path: root/env
2018-09-19fix: env: Fix the SPI flash device setup for DM modeKonstantin Porotchkin
For some reason the spi_flash_probe_bus_cs() is called inside the setup_flash_device() with zero values in place of configurated SPI flash mode and maximum flash speed. This code causes HALT error during startup environment relocation on some platforms - namely Armada-38x-GP board. Fix the function call by replacing zeros with the appropriate values - CONFIG_ENV_SPI_MAX_HZ and CONFIG_ENV_SPI_MODE. Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2018-08-24env: ubi: Add missing ENV_NAMEMarek Vasut
Add missing environment name for UBI, to prevent this NULL in output: Loading Environment from <NULL>... and rather have a valid UBI there: Loading Environment from UBI... Signed-off-by: Marek Vasut <marex@denx.de>
2018-08-19env: Merge Rockchip, Sunxi, Zynq and ZynqMPMichal Simek
There is no reason to have the same Kconfig options for different SoCs separately. The patch is merging them together. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> [trini: Fix ENV_SIZE around ENV_IS_NOWHERE] Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-08-10env: Don't show "Failed" error messageSam Protsenko
"Failed" error message from env_load() only clutters the log with unnecessary details, as we already have all needed warnings by that time. Example: Loading Environment from FAT... MMC: no card present ** Bad device mmc 0 ** Failed (-5) Let's only print it in case when DEBUG is defined to keep log clear. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2018-07-30u-boot: remove driver lookup loop from env_save()Nicholas Faustini
When called with ENVOP_SAVE, env_get_location() only returns the gd->env_load_location variable without actually checking for the environment location and priority. This behaviour causes env_save() to fall into an infinite loop when the low-level drv->save() call fails. The env_save() function should not loop through the environment location list but it should save the environment into the location stored in gd->env_load_location by the last env_load() call. Signed-off-by: Nicholas Faustini <nicholas.faustini@azcomtech.com> Reviewed-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
2018-07-21env: Simplify Makefile using $(SPL_TPL_)York Sun
Add Kconfig options SPL_ENV_* and TPL_ENV_* and simplify Makefile. This allows SPL/TPL image has different environment setting from full feature U-Boot. Signed-off-by: York Sun <york.sun@nxp.com>
2018-07-21env: typo in description of ENV_IS_IN_REMOTEHeinrich Schuchardt
%s/remove/remote/ Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-07-20env: add the same prefix to error messages to make it detectable by testsQuentin Schulz
The error message should start with `## Error: ` so that it's easily detectable by tests without needing to have a complex regexp for matching all possible error message patterns. Let's add the `## Error: ` prefix to the error messages since it's the one already in use. Suggested-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Quentin Schulz <quentin.schulz@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2018-07-19env: common: accept flags on reset to default envYaniv Levinsky
The function set_default_env() sets the hashtable flags for import_r(). Formally set_default_env() doesn't accept flags from its callers. In practice the caller can (un)set the H_INTERACTIVE flag, but it has to be done using the first character of the function's string argument. Other flags like H_FORCE can't be set by the caller. Change the function to accept flags argument. The benefits are: 1. The caller will have to explicitly set the H_INTERACTIVE flag, instead of un-setting it using a special char in a string. 2. Add the ability to propagate flags from the caller to himport(), especially the H_FORCE flag from do_env_default() in nvedit.c that currently gets ignored for "env default -a -f" commands. 3. Flags and messages will not be coupled together. A caller will be able to set flags without passing a string and vice versa. Please note: The propagation of H_FORCE from do_env_default() does not introduce any functional changes, because currently himport_r() is set to destroy the old environment regardless if H_FORCE flag is set or not. More changes are needed to utilize the propagation of H_FORCE. Signed-off-by: Yaniv Levinsky <yaniv.levinsky@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2018-07-19cmd: nvedit: set H_INTERACTIVE in do_env_defaultYaniv Levinsky
The function set_default_vars() in common.c adds H_INTERACTIVE to the h_import() flag, but the function has no way of telling if the command actually was user directed like this flag suggest. The flag should be set by the calling function do_env_default() in nvedit.c instead, where the command is certainty user directed. Move the H_INTERACTIVE flag from set_default_vars() to do_env_default(). Signed-off-by: Yaniv Levinsky <yaniv.levinsky@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2018-07-19cmd: nvedit: propagate envflag to set_default_varsYaniv Levinsky
