Fix below build warning and errors:
env/sata.c: In function ‘env_sata_save’:
env/sata.c:59:9: warning: implicit declaration of function ‘sata_get_dev’ [-Wimplicit-function-declaration]
sata = sata_get_dev(env_sata);
env/sata.c:59:7: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
env/sata.c: In function ‘env_sata_load’:
env/sata.c:101:10: warning: ‘return’ with a value, in function returning void
return -EIO;
env/sata.c:94:13: note: declared here
static void env_sata_load(void)
env/sata.c:105:7: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
env/sata.c:108:10: warning: ‘return’ with a value, in function returning void
return -EIO;
env/sata.c:113:10: warning: ‘return’ with a value, in function returning void
return -EIO;
env/sata.c:116:9: warning: ‘return’ with a value, in function returning void
return env_import(buf, 1);
env/sata.c: At top level:
env/sata.c:120:14: error: ‘ENVL_ESATA’ undeclared here (not in a function)
.location = ENVL_ESATA,
env/sata.c:122:11: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
.load = env_sata_load,
Signed-off-by: Ye Li <ye.li@nxp.com>
Wrong env buffer was passed into sata write function, so the saveenv can't work.
Fix this issue.
(cherry picked from commit 0fe7573cffcb50d6bcb401f644cc37f5af28b388)
For multiple env drivers to correctly implement fallback when
one environment fails to load (e.g. crc error), the return value
of env_import has to be propagated by all env driver's load
function.
Without this change, the first driver that succeeds to load an
environment with an invalid CRC return 0 (success) and no other
drivers are checked.
Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The load() methods have inconsistent behaviour on error. Some of them load
an empty default environment. Some load an environment containing an error
message. Others do nothing.
As a step in the right direction, have the method return an error code.
Then the caller could handle this itself in a consistent way.
Add a name to the driver and use that instead of the global variable
declared by each driver.
Most of the init() implementations just use the default environment.
Adjust env_init_new() to do this automatically, and drop the redundant
code.
Move over to use a the master implementation of the location drivers, with
each method calling out to the appropriate driver.
Set up a location driver for each supported environment location. At
present this just points to the global functions and is not used. A
later patch will switch this over to use private functions in each driver.
There are several special cases here in various drivers to handle
peculiarities of certain boards:
1. Some boards define CONFIG_ENV_IS_IN_FAT and CONFIG_SPL_ENV_SUPPORT but
do not actually load the environment in SPL. The env load code was
optimised out before but with the driver, it is not. Therefore a special
case is added to env/fat.c. The correct fix (depending on board testing
might be to disable CONFIG_SPL_ENV_SUPPORT.
2. A similar situations happens with CONFIG_ENV_IS_IN_FLASH. Some boards
do not actually load the environment in SPL, so to reduce code size we
need to drop that code. A similar fix may be possible with these boards,
or it may be possible to adjust the environment CONFIG settings.
Added to the above is that the CONFIG_SPL_ENV_SUPPORT option does not
apply when the environment is in flash.
Obviously the above has been discovered through painful and time-consuming
trial and error. Hopefully board maintainers can take a look and figure
out what is actually needed.
At present we have three states for the environment, numbered 0, 1 and 2.
Add an enum to record this to avoid open-coded values.
About a quarter of the files in common/ relate to the environment. It
seems better to put these into their own subdirectory and remove the
prefix.
