path: root/examples/standalone/Makefile
2012-03-26Examples: Properly append LDFLAGS to LD commandMarek Vasut
The LD command in examples/standalone/Makefile ignored platform specific LDFLAGS setup. Pass these LDFLAGS to the command. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Bryan Hundven <bryanhundven@gmail.com> Cc: Michael Schwingen <rincewind@discworld.dascon.de>
2011-11-03Reduce build timesWolfgang Denk
U-Boot Makefiles contain a number of tests for compiler features etc. which so far are executed again and again. On some architectures (especially ARM) this results in a large number of calls to gcc. This patch makes sure to run such tests only once, thus largely reducing the number of "execve" system calls. Example: number of "execve" system calls for building the "P2020DS" (Power Architecture) and "qong" (ARM) boards, measured as: -> strace -f -e trace=execve -o /tmp/foo ./MAKEALL <board> -> grep execve /tmp/foo | wc -l Before: After: Reduction: ================================== P2020DS 20555 15205 -26% qong 31692 14490 -54% As a result, built times are significantly reduced, typically by 30...50%. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andy Fleming <afleming@gmail.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Albert Aribaud <albert.aribaud@free.fr> cc: Graeme Russ <graeme.russ@gmail.com> cc: Mike Frysinger <vapier@gentoo.org> Tested-by: Graeme Russ <graeme.russ@gmail.com> Tested-by: Matthias Weisser <weisserm@arcor.de> Tested-by: Sanjeev Premi <premi@ti.com> Tested-by: Simon Glass <sjg@chromium.org> Tested-by: Macpaul Lin <macpaul@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-05-12Fix variable flavor in examples/standalone/MakefileChe-liang Chiou
GNU Makefile have two flavors of variables, recursively expanded that is defined by using '=', and simply expanded that is defined by using ':='. The bug is caused by using recursively expanded flavor for BIN and SREC. As you can see below, they are prepended by $(obj) twice. We can reproduce this bug with a simplified version of this Makefile: $ cat >Makefile <<\EOF obj := /path/to/obj/ ELF := hello_world BIN_rec = $(addsuffix .bin,$(ELF)) # recursively expanded BIN_sim := $(addsuffix .bin,$(ELF)) # simply expanded ELF := $(addprefix $(obj),$(ELF)) BIN_rec := $(addprefix $(obj),$(BIN_rec)) BIN_sim := $(addprefix $(obj),$(BIN_sim)) show: @echo BIN_rec=$(BIN_rec) @echo BIN_sim=$(BIN_sim) .PHONY: show EOF $ make show BIN_rec=/path/to/obj//path/to/obj/hello_world.bin BIN_sim=/path/to/obj/hello_world.bin Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
2011-04-12Make STANDALONE_LOAD_ADDR configurable per boardWolfgang Denk
Rename STANDALONE_LOAD_ADDR into CONFIG_STANDALONE_LOAD_ADDR and allow that the architecture-specific default value gets overwritten by defining the value in the board header file. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Tsi Chung Liew <tsi-chung.liew@freescale.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2010-10-12examples/standalone: Use gcc's -fno-toplevel-reorderPeter Tyser
Using -fno-toplevel-reorder causes gcc to not reorder functions. This ensures that an application's entry point will be the first function in the application's source file. This change, along with commit 620bbba524fbaa26971a5004793010b169824f1b should cause a standalone application's entry point to be at the base of the compiled binary. Previously, the entry point could change depending on gcc version and flags. Note -fno-toplevel-reorder is only available in gcc version 4.2 or greater. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-06-29examples/standalone: Remove relocation compile flags for PowerPCPeter Tyser
Previously, standalone applications were compiled with gcc flags that produced relocatable executables on the PowerPC architecture (eg with the -mrelocatable and -fPIC flags). There's no reason for these applications to be fully relocatable at this time since no relocation fixups are performed on standalone applications. Additionally, removing the gcc relocation flags results in the entry point of applications residing at the base of the image. When a standalone application was relocatable, the entry point was generally located at an offset into the image which was confusing and prone to errors. This change moves the entry point of PowerPC standalone applications from 0x40004 (usually) to 0x40000. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-12-02Fix build failure in examples/standaloneSanjeev Premi
Some versions of 'make' do not handle trailing white-spaces properly. Trailing spaces in ELF causes a 'fake' source to be added to the variable COBJS; leading to build failure (listed below). The problem was found with GNU Make 3.80. Using text-function 'strip' as a workaround for the problem. make[1]: Entering directory `/home/sanjeev/u-boot/examples/standalone' arm-none-linux-gnueabi-gcc -g -Os -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0x80e80000 -I/home/sanjeev/u-boot/include -fno-builtin -ffreestanding -nostdinc -isystem /opt/codesourcery/2009q1- 203/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.3/include -pipe -DCONFIG_ ARM -D__ARM__ -marm -mabi=aapcs-linux -mno-thumb-interwork -march=armv5 -Wall -Wstrict-prototypes -fno-stack-protector -g -Os -fno-common -ff ixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0x80e80000 -I/home/sanje ev/u-boot/include -fno-builtin -ffreestanding -nostdinc -isystem /opt/co desourcery/2009q1-203/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.3/includ e -pipe -DCONFIG_ARM -D__ARM__ -marm -mabi=aapcs-linux -mno-thumb-inte rwork -march=armv5 -I.. -Bstatic -T u-boot.lds -Ttext 0x80e80000 -o .c arm-none-linux-gnueabi-gcc: no input files make[1]: *** [.c] Error 1 make[1]: Leaving directory `/home/sanjeev/u-boot/examples/standalone' make: *** [examples/standalone] Error 2 premi # Signed-off-by: Sanjeev Premi <premi@ti.com> Fixed typo (s/ElF/ELF/). Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-15standalone: convert to kbuild styleMike Frysinger
Clean up the arch/cpu/board/config checks as well as redundant setting of srec/bin variables by using the kbuild VAR-$(...) style. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-04push LOAD_ADDR out to arch mk filesMike Frysinger
Rather than maintain/extend the current ifeq($(ARCH)) mess that exists in the standalone Makefile, push the setting up of LOAD_ADDR out to the arch config.mk (and rename to STANDALONE_LOAD_ADDR in the process). This keeps the common code clean and lets the arch do whatever crazy crap it wants in its own area. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-04atmel_df_pow2: standalone to convert dataflashes to pow2Mike Frysinger
Atmel DataFlashes by default operate with pages that are slightly bigger than normal binary sizes (i.e. many are 1056 byte pages rather than 1024 bytes). However, they also have a "power of 2" mode where the pages show up with the normal binary size. The latter mode is required in order to boot with a Blackfin processor, so many people wish to convert their DataFlashes on their development systems to this mode. This standalone application does just that. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-08Fix examples for OMAP3 boards...Michael Evans
The attached patch corrects an error in the examples/Makefile which causes the applications in the examples directory to hang on OMAP3 based boards. The current Makefile sets -Ttext during linking to 0x0c100000 which is outside of addressable SDRAM memory. The script corrects the existing ifeq...else...endif logic to look at the VENDOR tag rather than the CPU tag. The patch affects the following configs: omap3_beagle_config, omap3_overo_config, omap3_evm_config, omap3_pandora_config, omap3_zoom1_config and omap3_zoom2_config. Signed-off-by: Michael Evans <horse_dung@hotmail.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-21Move examples/ to examples/standalonePeter Tyser
The current files in examples are all standalone application examples, so put them in their own subdirectory for organizational purposes Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