The env_flag in do_env_default() doesn't get propagated and therefore gets ignored by himport_r(). This breaks to ability to "forcibly" reset variables to their default values using the environment command. Scenario example of the problem: # setenv kernel uImage # setenv .flags kernel:so # env default -f kernel ## Error: Can't overwrite "kernel" himport_r: can't insert "kernel=zImage" into hash table Change the call path so it will pass the flag correctly. Signed-off-by: Yaniv Levinsky <yaniv.levinsky@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2018-07-19env: Added support to save env to spi through KconfigVipul Kumar
This patch added support to enable CONFIG_ENV_SIZE, CONFIG_ENV_OFFSET and CONFIG_ENV_SECT_SIZE through Kconfig for Zynq and Zynqmp. Signed-off-by: Vipul Kumar <vipul.kumar@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-06-13env: Add !ENV_IS_IN_EXT4 dependency to ENV_IS_NOWHEREAlex Kiernan
If ENV_IS_IN_EXT4 is set you shouldn't be able to select ENV_IS_NOWHERE. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Petr Vorel <petr.vorel@gmail.com>
2018-06-13u-boot: Fix several typosShyam Saini
's/environemnt/environment/' and 's/Environemnt/Environment/' Signed-off-by: Shyam Saini <shyam@amarulasolutions.com>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-16env: mmc/fat/ext4: undefined reference to `mmc_initialize'Heinrich Schuchardt
For CONFIG_ENV_FAT_INTERFACE != 'mmc' a link error env/fat.c:93: undefined reference to `mmc_initialize' occurs if CONFIG_MMC_SUPPORT is not enabled. Fixes: 26862b4a40c3 ("env: mmc/fat/ext4: make sure that the MMC sub-system is initialized before using it") Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-04-16env: Relocate env drivers if manual reloc is requiredSiva Durga Prasad Paladugu
Relocate env drivers if manual relocation is enabled. This patch fixes the issue of u-boot hang incase if env is present in any of the flash devices. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-08Migrate CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to KconfigAlex Kiernan
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Petr Vorel <petr.vorel@gmail.com> Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
2018-04-06env: Properly check for BLK supportSjoerd Simons
Use CONFIG_IS_ENABLED to see if CONFIG_BLK is enabled. Otherwise SPL compilation breaks on boards which do have CONFIG_BLK enabled but not DM_MMC for the SPL as follows: env/mmc.c: In function ‘init_mmc_for_env’: env/mmc.c:164:6: warning: implicit declaration of function ‘blk_get_from_parent’; did you mean ‘efi_get_ram_base’? [-Wimplicit-function-declaration] if (blk_get_from_parent(mmc->dev, &dev)) ^~~~~~~~~~~~~~~~~~~ efi_get_ram_base env/mmc.c:164:29: error: ‘struct mmc’ has no member named ‘dev’ if (blk_get_from_parent(mmc->dev, &dev)) ^~ Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-06Allow providing default environment from fileRasmus Villemoes
Modifying the default environment via CONFIG_EXTRA_ENV_SETTINGS is somewhat inflexible, partly because the cpp language does not allow appending to an existing macro. This prevents reuse of "environment fragments" for different boards, which in turn makes maintaining that environment consistently tedious and error-prone. This implements a Kconfig option for allowing one to define the entire default environment in an external file, which can then, for example, be generated programmatically as part of a Yocto recipe, or simply be kept in version control separately from the U-boot repository. Tested-by: Sean Nyekjaer <sean.nyekjaer@prevas.dk> Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-04-06common: env_embedded: allow fine placement of environment objectChristophe Leroy
Commit 7653942b10e9e ("common/env_embedded.c: drop support for CONFIG_SYS_USE_PPCENV") dropped the .ppcenv section which was used in linking scripts to allow fine placement of embedded environment sections. This implies that GCC randomly places objects from env/embedded.o and environment is not guaranteed to be located at the correct address: 04003df8 g F .text 00000038 mii_init 04004000 g O .text 00000004 env_size 04004004 g O .text 00002000 environment 04006004 g F .text 00000040 .hidden __lshrdi3 This patch restores this capability by allocating each object marked with __UBOOT_ENV_SECTION__ into a different section. Hence 'environment' will be alone in .text.environment, allowing a fine placement in u-boot.lds with: . = DEFINED(env_offset) ? env_offset : .; env/embedded.o (.text.environment) Fixes: 7653942b10e9e ("common/env_embedded.c: drop support for CONFIG_SYS_USE_PPCENV") Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2018-04-04Merge git://git.denx.de/u-boot-sunxiTom Rini
2018-04-04sunxi: disable direct MMC environmentAndre Przywara
Since the dawn of time for the Allwinner support in mainline U-Boot we store the environment to the SD card and write directly at 544KB from the beginning of the device. This leads to problems when the U-Boot proper image grows beyond 504KB and eventually overlaps. With one release of having the environment preferably in a FAT partition, let's now turn off the MMC variant fallback, so we get back all the space we need to implement features. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
2018-03-24Convert CONFIG_UBI_SILENCE_MSG to KconfigPetr Vorel
