path: root/examples
2011-12-06Standalone Apps: Standalone apps should need only exports.h.Mike Partington
Modify exports.h to remove its dependencies on other files, thus enabling standalone apps to require only exports.h from the U-Boot source tree. This appears to be the intent based on the following note: http://lists.denx.de/pipermail/u-boot/2010-January/067174.html Signed-off-by: Mike Partington <mparting@lexmark.com>
2011-11-15api: export LCD device to external appsChe-Liang Chiou
This patch exports LCD info-query and bitmap-rendering functions to external apps. This patch is tested on a Seaboard. Because the LCD driver is not yet upstreamed, the test was done in a local downstream repo. Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
2011-11-03Reduce build timesWolfgang Denk
U-Boot Makefiles contain a number of tests for compiler features etc. which so far are executed again and again. On some architectures (especially ARM) this results in a large number of calls to gcc. This patch makes sure to run such tests only once, thus largely reducing the number of "execve" system calls. Example: number of "execve" system calls for building the "P2020DS" (Power Architecture) and "qong" (ARM) boards, measured as: -> strace -f -e trace=execve -o /tmp/foo ./MAKEALL <board> -> grep execve /tmp/foo | wc -l Before: After: Reduction: ================================== P2020DS 20555 15205 -26% qong 31692 14490 -54% As a result, built times are significantly reduced, typically by 30...50%. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andy Fleming <afleming@gmail.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Albert Aribaud <albert.aribaud@free.fr> cc: Graeme Russ <graeme.russ@gmail.com> cc: Mike Frysinger <vapier@gentoo.org> Tested-by: Graeme Russ <graeme.russ@gmail.com> Tested-by: Matthias Weisser <weisserm@arcor.de> Tested-by: Sanjeev Premi <premi@ti.com> Tested-by: Simon Glass <sjg@chromium.org> Tested-by: Macpaul Lin <macpaul@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22nds32: standalone supportMacpaul Lin
Add standalone program related support for nds32 architecture. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-10-22examples: api: allow build with private libgccChe-liang Chiou
The examples/api is not configured with USE_PRIVATE_LIBGCC. This makes building examples/api break on certain boards that do not/cannot use the public libgcc. Nevertheless, this patch has to also touch the top-level Makefile to fix this problem because the current top-level Makefile does not specify libgcc as a prerequisite of examples/api, and explicitly builds examples/api _before_ libgcc. For testing this patch, I added the following to configs/seaboard.h and ran demo.bin on a Seaboard. +#define CONFIG_API +#define CONFIG_SYS_MMC_MAX_DEVICE 2 +#define CONFIG_CMD_NET +#define CONFIG_NET_MULTI Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-17Replace space and tab checks with isblankJason Hobbs
These are various places I found that checked for conditions equivalent to isblank. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
2011-05-12Fix a few gcc warnings.Joakim Tjernlund
Noticed while building all of mpc8xx. Also constify usage string in timer.c Warnings fixed are: timer.c: In function 'timer': timer.c:189: warning: format not a string literal and no format arguments timer.c:258: warning: format not a string literal and no format arguments atm.c: In function 'atmUnload': atm.c:99: warning: array subscript is above array bounds atm.c: In function 'atmLoad': atm.c:65: warning: array subscript is above array bounds codec.c: In function 'codsp_write_pop_int': codec.c:678: warning: array subscript is above array bounds codec.c: In function 'codsp_write_cop_short': codec.c:585: warning: array subscript is above array bounds codec.c: In function 'codsp_write_sop_int': codec.c:512: warning: array subscript is above array bounds Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-05-12Fix variable flavor in examples/standalone/MakefileChe-liang Chiou
GNU Makefile have two flavors of variables, recursively expanded that is defined by using '=', and simply expanded that is defined by using ':='. The bug is caused by using recursively expanded flavor for BIN and SREC. As you can see below, they are prepended by $(obj) twice. We can reproduce this bug with a simplified version of this Makefile: $ cat >Makefile <<\EOF obj := /path/to/obj/ ELF := hello_world BIN_rec = $(addsuffix .bin,$(ELF)) # recursively expanded BIN_sim := $(addsuffix .bin,$(ELF)) # simply expanded ELF := $(addprefix $(obj),$(ELF)) BIN_rec := $(addprefix $(obj),$(BIN_rec)) BIN_sim := $(addprefix $(obj),$(BIN_sim)) show: @echo BIN_rec=$(BIN_rec) @echo BIN_sim=$(BIN_sim) .PHONY: show EOF $ make show BIN_rec=/path/to/obj//path/to/obj/hello_world.bin BIN_sim=/path/to/obj/hello_world.bin Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
