The original purpose of mtd_erase_callback() in Linux at the time it was
imported to U-Boot, was to inform the caller that erasing is done (since
it was an asynchronous operation).
All supplied callback methods in U-Boot do nothing, but the
mtd_erase_callback() function was (until previous patch) grossly abused
in U-Boot's mtdpart implementation for completely different purpose.
Since we got rid of the abusement, remove the mtd_erase_callback()
function and the .callback member from struct erase_info entirely, in
order to avoid such problems in the future.
Signed-off-by: Marek BehĂșn <marek.behun@nic.cz>
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
Add another custom environment flag which discerns environment coming
from external storage from environment set by U-Boot itself.
This file contains lots of internal details about the environment. Most
code can include env.h instead, calling the functions there as needed.
Rename this file and add a comment at the top to indicate its internal
nature.
[trini: Fixup apalis-tk1.c]
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
env_import (and env_import_redund) currently return 1 on success
and 0 on error. However, they are only used from functions
returning 0 on success or a negative value on error.
Let's clean this up by making env_import and env_import_redund
return 0 on success and -EIO on error (as was the case for all
users before).
Users that cared for the return value are also updated. Funny
enough, this only affects onenand.c and sf.c
Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The load() methods have inconsistent behaviour on error. Some of them load
an empty default environment. Some load an environment containing an error
message. Others do nothing.
As a step in the right direction, have the method return an error code.
Then the caller could handle this itself in a consistent way.
Add a name to the driver and use that instead of the global variable
declared by each driver.
Most of the init() implementations just use the default environment.
Adjust env_init_new() to do this automatically, and drop the redundant
code.
Move over to use a the master implementation of the location drivers, with
each method calling out to the appropriate driver.
Set up a location driver for each supported environment location. At
present this just points to the global functions and is not used. A
later patch will switch this over to use private functions in each driver.
There are several special cases here in various drivers to handle
peculiarities of certain boards:
1. Some boards define CONFIG_ENV_IS_IN_FAT and CONFIG_SPL_ENV_SUPPORT but
do not actually load the environment in SPL. The env load code was
optimised out before but with the driver, it is not. Therefore a special
case is added to env/fat.c. The correct fix (depending on board testing
might be to disable CONFIG_SPL_ENV_SUPPORT.
2. A similar situations happens with CONFIG_ENV_IS_IN_FLASH. Some boards
do not actually load the environment in SPL, so to reduce code size we
need to drop that code. A similar fix may be possible with these boards,
or it may be possible to adjust the environment CONFIG settings.
Added to the above is that the CONFIG_SPL_ENV_SUPPORT option does not
apply when the environment is in flash.
Obviously the above has been discovered through painful and time-consuming
trial and error. Hopefully board maintainers can take a look and figure
out what is actually needed.
At present we have three states for the environment, numbered 0, 1 and 2.
Add an enum to record this to avoid open-coded values.
About a quarter of the files in common/ relate to the environment. It
seems better to put these into their own subdirectory and remove the
prefix.
