path: root/env/onenand.c
2019-08-11env: Rename environment.h to env_internal.hSimon Glass
This file contains lots of internal details about the environment. Most code can include env.h instead, calling the functions there as needed. Rename this file and add a comment at the top to indicate its internal nature. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> [trini: Fixup apalis-tk1.c] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-31env: make env_import(_redund) return 0 on success, not 1Simon Goldschmidt
env_import (and env_import_redund) currently return 1 on success and 0 on error. However, they are only used from functions returning 0 on success or a negative value on error. Let's clean this up by making env_import and env_import_redund return 0 on success and -EIO on error (as was the case for all users before). Users that cared for the return value are also updated. Funny enough, this only affects onenand.c and sf.c Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-08-16env: Adjust the load() method to return an errorSimon Glass
The load() methods have inconsistent behaviour on error. Some of them load an empty default environment. Some load an environment containing an error message. Others do nothing. As a step in the right direction, have the method return an error code. Then the caller could handle this itself in a consistent way. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-15env: Drop the env_name_spec globalSimon Glass
Add a name to the driver and use that instead of the global variable declared by each driver. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15env: Drop common init() functionsSimon Glass
Most of the init() implementations just use the default environment. Adjust env_init_new() to do this automatically, and drop the redundant code. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15env: Switch over to use environment location driversSimon Glass
Move over to use a the master implementation of the location drivers, with each method calling out to the appropriate driver. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15env: Create a location driver for each locationSimon Glass
Set up a location driver for each supported environment location. At present this just points to the global functions and is not used. A later patch will switch this over to use private functions in each driver. There are several special cases here in various drivers to handle peculiarities of certain boards: 1. Some boards define CONFIG_ENV_IS_IN_FAT and CONFIG_SPL_ENV_SUPPORT but do not actually load the environment in SPL. The env load code was optimised out before but with the driver, it is not. Therefore a special case is added to env/fat.c. The correct fix (depending on board testing might be to disable CONFIG_SPL_ENV_SUPPORT. 2. A similar situations happens with CONFIG_ENV_IS_IN_FLASH. Some boards do not actually load the environment in SPL, so to reduce code size we need to drop that code. A similar fix may be possible with these boards, or it may be possible to adjust the environment CONFIG settings. Added to the above is that the CONFIG_SPL_ENV_SUPPORT option does not apply when the environment is in flash. Obviously the above has been discovered through painful and time-consuming trial and error. Hopefully board maintainers can take a look and figure out what is actually needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-15env: Add an enum for environment stateSimon Glass
At present we have three states for the environment, numbered 0, 1 and 2. Add an enum to record this to avoid open-coded values. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15Move environment files from common/ to env/Simon Glass
About a quarter of the files in common/ relate to the environment. It seems better to put these into their own subdirectory and remove the prefix. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
