path: root/examples/standalone
2020-04-10kconfig / kbuild: Re-sync with Linux 4.19Tom Rini
Align Kconfig and Kbuild logic to Linux 4.19 release with minimal impact on files outside of this scope. Our previous Kconfig sync was done by commit 5972ff077e0f ("kconfig / kbuild: re-sync with Linux 4.18"). In this particular re-sync in order to keep clang support working a number of related changes needed to be pulled in that had been missed previously. Not all of these changes we easily traceable and so have been omitted from the list below. The imported Linux commits are: [From prior to v4.18] 9f3f1fd29976 kbuild: Add __cc-option macro d7f14c66c273 kbuild: Enable Large File Support for hostprogs 6d79a7b424a5 kbuild: suppress warnings from 'getconf LFS_*' 24403874316a Shared library support 86a9df597cdd kbuild: fix linker feature test macros when cross compiling with Clang 0294e6f4a000 kbuild: simplify ld-option implementation [From v4.18 to v4.19] 96f14fe738b6 kbuild: Rename HOSTCFLAGS to KBUILD_HOSTCFLAGS 10844aebf448 kbuild: Rename HOSTCXXFLAGS to KBUILD_HOSTCXXFLAGS b90a368000ab kbuild: Rename HOSTLDFLAGS to KBUILD_HOSTLDFLAGS 8377bd2b9ee1 kbuild: Rename HOST_LOADLIBES to KBUILD_HOSTLDLIBS f92d19e0ef9b kbuild: Use HOST*FLAGS options from the command line 4ab3b80159d4 kconfig: check for pkg-config on make {menu,n,g,x}config 693359f7ac90 kconfig: rename SYMBOL_AUTO to SYMBOL_NO_WRITE f60b992e30ff kbuild: replace $(LDFLAGS) $(ldflags-y) with $(ld_flags) 2fb9279f2c3e kbuild: change ld_flags to contain LDFLAGS_$(@F) c931d34ea085 arm64: build with baremetal linker target instead of Linux when available 5accd7f3360e kconfig: handle format string before calling conf_message_callback() a2ff4040151a kconfig: rename file_write_dep and move it to confdata.c 0608182ad542 kconfig: split out useful helpers in confdata.c adc18acf42a1 kconfig: remove unneeded directory generation from local*config 79123b1389cc kconfig: create directories needed for syncconfig by itself 16952b77d8b5 kconfig: make syncconfig update .config regardless of sym_change_count d6c6ab93e17f kbuild: remove deprecated host-progs variable 56869d45e364 kconfig: fix the rule of mainmenu_stmt symbol c151272d1687 kconfig: remove unused sym_get_env_prop() function 1880861226c1 kconfig: remove P_ENV property type e3fd9b5384f3 scripts/dtc: consolidate include path options in Makefile 4bf6a9af0e91 kconfig: add build-only configurator targets f1575595d156 kconfig: error out when seeing recursive dependency 5e8c5299d315 kconfig: report recursive dependency involving 'imply' f498926c47aa kconfig: improve the recursive dependency report 98a4afbfafd2 kconfig: fix "Can't open ..." in parallel build 9a9ddcf47831 kconfig: suppress "configuration written to .config" for syncconfig 87a32e624037 kbuild: pass LDFLAGS to recordmcount.pl d503ac531a52 kbuild: rename LDFLAGS to KBUILD_LDFLAGS 217c3e019675 disable stringop truncation warnings for now bc8d2e20a3eb kconfig: remove a spurious self-assignment fd65465b7016 kconfig: do not require pkg-config on make {menu,n}config 5a4630aadb9a ftrace: Build with CPPFLAGS to get -Qunused-arguments Note that this adds new cleanup work to do in that we should adapt the shared library support we have to what is now upstream. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Masahiro Yamada <masahiroy@kernel.org>
2019-01-15Merge git://git.denx.de/u-boot-riscvTom Rini
1. Improve cache implementation. 2. Fix and improve standalone applications
2019-01-15kbuild: add .SECONDARY special target to scripts/Kbuild.includeMasahiro Yamada
