path: root/env
2018-02-01env: sf: use env_import_redund to simplify env_sf_loadSimon Goldschmidt
For the redundant environment configuration, env_sf_load still contained duplicate code instead of using env_import_redund(). Simplify the code by only executing the load twice and delegating everything else to env_import_redund. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-02-01env: make env drivers propagate env_import return valueSimon Goldschmidt
For multiple env drivers to correctly implement fallback when one environment fails to load (e.g. crc error), the return value of env_import has to be propagated by all env driver's load function. Without this change, the first driver that succeeds to load an environment with an invalid CRC return 0 (success) and no other drivers are checked. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-02-01env: move more common code to env_import_redundSimon Goldschmidt
There is more common code in mmc, nand and ubi env drivers that can be shared by moving to env_import_redund. For this, a status/error value whether the buffers were loaded are passed as additional parameters to env_import_redund. Ideally, these are already returned to the env driver by the storage driver. This is the case for mmc, nand and ubi, so for this change, code deduplicated. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-31env: make env_import(_redund) return 0 on success, not 1Simon Goldschmidt
env_import (and env_import_redund) currently return 1 on success and 0 on error. However, they are only used from functions returning 0 on success or a negative value on error. Let's clean this up by making env_import and env_import_redund return 0 on success and -EIO on error (as was the case for all users before). Users that cared for the return value are also updated. Funny enough, this only affects onenand.c and sf.c Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: sunxi: Enable FAT-based environment support by defaultMaxime Ripard
Now that we have everything in place to implement the transition scheme, let's enable it by default. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Mark env_get_location as weakMaxime Ripard
Allow boards and architectures to override the default environment lookup code by overriding env_get_location. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Allow to build multiple environments in KconfigMaxime Ripard
Now that we have everything in place in the code, let's allow to build multiple environments backend through Kconfig. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: mmc: depends on the MMC frameworkMaxime Ripard
The raw MMC environment directly calls into the MMC framework. Make sure it's enabled before we can select it. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2018-01-27env: Initialise all the environmentsMaxime Ripard
Since we want to have multiple environments, we will need to initialise all the environments since we don't know at init time what drivers might fail when calling load. Let's init all of them, and only consider for further operations the ones that have not reported any errors at init time. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Support multiple environmentsMaxime Ripard
Now that we have everything in place to support multiple environment, let's make sure the current code can use it. The priority used between the various environment is the same one that was used in the code previously. At read / init times, the highest priority environment is going to be detected, and we'll use the same one without lookup during writes. This should implement the same behaviour than we currently have. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: common: Make the debug messages play a little nicerMaxime Ripard
Since we have global messages to indicate what's going on, the custom messages in the environment drivers only make the output less readable. Make the common code play a little nicer by removing all the extra output in the standard case. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: mmc: Make the debug messages play a little nicerMaxime Ripard
Since we have global messages to indicate what's going on, the custom messages in the environment drivers only make the output less readable. Make MMC play a little nicer by removing all the extra \n and formatting that is redundant with the global output. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2018-01-27env: fat: Make the debug messages play a little nicerMaxime Ripard
Since we have global messages to indicate what's going on, the custom messages in the environment drivers only make the output less readable. Make FAT play a little nicer by removing all the extra \n and formatting that is redundant with the global output. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Make it explicit where we're loading our environment fromMaxime Ripard
Since we can have multiple environments now, it's better to provide a decent indication on what environments were tried and which were the one to fail and succeed. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Make the env save message a bit more explicitMaxime Ripard
Since we'll soon have support for multiple environments, the environment saving message might end up being printed multiple times if the higher priority environment cannot be used. That might confuse the user, so let's make it explicit if the operation failed or not. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Pass additional parameters to the env lookup functionMaxime Ripard