2011-05-10MIPS: Introduce --gc-sections for MIPSDaniel Schwierzeck
All architectures but MIPS are using --gc-sections on final linking. This patch introduces that feature for MIPS to reduce the memory and flash footprint. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Thomas Lange <thomas@corelatus.se> Cc: Vlad Lungu <vlad.lungu@windriver.com> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-04-13x86: Rename i386 to x86Graeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2011-04-12Make STANDALONE_LOAD_ADDR configurable per boardWolfgang Denk
Rename STANDALONE_LOAD_ADDR into CONFIG_STANDALONE_LOAD_ADDR and allow that the architecture-specific default value gets overwritten by defining the value in the board header file. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Tsi Chung Liew <tsi-chung.liew@freescale.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-03-31Fix build problems caused by "_end" -> "__bss_end__" renameWolfgang Denk
Commit 44c6e65 "rename _end to __bss_end__ broke building of a large number of systems (at least all PowerPC?): libstubs.o: In function `app_startup': examples/standalone/stubs.c:197: undefined reference to `__bss_end__' The rename should not be done for the files in the examples/standalone/ directory, as these are not using the code from start.S, but do their own BSS clearing, and either use their own linker scripts or the ones provided by the compilers. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2011-01-09examples: update do_reset prototypeMike Frysinger
One more place that was missed during the do_reset() unification. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-12examples/standalone: Use gcc's -fno-toplevel-reorderPeter Tyser
Using -fno-toplevel-reorder causes gcc to not reorder functions. This ensures that an application's entry point will be the first function in the application's source file. This change, along with commit 620bbba524fbaa26971a5004793010b169824f1b should cause a standalone application's entry point to be at the base of the compiled binary. Previously, the entry point could change depending on gcc version and flags. Note -fno-toplevel-reorder is only available in gcc version 4.2 or greater. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-09-04MIPS: update the MIPS u-boot.ldsXiangfu Liu
From the document, if set all arguments in "OUTPUT_FORMAT" to "tradbigmips", then even add "-EL" to gcc we still get EB format. pb1x00 is only used in Little-endian, so its default endian should be set to LE. Signed-off-by: Xiangfu Liu <xiangfu@openmobilefree.net> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2010-07-12smc91xx_eeprom: Correct chip detection check.Juergen Kilb
The smc911x_detect function in /net/driver/net/smc911x.c returns a 0 if everything was ok (a chip was found) and -1 else. In the standalone example 'smc911x_eeprom' the return value of smc911x_detect is interpreted in a different way (0 for error, !0 as OK). This leads to the error that the chip will not be detected. Signed-off-by: Juergen Kilb <j.kilb@phytec.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-04Make *printf() return "int" instead of "void"Wolfgang Denk
Change the return type of the *printf() functions to the standard "int"; no changes are needed but returning the already available length count. This will save a few additional strlen() calls later... Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-06-29examples/standalone: Remove relocation compile flags for PowerPCPeter Tyser
Previously, standalone applications were compiled with gcc flags that produced relocatable executables on the PowerPC architecture (eg with the -mrelocatable and -fPIC flags). There's no reason for these applications to be fully relocatable at this time since no relocation fixups are performed on standalone applications. Additionally, removing the gcc relocation flags results in the entry point of applications residing at the base of the image. When a standalone application was relocatable, the entry point was generally located at an offset into the image which was confusing and prone to errors. This change moves the entry point of PowerPC standalone applications from 0x40004 (usually) to 0x40000. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-05-28nios: remove nios-32 archThomas Chou