Signed-off-by: Petr Vorel <petr.vorel@gmail.com>
2018-03-24Convert CONFIG_UBIFS_SILENCE_MSG to KconfigPetr Vorel
Introduce another difference from upstream (kernel) source in fs/ubifs/super.c: adding preprocessor condition as y variable in mount_ubifs() depends on CONFIG_UBIFS_SILENCE_MSG: fs/ubifs/super.c:1337:15: error: variable ?y? set but not used [-Werror=unused-but-set-variable] long long x, y; Not setting CONFIG_UBIFS_SILENCE_MSG in am335x_igep003x_defconfig and igep0032_defconfig. Although it was defined in their config headers, it depends on CMD_UBIFS which is not set for them. Signed-off-by: Petr Vorel <petr.vorel@gmail.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Heiko Schocher <hs@denx.de>
2018-02-20env: mmc/fat/ext4: make sure that the MMC sub-system is initialized before ↵Faiz Abbas
using it When booting from a non-MMC device, the MMC sub-system may not be initialized when the environment is first accessed. We need to make sure that the MMC sub-system is ready in even a non-MMC boot case. Therefore, initialize mmc before loading environment from it. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2018-02-16env: restore old env_get_char() behaviourGoldschmidt Simon
With multiple environments, the 'get_char' callback for env drivers does not really make sense any more because it is only supported by two drivers (eeprom and nvram). To restore single character loading for these drivers, override 'env_get_char_spec'. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
2018-02-16env: Fix env_load_locationYork Sun
Commit 7d714a24d725 ("env: Support multiple environments") added static variable env_load_location. When saving environmental variables, this variable is presumed to have the value set before. In case the value was set before relocation and U-Boot runs from a NOR flash, this variable wasn't writable. This causes failure when saving the environment. To save this location, global data must be used instead. Signed-off-by: York Sun <york.sun@nxp.com> CC: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-02-12Fix misaligned buffer in env_fat_saveAlex Kiernan
When saving the environment on a platform which has DMA alignment larger than the natural alignment, env_fat_save triggers a debug message in file_fat_write: Saving Environment to FAT... writing uboot.env FAT: Misaligned buffer address (9df1c8e0) OK Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-02-01env: sf: use env_import_redund to simplify env_sf_loadSimon Goldschmidt
For the redundant environment configuration, env_sf_load still contained duplicate code instead of using env_import_redund(). Simplify the code by only executing the load twice and delegating everything else to env_import_redund. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-02-01env: make env drivers propagate env_import return valueSimon Goldschmidt
For multiple env drivers to correctly implement fallback when one environment fails to load (e.g. crc error), the return value of env_import has to be propagated by all env driver's load function. Without this change, the first driver that succeeds to load an environment with an invalid CRC return 0 (success) and no other drivers are checked. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-02-01env: move more common code to env_import_redundSimon Goldschmidt
There is more common code in mmc, nand and ubi env drivers that can be shared by moving to env_import_redund. For this, a status/error value whether the buffers were loaded are passed as additional parameters to env_import_redund. Ideally, these are already returned to the env driver by the storage driver. This is the case for mmc, nand and ubi, so for this change, code deduplicated. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-31env: make env_import(_redund) return 0 on success, not 1Simon Goldschmidt
env_import (and env_import_redund) currently return 1 on success and 0 on error. However, they are only used from functions returning 0 on success or a negative value on error. Let's clean this up by making env_import and env_import_redund return 0 on success and -EIO on error (as was the case for all users before). Users that cared for the return value are also updated. Funny enough, this only affects onenand.c and sf.c Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: sunxi: Enable FAT-based environment support by defaultMaxime Ripard
Now that we have everything in place to implement the transition scheme, let's enable it by default. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Mark env_get_location as weakMaxime Ripard
Allow boards and architectures to override the default environment lookup code by overriding env_get_location. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Allow to build multiple environments in KconfigMaxime Ripard
Now that we have everything in place in the code, let's allow to build multiple environments backend through Kconfig. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: mmc: depends on the MMC frameworkMaxime Ripard
The raw MMC environment directly calls into the MMC framework. Make sure it's enabled before we can select it. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2018-01-27env: Initialise all the environmentsMaxime Ripard
