path: root/examples
2006-06-02Fix examples/Makefile; some build targets were lostWolfgang Denk
2006-04-27Add support for Freescale M5271: Merge with /work/u-boot.mcf5271Marian Balakowicz
2006-03-12Coding Style cleanupWolfgang Denk
2006-03-12Add ADI Blackfin supportWolfgang Denk
- add support for Analog Devices Blackfin BF533 CPU - add support for the ADI BF533 Stamp uClinux board - add support for the ADI BF533 EZKit board Patches by Richard Klingler, June 11th 2005:
2006-01-26Add support for r5200 boardZachary P. Landau
2005-05-23* Extend burst mode RAM test program to take a loop countwdenk
(0 = infinite) * Use CONFIG_DRIVER_KS8695ETH to enable KS8695 ethernet driver on those boards that use it.
2005-05-16Fix compile problems caused by new burst mode SDRAM test;wdenk
make port pins to trigger logic analyzer configurable
2005-05-07Add test tool to exercise SDRAM accesses in burst modewdenk
(as standalone program, MPC8xx/PowerPC only)
2005-01-12* Patch by Robin Getz, 13 Oct 2004:wdenk
Add standalone application to change SMC91C111 MAC addresses, see examples/README.smc91111_eeprom * Patch by Xiaogeng (Shawn) Jin, 12 Oct 2004: Fix Flash support for ARM Integrator CP.
2005-01-09* Patch by Daniel Poirot, 10 Oct 2004:wdenk
Add support for Wind River sbc405 board * Patch by Rainer Brestan, 12 Oct 2004: Make examples/Makefile more robust
2004-10-10Patches by Scott McNutt, 24 Aug 2004:wdenk
- Add support for Altera Nios-II processors. - Add support for Psyent PCI-5441 board. - Add support for Psyent PK1C20 board.
2004-07-10Patches by Yasushi Shoji, 29 Jun 2004:wdenk
- add empty include/asm-microblaze/processor.h - add to CREDITS and MAINTAINERS - add gd initialization - add MicroBlaze and SUZAKU board to MAKEALL script - add reset support for SUZAKU - add flush_cache() for MicroBlaze - add CFG_FLASH_SIZE to include/configs/suzaku.h since we have fixed size flash memory on SUZAKU
2004-07-10* Patch by Fred Klatt, 25 Jun 2004:wdenk
Add support for WindRiver's SBC8560 board * Patch by Nicolas Lacressonniere, 24 Jun 2004 Small Bugs fixes for "at91rm9200dk" board: - Timing modifications for SPI DataFlash access - Fix NAND flash detection bug * Patch by Nicolas Lacressonniere, 24 Jun 2004: Add Support for Flash AT49BV6416 for AT91RM9200DK board
2004-07-01* Patches by Richard Woodruff, 10 Jun 2004:wdenk
- fix problems with examples/stubs.c for GCC >= 3.4 - fix problems with gd initialization * Enable FAT filesystem support for HMI10 board
2004-05-19Patch by Scott McNutt, 25 Apr 2004:LABEL_2004_05_19_2335wdenk
Add Nios GDB/JTAG Console support: - Add stubs to support gdb via JTAG. - Add support for console over JTAG. - Minor cleanup.
2004-04-18* Patch by Yasushi Shoji, 07 Apr 2004:wdenk
- add support for microblaze processors - add support for AtmarkTechno "suzaku" board
2004-04-12Add startup code to clear the BSS of standalone applicationswdenk
2004-02-12* Some code cleanupwdenk
* Patch by Josef Baumgartner, 10 Feb 2004: Fixes for Coldfire port * Patch by Brad Kemp, 11 Feb 2004: Fix CFI flash driver problems
2004-01-03* Patch by Ronen Shitrit, 10 Dec 2003:wdenk
Add support for the Marvell DB64360 / DB64460 development boards * Patch by Detlev Zundel, 10 Dec 2003: fix dependency problem in examples/Makefile
2003-12-08* Patch by Bernhard Kuhn, 28 Nov 2003:wdenk
add support for Coldfire CPU add support for Motorola M5272C3 and M5282EVB boards
2003-12-07* Patch by Yuli Barcohen, 3 Dec 2003:wdenk
"revive" U-Boot support for old Motorola MPC860ADS board * Patch by Cam(ilo?), 03 Dec 2003: make examples build even with broken Montavista objcopy * Patch by Pavel Bartusek, 27 Nov 2003: fix conversion problem with "bootretry" evironment variable
2003-10-14* Make sure HUSH is initialized for running auto-update scriptsLABEL_2003_10_14_2140wdenk
* Make 5200 reset command _really_ reset the board, without running any other code after it * Fix flash mapping and display on P3G4 board * Patch by Kyle Harris, 15 Jul 2003: - add support for Intel IXP425 CPU - add support for IXDP425 eval board
2003-10-08* Patch by Scott McNutt, 04 Oct 2003:wdenk
- add support for Altera Nios-32 CPU - add support for Nios Cyclone Development Kit (DK-1C20) * Patch by Steven Scholz, 29 Sep 2003: - A second parameter for bootm overwrites the load address for "Standalone Application" images. - bootm sets environment variable "filesize" to the resulting (uncompressed) data length for "Standalone Application" images when autostart is set to "no". Now you can do something like if bootm $fpgadata $some_free_ram ; then fpga load 0 $some_free_ram $filesize fi * Patch by Denis Peter, 25 Sept 2003: add support for the MIP405 Rev. C board
2003-09-12Move TRAB burn-in tests to TRAB board directoryLABEL_2003_09_12_1745wdenk
2003-09-11* Patch by Martin Krause, 11 Sep 2003:LABEL_2003_09_12_0110wdenk
add burn-in tests for TRAB board * Enable instruction cache on MPC5200 board
2003-08-29Patch by Yuli Barcohen, 14 Aug 2003:wdenk
add support for bzip2 uncompression
2003-07-26* Allow crc32 to be used at address 0x000wdenk
