#define CONFIG_NET_MULTI Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-17Replace space and tab checks with isblankJason Hobbs
These are various places I found that checked for conditions equivalent to isblank. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
2011-05-12Fix a few gcc warnings.Joakim Tjernlund
Noticed while building all of mpc8xx. Also constify usage string in timer.c Warnings fixed are: timer.c: In function 'timer': timer.c:189: warning: format not a string literal and no format arguments timer.c:258: warning: format not a string literal and no format arguments atm.c: In function 'atmUnload': atm.c:99: warning: array subscript is above array bounds atm.c: In function 'atmLoad': atm.c:65: warning: array subscript is above array bounds codec.c: In function 'codsp_write_pop_int': codec.c:678: warning: array subscript is above array bounds codec.c: In function 'codsp_write_cop_short': codec.c:585: warning: array subscript is above array bounds codec.c: In function 'codsp_write_sop_int': codec.c:512: warning: array subscript is above array bounds Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-05-12Fix variable flavor in examples/standalone/MakefileChe-liang Chiou
GNU Makefile have two flavors of variables, recursively expanded that is defined by using '=', and simply expanded that is defined by using ':='. The bug is caused by using recursively expanded flavor for BIN and SREC. As you can see below, they are prepended by $(obj) twice. We can reproduce this bug with a simplified version of this Makefile: $ cat >Makefile <<\EOF obj := /path/to/obj/ ELF := hello_world BIN_rec = $(addsuffix .bin,$(ELF)) # recursively expanded BIN_sim := $(addsuffix .bin,$(ELF)) # simply expanded ELF := $(addprefix $(obj),$(ELF)) BIN_rec := $(addprefix $(obj),$(BIN_rec)) BIN_sim := $(addprefix $(obj),$(BIN_sim)) show: @echo BIN_rec=$(BIN_rec) @echo BIN_sim=$(BIN_sim) .PHONY: show EOF $ make show BIN_rec=/path/to/obj//path/to/obj/hello_world.bin BIN_sim=/path/to/obj/hello_world.bin Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
2011-05-10MIPS: Introduce --gc-sections for MIPSDaniel Schwierzeck
All architectures but MIPS are using --gc-sections on final linking. This patch introduces that feature for MIPS to reduce the memory and flash footprint. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Thomas Lange <thomas@corelatus.se> Cc: Vlad Lungu <vlad.lungu@windriver.com> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-04-13x86: Rename i386 to x86Graeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2011-04-12Make STANDALONE_LOAD_ADDR configurable per boardWolfgang Denk
Rename STANDALONE_LOAD_ADDR into CONFIG_STANDALONE_LOAD_ADDR and allow that the architecture-specific default value gets overwritten by defining the value in the board header file. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Tsi Chung Liew <tsi-chung.liew@freescale.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-03-31Fix build problems caused by "_end" -> "__bss_end__" renameWolfgang Denk
Commit 44c6e65 "rename _end to __bss_end__ broke building of a large number of systems (at least all PowerPC?): libstubs.o: In function `app_startup': examples/standalone/stubs.c:197: undefined reference to `__bss_end__' The rename should not be done for the files in the examples/standalone/ directory, as these are not using the code from start.S, but do their own BSS clearing, and either use their own linker scripts or the ones provided by the compilers. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2011-01-09examples: update do_reset prototypeMike Frysinger
One more place that was missed during the do_reset() unification. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-12examples/standalone: Use gcc's -fno-toplevel-reorderPeter Tyser
Using -fno-toplevel-reorder causes gcc to not reorder functions. This ensures that an application's entry point will be the first function in the application's source file. This change, along with commit 620bbba524fbaa26971a5004793010b169824f1b should cause a standalone application's entry point to be at the base of the compiled binary. Previously, the entry point could change depending on gcc version and flags. Note -fno-toplevel-reorder is only available in gcc version 4.2 or greater. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-09-04MIPS: update the MIPS u-boot.ldsXiangfu Liu
From the document, if set all arguments in "OUTPUT_FORMAT" to "tradbigmips", then even add "-EL" to gcc we still get EB format. pb1x00 is only used in Little-endian, so its default endian should be set to LE. Signed-off-by: Xiangfu Liu <xiangfu@openmobilefree.net> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2010-07-12smc91xx_eeprom: Correct chip detection check.Juergen Kilb
The smc911x_detect function in /net/driver/net/smc911x.c returns a 0 if everything was ok (a chip was found) and -1 else. In the standalone example 'smc911x_eeprom' the return value of smc911x_detect is interpreted in a different way (0 for error, !0 as OK). This leads to the error that the chip will not be detected. Signed-off-by: Juergen Kilb <j.kilb@phytec.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-04Make *printf() return "int" instead of "void"Wolfgang Denk
Change the return type of the *printf() functions to the standard "int"; no changes are needed but returning the already available length count. This will save a few additional strlen() calls later... Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-06-29examples/standalone: Remove relocation compile flags for PowerPCPeter Tyser
Previously, standalone applications were compiled with gcc flags that produced relocatable executables on the PowerPC architecture (eg with the -mrelocatable and -fPIC flags). There's no reason for these applications to be fully relocatable at this time since no relocation fixups are performed on standalone applications. Additionally, removing the gcc relocation flags results in the entry point of applications residing at the base of the image. When a standalone application was relocatable, the entry point was generally located at an offset into the image which was confusing and prone to errors. This change moves the entry point of PowerPC standalone applications from 0x40004 (usually) to 0x40000. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-05-28nios: remove nios-32 archThomas Chou
The nios-32 arch is obsolete and broken. So it is removed. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