Based on the following Linux commits: - 54a702f70589 ("kbuild: mark $(targets) as .SECONDARY and remove .PRECIOUS markers") - 8e9b61b293d9 ("kbuild: move .SECONDARY special target to Kbuild.include") GNU Make automatically deletes intermediate files that are updated in a chain of pattern rules. Example 1) %.dtb.o <- %.dtb.S <- %.dtb <- %.dts Example 2) %.o <- %.c <- %.c_shipped A couple of makefiles mark such targets as .PRECIOUS to prevent Make from deleting them, but the correct way is to use .SECONDARY. .SECONDARY Prerequisites of this special target are treated as intermediate files but are never automatically deleted. .PRECIOUS When make is interrupted during execution, it may delete the target file it is updating if the file was modified since make started. If you mark the file as precious, make will never delete the file if interrupted. Both can avoid deletion of intermediate files, but the difference is the behavior when Make is interrupted; .SECONDARY deletes the target, but .PRECIOUS does not. The use of .PRECIOUS is relatively rare since we do not want to keep partially constructed (possibly corrupted) targets. .SECONDARY with no prerequisites causes all targets to be treated as secondary. This agrees the policy of Kbuild. scripts/Kbuild.include seems a suitable place to add it because it is included from almost all sub-makes. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-01-15riscv: support standalone applications on RV64I systemsLukas Auer
Add an implementation of EXPORT_FUNC() for RV64I systems to support them in standalone applications. Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2019-01-15riscv: replace use of callee-saved register in standaloneLukas Auer
Register x19 (s3) is a callee-saved register. It must not be used to load and jump to exported functions without saving it beforehand. Replace it with t0, a temporary and caller-saved register. Change the code comment to reflect this and fix it to correctly list gp as the register with the pointer to global data. Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2019-01-15riscv: remove RISC-V standalone linker scriptLukas Auer
Standalone applications do not require a separate linker script and can use the default linker script of the compiler instead. Remove the RISC-V standalone linker script. Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2018-11-27spi: Remove used spi_initJagan Teki
spi_init used in some areas in tree, but the respective drivers will remove in future patches. So remove the same instances. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2018-11-18MIPS: fix linking of standalone programsDaniel Schwierzeck
Use the global MIPS specific u-boot.lds for linking standalone programs instead of the outdated ones in examples/standalone/. Also pass --gc-sections in LDFLAGS_STANDALONE to optimize the size of standalone programs. Finally remove the deprecated config.mk files in arch/mips/cpu/mips[32,64]/. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-11-18Kbuild: standalone: do not ignore platform-specific OBJCOPYFLAGSDaniel Schwierzeck
Currently the OBJCOPYFLAGS are cleared when assigning "-O srec" or "-O binary" for standalone programs. All flags set by arch-specific Makefiles are lost. This is bad if an arch demands arch-specific flags for the objcopy step. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-11-18Kbuild: add LDFLAGS_STANDALONEDaniel Schwierzeck
Introduce a new Makefile variable for passing LDFLAGS to standalone programs. Currently the variable CONFIG_STANDALONE_LOAD_ADDR is misued on some archs to pass a specific linker script. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Rick Chen <rick@andestech.com>
2018-01-12riscv: Support standaloneRick Chen
Run hello_world successfully. U-Boot 2018.01-rc2-00033-gb265b91-dirty (Dec 22 2017 - 13:54:21 +0800) DRAM: 1 GiB MMC: mmc@f0e00000: 0 SF: Detected mx25u1635e with page size 256 Bytes, erase size 4 KiB, total 2 MiB In: serial@f0300000 Out: serial@f0300000 Err: serial@f0300000 Net: Warning: mac@e0100000 (eth0) using random MAC address - 0a:47:9b:f8:b4:f2 eth0: mac@e0100000 RISC-V # mmc rescan RISC-V # fatls mmc 0:1 318907 u-boot-ae250-64.bin 1252 hello_world_ae250_32.bin 328787 u-boot-ae250-32.bin 3 file(s), 0 dir(s) RISC-V # fatload mmc 0:1 0x600000 hello_world_ae250_32.bin reading hello_world_ae250_32.bin 1252 bytes read in 23 ms (52.7 KiB/s) RISC-V # go 0x600000 Example expects ABI version 9 Actual U-Boot ABI version 9 Hello World argc = 1 argv[0] = "0x600000" argv[1] = "$B@" Hit any key to exit ... RISC-V # Signed-off-by: Rick Chen <rick@andestech.com> Signed-off-by: Rick Chen <rickchen36@gmail.com> Signed-off-by: Greentime Hu <green.hu@gmail.com>