* Provide consistent interface to standalone applications to access the 'global_data' structure Provide a doc/README.standalone more useful to users/developers. * Make IceCube MGT5100 FEC driver work
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-05-31* Patch by Marc Singer, 29 May 2003:LABEL_2003_05_31_2115wdenk
Fixed rarp boot method for IA32 and other little-endian CPUs. * Patch by Marc Singer, 28 May 2003: Added port I/O commands. * Patch by Matthew McClintock, 28 May 2003 - cpu/mpc824x/start.S: fix relocation code when booting from RAM - minor patches for utx8245 * Patch by Daniel Engström, 28 May 2003: x86 update * Patch by Dave Ellis, 9 May 2003 + 27 May 2003: add nand flash support to SXNI855T configuration fix/extend nand flash support: - fix 'nand erase' command so does not erase bad blocks - fix 'nand write' command so does not write to bad blocks - fix nand_probe() so handles no flash detected properly - add doc/README.nand - add .jffs2 and .oob options to nand read/write - add 'nand bad' command to list bad blocks - add 'clean' option to 'nand erase' to write JFFS2 clean markers - make NAND read/write faster * Patch by Rune Torgersen, 23 May 2003: Update for MPC8266ADS board
2003-04-05* Patch by Arun Dharankar, 4 Apr 2003:LABEL_2003_04_05_0300wdenk
Add IDMA example code (tested on 8260 only) * Add support for Purple Board (MIPS64 5Kc) * Add support for MIPS64 5Kc CPUs * Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS * Patch by Denis Peter, 04 Apr 2003: - update MIP405-4 board * Patches by Denis Peter, 03 April 2003: - fix PCI IRQs on MPL boards - fix two more un-relocated pointer problems * Fix behaviour of "run" command: - print error message iv variable does not exist - terminate processing of arguments in case of error * Patches by Peter Figuli, 10 Mar 2003 - Add support for BTUART on PXA platform - Add support for WEP EP250 (PXA) board * Fix flash problems on INCA-IP; add tool to allow bruning images to flash using a BDI2000 * Implement fix for I2C Edge Conditions problem for all boards that use the bit-banging driver (common/soft_i2c.c) * Add patches by Robert Schwebel, 31 Mar 2003: - csb226 board: bring in sync with innokom/memsetup.S - csb226 board: fix MDREFR handling - misc doc fixes / extensions - innokom board: cleanup, MDREFR fix in memsetup.S, config update - add BOOT_PROGRESS to armlinux.c
2003-03-31* Patch by Arun Dharankar, 24 Mar 2003:wdenk
- add threads / scheduler example code * Add patches by Robert Schwebel, 31 Mar 2003: - add ctrl-c support for kermit download - align bdinfo output on ARM * Add CPU ID, version, and clock speed for INCA-IP
2003-03-27Fix MIPS build problemLABEL_2003_03_27_1900wdenk
2003-03-26Make compile clean, fix the usual small problems.LABEL_2003_03_26_1300wdenk
2003-03-26* Patch by Rick Bronson, 16 Mar 2003:wdenk
Add support for Atmel AT91RM9200DK w/NAND * Patches by Robert Schwebel, 19 Mar 2003: - use arm-linux-gcc as default compiler for ARM - fix i2c fixup code - fix missing baudrate setting - added $loadaddr / CFG_LOAD_ADDR support to loadb - moved "ignoring trailing characters" _before_ u-boot wants to print out diagnostics messages; removes bogus characters at the end of transmission * Patch by John Zhan, 18 Mar 2003: Add support for SinoVee Microsystems SC8xx boards * Patch by Rolf Offermanns, 21 Mar 2003: ported the dnp1110 related changes from the current armboot cvs to current u-boot cvs. smc91111 does not work. problem marked in smc91111.c, grep for "FIXME". * Patch by Brian Auld, 25 Mar 2003: Add support for STM flash chips on ebony board * Add PCI support for MPC8250 Boards (PM825 module) * Patch by Stefan Roese, 25 Mar 2003:
2003-02-28* Add support for 16 MB flash configuration of TRAB boardLABEL_2003_02_28_0150wdenk
* Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS * Add image information to README * Fix dual PCMCIA slot support (when running with just one slot populated) * Add VFD type detection to trab board * extend drivers/cs8900.c driver to synchronize ethaddr environment variable with value in the EEPROM * Start adding MIPS support files
2002-12-07* Patch by Hans-Joerg Frieden, 06 Dec 2002LABEL_2002_12_07_0120wdenk
Fix misc problems with AmigaOne support * Patch by Chris Hallinan, 3 Dec 2002: minor cleanup to the MPC8245 EPIC driver * Patch by Pierre Aubert , 28 Nov 2002 Add support for external (SIU) interrupts on MPC8xx * Patch by Pierre Aubert , 28 Nov 2002 Fix nested syscalls bug in standalone applications * Patch by David Müller, 27 Nov 2002: fix output of "pciinfo" command for CardBus bridge devices. * Fix bug in TQM8260 board detection - boards got stuck when board ID was not readable
2002-11-18* Patch by Daniel Engström, 13 Nov 2002:LABEL_2002_11_18_0115wdenk
Add support for i386 architecture and AMD SC520 board * Patch by Pierre Aubert, 12 Nov 2002: Add support for DOS filesystem and booting from DOS floppy disk
2002-10-07Initial revisionwdenk
2002-09-07Initial revisionwdenk
2002-04-27Initial revisionwdenk
