path: root/examples/stubs.c
2009-07-21Move examples/ to examples/standalonePeter Tyser
The current files in examples are all standalone application examples, so put them in their own subdirectory for organizational purposes Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-10-14sh: Fix cannot execute a stand-alone applicationNobuhiro Iwamatsu
Address calculated in EXPORT_FUNC in SuperH was wrong, I revised it. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-04-08SPARC: Added generic support for SPARC architecture.Daniel Hellstrom
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-03-02Fix alignment error on ARM for modulesWoodruff, Richard
Fix alignment fault on ARM when running modules. With out an explicit linker file gcc4.2.1 will half word align __bss_start's value. The word dereference will crash hello_world. signed-off-by Richard Woodruff <r-woodruff2@ti.com>
2008-02-14PPC: Use r2 instead of r29 as global data pointerWolfgang Denk
R29 was an unlucky choice as with recent toolchains (gcc-4.2.x) gcc will refuse to use load/store multiple insns; instead, it issues a list of simple load/store instructions upon function entry and exit, resulting in bigger code size, which in turn makes the build for a few boards fail. Use r2 instead. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-12-27Fix coding style issues; update CHANGELOG.Wolfgang Denk
2007-05-13sh: First support code of SuperH.Nobuhiro Iwamatsu
2007-03-09[Blackfin][PATCH-2/2] Common files changed to support bf533 platformAubrey.Li
2006-10-24Add AVR32 architecture supportWolfgang Denk
Patch by Haavard Skinnemoen, 6 Sep 2006 16:23:02 +0200 This patch adds common infrastructure code for the Atmel AVR32 architecture. See doc/README.AVR32 for details. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2006-06-08Nios II - Fix I/O Macros and mini-app stubsScott McNutt
-Fix asm/io.h macros -Eliminate use of CACHE_BYPASS in cpu code -Eliminate assembler warnings -Fix mini-app stubs and force no small data Patch by Scott McNutt, 08 Jun 2006
2006-03-12Coding Style cleanupWolfgang Denk
2006-03-12Add ADI Blackfin supportWolfgang Denk
- add support for Analog Devices Blackfin BF533 CPU - add support for the ADI BF533 Stamp uClinux board - add support for the ADI BF533 EZKit board Patches by Richard Klingler, June 11th 2005:
2004-10-10Patches by Scott McNutt, 24 Aug 2004:wdenk
- Add support for Altera Nios-II processors. - Add support for Psyent PCI-5441 board. - Add support for Psyent PK1C20 board.
2004-07-10Patches by Yasushi Shoji, 29 Jun 2004:wdenk
- add empty include/asm-microblaze/processor.h - add to CREDITS and MAINTAINERS - add gd initialization - add MicroBlaze and SUZAKU board to MAKEALL script - add reset support for SUZAKU - add flush_cache() for MicroBlaze - add CFG_FLASH_SIZE to include/configs/suzaku.h since we have fixed size flash memory on SUZAKU
2004-07-01* Patches by Richard Woodruff, 10 Jun 2004:wdenk
- fix problems with examples/stubs.c for GCC >= 3.4 - fix problems with gd initialization * Enable FAT filesystem support for HMI10 board
2004-04-18* Patch by Yasushi Shoji, 07 Apr 2004:wdenk
- add support for microblaze processors - add support for AtmarkTechno "suzaku" board
2004-04-12Add startup code to clear the BSS of standalone applicationswdenk
2004-02-12* Some code cleanupwdenk
* Patch by Josef Baumgartner, 10 Feb 2004: Fixes for Coldfire port * Patch by Brad Kemp, 11 Feb 2004: Fix CFI flash driver problems
2003-10-08* Patch by Scott McNutt, 04 Oct 2003:wdenk
- add support for Altera Nios-32 CPU - add support for Nios Cyclone Development Kit (DK-1C20) * Patch by Steven Scholz, 29 Sep 2003: - A second parameter for bootm overwrites the load address for "Standalone Application" images. - bootm sets environment variable "filesize" to the resulting (uncompressed) data length for "Standalone Application" images when autostart is set to "no". Now you can do something like if bootm $fpgadata $some_free_ram ; then fpga load 0 $some_free_ram $filesize fi * Patch by Denis Peter, 25 Sept 2003: add support for the MIP405 Rev. C board
2003-07-26* Allow crc32 to be used at address 0x000wdenk
* Provide consistent interface to standalone applications to access the 'global_data' structure Provide a doc/README.standalone more useful to users/developers. * Make IceCube MGT5100 FEC driver work
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