The nios-32 arch is obsolete and broken. So it is removed. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2010-05-28nios2: fix r15 issue for gcc4Thomas Chou
The "-ffixed-r15" option doesn't work well for gcc4. Since we don't use gp for small data with option "-G0", we can use gp as global data pointer. This allows compiler to use r15. It is necessary for gcc4 to work properly. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-03-12standalone eepro100_eeprom: fix build errorWolfgang Denk
Building examples/standalone/eepro100_eeprom triggers this error: In file included from include/common.h:629, from eepro100_eeprom.c:24: include/net.h: In function 'NetReadIP': include/net.h:430: warning: implicit declaration of function 'memcpy' eepro100_eeprom.c: At top level: eepro100_eeprom.c:81: error: conflicting types for 'memcpy' include/net.h:430: error: previous implicit declaration of 'memcpy' was here Fix this. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-12Update .gitignore's: add some generated filesWolfgang Denk
2010-01-31smc91111_eeprom: fix linking errorMike Frysinger
Building for a bf533-stamp ends up with this error: smc91111_eeprom.o: In function `smc91111_eeprom': examples/standalone/smc91111_eeprom.c:58: undefined reference to `memset' make[2]: *** [smc91111_eeprom] Error 1 The new eth_struct definition means gcc has to zero out the structure on the stack, and some gcc versions optimize this with an implicit call to memset. So tweak the structure style to avoid that gcc feature. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-01-19Fix breakage in SMC EEPROM standalone applicationsBen Warren
Commit 6a45e384955262882375a2785426dc65aeb636c4 (Make getenv_IPaddr() global) inadvertently added ' #include "net.h" ' to the standalone programs, creating duplicate definitions of 'struct eth_device'. This patch removes the local definitions and removes other code that breaks due to the change in definition. Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2009-12-05Merge branch 'master' into nextWolfgang Denk
Conflicts: board/esd/plu405/plu405.c drivers/rtc/ftrtc010.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-12-05Generic udelay() with watchdog supportIngo van Lil
According to the PPC reference implementation the udelay() function is responsible for resetting the watchdog timer as frequently as needed. Most other architectures do not meet that requirement, so long-running operations might result in a watchdog reset. This patch adds a generic udelay() function which takes care of resetting the watchdog before calling an architecture-specific __udelay(). Signed-off-by: Ingo van Lil <inguin@gmx.de>
2009-12-02smc91111_eeprom: drop CONFIG stub protectionMike Frysinger
Since the Makefile now controls the compilation of this, there is no need for CONFIG checking nor the stub function. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-02Fix build failure in examples/standaloneSanjeev Premi
Some versions of 'make' do not handle trailing white-spaces properly. Trailing spaces in ELF causes a 'fake' source to be added to the variable COBJS; leading to build failure (listed below). The problem was found with GNU Make 3.80. Using text-function 'strip' as a workaround for the problem. make[1]: Entering directory `/home/sanjeev/u-boot/examples/standalone' arm-none-linux-gnueabi-gcc -g -Os -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0x80e80000 -I/home/sanjeev/u-boot/include -fno-builtin -ffreestanding -nostdinc -isystem /opt/codesourcery/2009q1- 203/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.3/include -pipe -DCONFIG_ ARM -D__ARM__ -marm -mabi=aapcs-linux -mno-thumb-interwork -march=armv5 -Wall -Wstrict-prototypes -fno-stack-protector -g -Os -fno-common -ff ixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0x80e80000 -I/home/sanje ev/u-boot/include -fno-builtin -ffreestanding -nostdinc -isystem /opt/co desourcery/2009q1-203/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.3/includ e -pipe -DCONFIG_ARM -D__ARM__ -marm -mabi=aapcs-linux -mno-thumb-inte rwork -march=armv5 -I.. -Bstatic -T u-boot.lds -Ttext 0x80e80000 -o .c arm-none-linux-gnueabi-gcc: no input files make[1]: *** [.c] Error 1 make[1]: Leaving directory `/home/sanjeev/u-boot/examples/standalone' make: *** [examples/standalone] Error 2 premi # Signed-off-by: Sanjeev Premi <premi@ti.com> Fixed typo (s/ElF/ELF/). Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-11-23Nios2/Nios: Remove unnecessary (residual) linker Nios command scripts fromScott McNutt
