The smc911x driver changed the naming convention for its register funcs,
so update the eeprom code accordingly.
CC: Ben Warren <biggerbadderben@gmail.com>
A forward port of the last version to work with the newer smc911x driver.
I only have a board with a LAN9218 part on it, so that is the only one
I've tested. But there isn't anything in this that would make it terribly
chip specific afaik.
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Guennadi Liakhovetski <lg@denx.de>
CC: Magnus Lilja <lilja.magnus@gmail.com>
Add common board, interrupt and system info code.
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
Most of the bss initialization loop increments 4 bytes
at a time. And the loop end is checked for an 'equal'
condition. Make the bss end address aligned by 4, so
that the loop will end as expected.
Signed-off-by: Selvamuthukumar <selva.muthukumar@e-coninfotech.com>
Address calculated in EXPORT_FUNC in SuperH was wrong, I revised it.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
Attempt to bring i386 / sc520 inline with master
Add support SH2/SH2A basic function.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
Fix alignment fault on ARM when running modules. With out an explicit
linker file gcc4.2.1 will half word align __bss_start's value. The word
dereference will crash hello_world.
signed-off-by Richard Woodruff <r-woodruff2@ti.com>
Makefile
doc/README.standalone
R29 was an unlucky choice as with recent toolchains (gcc-4.2.x) gcc
will refuse to use load/store multiple insns; instead, it issues a
list of simple load/store instructions upon function entry and exit,
resulting in bigger code size, which in turn makes the build for a
few boards fail.
Use r2 instead.
- Add inline helper macros for basic header processing
- Move common non inline code common/image.c
- Replace direct header access with the API routines
- Rename IH_CPU_* to IH_ARCH_*
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
configuration file rather than a hardcoded list of boards
With recent toolchain versions, some boards would not build because
or errors like this one (here for ocotea board when building with
ELDK 4.2 beta):
ppc_4xx-ld: section .bootpg [fffff000 -> fffff23b] overlaps section .bss [fffee900 -> fffff8ab]
For many boards, the .bss section is big enough that it wraps around
at the end of the address space (0xFFFFFFFF), so the problem will not
be visible unless you use a 64 bit tool chain for development. On
some boards however, changes to the code size (due to different
optimizations) we bail out with section overlaps like above.
The fix is to add the NOLOAD attribute to the .bss and .sbss
sections, telling the linker that .bss does not consume any space in
the image.
drivers/Makefile
drivers/Makefile
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
Ensure that __got_start points to top of the `.got', and __got_end points
to bottom as well, so that we never fail to count num_got_entries.
Patch by Haavard Skinnemoen, 6 Sep 2006 16:23:02 +0200
This patch adds common infrastructure code for the Atmel AVR32
architecture. See doc/README.AVR32 for details.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Based on patch by Haavard Skinnemoen, 29 Aug 2006 11:20:39 +0200
Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
-Fix asm/io.h macros
-Eliminate use of CACHE_BYPASS in cpu code
-Eliminate assembler warnings
-Fix mini-app stubs and force no small data
Patch by Scott McNutt, 08 Jun 2006
- add support for Analog Devices Blackfin BF533 CPU
- add support for the ADI BF533 Stamp uClinux board
- add support for the ADI BF533 EZKit board
Patches by Richard Klingler, June 11th 2005:
