This CONFIG_ENV_DEFAULT_NOWHERE config must be enabled for USB download
when we implemented the override function to select env storage medium.
To avoid adding it to every imx8mn defconfig, enable the config as default
on imx8mn.
Signed-off-by: Ye Li <ye.li@nxp.com>
Get below build error in nand env, because we should not call function in
array initialization.
env/nand.c: In function ‘env_nand_save’:
env/nand.c:196:15: error: initializer element is not constant
.offset = env_get_offset(CONFIG_ENV_OFFSET),
When booting from USB there is no place to store the environment and
should use default env. However CONFIG_ENV_IS_NOWHERE has dependence
with other env storage config. If we enable multiple storages, NOWHERE
can't be enabled. And saveenv won't be built if NOWHERE is set.
This patch introduces a new CONFIG_ENV_DEFAULT_NOWHERE, that can enable
NOWHERE as a default env location when other storage are not avaliable.
And allow to build saveenv.
Add env_get_offset interface to override static CONFIG_ENV_OFFSET,
and update env location driver to use env_get_offset. So for different
storage medium, we are able to store the env at different offset.
We don't support this feature when CONFIG_ENV_IS_EMBEDDED is set.
The env location label ENVL_ESATA is missed in location tables, so
when we configure the ENV in SATA, u-boot fails to get correct env
location and cause boot hang in board_f.
Reviewed-by: Peng Fan <peng.fan@nxp.com>
When env save is failed, 2018 u-boot will loop infinitely to save the env,
and each time returns failure. The root cause is env_driver_lookup only returns
current env location for ENVOP_SAVE, no matter what the prio is. So the loop
can't exit until the save is successful.
The ENV_IS_IN_SATA config is missed, add it into env/Kconfig, that
we can enable it for SATA boot.
Fix below build warning and errors:
env/sata.c: In function ‘env_sata_save’:
env/sata.c:59:9: warning: implicit declaration of function ‘sata_get_dev’ [-Wimplicit-function-declaration]
sata = sata_get_dev(env_sata);
env/sata.c:59:7: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
env/sata.c: In function ‘env_sata_load’:
env/sata.c:101:10: warning: ‘return’ with a value, in function returning void
return -EIO;
env/sata.c:94:13: note: declared here
static void env_sata_load(void)
env/sata.c:105:7: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
env/sata.c:108:10: warning: ‘return’ with a value, in function returning void
return -EIO;
env/sata.c:113:10: warning: ‘return’ with a value, in function returning void
return -EIO;
env/sata.c:116:9: warning: ‘return’ with a value, in function returning void
return env_import(buf, 1);
env/sata.c: At top level:
env/sata.c:120:14: error: ‘ENVL_ESATA’ undeclared here (not in a function)
.location = ENVL_ESATA,
env/sata.c:122:11: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
.load = env_sata_load,
Wrong env buffer was passed into sata write function, so the saveenv can't work.
Fix this issue.
(cherry picked from commit 0fe7573cffcb50d6bcb401f644cc37f5af28b388)
using it
When booting from a non-MMC device, the MMC sub-system may not be
initialized when the environment is first accessed.
We need to make sure that the MMC sub-system is ready in even a non-MMC
boot case.
Therefore, initialize mmc before loading environment from it.
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
With multiple environments, the 'get_char' callback for env
drivers does not really make sense any more because it is
only supported by two drivers (eeprom and nvram).
To restore single character loading for these drivers,
override 'env_get_char_spec'.
Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Commit 7d714a24d725 ("env: Support multiple environments") added
static variable env_load_location. When saving environmental
variables, this variable is presumed to have the value set before.
In case the value was set before relocation and U-Boot runs from a
NOR flash, this variable wasn't writable. This causes failure when
saving the environment. To save this location, global data must be
used instead.
Signed-off-by: York Sun <york.sun@nxp.com>
CC: Maxime Ripard <maxime.ripard@free-electrons.com>
When saving the environment on a platform which has DMA alignment
larger than the natural alignment, env_fat_save triggers a debug
message in file_fat_write:
Saving Environment to FAT... writing uboot.env
FAT: Misaligned buffer address (9df1c8e0)
OK
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
For the redundant environment configuration, env_sf_load still
contained duplicate code instead of using env_import_redund().
Simplify the code by only executing the load twice and delegating
everything else to env_import_redund.