the standalone examples. Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2009-11-12smc911x_eeprom: fix building after smc911x overhaulMike Frysinger
When the smc911x driver was converted to NET_MULTI, the smc911x eeprom was missed. The config option needed updating as well as overhauling of the rergister read/write functions. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Mike Rapoport <mike.rapoport@gmail.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-27Fix bug in jumptable call stubs for SPARC.Sergey Mironov
Signed-off-by: Sergey Mironov <ierton@gmail.com> Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-15standalone: convert to kbuild styleMike Frysinger
Clean up the arch/cpu/board/config checks as well as redundant setting of srec/bin variables by using the kbuild VAR-$(...) style. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-04push LOAD_ADDR out to arch mk filesMike Frysinger
Rather than maintain/extend the current ifeq($(ARCH)) mess that exists in the standalone Makefile, push the setting up of LOAD_ADDR out to the arch config.mk (and rename to STANDALONE_LOAD_ADDR in the process). This keeps the common code clean and lets the arch do whatever crazy crap it wants in its own area. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-04atmel_df_pow2: standalone to convert dataflashes to pow2Mike Frysinger
Atmel DataFlashes by default operate with pages that are slightly bigger than normal binary sizes (i.e. many are 1056 byte pages rather than 1024 bytes). However, they also have a "power of 2" mode where the pages show up with the normal binary size. The latter mode is required in order to boot with a Blackfin processor, so many people wish to convert their DataFlashes on their development systems to this mode. This standalone application does just that. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-02Blackfin: change global data register from P5 to P3Robin Getz
Since the Blackfin ABI favors higher scratch registers by default, use the last scratch register (P3) for global data rather than the first (P5). This allows the compiler's register allocator to use higher number scratch P registers, which in turn better matches the Blackfin instruction set, which reduces the size of U-Boot by more than 1024 bytes... Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-08Fix examples for OMAP3 boards...Michael Evans
The attached patch corrects an error in the examples/Makefile which causes the applications in the examples directory to hang on OMAP3 based boards. The current Makefile sets -Ttext during linking to 0x0c100000 which is outside of addressable SDRAM memory. The script corrects the existing ifeq...else...endif logic to look at the VENDOR tag rather than the CPU tag. The patch affects the following configs: omap3_beagle_config, omap3_overo_config, omap3_evm_config, omap3_pandora_config, omap3_zoom1_config and omap3_zoom2_config. Signed-off-by: Michael Evans <horse_dung@hotmail.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-27ABI: fix build problems due to now needed div64 routine.Wolfgang Denk
2009-07-21Move api_examples to examples/apiPeter Tyser
Also add a rule to remove demo.bin which was previously leftover after a "make clean" Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-07-21Move examples/ to examples/standalonePeter Tyser
The current files in examples are all standalone application examples, so put them in their own subdirectory for organizational purposes Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-04smc91111_eeprom: move board-specific init into SMC91111_EEPROM_INIT()Mike Frysinger
Rather than sticking Blackfin-specific stuff into the eeprom example, use an indirect macro so that any board can override it with their own magic sauce in their board config file. Also fix some spurious semi-colons in defines while I'm at it ... Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-19smc911x_eeprom: update register APIMike Frysinger
The smc911x driver changed the naming convention for its register funcs, so update the eeprom code accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