Since we want to have multiple environments, we will need to initialise all the environments since we don't know at init time what drivers might fail when calling load. Let's init all of them, and only consider for further operations the ones that have not reported any errors at init time. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Support multiple environmentsMaxime Ripard
Now that we have everything in place to support multiple environment, let's make sure the current code can use it. The priority used between the various environment is the same one that was used in the code previously. At read / init times, the highest priority environment is going to be detected, and we'll use the same one without lookup during writes. This should implement the same behaviour than we currently have. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: common: Make the debug messages play a little nicerMaxime Ripard
Since we have global messages to indicate what's going on, the custom messages in the environment drivers only make the output less readable. Make the common code play a little nicer by removing all the extra output in the standard case. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: mmc: Make the debug messages play a little nicerMaxime Ripard
Since we have global messages to indicate what's going on, the custom messages in the environment drivers only make the output less readable. Make MMC play a little nicer by removing all the extra \n and formatting that is redundant with the global output. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2018-01-27env: fat: Make the debug messages play a little nicerMaxime Ripard
Since we have global messages to indicate what's going on, the custom messages in the environment drivers only make the output less readable. Make FAT play a little nicer by removing all the extra \n and formatting that is redundant with the global output. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Make it explicit where we're loading our environment fromMaxime Ripard
Since we can have multiple environments now, it's better to provide a decent indication on what environments were tried and which were the one to fail and succeed. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Make the env save message a bit more explicitMaxime Ripard
Since we'll soon have support for multiple environments, the environment saving message might end up being printed multiple times if the higher priority environment cannot be used. That might confuse the user, so let's make it explicit if the operation failed or not. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Pass additional parameters to the env lookup functionMaxime Ripard
In preparation for the multiple environment support, let's introduce two new parameters to the environment driver lookup function: the priority and operation. The operation parameter is meant to identify, obviously, the operation you might want to perform on the environment. The priority is a number passed to identify the environment priority you want to retrieve. The lowest priority parameter (0) will be the primary source. Combining the two parameters allow you to support multiple environments through different priorities, and to change those priorities between read and writes operations. This is especially useful to implement migration mechanisms where you want to always use the same environment first, be it to read or write, while the common case is more likely to use the same environment it has read from to write it to. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Rename env_driver_lookup_default and env_get_default_locationMaxime Ripard
The env_driver_lookup_default and env_get_default_location functions are about to get refactored to support loading from multiple environment. The name is therefore not really well suited anymore. Drop the default part to be a bit more relevant. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27cmd: nvedit: Get rid of the env lookupMaxime Ripard
The nvedit command is the only user of env_driver_lookup_default outside of the environment code itself, and it uses it only to print the environment it's about to save to during env save. As we're about to rework the environment to be able to handle multiple environment sources, we might not have an idea of what environment backend is going to be used before trying (and possibly failing for some). Therefore, it makes sense to remove that message and move it to the env_save function itself. As a side effect, we also can get rid of the call to env_driver_lookup_default that is also about to get refactored. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-22env: ENV_IS_IN_FAT improvementsTuomas Tynkkynen
Make it select FS_FAT as well, because if it's not selected, enabling ENV_IS_IN_FAT causes a Kconfig warning: warning: (ENV_IS_IN_FAT) selects FAT_WRITE which has unmet direct dependencies (FS_FAT) This also allows dropping some code from config_fallbacks. Also drop the unnecessary help text about having to enable CONFIG_FAT_WRITE - Kconfig automatically handles that. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-01-17Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