2017-07-06avr32: Retire AVR32 for goodAndy Shevchenko
AVR32 is gone. It's already more than two years for no support in Buildroot, even longer there is no support in GCC (last version is heavily patched 4.2.4). Linux kernel v4.12 got rid of it (and v4.11 didn't build successfully). There is no good point to keep this support in U-Boot either. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-06-16powerpc, 5xxx, 512x: remove support for mpc5xxx and mpc512xHeiko Schocher
There was for long time no activity in the mpx5xxx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in mpc5xxx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 8260: remove support for mpc8260Heiko Schocher
There was for long time no activity in the 8260 area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8260, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 8xx: remove support for 8xxHeiko Schocher
There was for long time no activity in the 8xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8xx, so remove it (with a heavy heart, knowing that I remove here the root of U-Boot). Signed-off-by: Heiko Schocher <hs@denx.de>
2017-04-05OpenRISC: RemoveTom Rini
The OpenRISC architecture is currently unmaintained, remove. Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-05SPARC: RemoveTom Rini
The SPARC architecture is currently unmaintained, remove. Cc: Francois Retief <fgretief@spaceteq.co.za> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05Blackfin: RemoveTom Rini
The architecture is currently unmaintained, remove. Cc: Benjamin Matthews <mben12@gmail.com> Cc: Chong Huang <chuang@ucrobotics.com> Cc: Dimitar Penev <dpn@switchfin.org> Cc: Haitao Zhang <hzhang@ucrobotics.com> Cc: I-SYST Micromodule <support@i-syst.com> Cc: M.Hasewinkel (MHA) <info@ssv-embedded.de> Cc: Marek Vasut <marex@denx.de> Cc: Martin Strubel <strubel@section5.ch> Cc: Peter Meerwald <devel@bct-electronic.com> Cc: Sonic Zhang <sonic.adi@gmail.com> Cc: Valentin Yakovenkov <yakovenkov@niistt.ru> Cc: Wojtek Skulski <info@skutek.com> Cc: Wojtek Skulski <skulski@pas.rochester.edu> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-26Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
trini: Drop local memset() from examples/standalone/mem_to_mem_idma2intr.c Signed-off-by: Tom Rini <trini@konsulko.com>
2016-08-15xtensa: add support for the xtensa processor architecture [1/2]Chris Zankel
The Xtensa processor architecture is a configurable, extensible, and synthesizable 32-bit RISC processor core provided by Cadence. This is the first part of the basic architecture port with changes to common files. The 'arch/xtensa' directory, and boards and additional drivers will be in separate commits. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-05-21Add support for 64-bit MIPS to examples/standaloneStanislav Galabov
Signed-off-by: Stanislav Galabov <sgalabov@gmail.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2015-11-19Move console definitions into a new console.h fileSimon Glass
The console includes a global variable and several functions that are only used by a small subset of U-Boot files. Before adding more functions, move the definitions into their own header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-10arm: support Thumb-1 with CONFIG_SYS_THUMB_BUILDAlbert ARIBAUD
When building a Thumb-1-only target with CONFIG_SYS_THUMB_BUILD, some files fail to build, most of the time because they include mcr instructions, which only exist for Thumb-2. This patch introduces a Kconfig option CONFIG_THUMB2 and uses it to select between Thumb-2 and ARM mode for the aforementioned files. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2015-05-19net: Remove all references to CONFIG_ETHADDR and friendsJoe Hershberger
