path: root/examples/standalone/smc91111_eeprom.c
2010-01-31smc91111_eeprom: fix linking errorMike Frysinger
Building for a bf533-stamp ends up with this error: smc91111_eeprom.o: In function `smc91111_eeprom': examples/standalone/smc91111_eeprom.c:58: undefined reference to `memset' make[2]: *** [smc91111_eeprom] Error 1 The new eth_struct definition means gcc has to zero out the structure on the stack, and some gcc versions optimize this with an implicit call to memset. So tweak the structure style to avoid that gcc feature. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-01-19Fix breakage in SMC EEPROM standalone applicationsBen Warren
Commit 6a45e384955262882375a2785426dc65aeb636c4 (Make getenv_IPaddr() global) inadvertently added ' #include "net.h" ' to the standalone programs, creating duplicate definitions of 'struct eth_device'. This patch removes the local definitions and removes other code that breaks due to the change in definition. Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2009-12-02smc91111_eeprom: drop CONFIG stub protectionMike Frysinger
Since the Makefile now controls the compilation of this, there is no need for CONFIG checking nor the stub function. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-21Move examples/ to examples/standalonePeter Tyser
The current files in examples are all standalone application examples, so put them in their own subdirectory for organizational purposes Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
