path: root/env/Kconfig
2017-11-21env: Remove CONFIG_ENV_AES supportTom Rini
This support has been deprecated since v2017.09 due to security issues. We now remove this support. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-27env: x86: braswell: Set ENV_IS_IN_SPI_FLASH as defaultBin Meng
Imply does not work for a Kconfig choice. Update ENV_IS_IN_SPI_FLASH to be the default one for Intel Braswell. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-16env: Drop CONFIG_ENV_IS_IN_DATAFLASHTuomas Tynkkynen
Last user of this option went away in commit: fdc7718999 ("board: usb_a9263: Update to support DT and DM") Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-10-15ARM: uniphier: switch to CONFIG_ENV_IS_NOWHEREMasahiro Yamada
The non-volatile storage varies board by board. The default should be NOWHERE. Please choose a proper device via Kconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-09-08env: Migrate CONFIG_ENV_AES to Kconfig and deprecateTom Rini
The underlying implementation for ENV_AES has security complications and is not recommended for use. Please see CVE-2017-3225 and CVE-2017-3226 for more details. Mark this as deprecated now and delete this in the medium term if no one comes forward to re-work the support. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-02Kconfig: Add EEPROM options to Kconfig when I2C_EEPROM is setAdam Ford
Add the following options to drivers/misc/Kconfig: SYS_I2C_EEPROM_ADDR SYS_I2C_EEPROM_BUS SYS_EEPROM_SIZE SYS_EEPROM_PAGE_WRITE_BITS SYS_EEPROM_PAGE_WRITE_DELAY_MS SYS_I2C_EEPROM_ADDR_LEN SYS_I2C_EEPROM_ADDR_OVERFLOW This does not migrate any boards, but provides a foundations for those who want/need these options Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Migrate uniphier] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-20env: Sort selection of default choicesAndy Shevchenko
It would be easier to catch out which platform is using which default. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-08-15env: Convert CONFIG_ENV_IS_IN... to a choiceSimon Glass
At present we support multiple environment drivers but there is not way to select between them at run time. Also settings related to the position and size of the environment area are global (i.e. apply to all locations). Until these limitations are removed we cannot really support more than one environment location. Adjust the location to be a choice so that only one can be selected. By default the environment is 'nowhere', meaning that the environment exists only in memory and cannot be saved. Also expand the help for the 'nowhere' option and move it to the top since it is the default. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Move all of the imply logic to default X if Y so it works again] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-15env: Use tabs in ENV_IS_IN_FATSimon Glass
Tidy up the formatting of this option. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-15Move environment files from common/ to env/Simon Glass
About a quarter of the files in common/ relate to the environment. It seems better to put these into their own subdirectory and remove the prefix. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