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
For multiple env drivers to correctly implement fallback when
one environment fails to load (e.g. crc error), the return value
of env_import has to be propagated by all env driver's load
function.
Without this change, the first driver that succeeds to load an
environment with an invalid CRC return 0 (success) and no other
drivers are checked.
There is more common code in mmc, nand and ubi env drivers that
can be shared by moving to env_import_redund.
For this, a status/error value whether the buffers were loaded
are passed as additional parameters to env_import_redund.
Ideally, these are already returned to the env driver by the
storage driver. This is the case for mmc, nand and ubi, so for
this change, code deduplicated.
env_import (and env_import_redund) currently return 1 on success
and 0 on error. However, they are only used from functions
returning 0 on success or a negative value on error.
Let's clean this up by making env_import and env_import_redund
return 0 on success and -EIO on error (as was the case for all
users before).
Users that cared for the return value are also updated. Funny
enough, this only affects onenand.c and sf.c
Now that we have everything in place to implement the transition scheme,
let's enable it by default.
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Allow boards and architectures to override the default environment lookup
code by overriding env_get_location.
Now that we have everything in place in the code, let's allow to build
multiple environments backend through Kconfig.
The raw MMC environment directly calls into the MMC framework. Make sure
it's enabled before we can select it.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Since we want to have multiple environments, we will need to initialise
all the environments since we don't know at init time what drivers might
fail when calling load.
Let's init all of them, and only consider for further operations the ones
that have not reported any errors at init time.
Now that we have everything in place to support multiple environment, let's
make sure the current code can use it.
The priority used between the various environment is the same one that was
used in the code previously.
At read / init times, the highest priority environment is going to be
detected, and we'll use the same one without lookup during writes. This
should implement the same behaviour than we currently have.
Since we have global messages to indicate what's going on, the custom
messages in the environment drivers only make the output less readable.
Make the common code play a little nicer by removing all the extra output
in the standard case.
Make MMC play a little nicer by removing all the extra \n and formatting
that is redundant with the global output.
Make FAT play a little nicer by removing all the extra \n and formatting
Since we can have multiple environments now, it's better to provide a
decent indication on what environments were tried and which were the one to
fail and succeed.
Since we'll soon have support for multiple environments, the environment
saving message might end up being printed multiple times if the higher
priority environment cannot be used.
That might confuse the user, so let's make it explicit if the operation
failed or not.
In preparation for the multiple environment support, let's introduce two
new parameters to the environment driver lookup function: the priority and
operation.
The operation parameter is meant to identify, obviously, the operation you
might want to perform on the environment.
The priority is a number passed to identify the environment priority you
want to retrieve. The lowest priority parameter (0) will be the primary
source.
Combining the two parameters allow you to support multiple environments
through different priorities, and to change those priorities between read
and writes operations.
This is especially useful to implement migration mechanisms where you want
to always use the same environment first, be it to read or write, while the
common case is more likely to use the same environment it has read from to
write it to.
The env_driver_lookup_default and env_get_default_location functions are
about to get refactored to support loading from multiple environment.
The name is therefore not really well suited anymore. Drop the default
part to be a bit more relevant.
The nvedit command is the only user of env_driver_lookup_default outside of
the environment code itself, and it uses it only to print the environment
it's about to save to during env save.
As we're about to rework the environment to be able to handle multiple
environment sources, we might not have an idea of what environment backend
is going to be used before trying (and possibly failing for some).
Therefore, it makes sense to remove that message and move it to the
env_save function itself. As a side effect, we also can get rid of the call
to env_driver_lookup_default that is also about to get refactored.
Make it select FS_FAT as well, because if it's not selected, enabling
ENV_IS_IN_FAT causes a Kconfig warning:
warning: (ENV_IS_IN_FAT) selects FAT_WRITE which has unmet direct dependencies (FS_FAT)
This also allows dropping some code from config_fallbacks.
Also drop the unnecessary help text about having to enable
CONFIG_FAT_WRITE - Kconfig automatically handles that.
ENV variables can now be used before relocation.
Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
For example to store the environment in a file named "/uboot.env" in MMC
"0", where partition "1" contains the EXT4 filesystem, the following
configs should be added to the board's default config:
CONFIG_ENV_IS_IN_EXT4=y
CONFIG_ENV_EXT4_DEVICE_AND_PART="0:1"
CONFIG_ENV_EXT4_FILE="/uboot.env"
CONFIG_ENV_EXT4_INTERFACE="mmc"
Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
[trini: Fix some line over 80 chars issues]
This commit adds ENV_SIZE and ENV_OFFSET configuration items for
ARCH_ROCKCHIP, but keeps these non-visible (i.e. not prompt is given).
With these new items present, the configuration from the header files
is moved to Kconfig.
Keeping these non-visible is necessary to have the possibility to
select new default values if CONFIG_IS_IN_* is changed (interactively
or with oldconfig). Otherwise it will always be set to a previous
value if used with a prompt. As an example if we do a defconfig with
CONFIG_IS_IN_MMC and change it to CONFIG_IS_IN_SPI_FLASH via
menuconfig, ENV_SIZE and ENV_OFFSET will not be changed to the correct
values as defconfig will already have set them to the default values
of CONFIG_IS_IN_MMC in .config.
Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
GCC 7.1 seems to be smart enough to track val through the various
static inline functions, but not smart enough to see that val will
always be initialised when no error is returned. This triggers
the following warning:
env/mmc.c: In function 'mmc_get_env_addr':
env/mmc.c:121:12: warning: 'val' may be used uninitialized in this function [-Wmaybe-uninitialized]
To make it easier for compiler to understand what is going on, let's
initialise val.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
This support has been deprecated since v2017.09 due to security issues.
We now remove this support.
Allow the platform to define a partition by name at the end of which
the environment data will be located.
Imply does not work for a Kconfig choice. Update ENV_IS_IN_SPI_FLASH
to be the default one for Intel Braswell.
Last user of this option went away in commit:
fdc7718999 ("board: usb_a9263: Update to support DT and DM")
The non-volatile storage varies board by board. The default should
be NOWHERE. Please choose a proper device via Kconfig.
U-Boot widely uses error() as a bit noisier variant of printf().
This macro causes name conflict with the following line in
include/linux/compiler-gcc.h:
# define __compiletime_error(message) __attribute__((error(message)))
This prevents us from using __compiletime_error(), and makes it
difficult to fully sync BUILD_BUG macros with Linux. (Notice
Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().)
Let's convert error() into now treewide-available pr_err().
Done with the help of Coccinelle, excluing tools/ directory.
The semantic patch I used is as follows:
// <smpl>
-error
+pr_err
// </smpl>
[trini: Re-run Coccinelle]
The underlying implementation for ENV_AES has security complications and
is not recommended for use. Please see CVE-2017-3225 and CVE-2017-3226
for more details. Mark this as deprecated now and delete this in the
medium term if no one comes forward to re-work the support.
Add the following options to drivers/misc/Kconfig:
SYS_I2C_EEPROM_ADDR
SYS_I2C_EEPROM_BUS
SYS_EEPROM_SIZE
SYS_EEPROM_PAGE_WRITE_BITS
SYS_EEPROM_PAGE_WRITE_DELAY_MS
SYS_I2C_EEPROM_ADDR_LEN
SYS_I2C_EEPROM_ADDR_OVERFLOW
This does not migrate any boards, but provides a foundations for
those who want/need these options
[trini: Migrate uniphier]
Some of these were missed in the conversion.
Now that we have errors available in the environment driver's load()
method, check the return valid.
With the change to the environment code to remove the common init stage
of pointing to the default environment and setting it as valid, combined
with the change to switch gd->env_valid from 0/1/2 to an enum we now
must set env_valid to one of the enum values rather than an int. And in
this case, not only was setting it to an int wrong, it was now the wrong
value. Finally, in the case of ENV_IS_NOWHERE we must still say that
our envionrment is invalid after init for things to continue to
function.
Fixes: 7938822a6b75 ("env: Drop common init() functions")
Tested-by: Marek Vasut <marek.vasut@gmail.com>
Reported-by: Marek Vasut <marek.vasut@gmail.com>
Reported-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Changes in v3:
- Actually include changes for env/nowhere.c
It would be easier to catch out which platform is using which default.
The load() methods have inconsistent behaviour on error. Some of them load
an empty default environment. Some load an environment containing an error
message. Others do nothing.
As a step in the right direction, have the method return an error code.
Then the caller could handle this itself in a consistent way.
