When having environment stored in EXT4 or FAT
and using an AHCI or SCSI device / partition
the scan would not be performed early enough
and hence the device would not be recognized.
This change adds the scan when the interface
is "scsi" in a similar way to mmc_initialize.
Signed-off-by: Rogier Stam <rogier@unrailed.org>
Reviewed-by: Pali Rohár <pali@kernel.org>
Add ENV_ERASE_PTR macro to handle erase opts and remove the associated
ifdef.
This patch is a extension of previous commit 82b2f4135719 ("env_internal.h:
add alternative ENV_SAVE_PTR macro").
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
This parallels what I added for FAT in commit 6731bef6966, allowing the
environment to be found in a specific partition on the device that the
board's mmc_get_env_dev() returns. On the Banana Pi R2 that means the
device that U-Boot was loaded from; either the internal eMMC or an SD
card.
Add another custom environment flag which discerns environment coming
from external storage from environment set by U-Boot itself.
Add support of opts erase for env in ext4,
this opts is used by command 'env erase'.
This command only fill the env file (CONFIG_ENV_EXT4_FILE)
with 0, the CRC and the saved environment becomes invalid.
Split the function env_ext4_save to prepare the erase support.
Add a missing initialization of gd->env_valid in env_ext4_load
as it is already done in some other env device.
Set gd->env_valid = ENV_VALID in env_ext4_save() and env_ext4_load().
This patch allows to have a correct information in 'env info' command.
Move this uncommon header out of the common header.
We should not be using typedefs and these make it harder to use
forward declarations (to reduce header file inclusions). Drop the typedef.
Removing this ifdef/endif pair yields a "defined but unused warning"
for CONFIG_CMD_SAVEENV=n, but that vanishes if we use the ENV_SAVE_PTR
macro instead. This gives slightly better compile testing, and
moreover, it's possible to have
CONFIG_SPL_SAVEENV=y
SPL_ENV_IS_IN_EXT4=y
in which case env_ext4_save would erroneously not be compiled in.
Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
This file contains lots of internal details about the environment. Most
code can include env.h instead, calling the functions there as needed.
Rename this file and add a comment at the top to indicate its internal
nature.
[trini: Fixup apalis-tk1.c]
Move these functions to the new header file and rename set_default_env()
to env_set_default() so that it has a consistent env_ prefix.
For platform which can boot on different device, this allows
to override interface, device and partition from board code.
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
Re-use the functions used to write/create a file, to support creation of a
symbolic link.
The difference with a regular file are small:
- The inode mode is flagged with S_IFLNK instead of S_IFREG
- The ext2_dirent's filetype is FILETYPE_SYMLINK instead of FILETYPE_REG
- Instead of storing the content of a file in allocated blocks, the path
to the target is stored. And if the target's path is short enough, no block
is allocated and the target's path is stored in ext2_inode.b.symlink
As with regulars files, if a file/symlink with the same name exits, it is
unlinked first and then re-created.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
[trini: Fix ext4 env code]
The function set_default_env() sets the hashtable flags for import_r().
Formally set_default_env() doesn't accept flags from its callers. In
practice the caller can (un)set the H_INTERACTIVE flag, but it has to be
done using the first character of the function's string argument. Other
flags like H_FORCE can't be set by the caller.
Change the function to accept flags argument. The benefits are:
1. The caller will have to explicitly set the H_INTERACTIVE flag,
instead of un-setting it using a special char in a string.
2. Add the ability to propagate flags from the caller to himport(),
especially the H_FORCE flag from do_env_default() in nvedit.c that
currently gets ignored for "env default -a -f" commands.
3. Flags and messages will not be coupled together. A caller will be
able to set flags without passing a string and vice versa.
Please note:
The propagation of H_FORCE from do_env_default() does not introduce any
functional changes, because currently himport_r() is set to destroy the
old environment regardless if H_FORCE flag is set or not. More changes
are needed to utilize the propagation of H_FORCE.
Signed-off-by: Yaniv Levinsky <yaniv.levinsky@compulab.co.il>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
We have a large number of places where while we historically referenced
gd in the code we no longer do, as well as cases where the code added
that line "just in case" during development and never dropped it.
For CONFIG_ENV_FAT_INTERFACE != 'mmc' a link error
env/fat.c:93: undefined reference to `mmc_initialize'
occurs if CONFIG_MMC_SUPPORT is not enabled.
Fixes: 26862b4a40c3 ("env: mmc/fat/ext4: make sure that the MMC sub-system
is initialized before using it")
using it
When booting from a non-MMC device, the MMC sub-system may not be
initialized when the environment is first accessed.
We need to make sure that the MMC sub-system is ready in even a non-MMC
boot case.
Therefore, initialize mmc before loading environment from it.
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
For multiple env drivers to correctly implement fallback when
one environment fails to load (e.g. crc error), the return value
of env_import has to be propagated by all env driver's load
function.
Without this change, the first driver that succeeds to load an
environment with an invalid CRC return 0 (success) and no other
drivers are checked.
Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
For example to store the environment in a file named "/uboot.env" in MMC
"0", where partition "1" contains the EXT4 filesystem, the following
configs should be added to the board's default config:
CONFIG_ENV_IS_IN_EXT4=y
CONFIG_ENV_EXT4_DEVICE_AND_PART="0:1"
CONFIG_ENV_EXT4_FILE="/uboot.env"
CONFIG_ENV_EXT4_INTERFACE="mmc"
Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
[trini: Fix some line over 80 chars issues]
The load() methods have inconsistent behaviour on error. Some of them load
an empty default environment. Some load an environment containing an error
message. Others do nothing.
As a step in the right direction, have the method return an error code.
Then the caller could handle this itself in a consistent way.
This variable is declared as a global in most environment location
drivers. But it is not used outside the drivers and most of the
declarations are unnecessary.
Also some drivers call free() on env_ptr which seems wrong since it is
not in the heap.
Drop the variable where possible, and all calls to free().
Add a name to the driver and use that instead of the global variable
declared by each driver.
Most of the init() implementations just use the default environment.
Adjust env_init_new() to do this automatically, and drop the redundant
code.
Move over to use a the master implementation of the location drivers, with
each method calling out to the appropriate driver.
Set up a location driver for each supported environment location. At
present this just points to the global functions and is not used. A
later patch will switch this over to use private functions in each driver.
There are several special cases here in various drivers to handle
peculiarities of certain boards:
1. Some boards define CONFIG_ENV_IS_IN_FAT and CONFIG_SPL_ENV_SUPPORT but
do not actually load the environment in SPL. The env load code was
optimised out before but with the driver, it is not. Therefore a special
case is added to env/fat.c. The correct fix (depending on board testing
might be to disable CONFIG_SPL_ENV_SUPPORT.
2. A similar situations happens with CONFIG_ENV_IS_IN_FLASH. Some boards
do not actually load the environment in SPL, so to reduce code size we
need to drop that code. A similar fix may be possible with these boards,
or it may be possible to adjust the environment CONFIG settings.
Added to the above is that the CONFIG_SPL_ENV_SUPPORT option does not
apply when the environment is in flash.
Obviously the above has been discovered through painful and time-consuming
trial and error. Hopefully board maintainers can take a look and figure
out what is actually needed.
At present we have three states for the environment, numbered 0, 1 and 2.
Add an enum to record this to avoid open-coded values.
About a quarter of the files in common/ relate to the environment. It
seems better to put these into their own subdirectory and remove the
prefix.