In preparation for the multiple environment support, let's introduce two new parameters to the environment driver lookup function: the priority and operation. The operation parameter is meant to identify, obviously, the operation you might want to perform on the environment. The priority is a number passed to identify the environment priority you want to retrieve. The lowest priority parameter (0) will be the primary source. Combining the two parameters allow you to support multiple environments through different priorities, and to change those priorities between read and writes operations. This is especially useful to implement migration mechanisms where you want to always use the same environment first, be it to read or write, while the common case is more likely to use the same environment it has read from to write it to. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27env: Rename env_driver_lookup_default and env_get_default_locationMaxime Ripard
The env_driver_lookup_default and env_get_default_location functions are about to get refactored to support loading from multiple environment. The name is therefore not really well suited anymore. Drop the default part to be a bit more relevant. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27cmd: nvedit: Get rid of the env lookupMaxime Ripard
The nvedit command is the only user of env_driver_lookup_default outside of the environment code itself, and it uses it only to print the environment it's about to save to during env save. As we're about to rework the environment to be able to handle multiple environment sources, we might not have an idea of what environment backend is going to be used before trying (and possibly failing for some). Therefore, it makes sense to remove that message and move it to the env_save function itself. As a side effect, we also can get rid of the call to env_driver_lookup_default that is also about to get refactored. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-22env: ENV_IS_IN_FAT improvementsTuomas Tynkkynen
Make it select FS_FAT as well, because if it's not selected, enabling ENV_IS_IN_FAT causes a Kconfig warning: warning: (ENV_IS_IN_FAT) selects FAT_WRITE which has unmet direct dependencies (FS_FAT) This also allows dropping some code from config_fallbacks. Also drop the unnecessary help text about having to enable CONFIG_FAT_WRITE - Kconfig automatically handles that. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-01-17Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2018-01-17env: sf: Add support for env init for QSPI-NORAshish Kumar
ENV variables can now be used before relocation. Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-01-15env: enable accessing the environment in an EXT4 partitionJorge Ramirez-Ortiz
For example to store the environment in a file named "/uboot.env" in MMC "0", where partition "1" contains the EXT4 filesystem, the following configs should be added to the board's default config: CONFIG_ENV_IS_IN_EXT4=y CONFIG_ENV_EXT4_DEVICE_AND_PART="0:1" CONFIG_ENV_EXT4_FILE="/uboot.env" CONFIG_ENV_EXT4_INTERFACE="mmc" Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org> [trini: Fix some line over 80 chars issues] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-12-18rockchip: move CONFIG_ENV_SIZE and CONFIG_ENV_OFFSET to KconfigKlaus Goger
This commit adds ENV_SIZE and ENV_OFFSET configuration items for ARCH_ROCKCHIP, but keeps these non-visible (i.e. not prompt is given). With these new items present, the configuration from the header files is moved to Kconfig. Keeping these non-visible is necessary to have the possibility to select new default values if CONFIG_IS_IN_* is changed (interactively or with oldconfig). Otherwise it will always be set to a previous value if used with a prompt. As an example if we do a defconfig with CONFIG_IS_IN_MMC and change it to CONFIG_IS_IN_SPI_FLASH via menuconfig, ENV_SIZE and ENV_OFFSET will not be changed to the correct values as defconfig will already have set them to the default values of CONFIG_IS_IN_MMC in .config. Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-11-29env: suppress a spurious warning with GCC 7.1Philipp Tomsich
GCC 7.1 seems to be smart enough to track val through the various static inline functions, but not smart enough to see that val will always be initialised when no error is returned. This triggers the following warning: env/mmc.c: In function 'mmc_get_env_addr': env/mmc.c:121:12: warning: 'val' may be used uninitialized in this function [-Wmaybe-uninitialized] To make it easier for compiler to understand what is going on, let's initialise val. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-21env: Remove CONFIG_ENV_AES supportTom Rini
This support has been deprecated since v2017.09 due to security issues. We now remove this support. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-11-17env: Save environment at the end of an MMC partitionJorge Ramirez-Ortiz
Allow the platform to define a partition by name at the end of which the environment data will be located. Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2017-10-27env: x86: braswell: Set ENV_IS_IN_SPI_FLASH as defaultBin Meng
Imply does not work for a Kconfig choice. Update ENV_IS_IN_SPI_FLASH to be the default one for Intel Braswell. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-16env: Drop CONFIG_ENV_IS_IN_DATAFLASHTuomas Tynkkynen
Last user of this option went away in commit: fdc7718999 ("board: usb_a9263: Update to support DT and DM") Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-10-15ARM: uniphier: switch to CONFIG_ENV_IS_NOWHEREMasahiro Yamada
The non-volatile storage varies board by board. The default should be NOWHERE. Please choose a proper device via Kconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-08env: Migrate CONFIG_ENV_AES to Kconfig and deprecateTom Rini
