path: root/examples/api/crt0.S
2016-05-21Fix FreeBSD loader API so that it works on both 32-bit and 64-bit targets.Stanislav Galabov
Specifically tested on MIPS under QEMU (works with all combination of bit-ness and endian-ness) Signed-off-by: Stanislav Galabov <sgalabov@gmail.com>
2016-02-08api: Add FreeBSD API support for MIPS platformsStanislav Galabov
This patch adds U-Boot API support (used by FreeBSD loader) for MIPS platforms. Signed-off-by: Stanislav Galabov <sgalabov@gmail.com>
2009-07-21Move api_examples to examples/apiPeter Tyser
Also add a rule to remove demo.bin which was previously leftover after a "make clean" Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