We really don't want boards defining fixed MAC addresses in their config so we just remove the option to set it in a fixed way. If you must have a MAC address that was not provisioned, then use the random MAC address functionality. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-01-29Export redesignMartin Dorwig
this is an atempt to make the export of functions typesafe. I replaced the jumptable void ** by a struct (jt_funcs) with function pointers. The EXPORT_FUNC macro now has 3 fixed parameters and one variadic parameter The first is the name of the exported function, the rest of the parameters are used to format a functionpointer in the jumptable, the EXPORT_FUNC macros are expanded three times, 1. to declare the members of the struct 2. to initialize the structmember pointers 3. to call the functions in stubs.c Signed-off-by: Martin Dorwig <dorwig@tetronik.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (resending to the list since my tweaks are not quite trivial)
2015-01-05mpc8xx: remove lwmon board supportMasahiro Yamada
This board is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de>
2014-09-16kbuild: standalone: simplify clean-filesMasahiro Yamada
Files added $(extra-) are removed by "make clean". Besides, wildcard "*.srec *.bin" is simpler. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-16standalone: use GCC_VERSION defined in compiler-gcc.hMasahiro Yamada
Now GCC_VERSION is defined in include/linux/compiler-gcc.h (with a little different definition). Use it and delete the one in examples/standlone/stub.c. This should work on Clang too because __GNUC__, __GNUC_MINOR__, __GNUC_PATCHLEVEL__ are also defined on Clang. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-05-23examples: select libgcc for non-default architectureAlexey Brodkin
In case of multilib-enabled toolchains if default architecture differ from the one examples are being built for linker will fail to link example object files with libgcc of another (non-compatible) architecture. Interesting enough for years in main Makefile we used CFLAGS/c_flags for this but not for examples. So fixing it now. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denx <wd@denx.de> Acked-by: WOlfgang Denk <wd@denx.de> Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-17standalone: delete an unused source fileMasahiro Yamada
2014-03-07powerpc: mpc8260: consolidate CONFIG_MPC8260 and CONFIG_8260Masahiro Yamada
Before this commit, CONFIG_MPC8260 and CONFIG_8260 were used mixed-up. All boards with mpc8260 cpu defined both of them: - CONFIG_MPC8260 was defined in board config headers and include/common.h - CONFIG_8260 was defined arch/powerpc/cpu/mpc8260/config.mk We do not need to have both of them. This commit keeps only CONFIG_MPC8260. This commit does: - Delete CONFIG_8260 and CONFIG_MPC8260 definition in config headers and include/common.h - Rename CONFIG_8260 to CONFIG_MPC8260 in arch/powerpc/cpu/mpc8260/config.mk. - Rename #ifdef CONFIG_8260 to #ifdef CONFIG_MPC8260 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de>
2014-03-07kbuild: improve Kbuild speedMasahiro Yamada
Kbuild brought about many advantages for us but a significant performance regression was reported by Simon Glass. After some discussions and analysis, it turned out its main cause is in $(call cc-option,...). Historically, U-Boot parses all config.mk (arch/*/config.mk and board/*/config.mk) every time descending into subdirectories. That means cc-options are evaluated over and over again. $(call cc-option,...) is useful but costly. So we want to evaluate them only in ./Makefile and spl/Makefile and export compiler flags. This commit changes the build system as follows: - Modify scripts/Makefile.build to not include config.mk Instead, add $(PLATFORM_CPPFLAGS) to asflags-y, ccflags-y, cppflags-y. - Export many variables Going forward, Kbuild will not parse config.mk files when it descends into subdirectories. If we want to set variables in config.mk and use them in subdirectories, they must be exported. This is the list of variables to get exported: PLATFORM_CPPFLAGS CPUDIR BOARDDIR OBJCOPYFLAGS LDFLAGS LDFLAGS_FINAL (used in nand_spl/board/*/*/Makefile) CONFIG_STANDALONE_LOAD_ADDR (used in examples/standalone/Makefile) SYM_PREFIX (used in examples/standalone/Makefile) RELFLAGS (used in examples/standalone/Makefile) - Delete CPPFLAGS This variable has been replaced with PLATFORM_CPPFLAGS - Copy gcclibdir from example/standalone/Makefile to arch/sparc/config.mk The reference in CONFIG_STANDALONE_LOAD_ADDR must be resolved before it is exported. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reported-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> [on Sandbox] Tested-by: Stephen Warren <swarren@nvidia.com> [on Tegra]
2014-02-25kbuild: use shorten logs for misc targetsMasahiro Yamada
2014-02-25kbuild: use shorten logs objcopy rulesMasahiro Yamada
2014-02-19examples: move api/ and standalone/ entry to examples/MakefileMasahiro Yamada
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19Makefile: move some flags to examples makefilesMasahiro Yamada
This commit moves some flags which are used under examples/ directory only. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19examples: Use scripts/Makefile.buildMasahiro Yamada
2014-02-07arc: add support for standalone programsAlexey Brodkin
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Francois Bedard <fbedard@synopsys.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de>
2014-01-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Bringing in the MMC tree means that CONFIG_BOUNCE_BUFFER needed to be added to include/configs/exynos5-dt.h now. Conflicts: include/configs/exynos5250-dt.h Signed-off-by: Tom Rini <trini@ti.com>
2014-01-09arm64: core supportDavid Feng
Relocation code based on a patch by Scott Wood, which is: Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: David Feng <fenghua@phytium.com.cn>
2013-12-16Makefile, .gitignore: Cleanup non-existing binariesMasahiro Yamada
2013-12-16examples: x86: delete 82559_eepromMasahiro Yamada
Commit fea25720 renamed arch/i386 to arch/x86. But it missed to modify examples/standalone/Makefile. Since then, examples/standalone/82559_eeprom has never compiled and nobody has noticed that. After some discussion on ML, we agreed to delete this example. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-16Makefile: Select objects by CONFIG_ rather than $(ARCH) or $(CPU)Masahiro Yamada
Convert like follows: CPU mpc83xx -> CONFIG_MPC83xx CPU mpc85xx -> CONFIG_MPC85xx CPU mpc86xx -> CONFIG_MPC86xx CPU mpc5xxx -> CONFIG_MPC5xxx CPU mpc8xx -> CONFIG_8xx CPU mpc8260 -> CONFIG_8260 CPU ppc4xx -> CONFIG_4xx CPU x86 -> CONFIG_X86 ARCH x86 -> CONFIG_X86 ARCH powerpc -> CONFIG_PPC Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-12ARM: fix the standalone programsJeroen Hofstee
The standalone programs do not use the api calls, but rely directly on u-boot variable gd->jt for the jump table. Commit fe1378a - "ARM: use r9 for gd" changed the register holding the address of gd, but the assembly code in the standalone examples was not updated accordingly. This broke the programs on ARM relying on the jumptable in the v2013.10 release. This patch unbricks them by using the correct register. Cc: Michal Simek <monstr@monstr.eu> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-11-25examples: delete unnecessary CPPFLAGSMasahiro Yamada
2013-11-15examples: remove the remainders of dead boardMasahiro Yamada
Commit 309a292e deleted OXC board, but missed to remove the standalone example specific to OXC board. eepro100_eeprom.c has been an orphan file for a long term. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