The underlying implementation for ENV_AES has security complications and is not recommended for use. Please see CVE-2017-3225 and CVE-2017-3226 for more details. Mark this as deprecated now and delete this in the medium term if no one comes forward to re-work the support. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-02Kconfig: Add EEPROM options to Kconfig when I2C_EEPROM is setAdam Ford
Add the following options to drivers/misc/Kconfig: SYS_I2C_EEPROM_ADDR SYS_I2C_EEPROM_BUS SYS_EEPROM_SIZE SYS_EEPROM_PAGE_WRITE_BITS SYS_EEPROM_PAGE_WRITE_DELAY_MS SYS_I2C_EEPROM_ADDR_LEN SYS_I2C_EEPROM_ADDR_OVERFLOW This does not migrate any boards, but provides a foundations for those who want/need these options Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Migrate uniphier] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-20env: Replace all open-coded gd->env_valid values with ENV_ flagsSimon Glass
Some of these were missed in the conversion. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-20env: Allow env_load() to detect errorsSimon Glass
Now that we have errors available in the environment driver's load() method, check the return valid. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-20env: Correct case of no sub-init functionTom Rini
With the change to the environment code to remove the common init stage of pointing to the default environment and setting it as valid, combined with the change to switch gd->env_valid from 0/1/2 to an enum we now must set env_valid to one of the enum values rather than an int. And in this case, not only was setting it to an int wrong, it was now the wrong value. Finally, in the case of ENV_IS_NOWHERE we must still say that our envionrment is invalid after init for things to continue to function. Fixes: 7938822a6b75 ("env: Drop common init() functions") Tested-by: Marek Vasut <marek.vasut@gmail.com> Reported-by: Marek Vasut <marek.vasut@gmail.com> Reported-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> --- Changes in v3: - Actually include changes for env/nowhere.c
2017-08-20env: Sort selection of default choicesAndy Shevchenko
It would be easier to catch out which platform is using which default. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-08-16env: Adjust the load() method to return an errorSimon Glass
The load() methods have inconsistent behaviour on error. Some of them load an empty default environment. Some load an environment containing an error message. Others do nothing. As a step in the right direction, have the method return an error code. Then the caller could handle this itself in a consistent way. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Adjust the get_char() method to return an intSimon Glass
In principle this can fail, e.g. if the index is out of range. Adjust the driver signature to allow returning an error code. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-16env: Rename some other getenv()-related functionsSimon Glass
We are now using an env_ prefix for environment functions. Rename these other functions as well, for consistency: getenv_vlan() getenv_bootm_size() getenv_bootm_low() getenv_bootm_mapsize() env_get_default() Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv_hex(), getenv_yesno(), getenv_ulong()Simon Glass
We are now using an env_ prefix for environment functions. Rename these for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-15env: Drop saveenv() in favour of env_save()Simon Glass
Use the env_save() function directly now that there is only one implementation of saveenv(). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Wolfgang Denk <wd@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15env: Drop env_relocate_spec() in favour of env_load()Simon Glass
This is a strange name for a function that loads the environment. There is now only one implementation of this function, so use the new env_load() function directly instead. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15env: Drop env_get_char_spec()Simon Glass
We only have a single implementation of this function now and it is called env_get_char(). Drop the old function and the weak version. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-15env: Drop env_init_new()Simon Glass
Now that env_init() is only defined once we can drop the env_init_new() name and just use env_init(). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15env: Drop unused env_ptr variablesSimon Glass
This variable is declared as a global in most environment location drivers. But it is not used outside the drivers and most of the declarations are unnecessary. Also some drivers call free() on env_ptr which seems wrong since it is not in the heap. Drop the variable where possible, and all calls to free(). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15env: Drop the env_name_spec globalSimon Glass
Add a name to the driver and use that instead of the global variable declared by each driver. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15env: Drop common init() functionsSimon Glass
Most of the init() implementations just use the default environment. Adjust env_init_new() to do this automatically, and drop the redundant code. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15env: Switch over to use environment location driversSimon Glass
Move over to use a the master implementation of the location drivers, with each method calling out to the appropriate driver. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15env: Add a new implementation of environment accessSimon Glass
We plan to move to a environment access via drivers for each location where the environment can be stored. Add an implementation for this. So far it is not used, but will be pressed into service in a future patch. Signed-off-by: Simon Glass <sjg@chromium.org>
